Staro 17.11.2025., 21:59   #4771
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,266
ATLANTA — Technology companies and developers are finally realizing that they’ll need to deal with the European Union’s (EU) Cyber Resilience Act (CRA). Fortunately, as Greg Kroah-Hartman, maintainer of the Linux kernel stable branch, explained at KubeCon + CloudNativeCon North America 2025, if you’re an individual open source developer, you don’t have much to worry about. It’s a different story, however, if your code ends up in commercial products for the EU market.
Understanding the EU Cyber Resilience Act (CRA)
Before diving into that, though, let’s have a quick refresher on what the CRA is anyway, since, as the Linux Foundation pointed out in a recent survey, 62% of developers and their companies are largely clueless about the CRA. The CRA is a sweeping set of regulations designed to establish unified cybersecurity standards for products with digital elements, hardware, software, and network-connected devices, sold or used in the EU.
The Act aims to significantly enhance cybersecurity and reduce vulnerabilities, while holding manufacturers, importers, and distributors accountable for the security of digital products throughout their entire lifecycle. That means all the way from design and development to deployment and decommissioning.
> Kroah-Hartman: Linux Kernel Maintainer on CRA Open Source Impact
Staro 17.11.2025., 22:28   #4772
Dottore
Dottore's Avatar
Postovi: 7,697
Autor Bono Pregled postova
Meni se cini da radi fluidno, gdje vidis taj lag?
Sent from my SM-S931B using Tapatalk
Testiram Ubuntu 25.10. Default
testna mašina Thinkpad L14 G1 , R5 4650u 32gb. Kad porekrenem Firefox isamo čeka loading pa pokrene. Dojam je kao da si na SATA disku iako ima NVME
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 18.11.2025., 08:36   #4773
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,706
Boot od biosa do logina je 17s
Startanje firefoxa je oko 3
Startanje Brava sa 9tabova je 2.8s
Chrome prvi start je oko 1s, ali bez tabova.
Nakon toga startanje traje cca 1-1.5s
Kod startanja browsera, vidim da zakuca procesore.
Staro 18.11.2025., 09:47   #4774
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,266
Autor Dottore Pregled postova
To ti se samo na Ubuntu dogada? Znam da kad sam zadnji put koristio da su mi Snap aplikacije ostale u pamcenju kao spore. Probaj firefox iz konzole startat pa vidi dal ikaj interesantnog ispljune da mu fali/smeta.
Staro 18.11.2025., 14:38   #4775
d0X
Kostolomac
d0X's Avatar
Postovi: 1,541
Naletio na AerynOS, čini se zanimljiva distra od etablirane ekipe iako je tek alpha. Kakva su vam mišljenja po pitanju immutable i atomic? Meni, kao laiku, se to čini dobro za stabilnost.
PSN Steam
Staro 18.11.2025., 14:58   #4776
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,266
Autor d0X Pregled postova
Na serveru? Da. Na desktopu vise pain in the ass nego koristi.
Staro 18.11.2025., 15:49   #4777
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,266
Systemd 259's first release candidate introduces Musl libc support, the innovative run0 privilege mode, and raised kernel requirements, signaling major shifts for Linux users. Drawing from sources like Phoronix and The Register, this deep dive explores features, security enhancements, and ecosystem impacts. Industry insiders will find these changes pivotal for future deployments.
> Systemd 259 RC1: Linux’s Backbone Evolves with Musl Support and Privilege Overhaul
Staro 19.11.2025., 17:30   #4778
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,108
Code:
i915 0000:00:02.0: [drm] *ERROR* [CONNECTOR:342:eDP-1][ENCODER:341:DDI A/PHY A][DPRX] Failed to enable link training
Buđenje iz sleepa traje par minuta, bez obzira jel sam spojen na dock ili ne. Kawk da njubara ovo reši?
EDIT:
https://gabrielstaples.com/common-wa...ues/#gsc.tab=0
Use a USB-C to DP (Display Port) [best], or USB-C to HDMI [ok] video cable, rather than a USB-C to USB-C cable to your monitor.
