#2731 |
Možda nije do hardvera? Imam isti proc, jednako rama, i radi mi sve perfektno. |
#2732 |
Postovi: 12,613
1 x Intel Core i9-9900K 1 x ASRock Z390 PRO4 1 x Zalman CNPS11X Performa+ 1 x Corsair Vengeance LED 32GB (4x8GB) DDR4 3000 MHz 1 x Gainward GF GTX1050Ti, 4GB GDDR5 1 x SSD ADATA 512GB SX8200 Pro PCIe M.2 2280 1 x WD Blue 1TB SATA 1 x Lian Li PC-O11 Dynamic Midi kućište Crno 1 x Riotoro ENIGMA G2 PSU, 650W, 80 GOLD Ukupno: 10 781,40 kn
#2733 | |
Datum registracije: Sep 2018
Postovi: 8
mislim moguće, ali nemam ja problema dok mi nije masa tabova upaljena https://imgur.com/a/as6fNLC evo refresh 1-2 taba i cpu odmah leti na 90+, memorija je cijelo vrijeme tamo dok se ne počnu rušit tabovi ![]() @nino gdje si slagao ovo? |
#2734 |
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,627
NePitajPuno 1 * INTEL Core i7-10700 2.9GHZ LGA1200 16M Cache Boxed BX8070110700 S RH6Y Šifra: INT-0718 - 3.222,00 Kn 1 * Enermax ETS-T50A-FSS AXE hladnjak za procesore, S.775-2066/FMx-AM2-AM4, PMW 140mm ventilator, Twister Bearing Technology Šifra: 43901 - 421,00 Kn 1 * ASRock Main Board Desktop Z490 PHANTOM GAMING 4 Šifra: ASR-0029 - 1.386,00 Kn 1 * Crucial Ballistix 2x16GB (32GB Kit) DDR4 3200MT/s CL16 Unbuffered DIMM 288pin Black EAN: 649528824141 Šifra: BL2K16G32C16U4B - 1.528,00 Kn 1 * XFX Radeon RX 570 8GB, XXX Ed 1286M D5 3xDP HDMI Šifra: RX-570P8DFD6 - 1.421,11 Kn 1 * SSD 512GB Adata SX6000PNP PCIe M.2 2280 Šifra: 0141091 - 721,00 Kn 1 * WESTERN DIGITAL WD10EZEX 1TB Blue Šifra: WD10EZEX - 400,00 Kn 1 * Riotoro ENIGMA G2 PSU, 650W, 80 GOLD Šifra: RIO-PR-GP0650-FMG2EU - 921,11 Kn 1 * Kućište BIT FORCE Mid Tower Tiho Gaming PC SHADOW SE-2 Šifra: 2911102 - 443,33 Kn 2 * BIT FORCE PC ventilator CHILL 120 crni Šifra: 3010101 - 55,56 Kn ---------------------------------------------------------------------------- Sveukupno na rate: 10.519,11 Kn (-2%=10.308kn) Sveukupno s popustom za keš: 9.467,20 Kn (-2%=9.277kn) Besplatno slaganje i dostava |
#2735 |
Postovi: 34,038
Ja bi prvo pokušao sa ubacivanjem još rama. Isto tako mi je vrlo čudno da je proc zakucan na 95% samo zbog browsera. Baš sam bacio oko kod sebe. FF sa 6 tabova i još nekoliko programa u pozadini, troše cpu sa mizernih 1-2% s time da radim na office konfi koja je starija (i5 3330, 16Gb DDR3). Pritom guta oko 30% rama.
#2737 | ||
Postovi: 8
ima ssd da Citiraj:
to je bio prvi plan ali sam onda vidio da je i procesor često na max opterećenju pa sam zaključio da možda red da ubrzam i uzmem neš ranije od planiranog sve novo stranice su većinom razne burze i sl gdje se cijelo vrijeme osvježavaju cijene i sl tak da se definitivno dešava nešto u pozadini konstatno, pretsptoavljam da je to razlog opterećenja |
#2738 |
Postovi: 34,038
Ja bi ipak išao u smjeru nabavke još 8Gb rama i pokušaja reinstalacije winsa. Ili, stavi neki live Linux i probaj otvoriti isti broj tabova u njemu. Ako ne zakuca proc na tih 90+%, onda je do winsa, a nikako do hardvera.
