Staro 06.03.2007., 14:01   #1
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Spdif ne radi?
na maticnoj iz siga spdif ne radi i fakat ne znam kako ga osposobiti da radi...htio bih koaksijalnim kablom spojiti sa receiverom...moram nekako izdrzati dok ne kupim novi i receiver i neku zvucnu a preko cinceva mi je ogavan zvuk(previse piskutav) tako da bih htio probat sa koaksijalnim...
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
Staro 06.03.2007., 14:30   #2
domy_os
domy_os's Avatar
Postovi: 18,875
Uključio si u driverima digital out?
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 07.03.2007., 09:50   #3
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
ma jesam ali nista....
Logitech MX500
DELL 2007FP
Abit AV8
Staro 07.03.2007., 11:38   #4
Dretar
Dretar's Avatar
Lokacija: Đakovo
Postovi: 60
probaj nabavit ili kupit opticki kabl (30-tak kn) pa vidi...ako reciever isto ima spdif...ak ima signala baca crveno svijetlo
Dretar je offline   Reply With Quote
Staro 07.03.2007., 12:07   #5
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
ma gdje ima kupit optički kabel za 30ak kn??
micek - jel goniš Vistu? ja na Visti nisam uspio natjerat digital out da mi radi.... iskreno, nisam se previše ni trudio, ali nije iz prve proradilo, ni iz druge, a na XP iz prve...
Staro 07.03.2007., 12:08   #6
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
pa nema ta maticna opticki koliko ja tu vidim...govorimo o integriranoj zvucnoj na ploci iz siga...ma izdrzat cu na kompozitnom kablu do dolaska neke dobre zvucne...
Logitech MX500
DELL 2007FP
Abit AV8
Staro 07.03.2007., 12:17   #7
SPLiFF
SPLiFF's Avatar
Postovi: 2,106
ja na sony reciveru imam tipku "Input" - mogu stavit na auto, coax i analog. To je ok?
Staro 07.03.2007., 16:30   #8
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
evo ja opet probao, i nema mi zvuka na receiveru ako spojim na zvučnij na digital out... upalim u postavkama da koristi samo digital, ali nikakvog zvuka nemam... ZAŠTOOOOOOOOOOO
Staro 07.03.2007., 16:41   #9
Ubleha
Ubleha's Avatar
Lokacija: BiH
Postovi: 1,485
Bas cudno kod mene na Asusu radi bez ikakvih problema, samo tako i mogu slusati analogno je uzas.
Nisam pijan sve dok mogu da ležim na podu i da se nizašta nedržim.
Ubleha je offline   Reply With Quote
Staro 07.03.2007., 17:37   #10
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
ma kad jednom probašdidgitalno, odnosno preko receivera, svaka druga zvučna je u kurxu.... ali ZAŠTOO... meni pod Vistom ne radi digital out...
Staro 07.03.2007., 18:26   #11
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,344
Vista zašto me ne čudi?
Jesi gledao na stranici od ASRocka da ima nešto po tom pitanju?
žmnpp
Staro 08.03.2007., 00:53   #12
Dretar
Dretar's Avatar
Lokacija: Đakovo
Postovi: 60
[quote=Gabre;667423]ma gdje ima kupit optički kabel za 30ak kn??
u emezeti
Staro 08.03.2007., 05:51   #13
SPLiFF
SPLiFF's Avatar
Postovi: 2,106
svaki puta mislim da pise Splif ne radi
Staro 08.03.2007., 20:12   #14
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
nakon mnogih pokusavanja odustao sam od toga i lijepo spojio sacd player preko digitalnog optickog i snimio par cda i slusam... dok ne dodje zvucna...
Logitech MX500
DELL 2007FP
Abit AV8
Staro 08.03.2007., 20:58   #15
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,539
Ne radi ti iz dva razloga. Prvi je što moraš prebaciti jumper na ploči (prouči manual na strani 33) u ovisnosti da li želiš koristiti S/PDIF od nforca ili realteka. Drugi razlog je što za Vistu još nema nforce drivera tj. ima ali ne za audio a i te što postoje NEMOJ slučajno instalirati jer će ti hardovi početi škljocati kod restarta/gašenja.
