Staro 24.04.2020., 22:25   #391
microsoft66
microsoft66's Avatar
Datum registracije: Apr 2008
Lokacija: VK
Postovi: 1,267
Moguće je, SMR je već par godina aktualan, ali ih dosad nitko nije prokužil dok nisu počeli i NAS diskove trpati s tim.
Jel znas jel u ovom disku smr?
Btw,dosao mi red 4tb pa ga isprobam kroz koji dan
Staro 24.04.2020., 22:46   #392
Postovi: 8,426
Jedini 2TB 7.200rpm BarraCuda model za koji je Seagate priznal da ima SMR je ST2000DM008, dok je ovaj tvoj ST2000DM006, tak da bi trebal biti OK.
Staro 25.04.2020., 22:34   #393
microsoft66
Lokacija: VK
Postovi: 1,267
stigao mi wd red 4tb efrx i problemi
kad ga spojim na sata3 utor,prvo klikće pa zuji i nekako se došulja do windowsa i onda prestane zujat i kliktat ali ga windowsi nevide...kad opet opalim restart ponavlja se isto...PC je međuvremenu znatno usporen.
na tom sata 3 ulazu mi drugi disk od 2 tb radi bez problema..
sutra cu probati na drugom PC-u pa javim jesu li isti simptomi
Staro 27.04.2020., 15:31   #394
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,195
WD Sets the Record Straight: Lists All Drives That Use Slower SMR Tech
https://www.tomshardware.com/news/wd...smr-techNOLOGY
Network-Attached Storage or NAS devices have become critical for homes and small businesses that need to find a larger and more reliable storage solution.
These often use high-capacity, high-speed hard drives in RAIDs (Redundant Array of Independent Disks) for data reliability and integrity.
Imagine the surprise, then, of some NAS users when their favorite brand’s NAS drive starts to behave poorly in such a RAID setup.
The culprit, it turns out, is the technology known as Shingled Magnetic Recording or SMR.
Unlike Conventional Magnetic Recording (CMR), SMR overlaps tracks a bit when writing data to a platter, creating a structure that resembles the shingles on a roof, hence the name.
The compact structure is great for increasing the capacity of a hard drive but it comes at the cost of performance.
You can only read and write on SMR drives sequentially because you can’t write to a track underneath another without potentially damaging the data on the upper track.
That makes SMR drives a poor choice for RAIDs where random access I/O is more the norm.
Unfortunately, a report from the Blocks and Files site reveals that Western Digital’s Red NAS drive is actually using SMR even if it doesn’t state it in any documentation.
WD isn’t the only culprit, though, as both Seagate as well as Toshiba also later admitted some of their drives marketed for NAS use employ a technique that is known to be bad for NAS use.
None of these three HDD makers find anything wrong with the little white lies. They basically claim that what they explicitly advertise and document is “consistent” with the drives’ performance. NAS users, however, might beg to differ.
https://www.slashgear.com/wd-seagate...yers-17617133/
/connect 185.107.96.125:28990
server rcon: oldschool
Staro 28.04.2020., 20:58   #395
domy_os
domy_os's Avatar
Postovi: 18,897
Znači takvih gluposti (zasad) nema u Gold seriji?
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 29.04.2020., 10:50   #396
microsoft66
Lokacija: VK
Postovi: 1,267
wd 4tb nemogu nikako "vidjeti" windowsi
spojio normlano sata utorom,odem na disk menagment i kad treba odabrati MBR ili GPT dobijem ovaj error dolje na obje opcije
u bios-u sata opcija stoji na AHCI, jer IDE uopce nece da boot a onda bios ni nevidi WD disk tako da AHCI opcija mora biti ukljucena
sistem je win10 pro 64bit
pokusao ga spojiti na isti port gdje inace spojim 2tb koji normalno radi i nece
spojio na drugi sata port sa drugim sata kablom i opet isto
ikakvi prijedlozi?
Zadnje izmijenjeno od: microsoft66. 29.04.2020. u 11:13.
Staro 29.04.2020., 11:40   #397
Desni klik na ovo gdje piše "Disk 0 Unknown Not Initialized" oa odabrati "Initialize" ??? Jesi probao to?
Staro 29.04.2020., 11:49   #398
microsoft66
Lokacija: VK
Postovi: 1,267
Da, i onda javlja tu gresku,sta god izabrao
Staro 29.04.2020., 12:35   #399
Postovi: 8,426
Izgleda da je disk DOA, tj. potrefil te sfušani primjerak. Reklamiraj ga dok još možeš, uzmi novi i voljno. Nema smisla da se zajebavaš danima, a disk očito ne radi kak spada.
