#422 |
Postovi: 8,546
Cijene budu sigurno popularne, ~1.500€ za mini-PC workstation izdanja bez pardona, posebice, jer budu ih nakrcali sa 96GB i 129GB RAM-a. Na CES-u je bilo rečeno da Strix Halo izlazi u raznim izdanjima i formatima tijekom prvog i(li) drugog kvartala ove godine. Lako moguće da Strix Halo iskombiniraju s 9950X3D, 9900X3D, te Radeon RX 9070 XT i običnim modelima, pošto su trenutno predviđeni za sljedeći mjesec. ![]()
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX |
#424 |
Postovi: 8,546
Je, to je to, na CES-u su imali hrpu tih kutijica, jer im AMD daje mogućnost da iskonfiguriraju potrošnju kak ih volja, jer ipak je mobilni APU u pitanju, tak da bude od svega svega pomalo.
#425 |
Postovi: 7,703
__________________ |
#426 | ||
Postovi: 8,546
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 18.02.2025. u 17:30. |
#427 |
All-rounder
Datum registracije: Sep 2013
Postovi: 1,342
Ovisi o cijeni... Ja se slomio i naručio 9800x3D, dosta mi je čekanja. Bio je 536e u Supernetu, past će još, ali ne bitno, pa sam povukao okidač. Uzeo Asrock B850 RS Pro, tu se moglo uštediti, ali barem znam da imam VRM bez ograničenja. 32gb CL30 meme. Valjda će doći do kraja tjedna. |
#428 | ||
Postovi: 1,707
![]() ![]() Citiraj:
Nisam ni ja bio ljubitelj, ali ovi fishtankovi i LianLi fanovi zbilja lipo izgledaju, a uvik mozes ugasit Nego, i dalje imam problem sa restartom. U međuvremenu je izašao beta BIOS, probao i niega, i dalje mi svake put zapne kad restartam iz Windowsa kompa, svaki put, 0d error code, sta bi znacio problem sa memorijom. Iz cold boota, restart iz BIOSa, live Linuxa, nikad ne zapne, samo kad restartam iz Win. Gore su Win11, zadnji driveri... Ponaša se isto i sa upaljenim ili ugasenim XMPom. Dalje, ne mogu isključiti LED kad je ugasen komp. Uvijek svijetli LED na matičnoj te na AIO od CPU. U BIOSu je podesno na stealth mode kad je komp off, ali ga svaki put ponovo upali. Pa moram gasit svakit put komp na PSU. Mislim jbt, ploca od gotovo 600E pa ovakva s*anja imam. Nikako na zelemu granu, bilo sa Intel om ili AMDom 🙈 BTW Asus ROG X870E-E Ostalo sve radi super, u iRacingu na 3x2K u full gridu sa gotovo max postavkama imam stabilnih 150-160FPS. Kad sam sam na stazi, zakucano na 164Hz.Ogranicio sam na 164 radi Gsynca. Znaci najmanje 20% bolje nego sa 14900K. Sent from my SM-S928B using Tapatalk Zadnje izmijenjeno od: jucca. 18.02.2025. u 18:09. |
#429 | |
Postovi: 8,546
Imaš možda kojim slučajem Aura Off opciju u BIOS-u pod LED lighting, jer Stealth Mode bude ti svakak držal upaljeno, jedino Aura Off gasi sve kompletno. Kaj se memorije tiče, možeš ju komotno ručno podesiti po pitanju, brzine, napona i latencija, ako je stvarno do toga da se blesira samo restart zbog RAM-a. Citiraj:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 18.02.2025. u 18:15. |
#430 | ||
Postovi: 1,707
Inace na Asus ROG Z790 je u stealth modeu gasio sve. Citiraj:
Nisam jedini izgleda, nije do memorije nego do Armory Cratea, koji izgleda pobuca nesto kad opalis restart iz Win. Koliko se sjecam, vec sam ga bio reinstalirao, no probat cu opet. https://www.reddit.com/r/ASUS/s/T1lYmukxiK Sent from my SM-S928B using Tapatalk |
#431 |
Postovi: 8,546
Da, to su te ASUS pizdarije, na prijašnjim B350 i B450 pločama sam sve u BIOS-u pogasil, jer inače se uvijek aktivira i instalira. Jedino da probaš još i kroz onaj njihov RGB softver nekaj za LED uključiti/isključiti.
