Staro 19.10.2006., 18:58   #61
Costa
Costa's Avatar
Datum registracije: Aug 2003
Postovi: 3,193
Za prvi izgled:
http://www.hydrogenaudio.org/forums/...dpost&p=439039
Za drugi izgled (kod mene je to kombinacija prvog i drugog):
http://www.hydrogenaudio.org/forums/...dpost&p=437898
Prvi izgled chupa covere iz cover direktorija i oni moraju biti 80x80 PNG dok drugi chupa iz direktorija samog albuma i coveri mogu biti bilo koje velichine ili formata (lik je stavio PNG no ja sam promjenio u JPG).
Staro 21.10.2006., 16:25   #62
Postovi: 7,568
Zadnje izmijenjeno od: McG. 13.01.2012. u 01:07.
Staro 21.10.2006., 16:34   #63
LuXor
Datum registracije: Jul 2004
Lokacija: Bjelovar
Postovi: 752
Costa jel mi mozes dat popis pluginova i .fcs file koji koristis?
LuXor je offline   Reply With Quote
Staro 21.10.2006., 17:08   #64
Costa
Costa's Avatar
Postovi: 3,193
Autor LuXor Pregled postova
Nema tu .fcs filea jer je u pitanju single columns playlist. Imash na ona dva linka sve objashnjeno.
Evo lista komponenti:
amip.dll, foo_abx.dll, foo_ac3.dll, foo_adpcm.dll, foo_albumlist.dll, foo_amipwrapper.dll, foo_audioscrobbler.dll, foo_autoplaylist.dll, foo_burninate.dll, foo_cdda.dll, foo_common.dll, foo_converter.dll, foo_cwb_hooks.dll, foo_dbsearch.dll, foo_dsp_continuator.dll, foo_dsp_crossfeed.dll, foo_dsp_std.dll, foo_dumb.dll, foo_freedb2.dll, foo_gep.dll, foo_infobox.dll, foo_info_samurize.dll, foo_input_monkey.dll, foo_input_shorten.dll, foo_input_std.dll, foo_lnk.dll, foo_lock.dll, foo_lunar2.dll, foo_masstag.dll, foo_midi.dll, foo_osd.dll, foo_out_ks.dll, foo_playlist_manager.dll, foo_pqview.dll, foo_psf.dll, foo_rgscan.dll, foo_run.dll, foo_sic.dll, foo_sid.dll, foo_tradersfriend.dll, foo_uie_albumart.dll, foo_uie_albumlist.dll, foo_uie_lyrics.dll, foo_uie_playlists_dropdown.dll, foo_uie_quicksearch.dll, foo_uie_single_column_playlist.dll, foo_uie_trackinfo_mod.dll, foo_ui_columns.dll, foo_ui_std.dll, foo_unpack.dll, foo_utils.dll, foo_verifier.dll, foo_vis_samurize2.dll, foo_winamp_spam.dll, foo_write_http.dll, libpng13.dll, zlib1.dll
Staro 21.10.2006., 17:36   #65
morph
morph's Avatar
Postovi: 1,530
@ luxor
pogledaj ovdje
iza plave crte imas objasnjeno single column
@mcg hvala na linku
evo moga, nikako da se priviknem skroz na ovaj single column
kod ovog dolje track infa ne sljaka pauza i volume bar
prikazivanje covera sam manje vise sredio, radi i sa modificiranim crnovim pluginom za samurize...doduse ne bas savrseno, ali radi
morph je offline   Reply With Quote
Staro 22.10.2006., 08:20   #66
nescuppir
nescuppir's Avatar
Lokacija: Sveta Nedelja
Postovi: 129
evo moga -->
ovaj dolje pause i meni nije šljakal jer je greška u kodu - treba dolje na kraju di se nalazi red
$button($sub($div(%_width%,2),64),32,0,0,0,0,neo1\pause1b.png,neo1\pause2b.png,Pause,)
treba na kraju promijenit - mislim da je pisalo "Playpause" tak nekaj, treba promijenit sam u "Pause" i sve radi - sad meni i dalje ne radi volume bar i gornji seekbar (sad za taj seekbar neznam dal bi uopće trebao radit...)
nescuppir je offline   Reply With Quote
Staro 22.10.2006., 14:22   #67
Costa
Costa's Avatar
Postovi: 3,193
Mozhe se koristiti Pause, a mozhe i Play or pause.
Za kontroliranje glasnoche zvuka mozhe se slozhiti Volume up i Volume down, npr. naprave se 2 prozirna PNG-a velichine onog volume bara i na jedan se stavi naredba za pojachavanje a na drugi za stishavanje.
