Staro 04.03.2007., 14:43   #1
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Focal Jmlab Chorus 714s
Description
2-1/2 way shielded bass reflex floor standing
Drivers
5-1/2" Polyglass woofer
5-1/2" Polyglass mid-bass
1" TNC inverted dome tweeter
Frequency response (+/- 3dB) 50Hz - 28kHz
Sensitivity (2,8 V/1 m) 91dB
Nominale impedance (EN 60065)
8 Ohms
Crossover
400Hz / 2400Hz
Power handling with musical program 90W
Dimensions (HxWxD) 900 x 200 x 270 mm
35.4x7.9x10.6inch
Weight
13,7kg (30.1lbs)
http://www.focal-audio.ru/files/304_1.jpg
evo jucer sam isao po njega i dobio ga jako jeftino sad o cijeni necemo...
jedino mi je bed sto je u style finishu a sub mi je u classic finishu...
uglavnom zvucnik je pobrao mnogo nagrada i ja stvarno mogu reci da je za te novce odlicna kupnja...sad je cak i na popustu u sonus artu...
spojio sam ga sa Van De Hul Cs-122 zvucnickim kabelom http://www.vandenhul.com/cable/cs-122-h.htm i svira odlicno
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
Staro 04.03.2007., 14:53   #2
BASSFREEK
BASSFREEK's Avatar
Lokacija: SLAVONSKI BROD
Postovi: 98
Na ćega je spojen zvučnik.
BASSFREEK je offline   Reply With Quote
Staro 04.03.2007., 15:13   #3
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
citaj sig prije postavljanja takvih pitanja...
Logitech MX500
DELL 2007FP
Abit AV8
Staro 04.03.2007., 17:17   #4
BASSFREEK
BASSFREEK's Avatar
Postovi: 98
kao i moje sony av pojačalo jesi zadovoljan sony pojačalom.
Staro 04.03.2007., 20:55   #5
syss
syss's Avatar
Postovi: 10,805
daj čovječe kupi normalni amp... hebo te sony iz peveca. mislim lupaš pare u zvučnike, a "motor" kompletnog audio sistema ti radi na 2 cilindra (slikovito rečeno).
Staro 04.03.2007., 21:41   #6
SPLiFF
SPLiFF's Avatar
Postovi: 2,076
mozda covjek oce prvo zvucnike rjesit... da ne bi uzeo novo pojacalo i spalio stare zvucnike :P
Staro 04.03.2007., 23:55   #7
Imagine
undercover
Imagine's Avatar
Lokacija: u raljama ovisnosti
Postovi: 1,407
Talking
Autor syss Pregled postova
syss opet nemaš pojma...
nisu to bilo koja 2 cilindra - to je Harley
btw znaš onu 100 ljudi ,100 čudi
ili 100 audiofila ,200 zvučnika ...
e sad se več pomalo gubim..uglavnom svatko u nečem vidi smisla te tako vjerovatno i on ima neki svoj plan u glavi....
if you build it they will come
Imagine je offline   Reply With Quote
Staro 05.03.2007., 13:33   #8
bego2
bego2's Avatar
Postovi: 2,724
Sad je tek kupio šta bi mjenjao. Dobar je taj reciever.
bego2 je offline   Reply With Quote
Staro 05.03.2007., 13:51   #9
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Autor Imagine Pregled postova
hvala sto si na mojoj strani
ma kupit cu pise u sigu al trenutacno sam puknuo pare na to a vidite i u sigu da nemam grafu(trenutno imam pci neku sis-ovu) pa tek dok kupim grafu idem na receiver...
Logitech MX500
DELL 2007FP
Abit AV8
Staro 06.03.2007., 19:26   #10
syss
syss's Avatar
Postovi: 10,805
tebi baš stereo ne leži?
Staro 07.03.2007., 12:05   #11
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
ma hocu za bolji uzitak u filmovima... i ne kanim ostati na ovim 714 nego idem na 726s najvjerovatnije...neznam jos ni sam prije nego kupim receiver, tek cu onda odluciti
Logitech MX500
DELL 2007FP
Abit AV8
Staro 07.03.2007., 19:03   #12
syss
syss's Avatar
Postovi: 10,805
koliko vremena gledaš filmove, koliko slušaš stereo? mislim ti možeš kupit i wilsone, ali će tebe uvijek kočiti ti receiveri koji su očajni.
p.s. z5500 imaju bolju digitaliju u sebi od tih sony-a, tak da bi si ja malo razmislio o tome koliko zaista vrijede takve igračke.
