|  15.02.2022., 09:21 | #6811 |
| #erase startup-config Datum registracije: Nov 2001 Lokacija: Zagreb
					Postovi: 3,729
				 | Za Bartona 3200+ moraš imati dobar cooler i dobro kućište   Mobilne verzije su bile hladnije. |
|  15.02.2022., 09:40 | #6812 |
| 1,2,3... fall over! Datum registracije: Dec 2005 Lokacija: Karlovac
					Postovi: 206
				__________________ vintage hi-tec |
|  15.02.2022., 11:25 | #6815 | ||||
| bu Datum registracije: Jan 2017 Lokacija: VŽ
					Postovi: 2,603
				 | Citiraj:
 Na ajmo reći - pred-otpadu  Sve što uzimam zapravo spašavam da ne ode u reciklažu-zlato, znači zadnja stanica prije eliminacije  Budem upogonio... Jednom, neznam kad  Citiraj:
 Da, imam ih hrpu, ali jednostavno nemam vremena i volje da to sve na brzinu testiram, pune kutije hardvera mi znaju po nekoliko mjeseci tako stajat  Citiraj:
 Zalman 7000B Al-Cu LED će biti sasvim OK, imam i mobilaca, ali tu je poanta "najjači socket A procesor" kad se gleda stock  Citiraj:
  Što je najveća fora, čovjek se ni ne kuži skoro ništa u to, on samo dovlači sve i svašta, a ja kad dođem mu napravim dar-mar među robom   Evo quote iz jednog reviewa We're far from audiophiles here, but I consider myself a decent audio enthusiast. I have a fairly nice setup at home consisting of a Denon amplifier/receiver, B&W speakers, and a Sony ES CD player for pure music listening, and I have a respectable pair of MidiLand S2 speakers for my computer audio and gaming. So what do I say about the AX4B Tube sound? It definitely has advantages over standard AC'97 that you get from any other integrated sound. In fact, we did some A-B comparison tests comparing the AX4B Tube against a few other motherboards with integrated audio, and it's very clear that the Tube brings out a richness and texture to the audio that can't be heard with the other motherboards. In music of all kinds, there's a sense of depth, of lushness and vigor that you don't get with regular audio. Detail in the higher frequencies is especially easy to identify: stringed instruments have a greater sense of depth, with orchestral pieces showing an open and airy soundstage. Deeper sounding instruments like the bass, cello, and the bass portions of piano pieces have a stronger, more subtly guttural impact. The overall experience is definitely more enjoyable than the same experience with regular, integrated audio.
				__________________ Nvidia u očima Intel u duši Alfa Romeo u srcu | ||||
|  15.02.2022., 11:50 | #6816 |
| Moderator Datum registracije: Sep 2006 Lokacija: St
					Postovi: 23,548
				 | Bome, bravo   Moglo bi se reći nekakav audiofilski sveti gral u PC svijetu sa tom Aopen AX4PE Tube. Za one koji ne kuže u čemu je štos, kada staviš lampu u audio lanac (najlakše je negdje kod predpojačala) dobiješ na "mekoći" a nekad i na dubini / širini stereo slike. Naprosto isti izvor / materijal zvuči prirodnije ... Sve zahvaljujući teh. razlici između lampe i prosječnog tranzistora (nemoj da mi netko pod tranzistor misli na cijeli radio)  |
|  15.02.2022., 13:21 | #6817 | ||
| Guest
				 | Citiraj:
 Dva mala odvojena svemira, čisto zato što smatram da digitalno i analogno nemaju što tražiti zajedno  | ||
|  15.02.2022., 14:53 | #6818 |
| Premium Datum registracije: Mar 2009 Lokacija: Zagorje
					Postovi: 1,001
				 | Sline mi cure ili cure mi sline, ni sam ne znam   Ovaj aopen, kakva luđačka ideja, staviti lampaško pojačalo na MB, to naprosto mora u nekakvo prozirno DIY izložbeno kućište. Dok je s druge strane katastrofalno realizirano sve skupa, očito je lampa više kao ukras ... nema posebno napajanje, nema EMI shield, rtl650 je kanta... ALI....da se sve to prelemiti kak spada i složiti da zvuči još bolje nego kak izgleda. P.S. ploča ima voice report, koji je vjerojatno standardni winbond(isto kao i kod asusa ili albatrona) koji se može editirati, pa npr. za uspješan POST da pantera zaurla: "We're taking over this town!" |