A mislim jeben odgovor, koristim USB-C to USB-C i baš to kao nije dobro...
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Zadnje izmijenjeno od: Mario92. 19.11.2025. u 18:21.
Staro 19.11.2025., 18:39   #4779
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,266
Autor Mario92 Pregled postova
Code:
EDIT:
Izgleda da je ili bug u driveru ili uopce nije podrzano...al cek malo kazes da ti se isto dogada kad dock (thunderbolt pretpostavljam) nije spojen? Mozda imas 2 razlicita problema..ajmo prvo vidjeti sto je sa thunderbolt opcijom...cekiraj ovo:
https://www.reddit.com/r/Fedora/comm...t_boltservice/
Uglavnom - dal je bolt servis instaliran i aktiviran? Dali prijavljuje kakve greske?
Staro 19.11.2025., 18:51   #4780
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,108
Nije thunderbolt, u pitanju je monitor sa usb-c kablom, LG
Bolt je intaliran (bolt-0.9.10-2.fc43.x86_64), ali ne radi, probal sam ga pokrenuti sa "sudo systemctl start bolt" ali se ugasi zato jer nije Thunderbolt nego USB-C u pitanju.
Po greški bi rekel da je unutarnji display problem zbog eDP
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 19.11.2025., 18:54   #4781
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,266
Hm...ali ako vanjski display nije spojen onda nebi smjelo biti problem. Znaci budenje is sleepa ti traje dugo cak i kad niti dock niti vanjski display nisu spojeni?
Staro 19.11.2025., 22:26   #4782
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,266
Linus Torvalds is "fairly positive" about vibe coding as a way for people to get computers to do things they otherwise could not. The Linux kernel maintainer made the comments during an interview at the Linux Foundation Open Source Summit in Seoul earlier this month. But he cautioned that vibe coding would be a "horrible, horrible idea from a maintenance standpoint" for production code.
Torvalds told Dirk Hohndel, head of open source at Verizon, that computers have become more complicated than when he learned to code by typing in programs from computer magazines. He said vibe coding offers a path into computing for newcomers. The kernel maintainer is not using AI-assisted coding himself. He said his role has shifted from rejecting new ideas to sometimes pushing for them against opposition from longstanding maintainers who "kind of get stuck in a rut."
Rust is "actually becoming a real part of the kernel instead of being this experimental thing," he said. Torvalds said AI crawlers have been "very disruptive to a lot of our infrastructure" because they gather data from kernel.org source code. Kernel maintainers receive bugs and security notices that are "made up by people who misuse AI," though the problem is smaller than for other projects such as curl.
Staro 19.11.2025., 23:45   #4783
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,108
Tak je
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 20.11.2025., 07:07   #4784
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,266
Tak je
Koji stroj? Ovaj u potpisu?
Staro 20.11.2025., 08:25   #4785
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,108
E nije
Laptop je iz potpisa,
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 20.11.2025., 09:08   #4786
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,266
E nije
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Hm...isto ponasanje imas na vise distri ili samo na odredenoj?
Staro 20.11.2025., 10:05   #4787
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,108
A ovo je na Fedori, na Mintu mislim da nisam imal taj problem, ali tam sam koristil X11 koji navodno nema taj problem iovak ionak. Izgleda da je nekaj do Waylanda, barem tak na usenetovima i BBSovima pišu
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 20.11.2025., 10:24   #4788
radi.neradi
Datum registracije: May 2023
Lokacija: Mrkopalj
Postovi: 84
Nedovoljno informacija. Insufficient information provided.
# uname -a; xrandr; dmesg; lspci; lsusb; lsmod; cat /proc/cmdline
Xrandr nam dobro dođe da vidimo podatke o monitorima.
Napravi disable 'bolt' servisa u potpunosti, u slučaju da pokušava uspostavit Thunderbolt, pa tek nakon time-outa spoji USB-C.
