Postovi: 8,570
Pokrenete builder, otvorit će vam prozor u browseru odakle dalje samo klikate dok ne završi proces. Na kraju dobijete patchani apk kojeg prebacite na mob i instalirate, to je to. Globalno popularna Vanced app je dobila svog nasljednika.
![]() Trenutno ju je malo komplicirano instalirati jer treba manualno, ali radi se na installeru i websiteu. Uputstva za instalaciju: https://github.com/revanced/revanced-documentation Reddit: https://www.reddit.com/r/revancedapp/ Github: https://github.com/revanced Telegram: https://t.me/app_revanced Discord: http://revanced.app/discord Twitter: https://twitter.com/revancedapp ------------------------------------------- EDIT 16.09.2022: ReVanced Manager je vani: https://github.com/revanced/revanced-manager/releases/ Kako patchati Youtube s njim: https://twitter.com/ng642727/status/1570499359623761921 ------------------------------------------- EDIT 09.10.2022: ![]() ![]() Od sada možete jednostavnije patchati aplikacije, pomoću ovog builder programa: https://github.com/reisxd/revanced-builder Ako koristite Windowse, skinete odavde revanced-builder-win.exe file: https://github.com/reisxd/revanced-b...eleases/latest Instalirajte 64bit free verziju Azul Zulu JDK-a: https://www.azul.com/downloads/?pack...wnload-openjdk Pokrenete builder, otvorit će vam prozor u browseru odakle dalje samo klikate dok ne završi proces. Na kraju dobijete patchani apk kojeg prebacite na mob i instalirate, to je to. Zadnje izmijenjeno od: Neo-ST. 09.10.2022. u 12:21. |
RESPECT MY AUTHORITAH
Postovi: 7,495
Previše komplicirano: Code:
Make sure your phone is connected adb shell exit If you plan to use the root variant, check if you have root access adb shell su -c exit Copy the ADB device name adb devices Run the CLI # Non-Root java -jar revanced-cli-all.jar \ -a some.apk \ -c \ -d device-name \ -o revanced.apk \ -b revanced-patches.jar # Root # In the case of YouTube you want to exlude the patch 'microg-support' with the option '-e'. The option '-e' allows you to exclude patches (e.g. -e 'microg-support' -e amoled ...) java -jar revanced-cli-all.jar \ -a some.apk \ -c \ -d device-name \ -o revanced.apk \ -b revanced-patches.jar \ -e microg-support \ --mount A lot of patches require the integrations which you can merge by adding the -m flag and passing the integrations file as the argument. If you need the list of patches available, pass in -l. If you specified an ADB device the application should now open on your device and the CLI will show logs until the app is closed.
Postovi: 1,022
Vanced jos radi. Strpimo se malo pa ce i ovo biti "simple" https://github.com/revanced/revanced-manager Zadnje izmijenjeno od: strikoo. 12.08.2022. u 08:21. |
Postovi: 8,570
#9 | |
Lokacija: RH
Postovi: 1,737
A za tv da, smarttube je must have |
Postovi: 1,317
Lokacija: Zagreb, Črnomerec
Postovi: 2,664
Nema, samo na TV-ima sa Androidom i android boxevima. Bar koliko ja znam. Pošto imam Samsunga jednostavnije mi je bilo riješiti premium nego se gnjaviti sa work aroundima, 2 eur mjesečno je smiješno a stavio sam pola familije da i oni imaju. |
#13 | |
Datum registracije: Apr 2017
Lokacija: SB
Postovi: 715
Ima par načina za instalirat i sve je tip top. Ne kužim šta ljudima znači update takve app kad sve i sa zadnjom verzijom radi bez problema. |
Postovi: 8,570
We have officially released an official Alpha version of the ReVanced Manager https://github.com/revanced/revanced-manager/releases/ |
#17 |
Postovi: 8,570
Vidim da je nova verzija vani pa probaj. How to patch: https://twitter.com/ng642727/status/1570499359623761921 Zadnje izmijenjeno od: Neo-ST. 16.09.2022. u 13:03. |
#18 |
tiki
Postovi: 2,762
Meni prije par dana nije radilo pa sam se danas išao pozabaviti. Updateao sam Patcher na najnoviju verziju. Važno je da je verzija Youtubea točno ona koju patcher traži (u mom slučaju 17.36.37). Pošto sam ja imao noviju verziju, morao sam u Postavke od mobitela, Aplikacije, naći Youtube aplikaciju i onda stisnuti Unistall updates. Jednom kad je vraćena tvornička Youtube aplikacija, treba otići na internet i naći točno tu verziju aplikacije (google youtube apk pa skinut sa nekih od dostupnih stranica, npr. apkpure i slično). Nakon što sam ručno instalirao tu verziju, patchao je bez problema te aplikacija radi. |
#19 |
Postovi: 8,570
Također, ako želite biti logirani, morate skinit i instalirati Vanced MicroG. Tj. mislim da ga morate svakako imati, inače će vam se Youtube crashati. https://github.com/TeamVanced/VancedMicroG/releases |
#20 |
Postovi: 34,075
Meni je taj MicroG radio probleme. Svako malo mi je S22 kod paljenja/resetiranja javljao da se MicroG crashao.
#21 |
Postovi: 8,570
Inače tko nije skužio, sa ReVanced patcherom možete patchati i ostale aplikacije poput Reddita, Twittera, itd. Bitno je pratiti točnu proceduru da bi to funkcioniralo. Recimo da želite patchati Reddit koji vam je već instaliran na mobu: 1. Uninstall 2. Skinit Reddit apk sa apkmirror, međutim paziti da skidate običan apk, ne bundle. Često to znači da ćete morati skinit malo stariju verziju. 3. Instalirate apk, ne pokrećete je 4. U patcheru odaberete Reddit i stavite kvačice šta želite patchati 5. Pokrenete patch. Kad završi ne klikati install 6. Sa home tipkom izađete i odete u svoje settingse, apps, i pronađete Reddit kojeg uninstalirate 7. Vratite se natrag u patcher i sada kliknite install To je to. |
#23 |
Fresh Juice
Postovi: 4,580
Kaj dobiš sa patchanim redditom? |
#25 |
Lokacija: SB
Postovi: 715
A koja je poanta tog re-vanced ak stari ima za skinuti i sve radi kao i do sad? Koja je uopće poanta updateanja takve aplikacije? Koliko se sjećam update je znao samo sjebat stvari, ovak, reklama nema, radi log in, sve fluidno, radi u pozadini i šta više treba čovjek. |
#27 |
Lokacija: SB
Postovi: 715
#28 | ||
tiki
Postovi: 2,762
Možda jedan dan upališ Vanced i samo ti izbaci poruku ova verzija Youtubea više nije podržana, skini najnoviju, a onda si nagrabusio. |
#29 |
Postovi: 8,570
#30 |
Postovi: 8,570
Pokrenete builder, otvorit će vam prozor u browseru odakle dalje samo klikate dok ne završi proces. Na kraju dobijete patchani apk kojeg prebacite na mob i instalirate, to je to. Od nedavno možete jednostavnije patchati aplikacije, pomoću ovog builder programa:
https://github.com/reisxd/revanced-builder Ako koristite Windowse, skinete odavde revanced-builder-win.exe file: https://github.com/reisxd/revanced-b...eleases/latest Instalirajte 64bit free verziju Azul Zulu JDK-a: https://www.azul.com/downloads/?pack...wnload-openjdk Pokrenete builder, otvorit će vam prozor u browseru odakle dalje samo klikate dok ne završi proces. Na kraju dobijete patchani apk kojeg prebacite na mob i instalirate, to je to. |
