Keeper of the Nine Keys
Postovi: 193
New In-game Crysis footage
http://downloads.guru3d.com/download.php?det=1423 http://www.crysis.ws/ evo pa pogledajte sto nas ceka... ![]()
L-L-L-Look at you, Hacker. A pa-pa-pathetic creature of meat and bone, panting and sweating as you r-r-r-run through my corridors-s-s. H-h-how can you challenge a perfect, immortal machine? - SHODAN CPU : AMD 64 X2 4600+ / 2400Mhz (Sckt AM2) CPU COOLER : Stock MOBO : Gigabyte GA-M59 SLI-S5 (BIOS - F8) RAM : 2x1GB SuperTalent CL4 (4-4-3-8) PC6400 DDR2-800MHz GPU : XFX 8800GT 512MB "Alpha Dog Edition" @ 710/1720/1030 POWER SUPPLY : Thermaltake Toughpower 600W PSU CASE : Thermaltake Armor Jr HDD : 2 x Seagate 320GB HDD SATA2 DVD-RW : Pioneer DVD-RW R-110 MONITOR : BenQ G2400W 24" 5ms LCD 1920x1200 |
Datum registracije: May 2005
Lokacija: Zgb - shpaolin
Postovi: 641
Koliko će to lošije izgledati na dx9 karticama? PUUUUUNO, puuuno, ili tako, podosta? |
#3 | |
Postovi: 193
Izmedju ostalog...na cemu je on to igrao uopce? Cini mi se da dx10 kartice nisu jos izasle...: stoopid
#4 | |
Postovi: 641
Kako bi inače isprobavali? |
#5 | |
Postovi: 193
Doktor znanosti!
Lokacija: Zg,Peščenica/borongaj
Postovi: 1,311
Pogledajte sam ovaj scrs http://www.crysis.ws/images/stories/...SpcSCRN00a.jpg Brijem da tu ima GRRROOOOO poligona... Ma pih.. di ovo sve ide, a samo da se prodaju nove kartce....Bahh |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Crysis Minimum System Specs Revealed
Minimum Requirements CPU: Athlon 64 3000+/Intel 2.8ghz Graphics: Nvidia 6600/X800GTO (SM 2.0) RAM: 768Mb/1Gb on Windows Vista HDD: 6GB Internet: 256k+ Optical Drive: DVD Software: DX9.0c with Windows XP Recommended Requirements CPU: Dual-core CPU (Athlon X2/Pentium D) Graphics: Nvidia 7800GTX/ATI X1800XT (SM 3.0) or DX10 equivalent RAM: 1.5Gb HDD: 6GB Internet: 512k+ (128k+ upstream) Optical Drive: DVD Software: DX10 with Windows Vista Ne znam da li je ovo skroz službeno-čut će se ![]() |
Ex-Gastarbajter
Lokacija: Zagreb / Rijeka
Postovi: 5,465
Mene je FarCry oduševio krajolikom, a ova ima čak i masu načina za igrat... definitivno mi se čini must have.. |
Super Moderators
Postovi: 17,485
Pa-dosta igara je malo odgođeno u zadnje vrijeme, valjda zbog Viste i DX10 hardwarea...neće tak skoro. Ja danas instaliram Far Cry na ljutu pilu od PIII, baš me zanima da li bude išlo na tom krampiću... ![]() |
Postovi: 2,458
Ovo kaze readme za farcry: Minimum: * Supported OS: Windows® 98SE/2000/XP (only) * Processor: AMD Athlon™ 1 GHz or Pentium® III 1 GHz * RAM: 256 MB * Video Card: 64 MB DirectX® 9.0b-compatible graphics card * Sound Card: DirectX® 9.0b-compatible PCI card * DirectX Version: DirectX 9.0b (included on disc) * CD-ROM: 4x DVD or 16x CD-ROM * Hard Drive Space: 4 GB Edit: Ja sam ga igrao sa Ti4600 pa mi se nije dalo predugo igrat a kad sam uzeo 6600GT ona je imala onaj bug sa teksturama pa mi se nije dalo patchirat kad su vec tada izasli drugi naslovi... Mogao bi ponovno isprobati sa X1800GTO makar nakon CoD2 multiplayera sve pucacine su mi dosadne, pogotovo u singleplayer modu |
Postovi: 9,067
Otisli smo u OT, ali istina je to sto si rekao. Probao sam nakon MPlayera igrati COD2 SPlayer, HF, Quake, ali to nije niti sjena MP CoD2 igri. Tako mi je naporno, dosadno, monitono i sve se giba po rutini. Sto MP ucini od covjeka. ![]()
___________ Just atha x |
#14 | |
Super Moderators
Postovi: 17,485
Bog te... Instalirao sam COD2 demo-DX7, ide čisto pristojno. |
#15 | ||
Postovi: 2,458
Nego ciji je to P3? Sto si zamjenio DFI i AMD64 za to cudo? Priznaj to je zbog ove histrije na forumu oko Intela...Na to ti nece conroe ![]() |
#16 | |
Super Moderators
Postovi: 17,485
Debeli O.T.