Pod WinXP meni nforce S/PDIF (sa nforce driverima) izlaz radi savršeno, i uredno prosljeđuje DTS, Dolby Digital, PCM na receiver. Oni audio driveri od nvidie koje možeš skinuti preko Vista update, su totalno smeće i znaju srušiti Vistu, alternativa je na realtek stranci ali tada moraš prebaciti jumper (u stvari vjerojatno ne moraš jer je meni po defaultu bio realtek S/PDIF). Postoje driveri i za x86 i za x64 ali su ružni, radi S/PDIF, ali 5.1 u igrama nekad radi nekad ne, dok sub u biti ne radi iako u testu radi.
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
LAcy je online   Reply With Quote
Staro 08.03.2007., 21:01   #16
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
thnx,probat cu pa javim...opce se nisam sjetio gledat manual...
btw koje drivere imas za plocu pa da ih skinem...
i konacno...koliko si dobio koaksijalnim spajanjem umjesto kompozitnim posto je ovo integrirana zvucna
Logitech MX500
DELL 2007FP
Abit AV8
Staro 08.03.2007., 21:33   #17
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,539
Autor micek_kc Pregled postova
Tko će čitati manual, lakše je pitati
Za WinXP zadnje nvida a za Vistu opet zadnje realtek
Moram priznati da ne kužim pitanje, vjerojatno si mislio na analogni izlaz. Imam računalni 5.1 sustav spojen na analogne izlaze (sig) za igre i 5.1 sustav (nema u sigu) sa receiverom na koji sam spojen S/PDIF koaksijalnim kabelom (drugi niti nema na ploči). Naravno da je razlika ogromna, prvenstveno zbog velike razlike u kvaliteti zvučnika i receivera. Analogno nisam, niti ću pokušavati spojiti PC sa receiverom.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 09.03.2007., 10:24   #18
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
i nista...od sad sluzbeno razmisljam da cjepam plocu sjekirom...novi driveri...jumper...nista... popizdim i stavim nove windoze slazem sve ono polako i pazljivo nista...probam staviti nove windowse i onda druge drivere...nista...uglavnom za***avao sam se do pola 4 u noc a slozio sam nista,niente,nič,zero...
Logitech MX500
DELL 2007FP
Abit AV8
Staro 09.03.2007., 13:48   #19
Dac
Dac's Avatar
Lokacija: Bjelovar
Postovi: 672
kupi neku zvučnu, polovnu, novu, bilo kakvu sa digitalnim izlazom. ako ti ne treba analogno (ili DD Live! ili DTS Connect) bilo koja će ti podjednako dobro raditi, pa i najjeftinija C-media . samo da ima Vista drivere, ak sam dobro skužio...
Dac je offline   Reply With Quote
Staro 09.03.2007., 13:57   #20
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,344
Imat će ih sve zvučne nakon određenog vremena, svi bi htijeli to odmah al to ne ide tako. nažalost.
žmnpp
Staro 09.03.2007., 14:01   #21
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
pa nemam ja vistu...xp imam
tko je poceo o visti ?
Logitech MX500
DELL 2007FP
Abit AV8
Staro 09.03.2007., 14:04   #22
Dac
Dac's Avatar
Lokacija: Bjelovar
Postovi: 672
a ne znam, neka Vista brija je na početku topika
ja sam imao redom: CMI jeftinjavu (optika), Audigy (koax), Terratec (optika), Soundstorm o/b (koax) i ne mogu baš reći da sam preko digitalije čuo neku razliku. ako ti to što znači
istina rado bih na ebayu ubo ovakvo nešto ali poslije nekog vremena bit će valjda i kod nas
Staro 09.03.2007., 20:02   #23
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,539
Kako ne radi?! Imaš skoro pa istu ploču kao i ja. Zar nema onaj karaian ili tako nekako modul? I lijepo ti piše u manualu koji jumper je za realtek a koji za nforce. U nvmixeru odeš na wizard kažeš da imaš digitalni izlaz i to je to. Za realtek pod winxp neznam jer su mi bili odvratni driveri.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 10.03.2007., 18:15   #24
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
nista od ovog svega...pribavljao deset vrsta drivera i nista...odustajem i cekam novu zvucnu
Logitech MX500
DELL 2007FP
Abit AV8
Staro 10.03.2007., 19:27   #25
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,539
Ma mora raditi! Nemoj da ti dođem to namjestiti Meni je godinama to radilo bez greške na WinXP, i DTS i DD i PCM.
MacBook M1 Pro
MacBook Air M2
Moto Edge
