Staro 21.02.2007., 21:42   #1
domy_os
domy_os's Avatar
Postovi: 18,894
Catalyst 7.2 for Windows XP & Vista
New Features
Catalyst™ 7.2 introduces a brand new version of the Catalyst™ Control Center for Windows XP. The new Catalyst™ Control Center delivers a number of significant enhancements:
  • Significant performance gains; Catalyst™ Control Center start-up time has been substantially reduced, and overall responsiveness has improved.
  • Reduced system resource usage
  • New 3D preview which significantly improves the ability for users to understand the benefits of enabling the many Catalyst™ features of their ATI Radeon™ graphics accelerator
  • Increased stability
  • Native 32 and 64-bit support
Performance Improvements
Open GL performance improves for all ATI Radeon™ X1000 series products. Gains of up to 25% in Doom 3, 48% in Quake 4 and 21% in Prey can be seen on a variety of ATI Radeon™ X1000 cards. These performance gains are noticed under the Windows Vista operating system.
Resolved Issues for the Windows XP Operating System
This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows XP. These include:
  • Battlefield 2: Attempting to launch the game under Windows XP with the in-game display setting at 1920x1440 or 2048x1536 and AA set to 6x no longer results in the game failing to launch. Further details can be found in topic number 737-22817
  • Desperados 2: The game no longer fails to play and display an error in atioglxx.dll when AA is enabled. Further details can be found in topic number 737-25109
  • Splinter Cell Double Agent: Corruption is no longer noticed when playing the game with AA enabled. Further details can be found in topic number 737-25104
  • Catalyst™ Control Center->Basic View: Connecting a secondary display device and attempting to enable it, no longer results in the inability to enable the device when using Basic view. Further details can be found in topic number 737-23447
  • Connecting a CRT as the primary display device and CV as the secondary display device no longer results in the desktop area and refresh rate being reported incorrectly when applying the 1080i30 Optimized mode within the Catalyst™ Control Center. Further details can be found in topic number 737-25174
  • Enabling CrossFire™ no longer results in display corruption being noticed when playing certain 3D games such as Tiger Woods PGA Tour 2006 and Madden Football. Further details can be found in topic number 737-23006
  • Catalyst™ Control Center->Basic View: Connecting a secondary display device and attempting to enable it, no longer results in the inability to enable the device when using Basic view. Further details can be found in topic number 737-24347
  • Catalyst™ Control Center: Connecting an HDTV or DFP display device no longer results in some of the HDTV formats being listed twice in the Catalyst™ Control Center->Digital Panel Properties->HDTV Support. Further details can be found in topic number 737-24349
  • A blank display no longer occurs when switching the display mode from 1920x1200 60Hz to 1600x1200 60Hz. Further details can be found in topic number 737-25811
  • The display mode of 1080p is no longer added to mode list and customized list on HDTV where the maximum display mode is 1080i. Further details can be found in topic number 737-25812
Known Issues Under the Windows XP Operating System
The following section provides a summary of open issues in the latest version of Catalyst™. These include:
  • Starwars Knights of the Old Republic II: The Sith Lords: Setting the in-game display option to low settings may result in corruption being noticed within the game. Further details can be found in topic number 737-25173
  • Enabling CrossFire™ may result in display corruption being noticed when playing a DVD or media clip using either WinDVD 7, Windows Media Player or PowerDVD 6. Further details can be found in topic number 737-22806
  • Uninstalling the graphics drivers may result in some of the files and folder failing to be removed in the Program File folder. Further details can be found in topic number 737-23715
  • Catalyst™ Control Center->OverDrive: The OverDrive setting are not retained for individual accounts. This issue may also be experienced under the Windows Vista operating system. Further details can be found in topic number 737-25805
  • The response time for the Catalyst™ Control Center may appear slow when attempting to make changes to the display devices when having both a CRT and HDTV connected and extended desktop mode enabled. This issue may also be experienced under the Windows Vista operating system. Further details can be found in topic number 737-25806
  • Choppy playback of media previews and captured files may be noticed in the media center and movie maker after applying WMP 11 update. This issue may also be experienced under the Windows Vista operating system. Further details can be found in topic number 737-25807
