Staro 08.10.2006., 14:24   #1
dadojaksa
bad ass madafaka
dadojaksa's Avatar
Postovi: 139
Problem: gf6800 leadtek 3dmark 1 frame/sec
bok,
kupio leadtekovu 6800 ovdje na trznici... i pustim 3dmakr06
i vidi... 1o cak 0 fps. : baad :
imam abit nf7
barton 2600 mob
i 2x512 ram supertalent cl2
e sad...
dali moze bit zbog napajanja...ms 400w ???
u utorak ce mi vjerojatno stic coolermaster 430w.
pozdrav
dadojaksa je offline   Reply With Quote
Staro 08.10.2006., 14:32   #2
zackoj
zackoj's Avatar
Postovi: 888
napajanje. mozda je pametno da ne forsiras komp dok ne dobije novo.
ali uvijek moze i grafa biti neispravna stari driveri itd.
ako mozes posudi neko napajanje pa probaj
jedan je GAZDA F1. Michael never give up, never surrender !!!
zackoj je offline   Reply With Quote
Staro 08.10.2006., 14:42   #3
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Nevjerujem da je zbog napajanja, mislim svakako ga promijeni. Ja sam imao slicnu konfu pogonjenu sa Codegenom 300W, bila je P4 2.4C, 2x256MB, 6800LE.
Jel sve testove vrti sa 0fps? Da to nije onaj CPU test (na marsu), jer kod njega skoro svi imaju 0 fps-a. Osim ekipe s DC, ili mrcinama od SC procevima..
Svakako promijeni napajanje prvom prilikom..
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 08.10.2006., 14:47   #4
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,506
Ma kakvo napajanje, uvijek vam je ono krivo. Kaže samo da je u Marku. Lijepo Driver Cleaner i onda stavi XTreme-G 85.96.
Staro 08.10.2006., 14:50   #5
dadojaksa
bad ass madafaka
dadojaksa's Avatar
Postovi: 139
najnoviji dirveri sa nvidijinih stranica sam instaliro sa novim windowsima....
di da skineam xtrme g 85,96 ???
Staro 08.10.2006., 14:53   #6
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Ako je u onom testu di je crveni planet kao, pa ti je tamo 0fps-a to ti je normalno. Njie to do grafe jer to je test za proc.
No, ako je na svim testovima tako, onda imaš problem...
EDIT:
XG drivere i drivercleaner Pro skinuti sa www.tweaksrus.com
Staro 08.10.2006., 14:55   #7
dadojaksa
bad ass madafaka
dadojaksa's Avatar
Postovi: 139
a mozda da uzmem 3dmark03 a ne 06 ???
Staro 08.10.2006., 14:58   #8
Vuco
Vuco's Avatar
Postovi: 9,505
I kaj si time napravio?
Daj samo kaži jel ti na svim testovima tako, 0fps-a ili samo na tom sa crvenim nekim planetom i dole desno radarom nekim zelenim?
Staro 08.10.2006., 15:01   #9
dadojaksa
bad ass madafaka
dadojaksa's Avatar
Postovi: 139
kolko sam skuzio na prva 3 je 0 i 1fps i sad sam kreno sa 3dmakr 03 i sad ima 70 fpsa
edit..: cak zan skocit i na 200 itd...
Staro 08.10.2006., 15:02   #10
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,506
Autor dadojaksa Pregled postova
Slušaj, sigurno imaš par igrica instalirano. Ako one rade i sve je 5, ne brini. Zar su nam svima markovi orijentir?! Probaj se igrati, a ne vrtiti markove.
Staro 08.10.2006., 15:04   #11
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
pa kak ti igre rade na njom...tipa far cry,fear i tak nešt?
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 08.10.2006., 15:08   #12
dadojaksa
bad ass madafaka
dadojaksa's Avatar
Postovi: 139
nemam nist instalirano.. friske windowse sam stavio dok sam grafku instaliro
Staro 08.10.2006., 15:12   #13
Thoroughbred B
Thoroughbred B's Avatar
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,915
Prije svega,fino počisti sve drivere i stavi nove,i nforce naravno...Po mogučnosti,ne stavljaj opet iste,ne rade svi driveri savršeno s određenim komadom hardvera.Tek kad to napraviš,idemo dalje...
I probaj navest koji testovi ti se vuku 1-0 FPS u 3DMark06.
Staro 08.10.2006., 15:26   #14
dadojaksa
bad ass madafaka
dadojaksa's Avatar
Postovi: 139
evo odvrtio 3dmark03 i skupio 7510 bodova...
frend mi imo sa novom x800rx gto oko 7800 bodova...
oba testa bez ikakvog klokanja....
mislim da je to onda ok....
mojoj zeni dost za igranje sims2
kolko bi dobio kad bi stavio xg dirvere ???
btw.. temeperatura grafke je od 40 - 44 stupnjeva....
pozdrav..
i da.... puno vam hvala sto ste u tolikoj kolicine navalili da mi pomognete...