Kod povratka iz sleepa ali dok još nemaš vizualni prikaz, pokušaj promjeniti tty odnosno aktivnu konzolu (ili ctrl+alt+del ili nešto što znaš da radi) - ako se nakon uspotavljanja vizualnog prikaza nađeš u konzoli znači da se uređaj podigao ali nije pustio video.
Koji desktop environment i window manager su postavljeni? Pokušaj napraviti sleep iz konzole, a ne iz DE, tako da se vratiš u konzolu - tako odstraniš potencijalni problem sa Xorg, DE i WM.
Dobivaju li svi uređaji dovoljno jaku struju kroz USB-C?
Što se dešava kod povratka iz sleepa ako LG monitor nije spojen?
Pokušaj downgrade kernela napravit.
Podigni kernel loglevel na 6 ili 7.
Što se desi ako ga probudiš iz sleepa nakon pola minute?
BIOS verzija?
Imaš li koji način konfiguriranja USB-C portova u BIOS-u kao što postoji mogućnost konfiguriranja da USB portovi ostanu omogućeni čak i u sleep i powered off modu.
Testiraj Ubuntu Live image i sleep, skroz druga distribucija, da izoliraš problem na trenutnu distribuciju, konfiguraciju, kernel itd.
https://wiki.archlinux.org/title/Intel_graphics
Pročitaj točke 6.12 i 6.16, primjeni jednu po jednu, primarno enable_dc=0 i enable_psr=0, prije toga provjeri trenutno stanje sa sysctl.
Možeš pročitati i 4.2 - fastboot za i915.
Preporučam da napraviš novi kernel entry za testiranje, ili radi izmjene iz grub boot editora.
Edit: Sad vidim da si na waylandu, baš super, nadam se da si zadovoljan. /s
I dalje pokušaj direktno iz konzole stavit ga u sleep da eliminiraš problem Waylanda. Možeš i Xorg testirati, jednostavno kroz .xinitrc file na novom useru.
Možeš probati i i915.reset=1.
Ili ići putem debugiranja waylanda, upali debug log nekako..
Zadnje izmijenjeno od: radi.neradi. 20.11.2025. u 10:43.
radi.neradi je offline   Reply With Quote
Staro 20.11.2025., 14:03   #4789
Postovi: 10,234
Kako naćerati Proxmox 9 da vidi Intel iGPU, tj Card i RenderD128 device. Ako se slučajno nađete u istom problemu kao ja i izgubite x dana spajajući kraj s krajem, možda vam pomogne. Naime, radim novu PVE9 instalaciju identičnu staroj PVE8 instalaciji, prepisujem setup i ne uspijevam dobiti /dev/dri/ deviceove, dobivam "no such directory" za tu lokaciju.
lspci -v uopće ne prikazuje "kernel driver in use" pod iGPU stavkom, to mi je bio prvi alarm:
Code:
00:02.0 VGA compatible controller: Intel Corporation CometLake-S GT2 [UHD Graphics 630] (rev 05) (prog-if 00 [VGA controller])
        DeviceName: Onboard - Video
        Subsystem: Dell Device 09a4
        Flags: bus master, fast devsel, latency 0, IRQ 187, IOMMU group 0
        Memory at 90000000 (64-bit, non-prefetchable) [size=16M]
        Memory at 80000000 (64-bit, prefetchable) [size=256M]
        I/O ports at 3000 [size=64]
        Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
        Capabilities: [40] Vendor Specific Information: Len=0c <?>
        Capabilities: [70] Express Root Complex Integrated Endpoint, IntMsgNum 0
        Capabilities: [ac] MSI: Enable+ Count=1/1 Maskable- 64bit-
        Capabilities: [d0] Power Management version 2
        Capabilities: [100] Process Address Space ID (PASID)
        Capabilities: [200] Address Translation Service (ATS)
        Capabilities: [300] Page Request Interface (PRI)
        Kernel modules: i915
Problem je što želim passtru-ati te /dev/dri/ deviceove u Plex LXC, ne radim onaj klasični passtru u VM - želim da Proxmox loadira iGPU drivere.