  • Installing an ATI Radeon™ X1900 CrossFire™ Master and X1900 slave under Windows XP may result in AA settings failing to be retained when rebooting the system. This issue may also be experienced under the Windows Vista operating system. Further details can be found in topic number 737-25808
  • Hot-plugging an HDMI TV to the DVI port of graphics adapter via HDMI to DVI cable may result in the DVI-to-HDMI detection message appearing but then disappearing within 30 seconds or when making a slight mouse movement. This issue may also be experienced under the Windows Vista operating system. Further details can be found in topic number 737-25809
  • Extend desktop mode may fail to work after rotating the extended secondary desktop to 90 degrees. This issue may also be experienced under the Windows Vista operating system. Further details can be found in topic number 737-25810
Windows XP download link:
http://ati.amd.com/support/drivers/xp/radeonx-xp.html
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Zadnje izmijenjeno od: domy_os. 21.02.2007. u 21:58.
Staro 21.02.2007., 21:50   #2
domy_os
domy_os's Avatar
Postovi: 18,894
Resolved Issues for the Windows Vista Operating System
This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows Vista. These include:
  • Doom 3: Setting AA to 4x and AT to 8x along with the display resolution to 2560x1600 no longer results in display corruption being noticed. Further details can be found in topic number 737-25520
  • Corruption is no longer noticed during fast motion of DVD playback when using MCE/WMP. Further details can be found in topic number 737-23550
  • Catalyst™ Control Center->Display Manager: Connecting only a CRT display device to a system running Windows Vista no longer results in TV display modes being available. Further details can be found in topic number 737-24467
  • The Microsoft Vista operating system no longer fails to resume from an S3 state on systems containing an ATI Xpress 200 series product. Further details can be found in topic number 737-25506
  • A flickering display is no longer noticed when playing a DVD using the Windows Media Player in full screen and resuming from a standby state after disconnecting a CRT display device. This issue was known to occur when using a system containing an ATI Xpress 1100/1150 series product. Further details can be found in topic number 737-25507
  • Catalyst™ Control Center: The Help Launching Dialog is now localized for all supported languages. Further details can be found in topic number 737-25508
  • Hot plugging or un-plugging a third display device when CrossFire™ is enabled no longer results in the primary display device being swapped and identified as the display device connecting to the primary port on the master card. Further details can be found in topic number 737-25509
  • Connecting a TV to a system containing an ATI Xpress 200 series and setting it to PAL no longer results in the user not being able to control the display resolution on the LCD display when using the Catalyst™ Control Center. Further details can be found in topic number 737-25511
  • The Windows Vista software driver for ATI Radeon™ products no longer fails to install if copied to a directory with a long name or to a directory with a long file path location. Further details can be found in topic number 737-25514
  • Display corruption is no longer noticed when watching TV under the Windows Vista operating system when using an ATI Radeon™ X1600 series product. Further details can be found in topic number 737-25515
  • The Catalyst™ Control Center no longer fails to launch under the Simplified Chinese version of Windows Vista. Further details can be found in topic number 737-25516
  • Connecting two display devices with one display device using the HDMI connector (secondary) no longer results in faded colors being noticed on the HDMI display device when swapping (primary and secondary) between the two display devices. Further details can be found in topic number 737-25793
  • The display mode of 1440X900@75Hz is now available within the Catalyst™ Control Center when using a system containing an ATI Radeon™ X1600/1650 series of product. Further details can be found in topic number 737-25794
  • Disconnecting the primary display device when the Windows Vista operating system is in a standby state may result in the log-in screen failing to appear when resuming. Further details can be found in topic number 737-24470
  • Hot-unplugging a secondary CRT display device while the Vista screen saver is active no longer results in corruption being noticed on the LCD display when ending the screen saver activity. Further details can be found in topic number 737-25795
  • The PowerPlay option is no longer available on systems that do not support the option under the Japanese version of the Windows Vista operating system. Further details can be found in topic number 737-25796
  • Changing the PowerPlay setting to either Power Saving or High Performance under Windows Vista, followed by rebooting the system no longer results in the PowerPlay setting displaying Battery Life mode regardless of the system being on AC power. Further details can be found in topic number 737-25797
