Staro 21.04.2006., 02:49   #5071
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
Autor Costa
Vaš score odgovara a njihov 189 a piše 194 - kaj neko izašao ili je greška? Inače jel igraju sa PB-om ili...
IT IS EASY TO KILL FIVE HUNDRED NOOBS. BUT THERE IS STILL FIVE HUNDRED AND ONE AND YOU ARE OUT OF AMMO!
1oo1
NOOB - POWER IN NUMBERS!
Good judgment comes from bad experience and a lot of that comes from bad judgment.
MisterM je offline   Reply With Quote
Staro 21.04.2006., 12:13   #5072
Hrconja
Hrconja's Avatar
Postovi: 1,624
Evo dokaza da chitevi rade savršeno na PB
"Call Of Duty 2 Multiplayer external wallhack
programmer: RedGhost
requirements:
windows 2000/windows XP
if you are having issues with windows 2000
please contact me and i'm sure we can work it out
usage:
launch Call Of Duty 2 Multiplayer 1.2
minimize to desktop and run cod2_wh.exe
x-fire:
can be used with any version of x-fire
changes 0.1:
-first release
contact:
bp2626@yahoo.com
irc.freenode.net (#flatassembler, #asm, #osdev, ##c)
/msg RedGhost
and here is a screenshot of it being used on punkbuster for doubting little kids like cod1989:
http://img46.imageshack.us/img46/974/pb2fp.jpg "
" Hey,
This is another update to the CoD 2 Wallhack by me. This version features:
Quote:
Originally Posted by Readme
Features: Enemy-only/deathmatch Wallhack
Enemy-only/deathmatch Name ESP
Dvar Hack
Compatibility with CoD 1.2
Undetected by PB as of (17/04/2006)
Credits: XWaRloRDX
Thanks to: 2ci "
ja ne koristim cheateve narafno, samo sam vam htio pokazati te quoteve sa jednog foruma
Hrconja je online   Reply With Quote
Staro 21.04.2006., 12:19   #5073
Costa
Costa's Avatar
Datum registracije: Aug 2003
Postovi: 3,193
Autor MisterM
Mozhda je netko josh nakratko bilo al ne sjecham se vishe. Uglavnom klali su nas sam tak. Rijetko kad fulaju tako da smo imali shanse jedino ako prvi ispalimo. Server je 1.2 s ukljuchenim PB-om.
Staro 21.04.2006., 12:26   #5074
Hrconja
Hrconja's Avatar
Postovi: 1,624
Staro 21.04.2006., 12:37   #5075
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Hrconja aj pukni koji zanimljivi screen iz filma ako si ga skinija... BTW zanimljiva informacija!
G0RKI je offline   Reply With Quote
Staro 21.04.2006., 12:43   #5076
Hrconja
Hrconja's Avatar
Postovi: 1,624
ma jesam, al neće skrinije uslikat
uslikam ga i onda je crno samo?
evo par manjih
20mb svaki
http://nc.elitecoders.org/cheats/cod...rs.cjb.net.wmv
ova 3 su sa aimbotom onaj od 207mb je wh+nofog i takva sranja
Staro 21.04.2006., 12:48   #5077
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Probaj sa PrintScreenom obicno onako bez nekog programa pa u paintu sacuvaj... moralo bi moc!
Staro 21.04.2006., 13:10   #5078
Hrconja
Hrconja's Avatar
Postovi: 1,624
to ssam i radio. u paintu ima ta slika. al kad ju sejvam, bude samo crni screen.
a lol
pa skin moraš to vidit u pokretu. barem ona 3 mala
e i daj mi pošalji oc bilble ako može na hrconja@gmail.com
Zadnje izmijenjeno od: Hrconja. 21.04.2006. u 13:35.
Staro 21.04.2006., 13:25   #5079
RAK
Feldwebel
RAK's Avatar
Datum registracije: Feb 2002
Lokacija: bolnica
Postovi: 3,739
Autor Hrconja
Thanks to: 2ci "
Otkrismo toplu vodu. Svaki novi hack će biti skriven za PB. Trenutno postoje tri takva. Jedan od njih je multihack koji po tradiciji radi odlično za cheatere. No već za nekoliko dana budu detektirani i opet po starom. Opet netko napavi novi, kojeg ne vidi PB. Veći je problem Ovaj smrad 2ci. Taj prodaje hackove koji se ne mogu otkriti za 35$.
S druge strane, svaki hack se prije ili kasnije otkrije. A onda udri po seronji koji ih koristi.
Tih kao mačka
Brz kao gepard
Jak kao lav
Elegantan kao leopard
Nisam to ja, to je moj komp.
Staro 21.04.2006., 13:50   #5080
Emissary
ČLAN FKTa
Emissary's Avatar
Datum registracije: Jul 2004
Postovi: 2,264
Šta je sa xPsychom, nema ga baš na forumu zadnjih dana?