Ispada da je problem bio u grub-u. Na PVE8 sam imao postavljeno:
Code:
"quiet intel_iommu=on iommu=pt pcie_acs_override=downstream,multifunction nofb nomodeset video=efifb:off initcall_blacklist=sysfb_init"
Dosta je tu nebitnih stvari, ali setup je ostao još iz doba kad sam passtru-ao fizičku GPU karticu pa sam mislio da će to i dalje raditi...
Na PVE9 sam morao to reducirati na:
Code:
"quiet intel_iommu=on iommu=pt"
Prije toga sam instalirao i "intel-media-va-driver-non-free", ali nisam siguran je li to i nužan korak pa ga ostavljam. To svakako nisam radio na PVE8 instalaciji.
Nakon promjena u grub-u, i915 driver je napokon loadiran i vidim /dev/dri/ deviceove:
Code:
crw-rw---- 1 root video  226,   1 Nov 20 12:21 card1
crw-rw---- 1 root render 226, 128 Nov 20 12:21 renderD128
Sad ih lako dodam u LXC dodajući par redova u lxc.conf (VIDI EDIT!):
Code:
lxc.cgroup2.devices.allow: c 226:1 rwm
lxc.cgroup2.devices.allow: c 226:128 rwm
lxc.mount.entry: /dev/dri/card1 dev/dri/card1 none bind,optional,create=file
lxc.mount.entry: /dev/dri/renderD128 dev/dri/renderD128 none bind,optional,create=file
Guglajući sam naletio na tucet postova kako je ljudima polomljen passtru iGPU-a u VM nakon upgradea na PVE9. Jest da je to malo drugačiji setup nego moj, ali možda je nešto ipak promjenjeno pod haubom, dunno.
EDIT: Morao sam na kraju podesiti passtru na sljedeći način da bi dobio hw akceleraciju:
https://www.reddit.com/r/Proxmox/com...gh_plex_guide/
Zadnje izmijenjeno od: xlr. 20.11.2025. u 17:02.
Staro 20.11.2025., 14:57   #4790
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,266
Autor radi.neradi Pregled postova
BIOS verzija?
Izvini al da ja trenutno vidim ovaj post reko bi "fuck it" i radije se drzao Windowsa. Kolega je Linux newbie pa ajmo malo lakse, baby steps. Linux je sto se power managementa na desktopu ionako malo "kaotican" a po ovome sto sam uspio izgooglat dosad je bug u i915 kernel modulu koji su vec bar 3 put krpali (kojeg li iznenadenja).
@Mario92 > s obzirom da je malo zeznuta situacija moja ti je preporuka - drzi se distre sa manje problema i koja ti sljaka kak spada. Ako je Wayland problem probaj ici u smjeru Minta i OpenSuse ...mozes probati i test Gnome vs KDE na istoj distri (imas Fedora spinove pa mozes Live lako zavrtiti i testirati, cisto da vidis dali se drukcije ponasaju).
@xlr > nice job
Staro 21.11.2025., 09:21   #4791
d0X
Kostolomac
d0X's Avatar
Postovi: 1,541
Probao PikaOS jučer, Niri i KDE Plasma GUI. Oboje izgledaju lijepo, Niri je dosta bare-bones i namijenjen kretanju tipkovnicom. KDE se čini kao dobra Windows alternativa. Odvrtio Cyberpunk2077, cca 10 fps-a manje svugdje (min, avg, max) nego Winsi. Sve opcije radile ok osim HDR-a. Nije loše, bit će samo bolje u budućnosti.
PSN Steam
Staro 21.11.2025., 12:12   #4792
strikoo
strikoo's Avatar
Postovi: 1,011
Niri meni shajna sa touchpadom i gestama
https://danklinux.com/docs/dankinstall
na Debian stable
EDIT:
Repo i paketi
https://github.com/AvengeMedia/DankL...readme-ov-file
Zadnje izmijenjeno od: strikoo. 25.11.2025. u 12:36.
strikoo je offline   Reply With Quote
Staro 21.11.2025., 12:20   #4793
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,108
Odustal sam sad od Fedore tj Waylanda i sad koristim Mint koji pak nema nativni fractional scaling, tj dela užasno. Text sam povećal na 1.2 pa ajde lakše je sad.