Known Issues Under the Windows Vista Operating System
This section provides information on known issues associated with the ATI Catalyst™ Vista RTM driver for both the 32bit and 64bit versions of the Microsoft Windows Vista operating system. These include:
  • Call of Duty: Setting AA to either 2 or 4x may result in display corruption or the Vista operating system failing to respond when using an ATI Radeon™ X800/850 series of product. Further details can be found in topic number 737-25523
  • Call of Duty->United Offensive: Setting the in game video mode to 2048x1536 may result in display corruption being noticed when playing the game under Windows Vista. Further details can be found in topic number 737-25519
  • City of Heroes: Changing the display resolution to 2560x1600 or higher may result in the game failing to run. Further details can be found in topic number 737-25518
  • Doom 3: Attempting to play the game on a system running the Windows Vista operating system and containing an ATI Radeon™ X550/700 series of product may result in the operating system failing to respond. Further details can be found in topic number 737-25513
  • Doom3/Quake 4: Setting the in game options for Video Quality to Medium and Screen Size to 1024x768 may result in display corruption being noticed when setting AA to 4x. Further details can be found in topic number 737-25802
  • NBA Live 07: The full animation may not be displayed when launching the game with AA set to 2x or higher. Further details can be found in topic number 737-25803
  • Never Winter Nights->Shadows of Undertide: Attempting to play the game on a system containing an ATI Radeon™ X800/850 series of product and running the Windows Vista operating system may result in game failing to respond after playing the opening cinematic. Further details can be found in topic number 737-25512
  • Never Winter Nights->Shadows of Undrentide: Attempting to play the game under the Windows Vista operating system (64bit version) may result in the opening cinematic failing to play when using an LCD display device. Further details can be found in topic number 737-25521
  • NHL 07: The in-game display settings may fail to be applied when playing the game under the Windows Vista operating system when using a supported ATI Radeon™ product. Further details can be found in topic number 737-23549
  • Quake 4: game corruption may be noticed when playing the game under the Windows Vista operating system when using an ATI Radeon™ 9800 XT product. Further details can be found in topic number 737-25510
  • X-Plane: Playing the game under the Windows Vista operating system may result in display corruption being noticed when using an ATI Radeon™ X1900/1950 series of product. Further details can be found in topic number 737-25522
  • The Force TV option may still be active after deselecting the option and then re-launching the Catalyst™ Control Center. Further details can be found in topic number 737-23547
  • Playing a DVD under the Windows Vista operating system using the Windows Media Player may result in the DVD failing to play when switching between display devices using the hot-key function. Further details can be found in topic number 737-24472
  • The Microsoft Vista gamma settings set by the operating system may be overwritten when launching the Catalyst™ Control Center. Further details can be found in topic number 737-25505
  • Launching the Catalyst™ Control Center after hot-plugging a secondary CRT display device may result in the desktop image reverting to a black and white image requiring a re-installation of the display driver. Further details can be found in topic number 737-25517
  • OverDrive™ may not function as expected under the Windows Vista operating system when running an OpenGL application. Further details can be found in topic number 737-25524
  • Resuming from an S3 state may result in a longer than expected time for the Windows Vista operating system to resume. Further details can be found in topic number 737-25798
  • Connecting a CRT to a system containing an ATI Radeon™ X1200/1250/1300 series of product may result in the Windows Vista operating system may fail to respond when attempting to resume from an S3 state by pressing the power button. Further details can be found in topic number 737-25799
  • Display corruption may be noticed when clone mode is enabled and the displays are set to either 1280x1024 75/85/100 Hz. or 1400x1050 60Hz. Further details can be found in topic number 737-25800
  • Hot-plugging a CRT to a system running Windows Vista and containing an ATI Radeon™ X1100/1150 series of product may result in extended desktop mode failing to be applied. Further details can be found in topic number 737-25801
  • Installing an ATI Radeon™ X800 GT in a system running the Windows Vista 64bit version operating system may result in the WDM driver being unloaded when opening a window or application. Further details can be found in topic number 737-25804
WDM drivera i dalje nema.
