#3271 |
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,401
Ne znam što ste se toliko za log uhvatili, pa dao sam par desetaka linija. Htio sam da se vidi malo šire što se dešava. Miopija često šteti. Evo ti ovo za sada. Code:
root@fedora:~# resolvectl Global Protocols: LLMNR=resolve -mDNS -DNSOverTLS DNSSEC=no/unsupported resolv.conf mode: stub Link 2 (enp6s0) Current Scopes: DNS LLMNR/IPv4 Protocols: +DefaultRoute LLMNR=resolve -mDNS -DNSOverTLS DNSSEC=no/unsupported Current DNS Server: 192.168.1.1 DNS Servers: 192.168.1.1 DNS Domain: home Link 3 (enp42s0) Current Scopes: none Protocols: -DefaultRoute LLMNR=resolve -mDNS -DNSOverTLS DNSSEC=no/unsupported Prebacio sam se sada na enp42s0. Nisam o ovome vodio računa, moguće da sam se i nehotice prebacio s jednog na drugi kada sam zadnji put ubacivao lan u drugi uređaj. Code:
root@fedora:~# rpm -qa |grep firmware alsa-sof-firmware-2024.03-2.fc40.noarch linux-firmware-whence-20240513-1.fc40.noarch amd-gpu-firmware-20240513-1.fc40.noarch amd-ucode-firmware-20240513-1.fc40.noarch atheros-firmware-20240513-1.fc40.noarch brcmfmac-firmware-20240513-1.fc40.noarch cirrus-audio-firmware-20240513-1.fc40.noarch intel-audio-firmware-20240513-1.fc40.noarch intel-gpu-firmware-20240513-1.fc40.noarch mt7xxx-firmware-20240513-1.fc40.noarch nvidia-gpu-firmware-20240513-1.fc40.noarch nxpwireless-firmware-20240513-1.fc40.noarch realtek-firmware-20240513-1.fc40.noarch tiwilink-firmware-20240513-1.fc40.noarch linux-firmware-20240513-1.fc40.noarch iwlegacy-firmware-20240513-1.fc40.noarch iwlwifi-dvm-firmware-20240513-1.fc40.noarch iwlwifi-mvm-firmware-20240513-1.fc40.noarch libertas-firmware-20240513-1.fc40.noarch Code:
*-pci:2 description: PCI bridge product: Advanced Micro Devices, Inc. [AMD] vendor: Advanced Micro Devices, Inc. [AMD] physical id: 7 bus info: pci@0000:03:07.0 version: 00 width: 32 bits clock: 33MHz capabilities: pci msi pm pciexpress normal_decode bus_master cap_list configuration: driver=pcieport resources: irq:38 ioport:e000(size=4096) memory:fc300000-fc3fffff *-network description: Ethernet interface product: RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller vendor: Realtek Semiconductor Co., Ltd. physical id: 0 bus info: pci@0000:06:00.0 logical name: enp6s0 version: 15 serial: 2c:f0:5d:5d:72:7d capacity: 1Gbit/s width: 64 bits clock: 33MHz capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiatio n configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=6.8.11-300.fc40.x86_64 firmware=rtl8168h-2_0.0.2 02/26/15 l atency=0 link=no multicast=yes port=twisted pair resources: irq:37 ioport:e000(size=256) memory:fc304000-fc304fff memory:fc300000-fc303fff *-pci:3 description: PCI bridge product: Advanced Micro Devices, Inc. [AMD] vendor: Advanced Micro Devices, Inc. [AMD] physical id: 9 bus info: pci@0000:03:09.0 version: 00 width: 32 bits clock: 33MHz capabilities: pci msi pm pciexpress normal_decode bus_master cap_list configuration: driver=pcieport resources: irq:40 ioport:d000(size=4096) memory:fc200000-fc2fffff *-network description: Ethernet interface product: RTL8125 2.5GbE Controller vendor: Realtek Semiconductor Co., Ltd. physical id: 0 bus info: pci@0000:2a:00.0 logical name: enp42s0 version: 04 serial: 2c:f0:5d:5d:72:7c size: 1Gbit/s capacity: 2500Mbit/s width: 64 bits clock: 33MHz capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd 2500bt-fd autonegotiation configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=6.8.11-300.fc40.x86_64 duplex=full firmware=rtl8125b-2_0.0. 2 07/13/20 ip=192.168.1.111 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s resources: irq:39 ioport:d000(size=256) memory:fc200000-fc20ffff memory:fc210000-fc213fff Code:
journalctl -xe | grep setroubleshoot ne vrati ništa
Zadnje izmijenjeno od: mkey. 06.06.2024. u 22:57. |
#3272 | |
Postovi: 3,475
Odustajem. Ti si baš ne daš pomoći... ko s malom djecom... |
#3273 |
Lokacija: tu
Postovi: 3,401
shadow, ne čitaš što čovjek koji traži pomoć piše. Što očekuješ? I nije ti prvi puta da se tako ponašaš. Hvala na vremenu. Sada sam već napravio 22 edita, nema smisla. Tomek, ti cronjobovi pojma nemam što rade tamo. Možda neki update? Maknut ću te browsere pošto ih i tako ne koristim i kao pokušavam se skrasiti na librefox. Thorium je instaliran kao RPM, sada sam maknuo. A za vivaldi sam dodao repositorij, maknem i to.
