Staro 11.09.2006., 12:43   #91
yggdrasil
yggdrasil's Avatar
Postovi: 233
official forum pain in the ass is back : hitthewa ....Zao mi je ljudi al moram pitat nesto...ma eto sta je tu je desilo se nesto tj iskrslo je nesto pa moram cekat do pocetka 10 mj. da kupim komp napokon. Uglavnom neke stvari su se promijenile, nestao je x2 3800+ (u ve-milu je navodno "trenutno nedostupan" i kosta 1380 kn) a slijedeci proc je 1500 kn tj x2 4200+. Moje pitanje je da molim Vas usporedite jednu i drugu varijantu ispod, hvala (da jos nisam makao gigabyte plocu btw boldano je glavna promjena zbog koje pitam). Dakle ljudi sta je po vama vise money worth kao gejmerski komp:
Gigabyte K8NF-9 Ultra,s939,nForce4, FW, GLAN............................597 kn
CPU AMD Athlon64 X2 3800+ BOX, dual core, Sck939...................1378 kn (ili cak stvarno x2 4200+ ako stvarno nigdje ne bude vise x2 3800+, ali to je onda 1500 kn)
DDR 1GB PC3200 (400MHz), Samsung, ST...................................783 kn
DDR 1GB PC3200 (400MHz), Samsung, ST....................................783 kn
HDD Seagate ST3250824AS, 250 GB 8MB, S-ATA300, NCQ, 7200........618 kn
Gainward BLISS 7600GT GS, 256MB.............................................1434 kn
DVD ROM LG, 16/48x, ATAPI, black, bulk..........................................133 kn
DVD+RW/-RW/RAM LG GSA-H10A, Dual Layer, 16x, black, bulk............269 kn
Thermaltake mid tower Mambo, bez PS, crno..................................344 kn
Chieftec power supply 450W, ATX 2.0, 2×12V................................380 kn
Ukupno: 6719 kn
OOOORRRRRRRRRRR (izbacen je DVD rom i smanjen HDD):
CPU AMD Athlon64 BOX 3800+, Sck939......................................972 kn
DDR 1GB PC3200 (400MHz), Samsung, ST................................783 kn
HDD Seagate ST3160812A, 160 GB 8MB, ATA-100, 7200..................462 kn
Leadtek GF 7900 GT TDH, 256MB...............................................2085 kn
Thermaltake mid tower Mambo, bez PS, crno................................344 kn
Chieftec power supply 450W, ATX 2.0, 2×12V.............................380 kn
Ukupno: 6675kn
Zadnje izmijenjeno od: yggdrasil. 11.09.2006. u 13:35.
yggdrasil je offline   Reply With Quote
Staro 11.09.2006., 12:56   #92
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Prva verzija ako ne se buš previše igral i/ili ako ne patiš da sve bude na max.
Druga verzija ako su ti igre život.
Ako odlučiš za prvu verziju, preporuka da zamjeniš tercet CPU,MBO i RAM zaa E6300, Asrokicom nekon Conroe Ready i 2x1GB Kingmax-a. Neš moć previše OC-at, ali će biti svejedno brže od ove tvoje prve verzije sa AMD-om.
Staro 11.09.2006., 13:06   #93
bobe
teta Mraz
Lokacija: hr
Postovi: 1,596
definitivno e6300 kako vucko kaže, a napajanje mislim da ti je dosta cheiftec delta 350w za nekih 250-260kn u linksu
bobe je offline   Reply With Quote
Staro 11.09.2006., 13:07   #94
yggdrasil
yggdrasil's Avatar
Postovi: 233
hehhehe hvala Vucko! Nego cuj ma vec sam rekao da necu Oc-at jer sam tudum za to a i malo me strah da ne skratim rok trajanja komponentama. Cak si i ti rekao da je gigabyte sasvim ok ako necu Oc-at a E.T. je rekao da je dapace stabilnija od drugih ako ostane na default-u.A necu sad ic na Conroe nek ostane dobri stari amd.
koliko je lose u 2 verziji komponenti imati onakav proc?
