|  23.11.2020., 22:22 | #5131 | |
| Premium spammer Datum registracije: Aug 2010 Lokacija: D.Zagora
					Postovi: 776
				 | Citiraj:
  Skidanje tipkovnice na xx40+ mi je najgori dio svega.. | |
|  24.11.2020., 03:35 | #5132 |
| EMP moderator Datum registracije: Apr 2005 Lokacija: Osijek
					Postovi: 18,885
				 | Ima li ovdje razloga za brigu? U pitanju T480 iz potpisa. Code: stu 24 02:21:19 Domy-NB kernel: mce: CPU2: Core temperature above threshold, cpu clock throttled (total events = 8682) stu 24 02:21:19 Domy-NB kernel: mce: CPU6: Core temperature above threshold, cpu clock throttled (total events = 8682) stu 24 02:21:19 Domy-NB kernel: mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 16454) stu 24 02:21:19 Domy-NB kernel: mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 16454) stu 24 02:21:19 Domy-NB kernel: mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 16454) stu 24 02:21:19 Domy-NB kernel: mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 16453) stu 24 02:21:19 Domy-NB kernel: mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 16454) stu 24 02:21:19 Domy-NB kernel: mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 16454) stu 24 02:21:19 Domy-NB kernel: mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 16454) stu 24 02:21:19 Domy-NB kernel: mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 16454) stu 24 02:21:19 Domy-NB kernel: mce: CPU2: Core temperature/speed normal stu 24 02:21:19 Domy-NB kernel: mce: CPU0: Package temperature/speed normal stu 24 02:21:19 Domy-NB kernel: mce: CPU6: Core temperature/speed normal stu 24 02:21:19 Domy-NB kernel: mce: CPU4: Package temperature/speed normal stu 24 02:21:19 Domy-NB kernel: mce: CPU6: Package temperature/speed normal stu 24 02:21:19 Domy-NB kernel: mce: CPU2: Package temperature/speed normal stu 24 02:21:19 Domy-NB kernel: mce: CPU1: Package temperature/speed normal stu 24 02:21:19 Domy-NB kernel: mce: CPU5: Package temperature/speed normal stu 24 02:21:19 Domy-NB kernel: mce: CPU3: Package temperature/speed normal stu 24 02:21:19 Domy-NB kernel: mce: CPU7: Package temperature/speed normal
				__________________ "Kako su krojači novog svjetskog poretka uspjeli u tako kratko vrijeme slomiti intelektualne sposobnosti društva, uništiti kritičku svijest i ljudima nametnuti izvrnutu logiku?"   |
|  24.11.2020., 16:26 | #5134 |
| Premium Datum registracije: Oct 2008 Lokacija: Dbk
					Postovi: 1,308
				 | Možda nekome bude zanimljivo ... Pošto mi klasična metoda uklanjanja IME iz BIOSa nije upalila, tj. nije se više moglo ući u BIOS iako se lap podizao u OS, tražio sam drugo rješenje i našao nešto dosta zanimljivo. https://medium.com/@n4ru/1vyrain-an-...k-fd4bb0bdb654 To je nekakav poboljšani firmware za xx30 seriju, konkretno ja sam zasad probao na T430s i radi super, idući mi je T530 na redu. Dobije se dosta opcija za fino tuniranje hardvera, overclock, i može se u BIOSu ugasiti Intel Management Engine. Navodno se i miče whitelista WiFi adaptera pa se može koristiti bilo koji, a ne samo onih par što Lenovo prodaje po zlato. Cijela procedura se odradi bez potrebe za otvaranjem laptopa i spajanjem programatora, sve je softverski. Edit, instalirano i na T530 bez problema. Naravno kao i kod svakog petljanja sa BIOSom dobro je imati programator pri ruci ako nešto pođe po zlu, meni onaj ch341a od 40kn radi odlično na nekoliko Lenova i jedanom Dellu, zapravo na svemu na čemu sam probao. . Zadnje izmijenjeno od: Night. 25.11.2020. u 14:03. |
|  24.11.2020., 16:37 | #5135 |
					Postovi: 18,885
|  25.11.2020., 00:07 | #5136 |
					Postovi: 776