#3274 |
Postovi: 641
A zašto točno mora? Znaš kako se kaže u dalmaciji, "ne moran ja ništa". ![]() Linux desktop nije server i nemaš brige da će netko preuzeti tvoj nestandardizirani kaos, i u tom slučaju ne vidim razlog zašto bi se nešto moralo... ljepota Linux desktopa upravo i je u mogućnosti izbora i slobodi customiziranja. |
#3276 | ||
Lokacija: München/Varaždin
Postovi: 4,818
Ti cronjobovi nisu uzrok problema samo me zanimalo zasto. No da se vratimo tvom problemu. Ono sto me zanimalo koja mrezna zeza i puca veza. Dakle: 1. Puca na Gigabit LAN 2. Imas instaliran ispravan firmware Mislim da saltanje mreznih nebu pomoglo. Mozes ostavit kao test sad na 2.5G cisto da iskljucimo mogucnost da je 1G kartica neispravna. Tvoj komp uvijek pita Router kao DNS server kad hoce van. Ono kaj bi trebao provjeriti ako budes u mogucnosti - kad se ponovi to sranje - jel mozes pingat router? Da nije da na Routeru nekaj sere pa je Fedora osjetljiva na to...mozda...valjda...testirat. Suma sumarum - imas skoro identican setup kao i ja - jedina razlika je GUI. TO MORA RADIT DA GA HEBES. Citiraj:
#3277 |
Lokacija: tu
Postovi: 3,401
> jel mozes pingat router? Budem probao, ali prilično sam siguran da da, jer mogu sve što sam probao pingat sa IP adresom. Torrenti rade normalno, promet teče. > TO MORA RADIT DA GA HEBES. I bit će tako, samo da mu damo malo vremena i živaca ![]() Gledao sam ovaj svoj ruter, nema custom DNS opciju. Koji bi bio najpametniji način za podesiti DNS na kompu? Prošlog puta kada sam to radio sam napravio 15 stvari, možda ipak bolje pitati nego poslije popravljati ![]() Inače, jučer nisam imao nikakvih problema, ali nisam niti palio komp uopće, pa moguće zbog toga. Danas budemo vidjeli što je na meniju.
#3278 |
Postovi: 23,521
A hebemu miša, fino postavi fiksne mrežne postavke za tu mrežnu preko je si spojen, IP, Subnet, Gateway, DNS1, DNS2. Većina operatera prilikom svoje idiot customizacije sklanja opciju custom definiranja DNS - ova jer forsiraju svoje. Fino otvori taj svoj xyz router, ako već nije u DHCP Serveru oslobodi / ostavi si xy IP adresa slobodno za klijente sa fiksnim IP adresama. Nakon toga je lako, ako zapneš onda pitaj ![]() |
#3279 | |
Postovi: 4,818
U Network Manageru...fino klik klik ![]() |
#3280 |
Postovi: 960
stubby ![]() |
#3282 | |
Postovi: 4,818
Router. Ovako doznas koje DNS-ove ti Fedora koristi: ( nmcli dev list || nmcli dev show ) 2>/dev/null | grep DNS IP4.DNS[1]: 1.1.1.2 IP4.DNS[2]: 1.0.0.2 Alternativno: systemd-resolve --status | grep "DNS Servers" |
#3283 |
Lokacija: tu
Postovi: 3,401
Opet izletilo. Pinganje 192.168.1.1 radi bez problema. Ovo i dalje ništa ne vraća. Code:
root@fedora:~# journalctl -xe | grep setroubleshoot root@fedora:~# Probao "sudo nmcli con reload enp42s0" ali to nije riješilo problem. Probao "sudo systemctl restart NetworkManager" i to je riješilo problem. Žao mi je da nisam pogledao što kaže "systemctl status systemd-resolved.service" dok problem traje, budem idući puta. Stavio sam provizorno Open DNS. Code:
[mkey@fedora ~]$ ( nmcli dev list || nmcli dev show ) 2>/dev/null | grep DNS IP4.DNS[1]: 208.67.222.222 IP4.DNS[2]: 208.67.220.220 Code:
[mkey@fedora ~]$ systemd-resolve --status | grep "DNS Servers" DNS Servers: 208.67.222.222 208.67.220.220 Vjerojatno treba jedan restart network managera da prihvati? nikky opet precjenujuje moje znanje mreža, fatalna greška.Ovo su moje DHCP postavke na ruteru. Ipak ima DNS pa sam ga i tu postavio.-> https://imgur.com/a/WjQuDGI Ovo su network manager postavke. -> https://imgur.com/RK17NXb (SS pokazuje 110, postavio sam na 100 na kraju) Meni je ovaj GUI bio toliko jasan da sam na kraju posegnuo za terminalom. Ako je GUI manje jasan od komandi u terminalu onda znaš da nešto nije u redu ![]() Code:
nmcli con mod "Wired connection 2" ipv4.addresses "192.168.1.100" ipv4.gateway "192.168.1.1" ipv4.dns "208.67.222.222,208.67.220.220" ipv4.dns-search "fedora" ipv4.method "manual" Nisam siguran zašto ifconfig kaže 111. Code:
root@fedora:~# ifconfig enp42s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.1.111 netmask 255.255.255.0 broadcast 192.168.1.255 ether 2c:f0:5d:5d:72:7c txqueuelen 1000 (Ethernet) RX packets 13638411 bytes 2278532391 (2.1 GiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 29224194 bytes 16596583333 (15.4 GiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 EDIT: ifconfig pokazuje 100 nakon reboota.
Zadnje izmijenjeno od: mkey. 09.06.2024. u 15:15. |
#3284 |
Postovi: 23,521
DHCP Server pool si stavio od 192.168.1.110 do 192.168.1.199, znači da za klijente sa fiksnim mrežnim postavkama imaš na raspolaganju od 192.168.1.2 do 192.168.1.109 + još odr, br adresa "na kraju" do 192.168.1.254. Dakle, za taj komp stavi recimo IP = 192.168.1.5, za svaki drugi ide različita IP adresa. Vidim da si našao gdje se postavlja custom DNS u routeru i na kompu, kad se već baviš svime tim, nije zgorega da sekundarni bude od drugog "davatelja usluge", u prevodu za Primarni si stavio Open DNS, za secondary stavi recimo Google (8.8.8.8). Inače bravo, sve si pohvatao ![]() |
#3287 |
Postovi: 23,521
I ne mora, jeli može CloudFlare (1.1.1.1) ? Za žuntu DNS by ISP Sticky > http://forum.pcekspert.com/showthread.php?t=91801 |
#3289 | |
Postovi: 4,818
Heads up... Citiraj:
https://www.gamingonlinux.com/2024/0...e-on-a-laptop/ ![]() |
#3290 |
Lokacija: tu
Postovi: 3,401
Novi dan, novi problemi. Naime, primijetio sam da zadnjih par puta (sada već 3 od 3 ukupno, čini mi se prvi puta da je bio problem u subotu) kad napravim shutdown računalo zaglavi u nekoj fazi i ne mrda. Dobijem crni ekran s pointerom od miša. Ne reagira na podražaje osim TTY. Shutdown kreće odavde (oko 22:15) Code:
lip 11 22:15:16 fedora systemd[1608]: Started dbus-:1.2-org.kde.LogoutPrompt@0.service. Code:
lip 11 22:18:13 fedora login[20081]: LOGIN ON tty3 BY mkey https://pastebin.com/AdgU5EqK Jedino što mi pada na pamet je sitan povremen problem kojeg imam s MX Master 3S i njegom donglom. Svako toliko (možda jednom od deset puta) kod dizanja iz standby miš kao da nije prepoznat, pa onda izvadim dongle i vratim ga u isti USB port i onda proradi. Isti problem je bio prisutan i u manjaru. Neki dan se dogodilo da je isti miš ostao prazne baterije i prestao raditi. Onda sam ga spojio na punjač ali nakon toga ga OS više nije prepoznavao odnosno primao input. Prebacio sam se privremeno na starog žičanog MX518 i nešto kasnije master je opet radio. Imao sam do jučer ugašen verbose boot, sada sam maknuo one dvije opcije iz /etc/default/grub i rebuildao grub.cfg, pa budem vidio kako će se dalje ponašati. Također bi možda bilo pametno probati s waylandom i provjeriti da li se i tamo dešava.
