Staro 29.01.2022., 23:07   #5191
Marko :)
Datum registracije: Feb 2016
Lokacija: Unknown
Postovi: 706
Autor Prezime Pregled postova
Salji i gnjavi dok ti to ne srede! Ovak to izgleda kod mene na Speedport Smart 3 500/250:
Code:
Microsoft Windows [Version 10.0.18362.1256]
(c) 2019 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>ping 195.29.144.5 -t
Pinging 195.29.144.5 with 32 bytes of data:
Reply from 195.29.144.5: bytes=32 time=2ms TTL=252
Ping statistics for 195.29.144.5:
    Packets: Sent = 22, Received = 22, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 2ms, Maximum = 2ms, Average = 2ms
Pinging 1.1.1.1 with 32 bytes of data:
Reply from 1.1.1.1: bytes=32 time=9ms TTL=52
Reply from 1.1.1.1: bytes=32 time=8ms TTL=52
Ping statistics for 1.1.1.1:
    Packets: Sent = 19, Received = 19, Lost = 0 (0% loss),
    Minimum = 8ms, Maximum = 9ms, Average = 8ms
Pinging 8.8.8.8 with 32 bytes of data:
Reply from 8.8.8.8: bytes=32 time=8ms TTL=118
Reply from 8.8.8.8: bytes=32 time=7ms TTL=118
Ping statistics for 8.8.8.8:
    Minimum = 7ms, Maximum = 8ms, Average = 7ms
Daj nabaci traceroute za 1.1.1.1 i 8.8.8.8, zanima me ruta. Na A1 je ping prema 1.1.1.1 1ms jer se ide preko CIX-a, a prema 8.8.8.8 mi je cca. 25ms.
Marko :) je offline   Reply With Quote
Staro 30.01.2022., 01:32   #5192
Prezime
Datum registracije: Aug 2013
Postovi: 4,316
Evo od veceras:
Code:
C:\WINDOWS\system32>tracert 1.1.1.1
Tracing route to one.one.one.one [1.1.1.1]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  SOFTATHOME [192.168.1.1]
  2     3 ms     2 ms     2 ms  172.29.252.64
  3     3 ms     2 ms     3 ms  172.29.18.193
  4     2 ms     2 ms    26 ms  gtr11-htr11.ip.t-com.hr [195.29.110.146]
  5    13 ms    12 ms    12 ms  cloudflare.cix.hr [185.1.87.115]
  6    13 ms    12 ms    12 ms  one.one.one.one [1.1.1.1]
Trace complete.
C:\WINDOWS\system32>tracert 8.8.8.8
Tracing route to dns.google [8.8.8.8]
  2     3 ms     2 ms     3 ms  172.29.252.64
  3     4 ms     3 ms     4 ms  172.29.16.117
  4     2 ms     2 ms     2 ms  gtr09-htr11.ip.t-com.hr [195.29.240.182]
  5     7 ms     7 ms     7 ms  72.14.204.128
  6     7 ms     7 ms     7 ms  74.125.242.241
  7     7 ms     7 ms     7 ms  142.251.65.219
  8     7 ms     7 ms     7 ms  dns.google [8.8.8.8]
Trace complete.
Meni se ping razlikuje na dnevnoj bazi ovisno o IP adresi koju router povuce svaka 24h
Staro 30.01.2022., 08:21   #5193
Kruno M
Kruno M's Avatar
Lokacija: VKCI
Postovi: 1,222
Ne, kod tebe nejde ovaj s linka. Kaj je spojeno na drugoj strani tog žutog kabla, uredjaj i konektor? Kolko je taj dio dugacak?
Bilo bi najbolje komplet zamjenit sa potrebnom duljinom.
20m je dužina i ide kroz bužir. Spojeno je vani isored stana u kanalici.
Tako da to nebi mijenjao nikako. Jel ne postoji neka spojnica plus kabel uzmem?
Staro 30.01.2022., 11:54   #5194
Blagus
Datum registracije: Jun 2012
Postovi: 508
Uzmi SC/APC spojnicu i SC/APC kabela koliko ti treba.
Staro 30.01.2022., 13:06   #5195
Kruno M
Kruno M's Avatar
Lokacija: VKCI
Postovi: 1,222
Autor Blagus Pregled postova
To je znaci ovo:
https://www.pcshop.hr/nfo-patch-cord...05016/product/
https://www.schrack.hr/trgovina/opti...mol000107.html
Staro 30.01.2022., 15:20   #5196
Postovi: 23,497
Mislim da je.
Staro 30.01.2022., 16:16   #5197
Blagus
Postovi: 508
Da, točno to.