|  15.02.2022., 15:03 | #6819 | ||
					Postovi: 2,603
				 | Citiraj:
  Zasad sve ostaje kod mene i sprema se, polako imam gadnih problema sa skladišnim prostorom koliko se toga nakupilo, ali uvijek nekako dotrpam  A za 20-30 godina tko zna...  Citiraj:
 Baš primjerak za case sa prozirnom stranicom, a baš takav jedan i imam tako da mislim da ću uskoro sastaviti i upogoniti to pa bacim slike
				__________________ Nvidia u očima Intel u duši Alfa Romeo u srcu Zadnje izmijenjeno od: maXonja. 15.02.2022. u 15:25. | ||
|  15.02.2022., 15:26 | #6820 |
| The mighty pirate Datum registracije: Sep 2007 Lokacija: London
					Postovi: 9,106
				 | Ako se ne varam, te ploče su imale Jukebox feature. Mogao si upaliti FM radio ili jukebox dio bez da se komp diže dalje od BIOS-a. Znam da sam slinio na to uvijek, ali onda nije bilo tih para. Vidim sad jednu AX4GE ploču na ebayu, 850 funti traži za nju…
				__________________ |
|  15.02.2022., 16:59 | #6821 |
					Postovi: 2,603
				 | Uh, znači dobar deal za 50kn koliko me došla cijela kanta   Doduše, moja Aopenica je malo "lošiji" model jer nema službenu podršku za DDR333 dok ova sa oglasa ima i ima integriranu grafičku, ali mislim da je to manje bitno
|  15.02.2022., 22:53 | #6822 |
					Postovi: 9,106
				 | Evo i linka za ostale https://www.ebay.co.uk/itm/265300707...wAAOSwKcRhNSaz Ambalaža mi je genijalna s lampom vani da se vidi. I još fino boldano "made in Russia"
|  17.02.2022., 03:58 | #6824 |
| Guest
				 | Inače, dobio sam danas jednu lijepu donaciju koja je dugo čekala, naprije zbog kolege a kasnije zbog mene. Riječ je o još jednom "Adisonu", ali ne - nije ono što mislite      Sam "Adison" je nažalost nepovratno izrezan. Dobro sam ga rastavio i pregledao, nadajući se da uz manje prepravke i možda malo varenja bude bilo moguće vratiti glavni okvir natrag u tvorničko stanje (svakako bih ostavio prozor, izgleda ludo!) Ali ne - nažalost previše je toga izrezano da bi se moglo jednostavno i jeftino obnoviti. Međutim sad kad sam to rekao, unutra se nalazi ispravna Abit IS7 matična ploča, Radeon 9800 Pro i Audigy 2 ZS zvučna  Dok mi sama Abit ploča nije potrebna (iako znam da ima onih koji bi "ubili" za Abit), Zalman CPU cooler & Audigy 2 ZS si definitivno namjeravam ostaviti ... i staviti ih (ni manje ni više) u jedan od svojih Adisona, P4 konfu tako da zapravo budu ostali u istom kućištu  Radeon 9800 nažalost ne pokazuje ohrabrujuće znakove, baca artefakte pa se bojim da je dala svoje. Ali možda je proslijedim dalje ovdje na forumu (jedan forumaš je već izrazio zanimanje) pa ako ju je moguće popraviti zašto ne! Sam tower budem svakako ostavio... Iako su šanse za restauraciju ravne nuli, još uvijek vrijedi "zlata" jer sam dobio rezervne dijelove. Gornji poklopac (panel), kao i jedna bočna stranica, od kojih su obje full originalne. A tu je vjerojatno i ono najbitnije - mali plastični nosač sa dvije posebno-dizajnirane LEDice i Reset tipkalom. Pa AKO naiđem na neki Adison kojem bude nedostajalo nešto od navedenog, dalo bi se složiti kompletan (i full ispravan) tower. Također, budem svakako ostavio plastičnu masku iako je ova u potpunosti prebojana u crnu boju. Pa vas ovom prilikom molim da ako imate bilo kakvih ideja kako bi se mogla skinuti boja sa plastike, BEZ kemijskog oštećivanja iste da mi pomognete. Logični odgovor bi bio Nitro razrjeđivač ili aceton, ali nažalost obje kemikalije rastapaju plastiku i rade nepovratnu štetu tako da ovo ne dolazi u obzir. A više slika budem uploadao sutra, ove dvije fotke gore su od kolege i stavio sam ih više kao ilustraciju  |