Autor domy_os Pregled postova
Mislim da su Red Pro, Gold i Ultrastar još uvijek CMR (barem dok ih ne sjebu SMR-om), ali ovi WD biseri zapravo tjeraju ljude da kupe skuplje diskove, ako im SMR ne paše. U svakom slučaju ih ne *ebe ni 5%.
Zadnje izmijenjeno od: The Exiled. 29.04.2020. u 12:43.
Staro 29.04.2020., 12:58   #400
microsoft66
Lokacija: VK
Postovi: 1,267
To mi je vec reklamirani disk pa kakve su mogucnosti da su 2 zaredom losa?
Ici cu danas do brata pa probat na njegovom pc-u
Staro 29.04.2020., 13:16   #401
Postovi: 8,426
Moguće da je cijela serija loša, ko bi ga znal. Možeš tražiti i nofce natrag da opet ne riskiraš s trećim u istom dućanu, pa fino odeš negdje drugdje po disk.
Staro 29.04.2020., 14:03   #402
microsoft66
Lokacija: VK
Postovi: 1,267
Živce ce mi pojesti ti hdd-ovi zivim za dan kad budu relikt proslosti
Staro 29.04.2020., 14:14   #403
c-shadow
c-shadow's Avatar
Postovi: 3,504
Nije dobro ako se uopće ne vidi disk. Na drugom kompu si probao?
Za takve stvari ponekad bude korisno dignuti neki live linux s USB sticka. Ako ništa, barem vidiš hrpu logova kernela pa imaš šanse razabrati jel problem u disku, kablu,....
Staro 29.04.2020., 14:21   #404
microsoft66
Lokacija: VK
Postovi: 1,267
Probat cu navecer na drugom pc-u
Prvi je cudno radio i usporio win maximalno uz istu gresku,a ovaj drugi radi ok ali i dalje ostaje ova greska...vidjet cu situaciju na drugom pc-u...
To za linux nema sanse da se zezam za disk koji je plug and play uz to nov uz to 1100 kn.
Ako tako zeza sad sta ce tek biti za 2-3 godine
Staro 29.04.2020., 14:40   #405
Postovi: 8,426
Ma nije to uopće normalno ponašanje za disk. Svi moji crveni su praktički nečujni, kamoli da bi odmah po prvom uključivanju kliketali ko ludi i još k tome usporavali OS. Stvarno je sasvim moguće da dućan u kojem ih kupuješ/reklamiraš ima neku sfušanu seriju, a zapravo nisu oni tu ništa krivi, jer je pošiljka stigla takva kakva je. Zato sam ti napomenul da, ako možeš, uzmi nofce i kupi isti takav disk u nekom drugom dućanu. Nema smisla da se zajebavaš u nedogled.
Staro 29.04.2020., 15:08   #406
Ili je disk/diskovi nekom ispalo iz ruke prilikom transporta ili skladištenja. Kakvi likovi rade tj kakve sam imao prilike vidjeti kod naših "većih" distributera na izdavanju robe, ništa nije nemoguće svaka čast ekipi koja radi, ali pojedinci kod određenih dealera... yikes
Staro 29.04.2020., 16:45   #407
nino
nino's Avatar
Postovi: 12,613
@microsoft66, koja ti upoce konfiguracija?
Staro 29.04.2020., 16:55   #408
Night
Lokacija: Dbk
Postovi: 1,314
Autor microsoft66 Pregled postova
Moguće je, meni su dva Reda od 4TB crkla u normalnom radu, a i dvaput sam dobio diskove mrtve zapakirane. Tako da su mi WDRed4TB uvjerljivo prvaci u crkavanju i nepouzdanosti, prešao sam na 8TB pa će valjda biti više sreće
E, da od ta dva što su krepala su simptomi bili kao u tebe, disk je počeo raditi sve sporije, dok se na kraju nije počelo događati da se nekad ni ne pojavi kod boota, pa reboot, pa se pojavi, pa onda čita pa stane, zapisi traju sto godina, dok na kraju nije potpuno stao.
Staro 29.04.2020., 17:06   #409
microsoft66
Lokacija: VK
Postovi: 1,267
i5 2500k,16gb ddr,ssd 250gb,rx 580
Ryzen 5,16gb ddr,m2 ssd 500,rx 580
Staro 29.04.2020., 17:31   #410
Postovi: 8,426
Di ste kupili diskove? Da ne ispadne da su vaši iz istog štacuna.