Windows Vista download link:
http://ati.amd.com/support/drivers/v...n-vista32.html
Staro 21.02.2007., 22:05   #3
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
48% za Quake 4??
Dobrano su se oni to potrudili.
BTW. kaj se to meni čini ili su ovi driveri dosta manji neg prijašnji...? Vidim ovaj 9MB(display driver only), a prije oni su znali biti od 12-15MB.
Matth€w je offline   Reply With Quote
Staro 21.02.2007., 22:53   #4
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
A fak, ja sam toliko ljen da sam još na 6.10
Staro 21.02.2007., 23:28   #5
domy_os
domy_os's Avatar
Postovi: 18,894
I ja na 6.9... Ne vrijedi mi ni isprobavat na ovoj mojoj konfi jer je proc preslab za grafu pa ne bih osjetio baš neku razliku.
Staro 22.02.2007., 01:50   #6
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
ja sam na 6.12 jer mi se 7.1 nisu htjeli pošteno insatlirat, nekak mi s eneda opet trpit sranej s driverima.
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 23.02.2007., 00:06   #7
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Jel isprobao to netko?Ja sad skidam
Staro 23.02.2007., 00:22   #8
Mailman
Mailman's Avatar
Postovi: 1,606
Autor Veki-os Pregled postova
7.2 display driver only instaliran preko 7.1 sa ATTom u pozadini...nikakve probleme nisam uočio (x800)
Mailman je offline   Reply With Quote
Staro 23.02.2007., 00:53   #9
Veki-os
Veki-os's Avatar
Postovi: 3,996
OMG,ne znam što su napravili ali Carbon sada LETI
1280x1024 4AA i sve na high,prije sam na tim postavkama imao od 30-50FPS-a sad ne pada ispod 60 i ide do 100
Staro 23.02.2007., 00:55   #10
strikoo
strikoo's Avatar
Postovi: 985
OK, mene si uvjerio.
Skidam ih i stavljam
strikoo je offline   Reply With Quote
Staro 23.02.2007., 01:11   #11
Veki-os
Veki-os's Avatar
Postovi: 3,996
UPDATE:Cod2 prije neigriv na Dx9 sad se vrti na oko 50FPS-a,i dalje neigrivo ali puno,puno bolje nego prije(20-30FPS-a).
Staro 23.02.2007., 01:59   #12
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
Evo, ja instalirao.. isprobao NFS: Carbon Demo.... na X1650Pro:
Prije sa cat6.12 neigriv sa svime na high (u najboljem slucaju dobivao sam 9-13 FPS, sa 2xAA i losije...4xAA nemoguce.. pravi slide show). Igrivo bilo sa svim na high, osim road detail na low, bez AA, reza 1024x768. Rezultat takvog podesavanja je 20-30FPS.
Sada sa svim na high i sa 4xAA ,1024x768 -> 22-29FPS!
Prvi dojam novih drivera je dobar, dalje cemo vidjeti..nakon vikenda
Staro 23.02.2007., 03:47   #13
Jelc
Super Moderators
Postovi: 17,485
Budem i ja prek vikenda isprobao.