Seekbar se mozhe slozhiti preko naredbi za premotavanje (sekunda, 5, 10, minuta i sl.) - npr. seek ahead by 5 seconds.
Staro 25.10.2006., 20:09   #68
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
meni se glupi foobar opet resetirao, i opet sam na nuli...
tako glupav program da glava boli.
Glupav zbog toga što ne možeš snimiti svoj setup file, i da nakon instalacije, ili slučajnog za***a, možeš odmah vratiti sve na staro.
Dok ne bude to u mogućnosti, meni neće na komp.
Media monkey me u potpunosti zadovoljava.
Staro 25.10.2006., 20:29   #69
morph
morph's Avatar
Postovi: 1,530
Autor Gabre Pregled postova
Meni se to dogodilo sigurno 5-6 puta, a da nisam napravio backup. Sad imam 5-6
vec slozenih setupa, ako nesto idem mrdati po njemu mogu vratiti na staro u roku 15 sekundi. (a najmanje 5 puta sam pisao kako i sto)
Znaci mozes vratiti sve na staro vrlo brzo i jednostavno. Mozes snimiti setup file.
Nije niti foobar za svakoga, zato i postoje winamp, helium, mediamonkey.
Staro 25.10.2006., 23:14   #70
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
Autor morph Pregled postova
i ja baš zbog razloga što moraš sve ispočetka raditi kažem da je taj program nedovršen, i sve dok ne bude imao opciju "undo" ili nakakvu opciju "exportanja" setup fileova... taj više kod mene neće... sve ok, ali stvarno nije NAJ NAJ player... daleko od toga.. stvarno je samo za entuzijaste i ljude s puno viška vremena..
Staro 26.10.2006., 00:07   #71
morph
morph's Avatar
Postovi: 1,530
@gabre
ok, tebi nije naj, meni je...
i ima opciju exportanja - to ti i govorim cijelo vrijeme
evo taman sam slozio jedan area04 yellow (da ne spamamo vise)
Staro 30.10.2006., 01:29   #72
morph
morph's Avatar
Postovi: 1,530
evo jos jedan setup ovog cd rippera iliti browsera
Staro 30.10.2006., 15:51   #73
B3mt1
Chipokemon
B3mt1's Avatar
Postovi: 339
ovako uglavnom svira (minimaziran), onaj skorz dole desno popup se pojavi na 2 sek. nakon sto se promjeni pjesma
i pomalo standardan (los ) look
Piracy helps stop global warming.Insted of driving to get CDs, buying pre-packaged software from megacorporations and wasting energy,you can help fight Global Warming by using P2P.Help save resources,fight pollution and save the enviroment.
-It`s what Jesus would do.
B3mt1 je offline   Reply With Quote
Staro 30.10.2006., 17:07   #74
svebee
Lokacija: /
Postovi: 2,053
by @CeciPerez
pital sam i morph-a prek PM-a, al svejedno ak se neko brži nađe...kak dodat onaj "rating" pokraj svake pjesme? tnx.
svebee je offline   Reply With Quote
Staro 03.11.2006., 21:10   #75
tutix
tutix's Avatar
Postovi: 4,069
Sličan vašima, ali morao sam jednostavno ugurati Album list i Playlist switcher.
Staro 04.11.2006., 07:51   #76
svebee
Lokacija: /
Postovi: 2,053
dobra zamisao sam daj ga još malko popravi
dodaj slike albuma jer se ovak teško kuži koja pjesma kojem albumu pripada....
i malo "stisni" foobar da nema ovih crnih sa strane... : goood :
http://img215.imageshack.us/img215/8...titled1yq0.jpg
Staro 04.11.2006., 11:59   #77
tutix
tutix's Avatar
Postovi: 4,069
Pa je stisnut je, kad ga ne rastegnem do kraja, neću coverse jer nisam spojen na net stalno pa mi ih nemre skidat, a albume mi odvoji sa dva reda pa se da skužit.
Staro 04.11.2006., 12:37   #78
Postovi: 7,568
Staro 04.11.2006., 21:16   #79
svebee
Lokacija: /
Postovi: 2,053
sry. na OT al može wallpaper : lol2 :
Staro 04.11.2006., 23:39   #80
tutix
tutix's Avatar
Postovi: 4,069
Tnx McG
Staro 05.11.2006., 12:57   #81
d0X
Kostolomac
d0X's Avatar
Postovi: 1,482
eto moga. kad dosadi mijenjam
EDIT: ako neko hoće ovakav foobar, evo linka:
http://www.hydrogenaudio.org/forums/...howtopic=49783
PSN Steam
Zadnje izmijenjeno od: d0X. 05.11.2006. u 14:42.