Staro 29.04.2020., 17:33   #411
Autor Night Pregled postova
Hijebote sad ste me baš obradovali moj je star 10 dana.
Nakon koliko dugo je tvoj usporio i počeo trokirat?
Staro 29.04.2020., 17:41   #412
Postovi: 8,426
Tvoj je iz Njemačke, a Švapske stvari se ne kvare, tak da si miran. Ja sam svoja tri 4TB prije puštanja u pogon, provrtil kroz par dana koristeći Data Lifeguard Diagnostic, pa moreš i s tim provjeriti.
Staro 29.04.2020., 17:47   #413
Imam to i odvrtio sam. Ok je.
Piše na njemu datum 21 JAN 2020 / Made in Thailand
Koji datum piše na tvome @microsoft66?
Staro 29.04.2020., 17:59   #414
Postovi: 8,426
BTW
Uzeo sam jednom dva komada od 4TB na PCexu zapakirana, jedan došao potpuno mrtav. Na poslu stavili 26 komada u Synologye, jedan krepao nakon mjesec dana, svi drugi nakon 2 godine još ok, tako da to i nije loše. Doma u računalu jedan od 4TB, odjednom samo postalo nemoguće čitati i zapisivati podatke, krepao. Nekidan kupio na Njuškalu novi zapakirani od 4TB, otpakirao ga, mrtav. Tako da nisu savršeni, ali rekao bih da su najbolje što se trenutno nudi za normalne novce, treba još vidjeti kakav će se IronWolf pokazati. Uz mirroring ili RAID5 bi WD Red trebao biti dovoljno pouzdan. Naravno i druga kopija podataka na nekom drugom uređaju dobro dođe.
Toshiba SMR detalji:
In the current range, the following drives do use SMR technology:
  • P300 6TB
  • P300 4TB
  • DT02 6TB
  • DT02 4TB
  • DT02-V 6TB
  • DT02-V 4TB
  • L200 2TB
  • L200 1TB
  • MQ04 2TB
  • MQ04 1TB
Staro 29.04.2020., 18:10   #415
wifi
wifi's Avatar
Datum registracije: Sep 2017
Lokacija: ST
Postovi: 240
meni je isto jedan od 6TB WD redova stiga neispravan, utvrđeno tijekom burn-in testa... reklamiran, i dali su novi.
Sto se 6TB Red sad tice, koliko vidim, na trzistu su samo ostali EFAX odnosno SMR, tako da se to sad komodno moze otpisat za koristenje u NAS-u. Unatoc losoj reputaciji Seageate-a, sad bi se vjerojatno prije odlucia na IronWolf, bar dok je jos uvik rijec o PMR (CMR) diskovima.
U rasponu do 4TB jos uvijek se moze nac EFRX varijanti pa kome triba, nek pozuri dok ima...
wifi je offline   Reply With Quote
Staro 29.04.2020., 20:12   #416
c-shadow
c-shadow's Avatar
Postovi: 3,504
Koliko vidim, ovdje je aktualna lista SMRova:
https://www.ixsystems.com/community/...mr-drives.141/
Naručio neki dan jednog IronWolfa, malo sam skeptičan jer je Seagate, ali vrijeme će pokazati kakav je.
Seagate je dao izjavu za onaj blocksandfiles da NAS ironwolf modeli nisu SMR, tako da je to vjerojatno dobra zamjena kad Red nestane.
Staro 29.04.2020., 20:40   #417
microsoft66
Lokacija: VK
Postovi: 1,267
Ista stvar i ista greska i na drugom kompu...definitivno je do diska...e pa ga jebi i srecu i sve
Staro 29.04.2020., 21:10   #418
c-shadow
c-shadow's Avatar
Postovi: 3,504
Gledaj na to ovako: dobro si prošao, bolje DOA nego da krepa nakon što ga napuniš
Staro 29.04.2020., 21:22   #419
Postovi: 8,426
Ili bude treća sreća s još jednim WD-om ili ovaj put idi na IronWolf, ako ti ne (po)nude nofce natrag.
Staro 29.04.2020., 21:24   #420
microsoft66
Lokacija: VK
Postovi: 1,267
Nije mi do novaca jer mi disk treba,zato i gledam preporuke i one kvalitetnije.bas mi se da zezat sa ovim