Staro 21.04.2006., 13:58   #5081
maX
maX's Avatar
Postovi: 7,326
Jos je danas LAN-u tak da nema pristup interentu, jucer sam i ja bil, ali sam otisel doma... Inace ja sam ga vidio kak igra i imam neke screenshotove na kraju i mogu potvrditi njegovu igru!
Staro 21.04.2006., 14:19   #5082
RAK
Feldwebel
RAK's Avatar
Lokacija: bolnica
Postovi: 3,739
Želim obavijestiti cijenjene igrače kako od dana današnjeg imamo potpuno funkcionalan PAM mod. U svega nekoliko zahvata se može prilagoditi tako da nitko niti ne vidi razliku između njega i trenutnog moda, osim natpisa pri vrhu ekrana i drugačijih pravila u igri.
Oni koji su igrali na PAM modu znaju o drugačijim pravilima koja vrijede. Tako se u SD ekipe automatski zamjene i aneri idu igrati na njemačku stranu i obrnuto. Pravila oko vrste oružja su drugačije definirana, ali to ne bi mijenjao jer nije fora. Onda je samo jedna bomba, određeni broj mitraljeza i sl.
Htio bi čuti glas naroda o tome želite li igrati takvu vrstu igre. Recimo da bi ga postavio na par dana, tako da se izguštate, vidim reakcije i možda spojio PAM i PS u cjelinu. Dakle, funkcionalnost PS-a i pravila PAM moda. Client side bi ostao nepromijenjen. Igrali bi PUB pravilo da bi izbjegli fijasko oko stiskanja F tipke kada je igrač spreman. Ili bi poštrikao neko drugo tako da to ne pita.
Za one neupučene, PAM mod je u osnovi isti kao i naš PowerServer mod, što je logično jer ga je radio isti tvorac, Worm. Worm je već u početku naglasio kako ne misli raditi mod koji će totalno izmjeniti igru sa vrištanjem, avionima i sl. Tako su oba mod default igra sa određenim sitnijim podešavanjima i dodatkom informacija za igrače (vidjeli ste poruke i one zastavice).
PAM mod nema te zastavice i malko se razlikuje po tome, ali je gotovo identičan onoj konfiguraciji koja je na serveru. Ono što je novo su pravila koja su određena. U PAM modu admin može birati između nekoliko pravila po kojim se igra igra. Ona govore koliko koji tim ima oružja i koje vrste, postoje li ograničenja na neko oružje, koliko traje partija, do koliko se igra i sl. U pola partije se ekipe zamijene za strane i nastavljaju igrati. Pobjednik je onaj koji u obije runde više skupi bodova. Vrlo zgodno za igranje. Neki bi mogli biti zbunjeni prvu partiju, ali već sljedeću bi igrali kao da PAM mod igraju cijeli život.
I ovaj PAM mod sam podesio tako da sam izbacio loše stvari iz verzije v1.2. I opet su izbačene animirane zastavice, spawn u Dubravi (Župi Dubrovačkoj, Trsatu ili sl.), i mape su malo optimizirane.
Tih kao mačka
Brz kao gepard
Jak kao lav
Staro 21.04.2006., 14:26   #5083
MRKONJA
M.U.P.
MRKONJA's Avatar
Datum registracije: Sep 2004
Postovi: 2,277
Ostavi par dana da vidimo kako će nam iči u praksi.
MRKONJA je offline   Reply With Quote
Staro 21.04.2006., 14:37   #5084
maX
maX's Avatar
Postovi: 7,326
Autor MRKONJA
Slazem se, ne mozemo reci nase dojmove ako ne vidimo!
Staro 21.04.2006., 15:50   #5085
Tomislav_m16
Pan,osvježi DAN !!
Tomislav_m16's Avatar
Lokacija: Krčma
Postovi: 3
bok max
Je ko novi došel na LAN ko jučer nije bio?
Tomislav_m16 je offline   Reply With Quote
Staro 21.04.2006., 15:51   #5086
Hrconja
Hrconja's Avatar
Postovi: 1,624
JOOJ pa zupy NARAVNO DA HOĆEMO PAMM!!!
e, može rak pls no fog na hrconja@gmail.com
HVALA!
Staro 21.04.2006., 16:07   #5087
Ramses_III
kapetan Janez Ibrahimovič
Ramses_III's Avatar
Lokacija: Novska
Postovi: 265
OK, znam da vjerojatno mrzite ovakva pitanja, ali ne da mi se čitati ovih 150 (!) stranica, pa bih vas lijepo molio da mi kažete jel na server od pc eksperta može doći svatko i kako uopće upasti na njega, ili mora biti član PCE tima, jel smije biti xxxxxxx igra i sve što smatrate korisnim za one koji ne znaju.
Intel P4 2666 MHz, Northwood
ASUS P4P800-X
512 MB PC2100 DDR
GeForce 4 Ti4200
HDD Seagate Barracuda 120GB
MS Gold MS-400ATX P4
Zadnje izmijenjeno od: E.T.. 22.04.2006. u 14:24.