#3291 |
Postovi: 10,034
Ima neko vrijeme da sam se i ja vratio na Fedoru... zasad imam malo vise srece od kolege iznad. Mozda jer svaki put nakon njegovog posta triput pljunem u kantu za smece i zapalim mirisni stapic pored kompjutera ^^,
#3292 | |
Postovi: 4,818
Ili se neka apikacija ne zeli ugasiti ili te nekaj od HW hebe. Postavio si KDE da se uvijek sa clean seassionom starta nadam se a ne da uvijek vraca sve od prosli puta? Ako smatras da bi te Logi mogao zezat - probaj sa iskljucenim misem pa vidi jel se isto ponasa. Cekiraj i ovo: https://itsfoss.com/long-shutdown-li...dirty%20fix%5D Pa javi rezultate. P.S.: https://bbs.archlinux.org/viewtopic.php?id=283539 Kod mene je GDM+Gnome....just saying :P |
#3294 |
Lokacija: tu
Postovi: 3,401
Radije bih se na windows vratio nego da gnome koristim. Nije niti do jedne aplikacije, na čistom startupu isti problem. Čisti session koristim, pogotovo pošto u 90+% slučajeva koristim standby. Verbose kernel logging (kako li se to već zove) ne igra ulogu jer izgleda da x server niti ne izađe vanka nego pusti samo crni ekran s funkcionalnim pokazivačem miša. Zanimljiva situacija se dogodila tijekom testiranja gdje sam na desktopu samo konsole imao otvoren, napravim shutdown, crna pozadina, pointer i konsole ostao otvoren. Ukucam reboot, enter i ode dolje bez problema. Dakle problem je isključivo s shutdown/restart preko GUI iz menija, ne sa reboot/shutdown naredbom koje rade kako spada. Problem je izgleda riješen s prisilnom reinstalacijom/rebuildanjem nevidijinih sranja. Malo me prckao akmods i nije htio odraditi pa nakon nešto peripetija i bootanja u prethodni kernel ipak je odradio. Užasno je ovo njesra osjetljivo, i ako ne odradi do kraja ne znaš dok ne uletiš u probleme. Pustio sam ga 10 minuta i napravio reboot natrag u 11 kernel. Code:
sudo dnf remove kmod-nvidia-6.8.11\* sudo akmods --force --kernels 6.8.11-300.fc40.x86_64 Code:
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Micro-Star MSI driver: nvidia v: 550.78 arch: Pascal pcie: speed: 8 GT/s lanes: 16 ports: active: none off: DP-3 empty: DP-1, DP-2, DVI-D-1, HDMI-A-1 bus-ID: 2b:00.0 chip-ID: 10de:1b81 class-ID: 0300 EDIT: Što se tiče tih SDDM poruka, drugdje sam našao da se to može komotno ignorirati. Da ga dosta trkelja, i preporučuju ugasiti to logiranje.
Zadnje izmijenjeno od: mkey. 12.06.2024. u 21:32. |
#3295 |
Postovi: 4,818
M...da ti nije bio kernel ili driver update? Rebuild nvidia drivera zna potrajat par minuta. P.S. - znam da mnogi imaju averziju prema Gnome sucelju ali - isprobaj malo druga sucelja...najcesce su bolje ispolirani (barem po mom iskustvu) nego KDE iako nije KDE 6 los. Samo kaj sam uvijek na neke bugove naletio na koje sam popoizdio. Na gnome lupis par extenzija koje ti pasu i vozi misko. Kazem - sprobaj par dana, nemas kaj izgubiti, ak ti se nakon toga ne svidi - hebiga ![]() |
#3296 |
Lokacija: tu
Postovi: 3,401
Ne znam kada je bio zadnji kernel update, nisam pratio. Moram o tome više voditi računa. Probao sam tonu DE i KDE mi najviše odgovara, ima sve šta mi treba out of the box. A bugovi kao bugovi, nema gdje ih nema.
#3299 |
aka Edo, aka Syncros
Postovi: 1,769
Po meni je baš napravljen za brzi prelazak sa Winsa na Linux. Čak ima odmah ugrađeno da možeš instalirati .exe aplikacije. Jedino šta vrti stariju bazu Ubuntua ali nije to nešto loše, barem je stabilno. |
#3300 |
Postovi: 4,818
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16GB DDR5 / Micron M.2 2242 1TB / nVidia Geforce RTX 4050 / Windows 11 Pro Lenovo Thinkpad L15 Gen 1 || Intel Core i5 10210U / 16GB DDR4 / WD SN730 256GB / Intel UHD / FreeBSD 14.3 |