|  25.11.2020., 19:40 | #5137 | |
| Premium Datum registracije: Mar 2010 Lokacija: Zagreb
					Postovi: 2,062
				 | Citiraj:
   Probao sam BOE staviti u T420 i tamo isto samo crnilo. Pozitivno je to kaj mi je za zamjenu ekrana trebalo manje od pet minuta (očekivao sam više), negativno kaj sad moram naći novi ekran pa mi je pala suluda ideja za ipak ubodem onaj Innolux GR2/GQ2 i da ga probam ubaciti u T420,... to bi zaista bio overkill za tako stari laptop  Usput, dok razmišljam što nabaviti, ako netko ima neki ok FHD IPS za T4x0 seriju nek se javi pa da ne naručujem i čekam proljeće da doputuje  EDIT: Sad kad gledam boje na monitoru sa S-PVA matricom i ovaj AUO IPS, nekako bi najrađe ekran za ThinkPada sa S-PVA matricom, ali to vjerojatno ne postoji  | |
|  25.11.2020., 20:51 | #5138 |
| Avocado Datum registracije: Aug 2005 Lokacija: Zagreb
					Postovi: 7,856
				 | Kupio sam za htpc veći SSD, dosadašnjih 120GB se eto napunilo. Kloniranje na veći je odrađeno bez problema, SSD fercera. Manji SSD sam odlučio staviti u svoj x60s i ostaviti HDD kao backup, jer na njemu imam nekih posebnih programa koje je problematično pribaviti i instalirati. Klonirao sam HDD na SSD na svom normalnom piceku ali mi se lapić neće bootat sa SSDom, nakon POST-a ostane na blinkajućem kursoru. HDD naravno fercera. winxp boot stick koji sam koristio imam i funkcionira, međutim čim ga bootam ne pokaže opciju "press R to enter Recovery" te ne mogu odraditi klasične fixboot fixmbr bootsect /nt60 c: /force /mbr Ne sjećam se otkud ili otkad mi taj stick, znam samo da sam ga nekoliko puta koristio bez da sam primijetio da mi fali recovery. Mislim da sam napravio iso od jednog origigi winxp CD-a kojeg sam imao. Naravno, bootanjem s CD-a je recovery bio prisutan. Mogu li kako dodati recovery na postojeći usb stick? Trenutno se pokušavam dokopati još jednog 32bit winxp imagea jer su mi originalni CD-i ko zna gdje - valjda u podrumu u ZG-u. Ima neki (polu)pouzdani izvor?
				__________________ Spoiler alert! |
|  25.11.2020., 21:07 | #5139 | |
| #erase startup-config Datum registracije: Nov 2001 Lokacija: Zagreb
					Postovi: 3,729
				 | Citiraj:
 Ima ih u 2280 i 2242 varijantama. Sve verzije su DRAM-less pa bi ti to mogao biti dealbreaker, ali rade jako dobro i ne zastajkuju. Meni su bili skroz fine. Prošle godine je puno HP laptopa dolazilo s tim SSD-ovima. | |
|  25.11.2020., 21:09 | #5140 |
| Moderator Datum registracije: Sep 2006 Lokacija: St
					Postovi: 23,548
				 | Nekad iako si radio "clone" ne napravi 100% isto i posljedično nema boot u winse. Druga moguća greška je boot loader ima "info" i put prema winsima na hdd - u a sad bi trebao "pucati" na ssd. Trebalo bi nekako dodati još jednu "stavku" u boot loaderu i prepraviti je da puca na winse sa ssd - a. |
|  25.11.2020., 23:07 | #5141 |
					Postovi: 18,885
				 | Nije dealbreaker kad ni SN520 nema DRAM. Ma nema veze, uzeo sam što je bilo kad je izbor nikakav. Hvala.
|  25.11.2020., 23:56 | #5142 | |
					Postovi: 7,856
				 | Citiraj:
 Sad gledam da sam napisao bootsect /nt60, čime se winxp može samo još više zeznuti, treba ići /nt52 (source). Nakon što postojeći usb nije imao recovery na sebi, skinuo sam neki treći xp image, stavio na stick. fixboot fixmbr nisu niš napravili, dapače, primijetio sam nakon fixboota da nemrem više bootat usb stick. *lampica* map naredba - samo USB stick mapiran, tak da sam naredbama zapravo "popravljao" stick. Pretpostavljam da je problem je što ovaj iso nema slipstreamane drivere za SATA, to se primijeti i prilikom podizanja tog plavog sučelja, vrlo malo stvari loada.