Ramses_III je offline   Reply With Quote
Staro 21.04.2006., 16:07   #5088
maX
maX's Avatar
Postovi: 7,326
Skinul sam ovaj veliki filmic, prejebeno Trebal bi to probati, samo za foru!!!
Staro 21.04.2006., 16:38   #5089
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Hrconja evo linka OC Bible zadnja verzija...
Joj Rak morat cu se malo uputit u ove nove vode..jos nisam proba zaigra od kada je server prisa na verziju 1.2 a ima sve potrebno za instalrat! Koja san ja lincina! : hitthewa
Staro 21.04.2006., 16:49   #5090
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Ja sam za PAM.
Staro 21.04.2006., 17:49   #5091
Hrconja
Hrconja's Avatar
Postovi: 1,624
pa reko sam da je lud filmich, samo šteta kaj je prevelik za vas sa paketima.
ja sam još ovaj mjesec na flatu, tak da uživam
rak, daj pošalji mi nofog pliiz hrconja@gmail.com
Staro 21.04.2006., 23:30   #5092
xPsycho
xPsycho's Avatar
Postovi: 963
Autor RAK
Zanimljiv log sam našao na serveru. Ovih sam dana prilično bio zabavljen modom, tako da na logove i nisam obračao pažnju. I eto što sam pronašao.
www.inet.hr/~gsenfner/sv_cheat.log
Mislim da je svima jasno što je ovdje napisano i što to predstavlja. Ja ne bi davao neke komentare.
sorry kaj se nisam javio u vezi ovoga (bio sam na lan partyu)
stvarno neznam kaj bi rekel
ali mislim da je to zbog ovog što sam mjenjao seta com_maxfps u config fajlu. tj. da mi FPS bude veci u igri drugo mi nist ne pada na ideju....
to sam još promjenio kad su bili popularni jumpovi tj. exploiti na mapama pa sam negdje procitao da ako je FPS veci od 125 da se može i više skočiti. Stvarno nemam ideja
xPsycho je offline   Reply With Quote
Staro 22.04.2006., 01:43   #5093
Amdejac
Amdejac's Avatar
Datum registracije: Jun 2003
Lokacija: Kuća
Postovi: 5,400
Autor Ramses_III
OK, znam da vjerojatno mrzite ovakva pitanja, ali ne da mi se čitati ovih 150 (!) stranica, pa bih vas lijepo molio da mi kažete jel na server od pc eksperta može doći svatko i kako uopće upasti na njega, ili mora biti član PCE tima, jel smije biti crackana igra i sve što smatrate korisnim za one koji ne znaju.
PCE nije tim nego sekta. Pošalji PM MM-u. On je zadužen za financiranje sekte.
Asus N750JK (Upgrade)
MBO: Asus N750JK
RAM: 2x8 Gb PC3-12800 DDR3
PSU: Asus Li-ion 69486 mWh
OS: Windows 8.1
Monitor: 17,3 LCD (FHD)
Net: Intel AX210 NGW
Net: TP-Link Archer TX55E
PSU: Xilence, Bronze 550W
Monitor: Samsung
VGA: ATI RX570, 4 Gb
HDD: NVMe 1 Tb, Patriot
PSU: Inter-Tech SP750
Monitor: Samsung
Staro 22.04.2006., 02:22   #5094
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
Autor AMD
homers2005@gmail.com
1oo1
Staro 22.04.2006., 02:27   #5095
Virus7
Datum registracije: Jul 2003
Postovi: 800
Nazalost mene nema do utorka na serveru
razlog pise u sigu pod VGA
Virus7 je offline   Reply With Quote
Staro 22.04.2006., 02:29   #5096
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Autor xPsycho
Ja sam takoder promijenio taj seta com_maxfps, stavio sam 800... Nisam uocio nikakve vise skokove niti nista... FPS mi je redovito veci od 125 fps...
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 22.04.2006., 02:33   #5097
Facelessone
Facelessone's Avatar
Postovi: 4,204
Autor Panzer
također....na 250..
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 22.04.2006., 02:34   #5098
atha
atha's Avatar
Postovi: 9,067
ajde ajde, to vrijeme che prochi brzo.
a i ne brini, mi chemo kempati umjesto tebe na ormaru.
___________
Just atha
x
Staro 22.04.2006., 02:35   #5099
Virus7
Postovi: 800
Autor atha
hvala ti puno i nemoj da mi ormaric ostane usamljen!!!
@MM dali ti mogu lovu uplatiti u obliku bon-a za mob jer ako ja budem isao u banku to ces se nacekati???
Zadnje izmijenjeno od: Virus7. 22.04.2006. u 02:45.
Staro 22.04.2006., 02:42   #5100
atha
atha's Avatar
Postovi: 9,067
ni govora,svaki dan chu vojnichke chizme odlagati u njemu.
___________
Just atha
x
