Staro 31.03.2006., 16:59   #1
Kera
Postovi: 41
Cambridge SoundWorks GIGAWORKS S750
Jel ima tko te zvučnike doma? da mi malo kaže kako to radi...da mi kaže nešto o njima...
Dal se isplati to uzeti? jer ja ih netrebam za igre ili tako nešto nego SAMO za mjuzu slušat.
Jel ima koji sustav jači od njih?
Kera je offline   Reply With Quote
Staro 31.03.2006., 17:01   #2
Kera
Postovi: 41
Sustav je 7.1
Sateliti imaju 70rms (dvosistemci)
Subwoofer ima 210rms (8'' ,3 zavojnice po 8 ohm)
_______________________________________________________________
Technical Specifications
Power Rating:
700 Watts RMS Total
700 Watts Total System Burst Power
Front Satellite Speakers: (Rated @ 8 ohms @ 0.1% THD @ 1kHz, 2 Channels Loaded)
70 Watts RMS per channel
Side Satellite Speakers: (Rated @ 8 ohms @ 0.1% THD @ 1kHz, 2 Channels Loaded)
Rear Satellite Speakers: (Rated @ 8 ohms @ 0.1% THD @ 1kHz, 2 Channels Loaded)
Center Satellite Speaker: (Rated @ 8 ohms @ 0.1% THD @ 1kHz, Single Channel Loaded)
70 Watts RMS
Subwoofer: (Rated @ 8 ohms @ 0.2% THD @ 70Hz, Single Channel Loaded)
210 Watts RMS
Signal-to-Noise-Ratio:
99 dB
Overall Frequency Response:
25Hz to 40kHz
Staro 31.03.2006., 17:20   #3
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Autor Kera
Po meni se ne isplati to uzet... Kaj ce ti 7.1 za muziku slusat?!
Kupi si rade neko stereo pojacalo i kvalitetne zvucnike i to je to... Makar rabljeno uzet...
Kolko uopce kostaju ovi zvucnici?
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 31.03.2006., 18:27   #4
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
Kažeš samo za muziku a gledaš 7.1... hmmm
Hi-Fi stereo i gotovo. Evo Panzer je rekao šta treba
žmnpp
buljo je online   Reply With Quote
Staro 31.03.2006., 19:13   #5
Kera
Postovi: 41
ma imam ja doma razglas od diskoteke. ali to mi je preveliko. ogromno. mislio sam uzeti gigaworks a ovo prodati. jer snaga od 700rms;tj 70x7 i1x210rms mi se sviđa. i mislim da bisviralo jako. ne zanima me 2+1 jerje preslabo. kad se spoji svih 7 zvučnika i podijele se po sobi to je efekat ko da imaš dva razglasna zvučnika i neko snažno pojačalo. inaće je cijena 2940kn za gigaworks. ili dva snažna ili više slabijih. to je to.
i mislim da ću uzeti to
Staro 01.04.2006., 02:09   #6
Panzer
Panzer's Avatar
Postovi: 1,814
Imam doma 2x150W sony floorstandere, 4x120W bookshelf i woofer od 150W, pa slusam na stereo modu, tj. 2 zvucnika i woofer... Ostale upalim kad gledam film, igram igre i tak jer onda dodu do izrazaja...
Neznam, radi kak hoces, ali osobno ja bi samo za muziku kupio stereo pojacalo, par jakih, kvalitetnih zvucnika i eventualno woofer (makar nevjerujem da bi trebalo) i ziher sam da bi sviralo jace, kvalitetnije, muzikalnije od ovih megaworksa...
Pozdrav
UPGRADED...
Staro 01.04.2006., 04:01   #7
Archangel
Archangel's Avatar
Lokacija: Zagreb (istok)
Postovi: 60
Pa ali šta će ti 7.1 kad kod slušanja muzike iskorištavaš samo 2.1 od tog sistema. Svoj prijedlog nasljeđujem od ljudi prije i mislim da ti se ne isplati.