Međutim, wake up from sleep se čini brži ali je i dalje puno sporiji nego Winsi. Isto tak, kreiranje mobile broadband profila je potrgano zadnjih x godina, složil sam workaround ali ono, svašta.
Evo iskreno, njub sam u Linuxu, ali još uvek je to daleko od zamjene za Windowse kaj se običnog korisnika tiče. Vjerujem da se da složiti to sa zajebancijom i konfiguracijom, ali nije to to.
Probal budem videti kak mi bude na Mintu, Fedora je puno ljepša i sviđa mi se od animacija, konzistentnog sučelja (kolko tolko), i mislim da bi Linux budućnosti trebal tak izgledati. Cinnamon je grd, ko i KDE, zato jer kopira Windowse ali na lošiji način. Osobno mišljenje, jel
Al ajde, dal si bum par dana / tjedana pa ćemo videti. Hvala svima na pomoći do sad <3
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 21.11.2025., 12:28   #4794
strikoo
strikoo's Avatar
Postovi: 1,011
Pa instaliraj na Mint DE koji si koristio na Gedori
Evo iskreno, njub sam u Linuxu, ali još uvek je to daleko od zamjene za Windowse .
100% i nikad nece ni biti jer GNU/Linux NIJE windows
jako ovisi o use case i o samom korisniku.
Zadnje izmijenjeno od: strikoo. 21.11.2025. u 12:35.
Staro 21.11.2025., 12:43   #4795
Dule
Dule's Avatar
Postovi: 691
Autor strikoo Pregled postova
Potpis ko kuća. Koliko god vas ekipa pokušavala uvjeriti u suprotno, Linux još jako dugo neće biti desktop zamjena za Windows da se sve samo može plug and playat i da sve radi out of the box na svakoj mašini. To se neće dogoditi još 20 godina.
Ali ono što dobijete sa Linuxom je sloboda i kontrola. Dobijete natrag vlasništvo nad svojim računalom - jer ono radi samo ono što vi želite i ništa drugo. Neće aktivno raditi protiv vas (jer Microsoft "zna bolje" što je bolje za mene) niti pametovati što smijete ili ne smijete. Želiš ugasiti računalo? F*ck you, update time.
Da li je to vrijedno povremenih mušica i tinkeranja da stvari prorade, na svakom je da odluči za sebe.
Zadnje izmijenjeno od: Dule. 21.11.2025. u 13:11.
Dule je offline   Reply With Quote
Staro 21.11.2025., 14:55   #4796
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,108
Ali problem je kaj ne radi kaj želim, jer ne radi :P
Mislim, zezam se sad malo, ali mislim da bi se trebal community baš žešće trgnuti da naprave plug and play nekaj pa da i normalni useri mogu sa što manje boli imati alternativu. Naravno, to bi značilo da bi Winsi se isto trgnuli, iako se ne bi čudil i da ih MS ugasi u ne tako baš dalekoj budućnosti.
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 21.11.2025., 16:11   #4797
radi.neradi
Lokacija: Mrkopalj
Postovi: 84
Ne znam što želite reći pod plug-and-play, ali smatram da to imamo već jako dugo vremena. Ne sjećam se da sam imao problem sa osnovnim funkcionalnostima sustava na nekoj basic Ubuntu instalaciji, od Pentium M-a pa nadalje. Ako već odaberete zadnju verziju Fedore, a koliko me pamćenje služi koriste dosta bleeding-edge paketa i guraju noviju tehnologiju, ne možete očekivati da primjerice Wayland radi savršeno na svakom uređaju. Ako vam treba kompatibilnost i stabilnost, onda odaberite Xorg, i neki minimalistički window manager. Windows ne dolazi u paketu sa trideset različitih desktop environmenta, isto tako ne možete očekivati da na Linuxu sve hardware/software kombinacije rade bez ikakvih grešaka - previše je dinamičkih dijelova koji tvore jednu cjelinu.