#2739 |
Postovi: 8
a probat ću onda zasada tako pa ću vidjet šta će biti, nova kanta ide sigurno u bližoj budućnosti a linux tesko da ide gore ali za nove windowse bi bilo vrijeme ![]() |
#2740 |
Postovi: 1,658
Linux za test pokreni sa USB stick-a Reinstaliraš windowse, ispušeš kompresorom od prašine i eventualno zamijeniš pastu na procesoru. Ili odnesi u jedan od servisa da ti to naprave. Taj komp bi trebao letiti za to što tebi treba, stvarno nema smisla kupova ništa novo ako je komp samo za surfanje i office. Ja i dalje imam i7-920 sa 6GB memorije i GF 570 kao backup komp za puno ozbiljnije programe, i radi bez greške.
I never make the same mistake twice I make it five or six times just to be sure... |
#2741 | |
Datum registracije: May 2019
Postovi: 522
edit: Sad tek vidim da si cijene za kartice stavljao. U tom slucaju je msi 170kn skuplja, ali na ovu cifru i ovakvu konfiguraciju svejedno nema mjesta za onu asrock plocu... Za tu razliku bolje da uzme nesto jeftinije kuciste. Zadnje izmijenjeno od: guerra. 23.07.2020. u 15:38. |
#2742 |
Postovi: 34,038
@nepitajpuno Ne čitaš s razumijevanjem - live Linux znači da se Linux pokreće direktno sa dvd/usb sticka i da se ne instalira na hard disk. Koristi se baš za takve stvari tj. da se vidi je li problem softverske ili hardverske prirode. Znači, ako ti u Linuxu FF/Chrome sa otvorenih 20-30 tabova ne zakucaju procesor na 90%, definitivno imaš softverski problem (čitaj: winse treba reinstalirati) i nemaš potrebe za novom konfom (čitaj: uštedio si sebi +10k kn).
#2743 |
Postovi: 14,584
@Nepitajpuno Neštu tu smrdi, nebi ti trebao browser toliko napuniti cpu i memoriju. Taj pc je čak i overkill za to što si naveo. Možda si pokupio minermalware. Rađe si napravi clean install windowsa EDIT Ah nisam vidio drugu stranicu |
#2744 | |
Postovi: 8
da nisam nikad to radio, budem proguglao kak ak reinstall ne pomogne ![]() |
#2746 | |
Lokacija: Dublin
Postovi: 1,977
#2747 |
Datum registracije: Nov 2014
Postovi: 109
Pozdrav znalci, Zadnji komp sam složio prema vašim preporukama pa nastavljam u tom duhu i dalje ![]() Ta zadnja konfa je bila Intelova i radila je perfektno (5 godina ni brige ni pameti), a sada vidim da su AMDovi preuzeli primarnu ulogu što se tiče CPU-a :O Trebam komp ISKLJUČIVO za gejming (kanta + monitor). 100% ga NEĆU OCat pa pliz uzmite i to u obzir. Jedino što NE TREBAM su miš i tipkovnica, to ostavljam. Budžet je max 12k kuna za keš. Vidim da ovdje ekipa spominje 2% popusta za članove foruma i dodatnih 2% za kupovanje na keš, ali ne vidim uopće o kojem se dućanu radi niti mogu li to uopće iskoristiti (možda vrijedi samo za istaknute članove?!)