Staro 21.06.2006., 23:13   #1
Mar
Suit up!
Mar's Avatar
Postovi: 5,975
Experimentalni server
Evo dignuli smo CSS server - ip: 161.53.144.219, ping oko 40ms na dsl 512kbps
Uskoro mozda dodje i COD2 (tko zna kako konfigurirati cod2 servere na linuxu nek se javi na pm).
Postajte ovdje svoja iskustva sa serverom (ping/lag i slicno).
: quake : : quake : : quake : : quake : : quake :
- Barney Stinson
Zadnje izmijenjeno od: Mar. 21.06.2006. u 23:25.
Staro 21.06.2006., 23:58   #2
RAK
Feldwebel
RAK's Avatar
Datum registracije: Feb 2002
Lokacija: bolnica
Postovi: 3,739
Autor Mar
isto kao i kod Windowsa ako host odradi svoj dio posla.
Tih kao mačka
Brz kao gepard
Jak kao lav
Elegantan kao leopard
Nisam to ja, to je moj komp.
Staro 23.06.2006., 02:31   #3
Mar
Suit up!
Mar's Avatar
Postovi: 5,975
Nitko? Niti da ste probali?
- Barney Stinson
Staro 23.06.2006., 12:22   #4
MOrdecai83
Keeper of the Nine Keys
MOrdecai83's Avatar
Postovi: 193
Gdje se upise ip?
L-L-L-Look at you, Hacker. A pa-pa-pathetic creature of meat and bone, panting and sweating as you r-r-r-run through my corridors-s-s. H-h-how can you challenge a perfect, immortal machine? - SHODAN
CPU : AMD 64 X2 4600+ / 2400Mhz (Sckt AM2)
CPU COOLER : Stock
MOBO : Gigabyte GA-M59 SLI-S5 (BIOS - F8)
RAM : 2x1GB SuperTalent CL4 (4-4-3-8) PC6400 DDR2-800MHz
GPU : XFX 8800GT 512MB "Alpha Dog Edition" @ 710/1720/1030
POWER SUPPLY : Thermaltake Toughpower 600W PSU
CASE : Thermaltake Armor Jr
HDD : 2 x Seagate 320GB HDD SATA2
DVD-RW : Pioneer DVD-RW R-110
MONITOR : BenQ G2400W 24" 5ms LCD 1920x1200
MOrdecai83 je offline   Reply With Quote
Staro 23.06.2006., 13:54   #5
Mar
Suit up!
Mar's Avatar
Postovi: 5,975
U konzolu "connect 161.53.144.219"
Ili steamov server browser.
- Barney Stinson
Staro 23.06.2006., 21:48   #6
Mar
Suit up!
Mar's Avatar
Postovi: 5,975
Evo server radi bez greske. Isproba sam ga od kuce i ping je 40 na 512 dsl-u.
Ako ima jos ekipe slobodno igrajte - ovaj server nema pravila i modova, ali uskoro dolazi counter bet, admin mod i mani plugin.
- Barney Stinson
Staro 23.06.2006., 22:19   #7
MOrdecai83
MOrdecai83's Avatar
Postovi: 193
Jos malo i spajam se i ja... Moram cekati da mi se update-a CSS...nisam vec dugo bio online na Steam-u...
Nadam se da ce biti ekipe koja ce zaigrati to cesto...
CPU COOLER : Stock
Staro 24.06.2006., 16:41   #8
tutix
tutix's Avatar
Postovi: 4,069
Ajd ako mi može netko objasnit za CSS, šta moram imat, znam da se nešto moralo skidat s interneta? Inače ja bi igrao isto s vama ako mogu...
Staro 24.06.2006., 20:36   #9
Mar
Suit up!
Mar's Avatar
Postovi: 5,975
Moras imati Half Life 2 original - ne originalnu piratsku kopiju, nego original ,
Ili ako imas kreditnu karticu instaliras steam sa www.steampowered.com i onda skines igru koju zelis preko neta.
Zgodna je stvar sto nemoras imati cd-ove (glavno da imas username/pass) i neki cd key s kojim si logiran na steam.
I onda iz bilo kojeg dijela svijeta mozes downloadati igru na svoj komp i igrati bez potrebe za cd-om.
- Barney Stinson
Staro 24.06.2006., 20:39   #10
iveumag
zippo61_junior
iveumag's Avatar
Postovi: 1,296
Stavite i od COD2
iveumag je offline   Reply With Quote
Staro 24.06.2006., 20:59   #11
Mar
Suit up!
Mar's Avatar
Postovi: 5,975
Ocemo, samo kako je to na faksu nevirujem da ce izdrzati dulje od 15.-20. srpnja.
Ali od 9. mj se opet biti u pogonu ako bude sreće.
- Barney Stinson