Staro 11.09.2006., 13:15   #95
bobe
teta Mraz
Lokacija: hr
Postovi: 1,596
za te pare mislim da nema boljeg proca, vidio sam ga na djelu, još ako nađeš x2..
Staro 11.09.2006., 13:21   #96
yggdrasil
yggdrasil's Avatar
Postovi: 233
Autor bobe Pregled postova
ma da odavno sam bio zapeo za x2 3800+ al eto nestao je potpuno....sad je samo taj x2 4200+ od 1533 kn : nono : a to ne dolazi u obzir. Nego ova leadtekica jede pare uzasno, a opet sta se zalim eto htjeo sam gejmerski komp, imam ga. Nego sta ima sta u drugoj verziji gore navedenih komponenti sta je moguce da se pretvori u bottleneck (eto meni je paranoja da ce proc biti slab)?
P.S. napravio sam lagani edit kod vers 2 jer sam zaboravio izbacit DVD rom i smanjit HDD, pa je sad tek cijena uredu...
Zadnje izmijenjeno od: yggdrasil. 11.09.2006. u 13:37.
Staro 11.09.2006., 13:30   #97
nicko
Postovi: 4,190
Za gejmanje bi bolji bio donji, ali idealna kombinacija bi bila X2 i 7900
Sad ti je dosla 7900GS graficka, pa si uzmes nju i X2, to bi ti savrseno bilo!
A napajanje si mozes i neko slabije uzet od 350-400W, bit ce ti dosta...
Edit: pogledaj i X1900GT za oko 1700kn....
nicko je offline   Reply With Quote
Staro 11.09.2006., 13:38   #98
bobe
teta Mraz
Lokacija: hr
Postovi: 1,596
definitivno 7900gs,(bude u linksu sljedeći tjedan za 1700kn), napajanje koje sam ti već prije rekao je sigurno dosta, a dvd-ove možeš pržit i samo sa dvd-rw (ako ih ne pećeš na veliko), tak da bi ja dvd rom izbacio
mislim da sad imaš za 4200 x2!
Staro 11.09.2006., 13:48   #99
Vuco
Vuco's Avatar
Postovi: 9,505
U većini igara danas još nema MP podrške (za više jezgri). Ali to ne znači da ih neće biti
Ako nećeš OC-at, pređi na Core 2 Duo jer ionako kupuješ novi komp, cijeli. X2 3800+ za soc. 939 teško da ćeš naći. A za 1500kn ti je bolje ići na E6300, DDR2 od Kingmax-a i Asrokicu.
Najbolje ti je ovako:
E6300 - 1530kn
2x1GB PQI DDR2 667 - 1220kn
Asrock ConRoeXFire-eSATA2 - 655kn
Leadtek GF 7900 GT TDH, 256MB - 2085kn
HDD Seagate ST3160812A, 160 GB 8MB, ATA-100, 7200 - 462kn
DVD+RW/-RW/RAM LG GSA-H10A, Dual Layer, 16x, black, bulk - 269 kn
Thermaltake mid tower Mambo, bez PS, crno - 344 kn
Chieftec power supply 450W, ATX 2.0, 2×12V - 380 kn
UKUPNO=6945kn
A to padne na 6700kn ako se kupi ova nova 7900GS koja je jeftinija tako 200-300kn a nije niš slabija od 7900GT.
Ja ti velim, a ti poslušaj ako oćeš...