@Dule - Kada se koristi i neka popularna Linux distribucija, i dalje se oslanja na odluke drugih (RHEL, Ubuntu, Debian, Alpine itd.), stoga nebih se složio da si dobio vlasništvo nad svojim računalom, već mislim da si samo zamjenio korporativni način korištenja Windowsa sa besplatnim, open-source i transparentnijim korištenjem Linuxa, ipak to ne znači da svaki korisnik čita kod i provjerava koji procesi se vrte, i dalje se oslanja na povjerenje u zajednicu. Svakako je bolje, ali nije isto kao da kontroliramo svoj sustav, jer i dalje postoje ograničenja, samo što korisnik ima mogućnost izbora između onoga što mu je više i manje prihvatljivo, pa ovisno o tome bira distribuciju i koristi ju u zamišljenim okvirima. Ako netko ima viška vremena i želi postavljati stvari kako njemu odgovaraju, isprobajte LFS.
Zadnje izmijenjeno od: radi.neradi. 21.11.2025. u 16:26.
Staro 21.11.2025., 16:39   #4798
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,266
I to je sasvim OK, ne zamaraj. Ak ide ide , ak nejde onda hebiga nejde. E sad - that said...ja sam toliko zaglibio da mi MS vise nije potreban u privatnom zivotu ali to ne znaci da mu ne raspalim tu i tamo kojeg sveca. No kaj se plug 'n' play price tice - Linux je bolji nego Windows po mom iskustvu - osim ako driveri nisu kak spada ..ili firmware za isti taj hardware...al to je do proizvodaca koji ne vide $$$ u podrsci Linux platforme. Tak je kak je
@Dule > odlican sumarum. Ta modularnost Linux OS-a je mozda i najveci problem jer korisnici nisu ni svjesni sto sve mogu sustavu raditi - sa dovoljno znanja naravno. Svaki aspekt Linux OS-a je izmjenjiv i kladim se da u gornjem slucaju bi se dalo naci rijesenje za "sporost" GUI-a ali pokraj toliko opcija - nadi distru koja ti zadaje najmanje glavobolje (citaj koja ima kombinaciju svih "modula" da tvom PC-u i tebi odgovara) i to koristi. Debugging i shvacanje sustava dolazi s vremenom.
@radi.neradi > kolega , zvala je 1984 > kazu da oladis malo. Kuzim nerdgasm dio al fakat ga pretjerujes malo...
Staro 21.11.2025., 17:25   #4799
radi.neradi
Lokacija: Mrkopalj
Postovi: 84
Korisnije bi bilo da ljudi potroše to isto vrijeme koje troše za drkanje po window managerima, distribucijama i reinstaliranje na nešto drugo. Kao i ja sad što tipkam u prazno pokušavajući nešto, kao i neki dan, pomoći čovjeku da debugira problem, njemu se neda, lakše je reinstalirat. Vraćam se u 1984 kada foruma nije bilo. Ciao.
Staro 21.11.2025., 18:15   #4800
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,266
Bas dobro da si iskljucio da ti itko salje PP pa cu ovdje formirati odgovor. Gle...vidim da imas hrpu iskustva u nekim stvarima i u tome te postujem kao clana foruma. Ali imas tako stisnut i perfekcionisticki stav kad su u pitanju teme sigurnosti i Linux da samim nastupom radis suprotno onome sto zelis. Pomogni ljudima, struke treba, zato je i forum tu al fakat olabavi malo ne prati nas FBI/CIA/KGB za svaki post koji pisemo i ne trebas tako stiskat guzicu ko da iza tebe stoji tamnoputi sa 20cm stapom. Nije sve u tehnickom znanju nego i prepoznavanju potreba korisnika i nacinu na koji pruzas support istima. Tak da...relax