Nego, imam i ja pitanje. U hodniku je u kanalicama bijeli poluprozirni kabel i ulazi u stan kroz rupu koja je zagipsana. Jedva pola metra dalje, u razvodnoj kutiji u stropu (kud kabel prolazi) je žuti kabel. Jel stvarno moguće da su negdje u zid zagipsali konektor, i bi li HT to zamijenio s kraćim kabelom na zahtjev, ili bi došli samo ako se "slučajno" ošteti?
Staro 30.01.2022., 16:56   #5198
okarm
Postovi: 772
ne, ht kod montaze optike ne koristi gips, netko je prtljao po tome nakon njih.
al jesi ti siguran da je to ista instalacija? ak je unutra optika u postojecoj kutiji od bakrene instalacije onda nema bas nekog smisla da su u stan usli s novom rupom i kanalicama.
Staro 30.01.2022., 17:39   #5199
Prezime
Postovi: 4,316
Iz mog iskustva, ako se osteti taj prozirni patch HT tehnicari dolaze u roku od odmah tj. vec drugo jutro, nakon (jutarnje) prijave kvara. Duljina kabla koji ce ti stavit ovisi o sadrzaju kojeg ima u ruksaku. Kad je meni dosao imao je punkurac dugackih (3+ m) ali vrlo malo kratkih od 1m...
Staro 30.01.2022., 19:52   #5200
Marko :)
Lokacija: Unknown
Postovi: 706
Evo od veceras:
Code:
Trace complete.
Trace complete.
Hvala.
Staro 30.01.2022., 21:58   #5201
Blagus
Postovi: 508
Autor okarm Pregled postova
Dobro je znati, hvala.
Ne izgleda mi kao da je naknadno dirano. Bijela nit prolazi kroz kanalicu u zid, da je netko poslije njih išao to gipsati, morao bi skidati par metara kanalice i natezati nit. A ulazna točka je u kutu hodnika i to bi bilo puno posla za pljunuti komadić gipsa.
Inače, da, prolaze kroz istu kutiju, ali optika i parica ne dolaze iz istog smjera nego je optika naknadno provučena nadžbukno kroz zgradu. A tu je samo HT i to može biti jedino njihova nit.
Tako da mi ne izgleda kao da može biti išta drugo nego da je prespoj zatvoren negdje u zidu, pa otpada plan kraćenja ovog koluta optike s kojim se može iskablirati manja kućna mreža
Staro 30.01.2022., 22:30   #5202
okarm
Postovi: 772
ne znam, vidio sam na stotine tih prikljucaka u zagrebu, i sto je radio HT i od vanjskih firmi kaj su za njih radili i jos nigdje nisam sreo da se koristio gips, eventualno malo akrila stave ak se odlomi malo zbuke kod proboja zida.
Staro 30.01.2022., 22:49   #5203
Blagus
Postovi: 508
Moram priznati da nisam išao prčkati po tome da vidim jel gips ili akril, no ostaje to da je prespoj skriven negdje u zidu. I da je akril, trebalo bi ga rezati i riskirati oštećenje dolazne niti.
Staro 31.01.2022., 12:19   #5204
Prezime
Postovi: 4,316
Kak to izgleda, jel samo ta tanka nit izlazi iz gipsa/akrila? Mozes to slikat?
Staro 31.01.2022., 18:01   #5205
Doktor-X
Doktor-X NetWork
Doktor-X's Avatar
Lokacija: .
Postovi: 287
E a šta je sa onim projektom da se optika postavlja preko stupova od hep-a pa da se ubrza penetracija
Doktor-X je offline   Reply With Quote
Staro 01.02.2022., 10:01   #5206
Noctifer
Datum registracije: Sep 2021
Lokacija: Sveta Nedelja
Postovi: 26
Autor Doktor-X Pregled postova
Moze i tako. Meni je tako poslovna optika vucena. Ali se tu cekalo par mjeseci da se dobe sve dozvole (grad se najvise cekalo)
Noctifer je offline   Reply With Quote
Staro 01.02.2022., 10:55   #5207
tascam
Datum registracije: Jun 2010
Lokacija: hr
Postovi: 887
Autor SinfulSaint Pregled postova
možemo ga tražiti ko zamjenu za speedporta smart ovo ono?
Ide samo za nove korisnike.
tascam je offline   Reply With Quote
Staro 07.02.2022., 21:00   #5208
dadoremix
dadoremix's Avatar
Postovi: 4,684
Autor jp_rv Pregled postova
novi korisnik optike, i novi korisnik ht-a.
ja mislim da cu napucat magica i probat tht optiku
imas li gigu ?
koliko je najniža cijena
na webu gledam 239kn + 45 za gigu paket = 284kn
magic je sad 199kn .. al nemas bridge, nakon upgrejda na gigu imas random vrijeme za ip change, a prije držalo 30 dana ako ne i više
dadoremix je online   Reply With Quote
Staro 07.02.2022., 21:20   #5209
johnsmith
Lokacija: vž
Postovi: 1,330
Kaj ti ne odgovara na Magicu da bi išao na skuplji tcom?