Staro 23.02.2007., 09:47   #14
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,006
Konačno su se prebacili sa .net 1.1 na .net 2.0 kod CCC-a
Interesantno da su "licencirali" nekakvu tehnologiju od ekipe koja radi WindowsBlinds, kao da je neka filozofija prebaciti se sa onog zaobljenog skina na ovaj "windows2000 like" i ubrzati stvar (a moguće da je i korištenje .net 2.0 pomoglo)
segregator je online   Reply With Quote
Staro 23.02.2007., 10:28   #15
domy_os
domy_os's Avatar
Postovi: 18,894
Taj classic skin postoji još od prve verzije CCC-a samo što je tek u 7.2 postavljen na default...
Staro 23.02.2007., 10:33   #16
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,006
Vidiš vraga, nisam nikad toliko kopao po tome da vidim da CCC ima skinove
Kod mene izgleda ko win2000 jer po defaultu koristim classic skin od win xp-a
Staro 23.02.2007., 11:05   #17
strikoo
strikoo's Avatar
Postovi: 985
Jel zna netko kako bi mogao natjerati drivere da se instaliraju na notebook?
x1600 mobile... stalno mi govori da ne prepoznaje hardware, a oni što sam dobio s njime rade normalno...
Staro 23.02.2007., 11:13   #18
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,006
Autor strikoo Pregled postova
Probaj Installation verification software sa
http://ati.amd.com/support/drivers/xp/mobility-xp.html
pa vidi dal imaš sreće
Staro 23.02.2007., 11:15   #19
domy_os
domy_os's Avatar
Postovi: 18,894
Skini DH Mobility Mod Tool pa ih modaj u mobilne...
http://www.driverheaven.net/modtool/
Staro 23.02.2007., 11:28   #20
strikoo
strikoo's Avatar
Postovi: 985
Onaj verification tool mi nije radio...sa mi se ne skida.
Ovo modanje još nisam probavao, ali sad ni ne trebam.
Našao sam direktan link za mobilne 7.2 drivere i instalirao i radi.
Vidi se ubrzanje i to dosta.
Baš dobro da smo i mi atijevci jednom zadovoljni sa driverima
čak mi se čini da se sada ne pali više onaj neki CLI.exe od CCC-a.
Staro 23.02.2007., 23:00   #21
DoX_Chabar
DoX_Chabar's Avatar
Lokacija: Čabar/Rijeka
Postovi: 655
Jel izašla verzija s CP?
DoX_Chabar je offline   Reply With Quote
Staro 23.02.2007., 23:02   #22
Veki-os
Veki-os's Avatar
Postovi: 3,996
Nije još.Staviš si samo drivere i najnoviji ATT i to je to,ne trebaš ni CP.
Staro 23.02.2007., 23:12   #23
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,006
Autor DoX_Chabar Pregled postova
Nije i neće
Staro 23.02.2007., 23:14   #24
Veki-os
Veki-os's Avatar
Postovi: 3,996
Kako znaš da neče?
Staro 23.02.2007., 23:14   #25
domy_os
domy_os's Avatar
Postovi: 18,894
Zašto ne bi izašla? Verzija 7.1 postoji sa CP-om, vjerujem da će i 7.2...
Staro 23.02.2007., 23:22   #26
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,006
Koliko sam ja vidio bila je samo verzija "driver only", tj. bez CCC-a i WDM-a, i to već par mjeseci (osim ako nije bila na nekom lijevom linku)
Staro 23.02.2007., 23:24   #27
Veki-os
Veki-os's Avatar
Postovi: 3,996
Staro 23.02.2007., 23:29   #28
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,006
Ma dobro, to netko neslužbeno pakira stari CP i nove drivere...bolje onda stavit ATT imho
Staro 24.02.2007., 01:20   #29
Mailman
Mailman's Avatar
Postovi: 1,606
link?
Staro 24.02.2007., 11:10   #30
strikoo
strikoo's Avatar
Postovi: 985
Autor Mailman Pregled postova
link?
http://ati.amd.com/online/mobilecatalyst/