BIG THX
Staro 08.10.2006., 15:29   #15
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,506
Što se tiče XG-a pokazali su se mnogima kao najbolji izbor, jer s njima radi 97% svih igara bez problema. Daje možda malčice manje scorove u sintetici, ali igre idu jako dobro.
Zadnje izmijenjeno od: -POP-. 08.10.2006. u 15:59.
Staro 08.10.2006., 15:34   #16
Vuco
Vuco's Avatar
Postovi: 9,505
Dobro je. Mada sam ja sa OC-anom 6800 (i OC-anim procem) vulgaris u 03 dobio cca. 11000.
Mislim da ti je reza ok
Staro 08.10.2006., 15:34   #17
Thoroughbred B
Lokacija: RI
Postovi: 4,915
pozdrav..
BIG THX
XG krpa sve nedostatke originalnih nvidia drivera i optimizira ih,85.96 su proslavljeni driveri i slove za jedne od najboljih,meni su praktički do jučer bili jedini izbor,sada više nemam nvidiu ali imao sam je donedavno i 91.48 WHQL su se također pokazali odličnim izborom.Neznam koje sada imaš,ali s 85.96 ili 91.48 imat češ najbolje i najstabilnije drivere današnjice
Još jedna stvar,ako ti igre zaista rade bez greške,ne opterećuj se sintetičkim testovima poput 3DMarka.
Inače,rezultat u 03 ti je OK
Staro 08.10.2006., 15:35   #18
Foxman
localhost
Foxman's Avatar
Postovi: 711
0 ili 1 FPS imaš na testovima za proc i to je normalno..... i grafika ti trza i sve.... Ne sekiraj se nije do hardwarea ni pogrešnog 3Dmarka već do testa koji tako mora izgledati....
Foxman je offline   Reply With Quote
Staro 08.10.2006., 16:05   #19
dadojaksa
bad ass madafaka
dadojaksa's Avatar
Postovi: 139
aha , ok sve 5
pa istaliro bih ja ovaj XTreme-G 85.96.
ali nemrem ga naci... ima samo novije tipy 91.** itd.. zna li tko kakav link ??
thx
Staro 08.10.2006., 16:54   #20
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,506
aha , ok sve 5
thx
http://www.hwupgrade.it/download/file/2811.html
Staro 08.10.2006., 16:56   #21
Thoroughbred B
Lokacija: RI
Postovi: 4,915
aha , ok sve 5
thx
Samo ti stavi 91.48 Odlični su to driveri,IQ je bolji.
http://tinyurl.com/jxlnx
Staro 08.10.2006., 17:10   #22
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Autor Thoroughbred B Pregled postova
Jel ima neke vidljive razlike između 91.47 i 91.48?Imam friške win pa ne znam jel mi se isplati prelaziti na 91.48?
Staro 08.10.2006., 17:12   #23
Thoroughbred B
Lokacija: RI
Postovi: 4,915
Autor Veki-os Pregled postova
Nema nikakve,ali sam koristio 91.48,preferiram uvijek novije.
Staro 08.10.2006., 18:06   #24
dadojaksa
bad ass madafaka
dadojaksa's Avatar
Postovi: 139
jehem mu misa
jel sad trebam
XTreme-G 91.48-AD
ili
XTreme-G 91.48
sta uopce taj AD znaci...
Staro 08.10.2006., 18:38   #25
MAHER
Postovi: 1,583
AD ti je s optimiacijama za video prikaz,ali to možeš i u običnoj verziji napraviti,ako imaš malo znanja i nisi lijen,meni njihov AD izgleda malo pretamno
MAHER je offline   Reply With Quote
Staro 08.10.2006., 20:09   #26
dadojaksa
bad ass madafaka
dadojaksa's Avatar
Postovi: 139
eto..
istaliro ja XTreme-G 85.96. i prije ocistio sa drivercleanerom...
eto pustio je opet 3dmark (vrag mi neda mira )
cini mi se puno brze... i onda stane i napisi mi ovo
"reliable benchmarking cannot be completed because the 3dmakr
displey window lost focus. "
sta sad ovo pak znaci.. ???
Staro 09.10.2006., 06:37   #27
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,315
..to znaci da se nesto pokrenulo u pozadini,nekakav program,antivrius..uglavnom nesto je prekinulo 3d mark..pogasi sve nepotrebne procese onda pusti da vrti
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