Staro 07.02.2022., 21:30   #5210
jp_rv
Datum registracije: May 2014
Lokacija: istra
Postovi: 3,471
ht je 169 za basic paket 200/100.
neznam kolika je doplata za điđabit, ne treba mi.
edit:
recconect je svaka 24 sata.
samo jednom mi je bilo 30h, nakon toga ide reconnect svaku noć u 1 ujutro.
Zadnje izmijenjeno od: jp_rv. 07.02.2022. u 22:04.
Staro 07.02.2022., 21:47   #5211
dadoremix
dadoremix's Avatar
Postovi: 4,684
nadrobil sam u magic topicu, da sad ne ponavljam
Staro 09.02.2022., 15:24   #5212
lukec
Postovi: 1
dakle, problem je valjda u implementaciji bridge moda.
nije mi dalo mira, prebacio sam router natrag u router mode , podesio dmz a mikrotika prebacio na static ip.
Pozdrav,
dobio sam i ja isti router (Technicolor FGA 2233). Imam pppoe username i pass, i pokušavam router prebaciti u bridge mode.
Pitanje: da li za bridge mode treba samo u postavkama technicolora uključiti opciju "pppoe pt" (kao na slici ispod) ili treba još nešto sa SZK dogovoriti?
Hvala..
Zadnje izmijenjeno od: lukec. 09.02.2022. u 15:29. Razlog: img url
lukec je offline   Reply With Quote
Staro 09.02.2022., 18:55   #5213
the chosen one
the chosen one's Avatar
Postovi: 729
Autor lukec Pregled postova
Pozdrav,
Hvala..
To je pass through... Meni je bilo to isto uključeno na speedportu pa sam svejedno morao zvati korisničku da me stave u "pravi" bridge
Staro 09.02.2022., 19:02   #5214
jp_rv
Lokacija: istra
Postovi: 3,471
prebacuješ u bridge mode (i nazad) preko moj telekom stranice.
kod svake promjene se router resetira na tvorničke postavke.
u bridge modu mora biti uključen pppoe pass-trough.
Staro 09.02.2022., 19:41   #5215
Postovi: 23,497
Ako ćeš se sam "igrati" uključi taj PPPoE Pass-Trough ali moraš trenutnu konekciju (bilo da je xDSL ili Optika) staviti na disable ili na manual kako router nebi uspostavljao tu konekciju.
Ako ideš preko SZK / moj telekom onda će oni odraditi daljinski i prebaciti konekciju u Bridge mode, tada ti ne treba PPPoE Pass-Trough.
Staro 09.02.2022., 19:47   #5216
jp_rv
Lokacija: istra
Postovi: 3,471
Autor Nikky Pregled postova
ne možeš, technicolor to nema.
sve se radi preko moj telekom stranice. ili je router mode, ili je bridge mode, i nema apsolutno nikakvih opcija koje korisnik može dirati u niti jednom od ta 2 načina rada. niti jedno polje nije otključano niti postoji opcija za nešto promijeniti.
treba, jer je takva logika tog routera.
ako PT nije upaljen, router iza modema nema pristup interfejsu i ne diže pppoe konekciju.
Staro 09.02.2022., 20:31   #5217
panda505
panda505's Avatar
Lokacija: Beertopia
Postovi: 2,013
rođak ide na novi stan di ima opciju za optiku, hoće HT - kak je išla ona spika - nazoveš ih i tražiš prema cjeniku posebnih i proteklih ponuda MAX2 za koliko je ono bilo - 169kn?
54' / 74' / 90' / 2014
Staro 10.02.2022., 13:27   #5218
alen_os
Postovi: 26
Ja tražio zamjenu jučer za oba stana u zgradi i napravili su mi zamjenu.
Za sada sam iznimno zadovoljan sa routerom. jedan je 2.5 gigabita port ostali su gigabitni.
alen_os je offline   Reply With Quote
Staro 10.02.2022., 13:34   #5219
Postovi: 23,497
@jp_rv
Kao i kod drugih novijih routera, pitanje je šta koji (l)user ima ovlasti,
ako otkriješ i ulogiraš se kao pravi admin onda se vjerojatno može sve šta treba odraditi.
Staro 10.02.2022., 13:38   #5220
alen_os
Postovi: 26
Autor daki Pregled postova
Obrisao si passworde sa slike, ali mogu se očitati iz QR koda
Ali baš me zanimaju wifi performanse i hoce li bit u ponudi kakav mesh uz taj router.
Samsung S21 mjereno jučer gigabitna optika speedtest
https://www.speedtest.net/result/a/8132471591