Inače zvučnici su mi bili na testu i mogu samo pohvale reći za zvučnike koji se nalaze unutar industrije računala, naravno govoreći o tim zvučnicima.
cheers
Zadnje izmijenjeno od: Archangel. 01.04.2006. u 11:11.
Archangel je offline   Reply With Quote
Staro 13.04.2006., 12:39   #8
Kera
Postovi: 41
Od kud tebi da za slušalje mjuze iskorištavam samo 2.1?? to je glupost....svih sedam se iskorištava....ili u mojem slučaju svih 5+1 jer sam uzeo megaworkse
Staro 13.04.2006., 13:07   #9
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
Autor Kera
Znači ti imaš surround muziku doma?
Svih 5 kanala imaju posebno svoj zvuk?
žmnpp
Staro 13.04.2006., 13:14   #10
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,471
ja bi rađe dva zvučnika + pojačalo nego gigaworkse...
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 13.04.2006., 13:17   #11
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
Naravno se podrazumjeva samo slušanje mjuze i ja bi.
žmnpp
Staro 13.04.2006., 13:43   #12
Kera
Postovi: 41
Ako slušam na preko računala onda koristim 5+1 zvučnu karticu.... a ako odlučim spojiti nešto drugo kao npr. mp3 player ili cd player onda koristim OVO:
Onda sviraju svi kanali. Uz malo znanja i vremena sve se može rješiti.....uopće nije problem
Staro 13.04.2006., 14:04   #13
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
Al to je običan zvuk ajmo reč stereo, za te novce se mogu kupit ok HiFi zvučnici koji imaju bolji zvuk od Gigaworksa.
Imao sam ja jedno vrijeme 5.1 sustav doma al mi je to bilo bzvz pa sam se vratio na "staromodni" stereo.
Istina da su filmovi i igre bolje zvučali al mjuza nije.
žmnpp
Staro 13.04.2006., 22:55   #14
Kera
Postovi: 41
svatko ima svoj ukus..... meni zvuk mora ići sa svih strana! ne samo s dva kuta....
ali hebiga to je samo moj ukus
Staro 14.04.2006., 00:01   #15
Archangel
Archangel's Avatar
Postovi: 60
Ajd dobro ja imam dva mono bloka s dvije 30tke(dinaudio) kutije kucne izrade te zatim dva analogna pojacala marantz od po 200W sinusne snage sa kućno napravljenim trosistemcima. Imam par recivera i bla zvučnika to nije poanta sta ti imas doma nego je poanta da se od ovog zvučničkog sistema moze dobit 2.1 zvuk na muzici, a 2.1 moze biti na 15 zvučnika...
Ja tvrdim da bolji sistem s manjim brojem kvalitetnijih zvučnika može imati bolji zvuk od gro neusklađenih
cheers
Staro 14.04.2006., 00:05   #16
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
Baš o tome ja govorim..
žmnpp
Staro 14.04.2006., 10:37   #17
Kera
Postovi: 41
Pa i ja sam imal razglas iz diskoteke doma. Imal sam dva zvučnika od 500rms, 380mm bass,trosistemci. Mikseta sa equlizerima od 8 kanala, crossfader,efekti i pojačalo od 2KW. Ali to mi je bilo preeeeeeeveliko i nisam imal kamo staviti pa sam prodao. Pa sam odlučio kupiti megaworkse jer su mali i daju pun kufer snage. Dobra stvar je da ne moraš tražiti mjesto za njih....staviš ih kamo ti padne na pamet. ali dobro....to je moj ukus. O tome se ne raspravlja.
Staro 14.04.2006., 21:26   #18
Panzer
Panzer's Avatar
Postovi: 1,814
Autor Kera
Ja imam doma 6.1 sistem, koji sam slagao (skupljao pare) nekih 7-8 mjeseci, a kad slusam ziku rade samo 2 zvucnika (stereo) evetualno bass upalim...