? Pa eto, ako mogu dobiti samo ovaj popust za keš pliz uzmite i to u obzir. Volio bih sve uzeti u ADM-u i da mi oni to slože, ali ako se nešto promijenilo od zadnjeg puta naravno da ću uzeti gdje god preporučite. Neke posebne želje i pozdrave nemam, ali pod obavezno bih 1 TB SSD + neki best buy monitor (144hz) za oko 1500 - 2000 kn (minimum 24 inca, idealno 27*), kao i 32 GB RAM-a jer ne mislim kupovat ništa idućih 5 godina, a vjerujem da će mi trebati kasnije. Hvala unaprijed.. |
#2748 |
Postovi: 1,627
1 * Monitor 27" AOC Q27G2U, VA, 144Hz, 1ms, 250cd/m2, 3000:1, pivot, crni Šifra: 100.300.501 - 2.693,00 Kn 1 * Procesor AMD Ryzen 7 3700X Šifra: 0400500 - 2.776,67 Kn 1 * Hladnjak LC-Power LC-CC-120, Intel/AMD + AM4 Šifra: lcp-hlad-lc-cc-120 - 200,00 Kn 1 * ASRock Main Board Desktop B450 GAMING K4 Šifra: ASR-0004 - 861,00 Kn 1 * Corsair 2X16GB DDR4 3000 C15 Šifra: COR-CMK32GX4M2B30C15 - 1.368,00 Kn 1 * Sapphire RX 5700XT Pulse, 8GB GDDR6 Šifra: sap-rx5700xt-pul-8 - 3.778,00 Kn 1 * SSD Western Digital Green™ 1TB WDS100T2G0A Šifra: 0130860 - 893,00 Kn 1 * Napajanje Seasonic SS-650GB, 650W, 80+ Bronze Šifra: 0151690 - 600,00 Kn 1 * Zalman S4 PLUS Mid Tower Case Šifra: ZAL-S4 PLUS - 433,33 Kn Sveukupno na rate: 13.603,00 Kn (-2%=13.330kn) Sveukupno s popustom za keš: 12.242,70 Kn (-2%=11.997kn) Besplatno slaganje i dostava |
#2749 |
MiningMod
Postovi: 8,715
3700x mu ne treba za igre, tu je 3600 bb i onda utrpati rtx 2070 super. A i ram pogotovo nema potrebe 32GB. I bolje Bit Force Galaxy kućište jer ima bolje i tiše ventove od tog Zalmana. 1 * Procesor AMD Ryzen 5 3600, 6C/12T, 3.6GHz/4.2GHz, 32MB, AM4 Šifra: 0400496 - 1.644,44 Kn 1 * Hladnjak ID-Cooling SE-224-XT ARGB, 120mm, Intel/AMD Šifra: SE-224-XTARGB - 354,44 Kn 1 * GIGABYTE Main Board Desktop B550 GAMING X Šifra: B550_GAMING_X - 1.234,00 Kn 1 * Patriot Viper Steel, 3200Mhz, 16GB (2x8GB), CL16 Šifra: pat-vs416g320k-16g - 654,44 Kn 1 * Palit GF RTX2070 Super GamingPro, 8GB GDDR6 Šifra: pal-2070s-gp-8gb - 4.278,00 Kn 1 * SSD 1TB AD SX8200 PRO PCIe M.2 2280 NVMe Šifra: 0141105 - 1.332,22 Kn 1 * Napajanje Seasonic SS-650GB, 650W, 80+ Bronze Šifra: 0151690 - 600,00 Kn 1 * Kućište BIT FORCE Mid Tower ARGB Gaming PC GALAXY ARGB-4 Šifra: 2911104 - 598,89 Kn 1 * Monitor 27" AOC Q27G2U, VA, 144Hz, 1ms, 250cd/m2, 3000:1, pivot, crni Šifra: 100.300.501 - 2.693,00 Kn Sveukupno: 13.389,43 Kn Sveukupno s popustom: 12050,49 Kn -2 % za članove foruma, 11.810,00 Kn Ako je baš potrebno 32GB RAM-a, uzme se slabija B450 ploča. Zadnje izmijenjeno od: FRipper. 12.08.2020. u 10:16. |
#2750 |
Postovi: 1,627
rekao je da ne planira ništa kupovati u narednih 5 godina, vjerujem da će mu dodatne 2 jezgre i 4 threada dobro doći u tom periodu... ali kako goduzeo, ako se želi igrati na 1440p 144hz ne gine mu u tih 5 godina promjeniti grafu, uzeo sada rtx2070s ili rx5700xt Što se RAM-a tiče izrazio je želju za 32Gb, dali će mu u idućih 5 god trebat 32GB ili ne teško je reći. |