COMPAQ Deskpro EN. Frend ga je kupio na rashodu u firmi za par sto kunića skupa sa 17" monitorom i dovukao meni za nadogradnju. Budući da je prigorski židof-nije htio dati više od 100€ za nadogradnju pa sam se ja morao sramotit okolo i cjenjkat sa frendovima..(kao dizo je kat, žena, sitna dječica, pes i mačka...) Kaj više radim na tom kompu više mi se sviđa, sve će mi biti žao kad ga budem vraćao... Naravno-nema ni jedne opcije za overclock ni proca, ni meme, FSB-a, to je bilo zamišljeno kao konfa za rad-vele mi frendovi da onda Intel ni nije imao điđe za overclock na svojim pločama. Uglavnom-dobra konfa za te pare. Ja sam još uvijek na svojoj staroj konfi-eventualno nadogradim sa X2 ili jačom grafom... |
#17 |
Ex-Gastarbajter
Postovi: 5,465
nije imao na ploči, nema ni sada. samo ove 975 ako se ne varam. ali ako ima neki programčić za clockat iz win... ![]() |
#18 |
Postovi: 587
ako nas to ceka onda se treba strpiti za kupnju kompova jer ce u pocetkom 2006 izaci ddr3, a malo kasnije gfafe sa dx10, ionda ljijepo kupis maticnu za to i jednog conroe-a, i nemas frke bar cistu godinu ali tko ce cekati do onda . |
#19 |
Ex-Gastarbajter
Postovi: 5,465
gledaj, ako misliš nešto čekat, onda ćeš uvijek čekat. kada dođe vrijeme treba stati na loptu i reći. Kupujem komp. moj je zasada sasvim solidan. vrti mi COD2 i to je sve šta mi treba. ostalo nije tolko power consuming tako da... |
#20 | |
Lokacija: Sv. Nedjelja
Postovi: 1,814
![]() Ja cu sebi kupit jaci proc i 2x1GB rama i to je to... Kad dodu igre koje nemogu igrat ili cu prestat igrat ili novi komp, ali sumnjam da ce to bit tak brzo.
#21 | |
music freak
Lokacija: Sibenik
Postovi: 3,316
..nece,cekaj kad crysis izadje ![]()
#23 |
The Geek Wants Out
Lokacija: xxx
Postovi: 1,193
Evo još malo scena iz igre koje su prije par dana procurile na net i odmah povučene na zahtjev Crytek-a i EA... http://forums.tweakguides.com/showth...2730#post42730
#24 |
Prečupavi mod
Postovi: 9,127
Ovo je brutalno, PREBRUTALNO dobro! Kad to treba izac? ![]()
Member of PCE 100+kg demolition squad Pozz, nezz, ojzz, jbt, owak, onak, inst, bzvz, svst, kuiš, neam, dns, nzm, oc, went, graf, laikam, oču, neču, e ovako, e sad, probo, neče, psmtr, ne beliiwam, ugl probo o5, tkđ neradi, pčkmtrnu, mslm onaak haaalo, reko dbr, stv, dali, jeli, zato jel, jer mi može neko, rispekt, thx......... ...wau, radi, zkn, pozz!?!?11 |
#27 |
The Geek Wants Out
Lokacija: xxx
Postovi: 1,193
A je*** uvijek nas nekako navuku ![]()
