Staro 06.04.2006., 01:11   #1
gnomisa
gnomisa's Avatar
Datum registracije: Feb 2003
Postovi: 1,556
Question 2 keksića od 512MB u dual channelu --> 3 keksića = banana?
imam u konfi dva keksa od 512MB (KINGMAX, DDR 400 MHz) koji rade u dual-channelu...i sad, nakon godinu dana, razmišljam piknut još jedan keksić od kingmaxa.....pitanje glasi: Jel gubim kaj na brzini? jel i tada u igri dual channel ili ta prednost otpada?
gnomisa je offline   Reply With Quote
Staro 06.04.2006., 01:14   #2
h3lld
Disturbed
h3lld's Avatar
Lokacija: Bogu Iza Nogu
Postovi: 1,420
ako imas 3x512 nemas vise dual channel i malo ce ti brzina opasti, ali ce ti opet ovih 512mb kompenzirati tako da ne bi trebalo biti problema......
-potpis-
h3lld je offline   Reply With Quote
Staro 06.04.2006., 01:39   #3
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Imam 2x256 DDR400 u dual chanell modu, dodao sam jos napolitanku od 512MB, ali DDR333. Ploca mi je automatski spustila frekvu memorije na 320MHz, nisam naravno imao dualchanell, ali je islo dosta brze nego samo 512MB u DualC... Sad mi je zao kaj sam prodao tih 512MB... Brijem da ti je taj DualC samo za testove poput SuperPI, Everest write, read i tak...
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 06.04.2006., 07:02   #4
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
Već sam negdje bio postao. Ovisi o ploči da li podržava dual sa 3 ili ne.
Ovo je slika iz mog manuala.
Znači ovdje se vidi kako stavit memorije ako imate 3 iste ili 3 različite da rade u dualu.
Nebi bilo loše da i vi koj put otvorite svoj manual
Po ovoj slici ispada da se ne može imat 3*512 u dualu, ali to je možda do moje ploče i intelovog chipseta
Nemam više lema!!!
Staro 06.04.2006., 09:56   #5
domy_os
domy_os's Avatar
Postovi: 18,828
Jako li je bitan taj dual channel... Razlika se ni ne osjeti. Bolje imat više memorije...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 06.04.2006., 11:20   #6
gnomisa
gnomisa's Avatar
Postovi: 1,556
Autor domy_os
pa tak nekak i ja mislim....
Staro 06.04.2006., 20:44   #7
Mar
Suit up!
Mar's Avatar
Postovi: 5,962
Zna li možda tko ako nadokupim još 2x512 (uz ovih početnih 2x512) -> dakle na 2 GB, da li cu morati rezati latencije memorije i command rate?
Radi(lo) bi se o SuperTalent CL2 DDR 400 modulima.
Ploča: DFI Infinity Ultra (NF4)
Staro 06.04.2006., 21:12   #8
Pr@ko
Pr@ko's Avatar
Postovi: 127
A najbolje je imati što više meme u dc-u! Nemože se reći da nema razlike i nemožeš na XP-u porediti 512MB u DC i 1GB u SC nikako moreš jedino iste kapacitete da bi nešto mogao zaključiti!
CPU Pentium 4 3E
MBO ABIT IC7-G
RAM OCZ Platinum Rev2 2x512MB
VGA ATI Radeon X850XTPE
HDD WDC1200JDX2; WDC800; WD740GD; WD1200JB
OKO LG F920P
POW Chieftech 420W DF
CAS Chieftech Bravo BIG
Pr@ko je offline   Reply With Quote
Staro 06.04.2006., 21:47   #9
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,314
Autor Mar
..za latencije neznam,ali ce ti najverovatnije spustiti command rate na 2,bar je meni tako bilo,ali opet ovisi koju proc imas,na venice-u je tako sigurno...
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
Staro 06.04.2006., 21:55   #10
domy_os
domy_os's Avatar
Postovi: 18,828
Nije bitno i ako spusti latencije, bitno da ti imaš 2 gige.
Prako, imao sam prije 2 x 512 MB u DC-u i sada 1 GB u singleu i znam šta pričam. Razliku se vidi jedino u benchmarcima, u normalnom radu ne.
Staro 07.04.2006., 15:00   #11
gnomisa
gnomisa's Avatar
Postovi: 1,556
kaj mislite, da si ipak ubodem 2 keksića od 256MB tak da mi svi keksići rade u dual-channelu...ploča je Intelova D915PGN
Zadnje izmijenjeno od: gnomisa. 07.04.2006. u 16:33.
Staro 07.04.2006., 16:34   #12
gnomisa
gnomisa's Avatar
Postovi: 1,556
jel dečkići?