#2751 |
Postovi: 12,613
1 x GIGABYTE Main Board Desktop B550 GAMING X 1 x AMD Ryzen 5 3600 1 x G.Skill Ripjaws V (2x16) 32GB DDR4 3200MHz 1 x KFA2 GeForce RTX 2070 Super EX Gamer Black Edition 1 x KINGSTON 1000GB A2000 M.2 2280 NVMe 1 x GIGABYTE B700H Power Supply 700W 1 x Aerocool AERO-500G RGB White Midi 1 x AOC LCD 27" Q Wide , 1ms, 16:9, DP Ukupno: 12.000 kn
#2752 |
Postovi: 109
Svaka cast na brzini i savjetima! Danas cu uzet malo vremena pa proucit sto je sve napisano, javim se se pitanjima jer vec vidim da imam dosta upitnika nad glavom ![]() Edit: vec sam prakticki narucio jednu od gore predlozenih konfi i uletio mi je neplanirani trosak. A sada citam da vec 1.9. nvidia izbacuje 3xxx seriju pa pretpostavljam da je pametno pricekati jos mjesec dva sa nabavkom racunala, pogotovo jer je i intel poceo smanjivati cijene procesora, a i amd bi trebao izbaciti neke novine..Tako da hvala jos jednom i malo cu se strpit jer realno trenutna konfa i dalje vrti skoro sve, a moguce da za tih mjesec dva puno bolje prodem za istu lovu.. Zadnje izmijenjeno od: ppm3. 18.08.2020. u 10:06. |
#2753 | |
Postovi: 8
Ipak ću uzet nešto, ali ću uzet u protisu pa ak može mala prepravka jer nema svega ovog tamo. Znači trebao bi drugu grafu (ima slična ali neznam jel to ok?), kućište, napajanje i ventilator/e Zamjenio sam za onu dolje preporuku matičnu isto pretpostavljam da je upgrade za sitno $$ Hvala ![]() |
#2754 |
Powaaa user
Lokacija: Hrvatska, Zagreb
Postovi: 160
Pozdrav svima, Trebam savjet, kolega kupuje računalo za nekih cca 9.500-10.000 kn sa monitorom unutra i Windowsima, ostalo od periferije ne treba. Glavna namjena računala je gaming, nekih preferencija nema, eventualno da za koju godinu može ustekati jaci proc ili grafičku ako će trebati. Kupovati će u Zagrebu i platiti gotovinom, tako da to uračunate u cijenu. Ako treba još informacija za složiti konfiguraciju pišite! Hvala unaprijed na pomoći 👋🏻 Poslano sa mog SM-G986B koristeći Tapatalk |
#2755 |
Postovi: 1,658
Ako kupuje za gaming, neka čeka da stignu nvidia rtx30xx grafičke u dućane... prije toga nema smisla.... komp će mu vrijediti 3-4 tisuće manje kad dođu ove grafičke kroz koji tjedan
#2756 |
Postovi: 34,038
Windowse mu nema potrebe kupovati kod nas kad ih na ebayu dobije za kikiriki. Isto važi za Office i brdo drugog softvera.
#2758 |
Powaaa user
Postovi: 160
Tnx na odgovorima! Ima smisla onda slagati ostatak konfiguracije uopće ili jednostavno sačekati ovo sve? Poslano sa mog SM-G986B koristeći Tapatalk |
#2759 |
Ne kupuj ništa, strpi se još tjedan dana. ![]() |