Staro 05.11.2006., 14:18   #82
Postovi: 7,568
Staro 05.11.2006., 21:25   #83
morph
morph's Avatar
Postovi: 1,530
Autor d0X Pregled postova
Evo ovo je jedna od novosti vezanih uz foobar - dozvoljeno je dijeljenje foobar.cfg filea.
Sad bi se trebala napraviti import-export skripta koji ce omoguciti lako backupiranje i razmjenjivanje setupa. (vise ovdje
Korak u pravom smjeru
Staro 06.11.2006., 10:21   #84
svebee
Lokacija: /
Postovi: 2,053
Talking
složio si ja drugi setup al sad nailazim na par problema...
zakaj mi se redni brojevi pjesma "skraćuju" odozdo? - btw. imam instaliran Calibri Font
zakaj mi se rating pjesme pokaže tek kad kliknem na nju, a kad idem neku drugu slušat sa ove stare se onda ne prikaže...kužite kaj hoću reć? hehe
i zakaj nemrem gore onaj Track Info Mod "proširit" malo za dolje...jednostavno mi foobar ne da...why? hvala
Staro 08.11.2006., 21:10   #85
svebee
Lokacija: /
Postovi: 2,053
evo uspel sam
kak napravit ovakav skin ??? - btw. rađeno po ovom topicu...
ja sam si to sve sredil i zbiksal i ovaj .zip sadrži sve potrebne componente (sve koje će vam (valjda) ikad trebat...hehe), slike za ovaj skin te .cfg odnosno configuration file....pa uživajte
http://rapidshare.com/files/2541766/...WMP11.zip.html - oko 5MB
Staro 05.12.2006., 17:52   #86
F@NTOM
Darth Pope
F@NTOM's Avatar
Lokacija: localhost
Postovi: 225
evo novi fooić
prilicno standardna konfiguracija sa single column pluginom i album listom na auto hide.
@morph: sto tocno treba da se dobije ovakav setup http://www.imagesforme.com/viewer.php?id=476f2k.jpg, koji fcs, track info, akko se sređuje ovaj rating i kako dodati hebene buttone. I jos nesto koji je ovo skin za win?. Valjda nije pre tesko pitanje.
F@NTOM je offline   Reply With Quote
Staro 05.12.2006., 19:59   #87
morph
morph's Avatar
Postovi: 1,530
Naravno da nisu preteska pitanja : sweating
Windows Vs je foton
Autor Foobar setupa je spex04 i mozes ga naci ovdje
(da sad ne c/p-am cijeli post ovdje)
Tu imas sve kodove, layout i images za download. Samo ubaci kodove u single column playlist i track info mod i raspakiraj images u odgovarajuci folder. Da bi ti ovi buttoni u track info modu funkcionirali moras imati foo_cwb_hooks plugin.
Sto se tice ratinga on je u kodu od single column playlista, zvjezdice se dodaju automatski ovisno o tome koliko je puta pjesma poslusana.
Ako bude problema napisi (samo sto preciznije)pa cemo probat rijesiti.
Staro 05.12.2006., 20:07   #88
morph
morph's Avatar
Postovi: 1,530
Autor phissen Pregled postova
Nisam vidio prije ovo pitanje, to ti je rad od Draikin...na francuskom je site, ali ispod slike ti je link na download, trebale bi biti prilozene i upute na engleskom
Staro 02.01.2007., 13:46   #89
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,772
pozdrav ljudi.
puklo i mene jučer ušminkati foobar, mešutim kako nemam dume to napraviti sam, išao sam na hydrogenaudio i uzeo http://img120.imageshack.us/img120/3673/3nc4.png taj.
međutim, problem mi je što se onaj gornji prikaz, znači brojke na kojoj je trenutno pjesma minuti/sekundi, uopće ne vrte, tj pomaknu se ako stisnem na one zvjezdice/srčeka znači tek se onda refresha. nije problem samo u ovom modu, probao sam još jedan, i isti slučaj. zna li netko možda rješenje problema?
thx
Staro 02.01.2007., 13:47   #90
kalixius
...carpe diem...
kalixius's Avatar
Lokacija: Zagreb - okolica
Postovi: 1,363
evo,sve sam kak ti uspio nekak pohvatat upute ali nikak da dobim ono kaj hoću.
pa da pitam dal ovo zna netko napravit:
-ovo dvoje je zajedno
ili ovo:
kalixius je offline   Reply With Quote