Staro 08.03.2007., 20:17   #13
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
ma lezi mi stereo ali gledam dosta filmova i nakon sto sam cuo kako mogu zvucati u 6.1 sa ovom chorus serijom ostao sam zapanjen...
ali da te utjesim...gledam neki receiver sa preoutima tako da mogu spojiti na stereo...recimo ovo od rotela iz 06 serije pojacalo mi se bas dopada
Logitech MX500
DELL 2007FP
Abit AV8
Staro 08.03.2007., 22:59   #14
syss
syss's Avatar
Postovi: 10,805
to je već posao... sa dobrim razmještajem i kabelima loš zvuk nemre izostat.
taj rotel (ili bilo koji iz euro serije) može nadsvirat 50 ovih sony receivera u kaskadi
Staro 09.03.2007., 10:19   #15
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
ma nema receivera koji moze raditi stereo ekvivalentan sa stereo pojacalom...
ali ja hocu obadvoje
sto se tice dvd playera ide vjerovatno denon dvr 1930 a receiver 1707 ili 1907
+ neki denonov sacd player do 2k kn
uglavnom slaze se lagano...ali treba vremena...
pazi parodije...
slusao sam razliku u kompozitnim kablovima...
i stavim onaj od audio questa sa 36v baterijama sa cijenom XXXXkn i zvuk mi nikakav...Stavim jedan upola jeftiniji malo bolje... i na kraju stavim za 1200kn i radi Savrseno...ali opet je sve to subjektivno...svaki covjek drukcije cuje...
Logitech MX500
DELL 2007FP
Abit AV8
Staro 09.03.2007., 15:25   #16
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
e malo OT...
daj mi recite koliko vrijedi Nikko 4 x 260w (A+B) Pojacalo...napisat cu vam model sutra...
Logitech MX500
DELL 2007FP
Abit AV8
Staro 10.03.2007., 18:10   #17
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
evo model onog gore pojacala je str-650....ajd netko neka da procjenu...
btw imam jedno pitanje... nasao sam Focal jm lab 706s http://www.focal-audio.ru/files/291_1.jpg za jeftine pare samo neznam kako ce se slagati sa ovim stupovima jer uz ove stupove idu inace 705s... savjet molim
Logitech MX500
DELL 2007FP
Abit AV8
Staro 10.03.2007., 18:33   #18
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
Autor micek_kc Pregled postova
Mislim u PM! 5.1 sistem radi i ako su ti prednji focal, zadnji b&w, srednji mission sub jamo. Hebiga poslušaj, nema razloga da sve ne bude štimalo. Ovisi šta tražiš.
Staro 11.03.2007., 02:16   #19
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
pitam zato jer ovi bookshelfi imaju 6" drivere i da ne bi nadjacali stupove... jer ipak su ovo "najslabiji" stupovi u seriji a ovo drugi po redu bookshelfi...
Logitech MX500
DELL 2007FP
Abit AV8
Staro 11.03.2007., 12:03   #20
bego2
bego2's Avatar
Postovi: 2,724
Ma nadjačat će oni qurac. Radit će kako Bog zapovjeda, tj kako ti namjetiš na recieveru.
Staro 11.03.2007., 13:01   #21
Imagine
undercover
Imagine's Avatar
Postovi: 1,407
Autor -POP- Pregled postova
Ah -POP- , ti ništa ne kužiš te micekove "audiofilske" probleme
Staro 11.03.2007., 14:08   #22
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Autor bego2 Pregled postova
evo za nekih sat vremena cu ici vidjeti te zvucnike pa ono ako su oscuvani vjerovatno cu kupiti...ill stay in touch with you
Logitech MX500
DELL 2007FP
Abit AV8
Staro 11.03.2007., 19:06   #23
bego2
bego2's Avatar
Postovi: 2,724
Prošlo sat vremena.
Jesi kupil?