Ova konfa će ti biti mrcina do jaja. Razvali obje tvoje
Staro 11.09.2006., 13:48   #100
yggdrasil
yggdrasil's Avatar
Postovi: 233
ufffff jao dobrooo hehehehh hvala ljudi, vidjet cemo.....cekat cu ovu GS-icu
Staro 11.09.2006., 13:52   #101
yggdrasil
yggdrasil's Avatar
Postovi: 233
Autor Vucko Pregled postova
E6300 - 1530kn
UKUPNO=6945kn
a x2 4200+ i 7900 GS? kombinacija.
sta intel sad toliko lomi Amd? Odnosno E6300 > x2 4200+ oboje 1500 kn?
dobro razmislit cu tnx
Staro 11.09.2006., 13:59   #102
Vuco
Vuco's Avatar
Postovi: 9,505
Dođe ti isto, ali ti je E6300 brži.
Velim ti, ako možeš, pokušaj u moju konfu ubaciti samo 7900GS i cijena ti dođe ko ova tvoja prva...
Staro 11.09.2006., 14:06   #103
yggdrasil
yggdrasil's Avatar
Postovi: 233
a daj mi objasni (uvjeri) za ovaj DDR2. Jer negdje sam procitao da ako DDR2 nije 800Mhz uopce nema vidljive razlike. tj DDR2 na 667Mhz=DDR tu su negdje
Staro 11.09.2006., 14:12   #104
Vuco
Vuco's Avatar
Postovi: 9,505
To je priča za AM2 socket naprema 939 i DDR400.
A na E6300 i DDR2 667 je jači od 4200+ i DDR2 667 (a valjda i od DDR2 na 800).
Naravno, bilo bi bolje da je i na E6300 DDR2 800, ali nećeš patit toliko. On će svojom brzinom (proc) nadoknadit to.
Šteta što više nema Kingmax-a 667-ice jeftino u Linksu, sad je skuplja od Kingamaxa DDR2 800, kojeg nema, ali sigurno kada dođe bit će skuplji nego što sada piše na cjeniku.
Možda je u Ve-milu bolja cijena...
A sad, što se tiće OC-anja. Ova Asrokica trenutno ne može zbog BIOS-a preko 300mhz. Tvoj proc radi na 266. Bez ikakvog dizanja voltaže, taj E6300 će raditi na 300Mhz (što uz množitelj x7 daje 2,1Ghz), a memu staviš 1:1 i ona radi na 600Mhz sa nekim relativno niskim latencijama i eto ti đabe brzine, a ako ti proc krepa kad ga dižeš na defoltu, ja ću ti osobno kupit drugi E6300
Staro 11.09.2006., 14:16   #105
yggdrasil
yggdrasil's Avatar
Postovi: 233
DDR2 1GB PC6400 (800MHz), GoodRAM PRO 863,46 kn
http://www.ve-mil.hr/cjenik.aspx?Gru...Oznaka=memddr2
Staro 11.09.2006., 14:20   #106
nicko
Postovi: 4,190
Ja isto mislim da ti je sad bolje ici na intela....a uzmi u obzir i X1900GT..
Staro 11.09.2006., 14:21   #107
yggdrasil
yggdrasil's Avatar
Postovi: 233
Staro 11.09.2006., 14:22   #108
yggdrasil
yggdrasil's Avatar
Postovi: 233
Autor nicko Pregled postova
ocu hvala
Staro 11.09.2006., 14:25   #109
yggdrasil
yggdrasil's Avatar
Postovi: 233
mema 1:1 to mislis na dual channel? ili? ajde ti si tu nesto racunao mnozio...ok ok uvjerio si me hehehhe....doobro vec cu nekom da da mi OC-a ko se razumije
Staro 11.09.2006., 14:42   #110
bobe
teta Mraz
Lokacija: hr
Postovi: 1,596
conroe definitivno!
taj goodram je odlićan ali teško da ćeš ga nać tako da uzmmeš u obzir kingmax ili goodram 667Mhz
Staro 11.09.2006., 20:03   #111
yggdrasil
yggdrasil's Avatar
Postovi: 233
Hvala ljudi, conroe it is! sad jos 20 dana moram cekat