				__________________ Spoiler alert! | |
|  26.11.2020., 01:37 | #5143 | |
| Omicron Alpha resident Datum registracije: Jun 2009 Lokacija: Bistra
					Postovi: 5,075
				 | Citiraj:
 https://www.panelook.com/modelcompar...ds=30063,42985 Bolji color coverage, veći brightness, kontrast, broj boja (ne kuzim kak ovaj pokazuje samo 262k boja, mozda to nije točna informacija?), al pod total power consumption razlika nije velika (3.36W naspravm 3.05W), dok je ta neka BLU power consumption čak na strani jeftinijeg panela. Interesantno, trebalo bi usporediti panele jednog kraj drugog... ili možda bolje ne, onda će me to previše kopkati
				__________________ 95% of the world is retarded, I'm glad I am the 10%. | |
|  26.11.2020., 02:51 | #5144 | ||
| Premium Datum registracije: Nov 2007 Lokacija: -
					Postovi: 4,403
				 | Citiraj:
 Na tom panelooku zna bit dosta krivih informacija pa i kontradiktornih. Za GR2 kaže sRGB color coverage 88%, a NTSC 82%, što ni matematički ne može biti.točno Naravno, kolorimetrom sam izmjerio 99% sRGB-a (što je oko 72% NTSC-a, uz standardnih 75% Adobe RGB-a i DCI-P3). A što se potrošnje tiče, zaboravljaš da se radi o ~ potrošnji 250 vs 400 nitsa   Eh, N140HCA-EAB...  Citiraj:
 Citiraj:  Ne znam kak u Linuxu upravljat color profilima, ali predlažem da si skineš color profil za taj ekran: link I provjeri hoće li ti PCB za retrofit raditi s bilo kojim drugim ekranom.
				__________________ Zadnje izmijenjeno od: ThePornstar. 26.11.2020. u 03:00. | ||
|  26.11.2020., 12:28 | #5146 |
					Postovi: 4,403
				 | Ma dobro, crvenkasta slika se da riješiti color profilima, ali gamut ostaje kakav je. Neki kažu da su im ti ekrani ok, mogu živjeti s njima. Zapravo su isti kao i ostali FHD IPS od T460 do T470, tako da nisi fulao po pitanju tvorničkih vrijednosti    T440 i pogotovo T450 su tvornički dolazili s boljim FHD IPS ekranima od tih serija, a gore navedeni AUO je jedan od njih.
				__________________ |
|  26.11.2020., 13:08 | #5148 |
| Premium Datum registracije: Jul 2005 Lokacija: Novi Zagreb
					Postovi: 979
|  26.11.2020., 13:24 | #5149 |
					Postovi: 5,075
				 | Niš još nisam fiksao, mentalno se - pokušavam - spremiti   Prvo moram odfurati laptop na zamjenu backlight fuse-a pa onda ide instalacija ekrana. Nego, kaj se tiče zamjenske backlit tipkovnice koju sam naručio preko AliExpressa - Ne znam zapravo jel je to original ili fake, ali iza na naljepnici piše: Product number: SN20K93235 Model: SN5324 FRU No.: 01AX080 Na drugoj naljepnici ispod nje stoji: SG-84500-XUA PK1311N3A00 SN5325 9026 LITEON
|  26.11.2020., 13:55 | #5151 |
					Postovi: 23,548
				 | @De5tr0yer Pa poznati je zaheb da (sve) treba imati integriran sata drajver kako bi vidio ssd / hdd. Sad sam se sjetio da je razlika XP (NT52) u odnosu na W7 i novije, prvi koristi boot.ini i radi ručno kukičanje po njemu, treba znati / pogoditi kako "vidi" ssd u odnosu na hdd (ono br. diska, br. particije). W7 i noviji rade preko boot loadera, M$ je predvidio koristiti dosadno komplicirani BCD cmd tool pa je bitno lakše preko alt. alata kao EasyBCD. E sad, kako da riješiš problem: - boot u Live Win sa integriranim sata drajverom, čak nije nužno da je XP based, može i W10, bitno je da "vidi" ssd i hdd - kroz Notepad urediš boot.ini da: a) stavi timeout=10 (da čeka tvoj izbor, to kasnije lako makneš) b) kopiraš stavku pod "operating systems" c) tu drugu stavku treba preurediti da "puca" na ssd Ne zaboravi da prije edita boot ini treba makniti (a kasnije vratiti) S, H, R atribute fajla. Za žuntu: https://www.howtoforge.com/custom_boot_menu_windows_xp https://neosmart.net/wiki/invalid-boot-ini-file/ https://neosmart.net/wiki/windows-wont-start/ Da si olakšaš možeš i ovako: - privremeno makni ssd - neka je hdd gdje i treba biti i da winsi rade sa njega kako treba - odradiš ove manipulacije sa boot.ini da imaš menu i dvije boot opcije - spremi negdje taj boot.ini na sick - zamijeni hdd sa ssd - om, nemoj stavljati hdd - boot u Live Win - kopirati boot.ini, editirati da pogodiš kako treba ... Nadam se da sam te usmjerio u dobrom pravcu. |
|  26.11.2020., 14:01 | #5152 | |
| Premium Datum registracije: Oct 2002 Lokacija: Zagreb/Rijeka
					Postovi: 1,994
				 | Citiraj:
 Instaliraj intel XTU i odradi Stress Test na default postavkama... Ako ti tamo stalno throttla CPU, nosi na servis ako je laptop jos pod jamstvom...