|  17.02.2022., 09:14 | #6825 |
| Premium Datum registracije: Jan 2006 Lokacija: Zagreb
					Postovi: 1,180
				 | Meni ovo izgleda kao odlican Adison mod, da ne pricam da sigurno nema ni j3edan Adi sa plexijem. Ja bi to osobno ostavio tako kako je i slozio daily driver konfu (npr onu na koju si se zalio da ima los airflow), vidim da na ovoj ima mjesta za zrak kolko oces   Samo staviti crnu optiku i problem solved. Pa imas "stock" i "tuned" konfe, po mogucnosti jednu kraj druge. No znam da nis od toga kod tebe tako da sretno sa skidanjem boje  |
|  17.02.2022., 13:56 | #6827 | |
| Guest
				 | Citiraj:
 Štoviše, nosači za prekidač (koji bi inače sam po sebi bio najmanji problem, riječ je o industrijskom standardu i dalo bi ga se naručiti online) su izrezani, tako da je nemoguće montirati ga natrag bez varenja i pojačavanja metalne konstrukcije  Opet - budem stavio fotke ovdje u temi kad nađem vremena. Kroz zadnjih godinu, godinu i pol sam postao "stručnjak za Adisone", pa mogu i bez usporedbe dva towera odmah reći gdje je uklonjena površina, i što je sve izrezano  | |
|  17.02.2022., 14:10 | #6828 |
| Premium Datum registracije: Sep 2004 Lokacija: Split
					Postovi: 834
				 | Kad ste se vec takli VHS-a par postova prije. Veliki sam ljubitelj i skupljac video kazeta, pa ako neko ima za prodat ili udomit vhs kazete molim na pm.  Kad uvatim malo vise vremena poslikat cu vam jednom prilikom sta imam |
|  17.02.2022., 14:20 | #6829 |
| Premium Datum registracije: Feb 2007 Lokacija: Istra
					Postovi: 3,494
				 | Ima netko savjet kakav hardver bi trebao da si digitaliziram neke stare VHS kazete? Videorecorder imam jedno 2 komada na lageru, ali na kompu sam u deficitu  Zadnje sam to radio tamo negdje krajem 90-ih s nekom ATI AIW karticom na koju je bila naštekana VHS kamera. |
|  17.02.2022., 15:05 | #6830 | |
| Guest
				 | Citiraj:
 Nego evo i par fotki Adisona...       A kako bi fronta trebala izgledati tvornički najbolje govori ova ovdje slika:  | |
|  17.02.2022., 16:36 | #6831 | |
					Postovi: 23,548
				 | Citiraj:
 prvo šta izađe po cijeni: https://megabajt.hr/proizvod/gembird-usb-videograbber/ https://supernet.hr/proizvod/E_GEM-UVG-002 str. proizvođača > https://gembird.com/item.aspx?id=7998 E sad, jeli šta valja, kakav je sw šta dođe sa njim, koji je os podržan ??? | |
|  17.02.2022., 19:03 | #6833 |
					Postovi: 23,548
				 | Vidiš, nije ti ta ni luda, skroz zaboravio na tu mogućnost   Onda u virtualku stavi "gotovi" AVLinux, možeš Live, može i "install". Install je u navodnike jer nije klasični nego se iskipa pripremljeni image, a cijela poanta je šta je patch - an baš za AV "poslove". |
|  17.02.2022., 20:44 | #6837 | |
| White Rabbit Datum registracije: May 2006 Lokacija: -
					Postovi: 5,043
				 | Citiraj:
 Probaj ovo: https://sdi-tool.org/ | |
|  17.02.2022., 22:10 | #6839 |
					Postovi: 23,548
				 | Htio ranije napisati taj SDI, to bi trebalo iskopati za XP i novije. Može se i pješke po Device / Hardware ID, lakše je sa Bubbinim PCI-Z. Za ranije od XP - a kopati po Internetu. Izvadi, stavi ovdje pa možemo potražiti. |
|  17.02.2022., 23:44 | #6840 | |
| Guest
				 | Citiraj:
 Uglavnom, uz FM radio, DVB-T/analogni receiver i daljinski imaš i Audio/Video input, za spajanje na uređaje baš kao što je VHS rekorder. Pa javi na PP ako si zainteresiran, trebaš samo doći do mene  | |