#432 |
Datum registracije: Dec 2012
Lokacija: Vž
Postovi: 277
Armory crate je žestoko bloatwareovsko smeće, jedno od najvećih s kojim sam se susreo. Instaliram ja i hrpa nepotrebnih procesa se palilo i radilo u pozadini i počeo win štekati i čudno se ponašati komp općenito. Nekako sam se riješio svega s Revo uninstallerom jer kod normalne ne pobriše sve. |
#433 |
Postovi: 8,546
Da, dobro je još dok uopće nude u BIOS-u da se to sve može isključiti, makar i ostali proizvođači forsiraju slične ideje.
#434 | |
Dobro je sve.
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,519
Poslano sa mog SM-S918B koristeći Tapatalk |
#435 | |||
Lokacija: Zagreb, Črnomerec
Postovi: 2,664
![]() Citiraj:
![]() Citiraj:
![]() Ali ako se budeš htio patiti sa štelanjem RAM-a, tu onda možeš provest kvalitetnog vremena ![]() |
#436 |
All-rounder
Postovi: 1,342
Ma da, to sebi pravdam što sam potrošio 200e na ploču, a mogao sam manje Čini se u redu, ima 14 faza za proc i PCI-E 5.0 pa sam tu futureproofan na grafičke, mada znam da ni to ne znači ništa. Gledao sam testove toga i memorije, ništa to ne donosi, ali neka stoji. Curve optimizer ide na -20 ili koliko ide i to je to od štelanja.Trebalo bi novu instalaciju windowsa staviti, a to mi se opako ne da ispočetka... Vidjet ću još. |
#437 |
Postovi: 2,664
A mogao si nekih pedesetak eur manje, danas to nije dosta ni za pošteni ručak za dvoje ![]() Na 9800x3d, za razliku od prijašnjih 3d modela, možeš stavit neki overklok, uključiš PBO, staviš +200 i tako. Sumnjam da je potrebno naravno, ali možeš. |
#438 | |
mag.math.
Datum registracije: Dec 2021
Lokacija: Daruvar/Zagreb, Republika Hrvatska
Postovi: 366
#439 | |
Prvoklasni Krkan
Postovi: 5,383
#440 |
Postovi: 10,282
#442 | |
Prvoklasni Krkan
Postovi: 5,383
#444 |
mag.math.
Postovi: 366
Moglo bi se izvesti neko istraživanje što je veća opasnost po računalo, Asus AI Suite ili Asus Armory Crate. Kolega @jucca ima hardware sa najgornje police i šteta je da ga kompromitira uz pomoć ovog bloatware-a. |
#445 |
#erase startup-config
Postovi: 3,732
Složio sam 9600X na A650 chipsetu. Ugodno sam se iznenadio koliko se malo grije u radu. Nije se moglo čekati 9600 non-X. Grafika je integrirana. Sutra ću malo bolje vidjeti što može i kako radi pod Windozama i Linuxom. |
#447 | ||
Postovi: 8,546
#448 | ||
Postovi: 1,707
Super stvar, rekao bi must have za multimonitor setup. Evo kratke snimke voznje u simrigu, kako mi je sve skupa ispalo. Super zadovoljan. FOV konacno kako treba biti https://youtube.com/shorts/7oLejwIhCCQ Citiraj:
Sent from my SM-S928B using Tapatalk Zadnje izmijenjeno od: jucca. 25.02.2025. u 15:24. |
#450 | |
Postovi: 7,703
9600x prilično dobar na onboard gpu. Može zaigrati starije naslove bez problema.