				__________________ | |
|  26.11.2020., 15:22 | #5153 |
					Postovi: 5,075
|  26.11.2020., 15:30 | #5154 |
					Postovi: 4,403
				 | Nije baš pomoć, više party-pooping   Prije nego naručiš, scimaj lika s Njuškala od kojeg smo (forumaši) već uzimali. Trenutno ne vidim da ima za T460/50/40 (od T460s ili p ne paše), ali je blizu i ima skroz korektne cijene pa ga ne bih preskakao. I probaj da je Lite-On backlit - i @bertone ti može potvrditi da je bolja od Chicony backlit tipkovnica.
|  26.11.2020., 18:01 | #5155 | |
					Postovi: 18,885
				 | Citiraj:
  Testirao sam u Primeu i ThrottleStopu više U procesora uključujući i ovaj kad sam ga tek kupio i svaki mi je throttlao u turboboostu, to je za njih normalno. Kada nisu u turboboostu, onda nema ni throttlinga, a uz undervolt mi je sweetspot bio negdje na pola puta između nominalne i max turboboost frekvencije.
				__________________ "Kako su krojači novog svjetskog poretka uspjeli u tako kratko vrijeme slomiti intelektualne sposobnosti društva, uništiti kritičku svijest i ljudima nametnuti izvrnutu logiku?"   | |
|  26.11.2020., 18:06 | #5156 | |
| Extrema Thule Datum registracije: Feb 2005 Lokacija: 「 ✖ ✖ ✖ 」
					Postovi: 7,671
				 | Citiraj:
 Отправлено через SM-N986B
|  26.11.2020., 23:52 | #5157 |
					Postovi: 18,885
				 | Ja baš nemam sreće s ekranima. Od dva ThinkPada, kod oba problematičan ekran. Pokušao sam uslikati da bude koliko toliko blizu onome što ja vidim, ali je jako teško, pogotovo što ne mogu dobiti focus na pravom mjestu, a da slika liči na nešto, i još mobitel previše kompresira slike pa dobijem ove kao artefakte.  Problem je taj kao neki svjetli okvir uz sam rub, kao da neka tepsija stoji preko ekrana. Ali pošto je brightness bio na 100% dok sam pokušao uslikati, skužio sam da pomalo nestaje i nakon 10 min se skoro ništa nije vidjelo. Nije mi vrag dao mira, stavio sam bijelu boju da stoji neko vrijeme na max osvjetljenju jer sam to našao na Lenovo forumu i poslije toga je nestalo da bi se nedugo nakon što smanjim osvjetljenje počelo opet lagano pojavljivati. To sam napravio i na T580 i otklonilo je image retention problem, ali i to se vrati natrag. Sudeći po forumima, očito su im te novije serije ekrana malo u banani. Pošto radim u mračnijoj prostoriji, rijetko kad mi je brightness na preko 10% pa ga možda i to zeza, a na 20% i više već dosta blješti pa ga tako koristim kad sam vani. Ima li netko od vas takvih problema?
|  28.11.2020., 13:45 | #5158 |
					Postovi: 7,856
				 | Nakon što sam zagnjavio Nikkya još dodatno preko PM-a, moje kloniranje je uspjelo tek kad sam uzeo eksternu usb ladicu i klonirao disk na nativnoj platformi, tj. acronis true imageom iz winxp. Isproban je i Macrium Reflect, ali nema vajde na drugom računalu. Nakon ubacivanja ssda je vremešni x60s odmah bootao, malo se pobunio i nije imao driver za wlan i integrušu, ali je brzo dodano i ne vidim daljnje probleme. Maknuo pagefile, ugasio prefetch. Za povremenu upotrebu bi to trebalo funkcionirati kako treba  Hvala na pomoći
|  28.11.2020., 14:13 | #5159 |
					Postovi: 23,548
				 | Nisi ništa "zagnjavio", bitno da je beba ili starčić   oživilo i ubrzan. I da, bude tih situacija gdje je bitno da se odrađuje na nativnoj platformi. |
|  28.11.2020., 17:05 | #5160 | |
| Premium Datum registracije: Jun 2009 Lokacija: Zagreb
					Postovi: 2,392
				 | Citiraj:
  Ima čak i plastika za kanaliziranje žica, ali njih nigdje. Ah well, imate li preporuku za USB 4G modem i A1 tarifu? | |