Imao sam i ja razglas doma, 2x300 i bass 400W (aktivni monitori i bass), isto 8 kanalna mikseta, i kaj bi s time? Jako je pun k..., a netreba mi jace od ovih mojih... Uglavnom kak je neko rekao vec, bolje 2 kvalitetna (velika) nego puno nekvalitnijih (manjuh) zvucnika... To kaj ti hoces da ti muzika ide iz svih kuteva, to je tvoja stvar. I ak tezis kvalitieti, ziher neces prek onog splitera slusat... Eto, to je moje misljenje... Pozdrav!: cheers2
UPGRADED...
Staro 15.04.2006., 01:41   #19
Doom
Émile Flournoy
Doom's Avatar
Lokacija: Chicharija
Postovi: 1,534
Ja doma u dnevnoj sobi imam entry level audiofilski stereo sistem koji mi je nezamijenljiv kada govorimo o prirodnosti zvuka kod CD-ova ali mi je za prostornost zvuka draži sony one box HT sisitem kojeg imam u radnji jer koristim stereo CD + Dolby prologic 2 ili Cinema ex mod rada. Osobito su mi dragi vokali koji su jaci i jasniji jer se filtriraju i idu kroz centralni zvučnik. Kada sam kupovao taj HT ocekivao sam da ce ti modovi samo degradirati zvuk jer sam navikao slušati glazbu bez ukljucivanja raznih efekata ali baš suprotno. Zvuk je jasan, prostran i tocno osijecam raspored instrumenata u prostoru oko mene. Posebno me impresionirao 5.1 ch SACD koji zvuci bolje nego iti jedan cd koji sam slušao na svom pažljivo odabranom audifilskom sistemu.
To je moje mišljenje i s njime se audiofili na ovome forumu nemoraju složiti ali ima dosta ljudi koji kupuju skupe HI-FI komponente a koriste ih za slušanje Cd-ova sprženih iz MP3-ca pa mislim kako im je ovo bolje riješenje. Znaci taj Gigaworks+ kvalitetna zvucna ili najnolje kvalitetniji one box HT sisitem.
Staro 15.04.2006., 02:42   #20
Panzer
Panzer's Avatar
Postovi: 1,814
Autor Doom
Koji model sony-ja?
UPGRADED...
Staro 15.04.2006., 03:23   #21
Doom
Émile Flournoy
Doom's Avatar
Postovi: 1,534
Ovaj: http://www.svijet-medija.hr/product_...ame=Kucna_kina
Mozda jedini One box sistem koji mi se svidio. koristim ga 100% za mjuzu,
najviše onu sa digi satelitske. Kod njega volim PL2 i sub ali zvuk Camridge audio + Tannoy kombinacije je neusporedivo kvaliteniji posebno za Blues, Rock i sl. Ja bih također preporucio onome tko ima novca i vremena da složi Denon + Dali sistem za HT koji ce se dobro snaci i u stereu ali to dosta košta.
Samo Interkonekcijski chinch između Camnridge Cd-a i pojačala me je došao 400kn ali se isplati kada slušam Cream-ovce ili Hendrix-a. SACD je vec druga prica ali je također preskup i neisplati ga se kupovati osim ako ga ne dobiješ na poklon kao što sam ga ja donio sa sony-jem. Najbolja bi kobinacija bila da kupim SACD player za doma ali mi se neisplati nakon što sam platio cd player 2000 kn. Uostalom sa sony-jevim Ht-om dobiješ SACD podršku onako usput.
sve ovisi o stilu muzike koja ce se na sistemu slušati. Za 80% današnje muzike je ovaj Ht što ga imam overkill.
Staro 17.04.2006., 15:31   #22
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,507
Autor Archangel
Ajd dobro ja imam dva mono bloka s dvije 30tke(dinaudio) kutije kucne izrade te zatim dva analogna pojacala marantz od po 200W sinusne snage sa kućno napravljenim trosistemcima. Imam par recivera i bla zvučnika...
: nuts : : nuts :