Staro 11.03.2007., 22:28   #24
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
nisam isao...zovem covjeka nesto prica da nije spojeno da mu stoji sa strane da sad ima nesto novo itd... ono koliko je tesko spojiti zvucnike da ih cujem na 5 min? tako da nakon toga nisam ni isao...
Logitech MX500
DELL 2007FP
Abit AV8
Staro 11.03.2007., 23:33   #25
newalss
Raindrops keep fallin'...
newalss's Avatar
Lokacija: Đakovo
Postovi: 826
Nemoj me krivo shvatiti ali jesi možda razmišljao o otvaranju bloga "Kako sastavljam 5.1 sustav"?
Ne vidim niti jedan razlog zašto otvaraš već valjda peti topic o tome.
Evo ovaj topic. Korisno bi bilo da si poslušao par drugih zvučnika iz štala ostalih proizvođača pa da si dao usporedbu tipa "Zašto je moj konj bolji". Korisno bi bilo da si napisao pluseve i minuse ovih zvučnika. Još nisu izmislili savršen zvučnik ili mi bar nitko nije rekao za to. Vijest da si kupio to i to (ti ili roditelji) baš mi i nije nešto.
Ako sam te dobro pohvatao ove zvučnike slušaš na Sony reciever-u i puštaš glazbu preko kompa? Izvini što sumljam u tvoju ocjenu da je zvuk koji izlazi iz zvučnika odličan.
"I told my parents that when I grew up I wanted to be a musician.They said it had to be one or the other"
newalss je offline   Reply With Quote
Staro 11.03.2007., 23:35   #26
syss
syss's Avatar
Postovi: 10,805
naravno da je odličan... pogotovo referentne mp3ce od 256k
Staro 13.03.2007., 16:24   #27
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
slusam na dvd playeru zasad a preko kompa slusam samo dok igram igre...
pa gle svatko ima svoj pojam o tome kakav bi zvuk trebao izgledati...meni je ovo odlicno ali znam da se moze i bolje tako da i idem na bolje...normalno da necu ostati s ovakvim zvucnicima na takvom receiveru...pise mi u sigu plan za receiver... i ne kuzim zasto se ti bunis zbog mojih tema...koliko se puta otvarala(i jos se otvara) tema o ***enih Z5500 i derivacijama istih pa zasto nebih smio i ja? i covjece kupio sam onaj woofer i ove stupove(i jos ih mozda zamijenim za 726s)i kablove al nemogu u mjesec-dva istresti peteroznamenkasti broj za audio sistem...daj malo polakse...imam vremena...ja uvjek tezim boljem tako da sve sto vidite u sigu tezi prema boljem...zato me nemojte napadat odmah zato jer privremeno slusam na sony receiveru.glavna je rijec PRIVREMENO
Logitech MX500
DELL 2007FP
Abit AV8
Staro 13.03.2007., 16:32   #28
syss
syss's Avatar
Postovi: 10,805
ne napadam te ja ništa, z5500 su po meni prosječni zvučnici relativno oke za surround tako da se ne bi krivo shvatili... to što ih posjedujem ne uvećava niti umanjuje njihovu vrijednost.
problem je što ulažeš na kriva mjesta... što točno misliš dobiti sa novim receiverom?
Staro 14.03.2007., 13:29   #29
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
sigurno ce raditi bolje od ovoga sonya na kojem masno pise na naljepnici 6 x 150w(moš misliti) a u specifikacijama pise 6 x 90w(tko sad tu koga prca?!)
a vidim da se vec na preko pola pojacanog gubi zvuk...hocu denon ili rotel jer koliko sam cuo(ne citao nego svojim usima cuo) razlika je ogromna... i syss nisam tebi nista prigovorio nego newalssu
Logitech MX500
DELL 2007FP
Abit AV8
Staro 14.03.2007., 19:44   #30
newalss
newalss's Avatar
Lokacija: Đakovo
Postovi: 826
Eto sad ja kriv. Syss tebi je rekao, samo ga strah priznati.
Niti te ja napadam niti se bunim zbog ponovnog spominjanja Focala.
Samo sam napisao da mi ovaj tvoj topic nema smisla i obrazloženje. Nije vrag da moram staviti IMHO ispred svakog post-a...
