Staro 11.03.2020., 10:10   #3571
Postovi: 16,881
ja nebi
The XS case will fit on an iPhone X but with a tiny gap around the bottom and right-hand-side of the camera bump on the back (about half a millimetre, not really noticeable unless you look for it). However the X case will not fit on an iPhone XS, as the XS camera bump is slightly bigger
Da, to sam skužio.
A ništa, probam uhvatiti neku za 100kn za prvu silu, pa uzeti s Amazona oriđiđi.
Staro 11.03.2020., 10:20   #3572
Dottore
Dottore's Avatar
Postovi: 7,660
Probaj vidjeti u Linksu. Uzeo sam oem silikonsku masku za 11 i koštao ravno 300kn.
Отправлено через iPhone
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 11.03.2020., 10:23   #3573
Postovi: 16,881
Autor Dottore Pregled postova
Ma nemaju, to sam prvo otišao ujutro.
Samo XS, XR, 11...
Staro 11.03.2020., 10:32   #3574
Spikeman
Lokacija: bi volio znat?
Postovi: 1,221
According to a source within Apple:
Apple’s March event is officially cancelled / not happening.
Staro 11.03.2020., 10:52   #3575
Garro
Postovi: 2,390
Ekipa, iPhone X, trebam hitno masku. Gdje kupiti nekakvu kvalitetnu masku do 250-300kn, danas u Zagrebu? Istok - Selska potez, može i novi ZG, samo da ne moram ići u centar.
Jesi zvao iKliniku na Fallerovom šetalištu?
Staro 11.03.2020., 10:58   #3576
Postovi: 16,881
Autor Garro Pregled postova
Hvala na ovome, u Selskoj sam taman, pa ću skočiti tamo vidjeti.
Staro 11.03.2020., 15:17   #3577
Garro
Postovi: 2,390
Jesi našao?
Staro 11.03.2020., 15:18   #3578
Postovi: 16,881
A nisam ipak stigao danas, morao hitno na sastanak se vratiti u VŽ.
Idem sutra ponovo u DC, pa ću probati naći vremena.
Staro 11.03.2020., 16:35   #3579
Dottore
Dottore's Avatar
Postovi: 7,660
Upitaj preko telefona. Nismo u kameno doba.
Za sve opcije postoji komunikacija
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 11.03.2020., 23:07   #3580
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,100
Obično uvijek nađem u shopping centru prečko, u prizemlju ima dućan s maskicama. Ima i na križanju selske i ozaljske neki
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 12.03.2020., 10:49   #3581
Postovi: 16,881
Da provjerim s vama.
Uzeo iphone X tu od kolege, ali imam problem.
Nije da ne vjerujem njemu, nego je možda problem i do mene.
Jučer osposobio taj iphone i jučer primjetio da me u pozivu druga strana ne čuje. Riješim problem tako da ugasim poziv i zovem povratno.
Od 10 poziva bar u 3-4 je tako.
Greška u mobitelu? Kartica je stara manje od godine dana, broj isto tako (uzimali nove brojeve u firmi).
Imao sam sličan problem na Samsungu S8, tamo sam riješio tako da sam ugasio 4G (što mi ne dolazi u obzir).
Imao netko sličan problem?
Staro 12.03.2020., 10:53   #3582
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,391
ako si napravio setup as new phone, time si eliminiro softver, apdejtaj na najnovio ios i to je sve što možeš, reset network settings eventualno
dal to može bit do kartice neznam pa neću komentirat
Staro 12.03.2020., 10:55   #3583
Postovi: 16,881
Sve od toga je odrađeno. Čim pališ novi iphone te traži da napraviš update iOS-a, tako da je to odrađeno.
Zadnje izmijenjeno od: Mommistake. 12.03.2020. u 11:01.
Staro 14.03.2020., 08:53   #3584
Remix
Remix's Avatar
Datum registracije: Dec 2019
Postovi: 78
Jesi t-mobile? Tako i meni dropaju pozivi na xs, traje dva tri dana tako pa prestane pa za mjesec ili dva opet ista stvar, traje par dana i prode. Valjda nije do uredaja i kartice nego mreze.
Remix je offline   Reply With Quote
Staro 14.03.2020., 10:29   #3585
Postovi: 16,881
Autor Remix Pregled postova
Da, čini mi se da je u redu zadnjih par dana.
Staro 15.03.2020., 12:11   #3586
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,100
Na koji način s Androida prebaciti Whatsapp backup na iPhone?
LCD: BENQ PD3200Q
Staro 15.03.2020., 12:13   #3587
prileee
laser
prileee's Avatar
Postovi: 2,346
Pa ako se dobro sjecam nebitno je koji je uredaj. Na starom odes na backup i napravis backup taj tren. Na novi install vacap i povuc ce ti sve nazad. Ako se dobro sjecam tako sam ja odradia kad sam prisa na SE. Nikakve dodatne ludosti. Cekaj jos koji odgovor da neko potvrdi ali mislim da je to to.
Staro 15.03.2020., 12:38   #3588
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,100
Android radi backup lokalno ili na google drive.
iOS to isto radi na iCloud i ne može povući s google drivea ništa.
Vidim da postoje alati (Wondershare), ali hoće 100$ za to
LCD: BENQ PD3200Q
Staro 15.03.2020., 12:41   #3589
thuNdeR
thuNdeR's Avatar
Lokacija: na sombra
Postovi: 1,048
Nemres nikak
thuNdeR je offline   Reply With Quote
Staro 15.03.2020., 13:07   #3590
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,100
Uzeo sam ovo, 30€
https://drfone.wondershare.com/whats...d-restore.html
Ako ne radi, lako tražim povrat preko Paypala. Javim rezultate
LCD: BENQ PD3200Q
Staro 15.03.2020., 14:02   #3591
Dottore
Dottore's Avatar
Postovi: 7,660
Javi povratno, prije sam to mučio i nije uspijelo.
Отправлено через SM-N975F
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 15.03.2020., 16:10   #3592
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,100
Javljam da je posao odrađen besprijekorno. Napravljen backup svega na Androidu i apsolutno sve je prebacio na iPhone. Sve slike, linkovi, video...sve je tu.
Relativno skup softver, ali vrijedi.
Eto, ako netko zatreba, rješavam probleme za pivu/rakiju i ostale dezinfecijske materijale tog tipa na bazi alkohola
LCD: BENQ PD3200Q
Staro 15.03.2020., 23:11   #3593
Wizzard
Wizzard's Avatar
Postovi: 493
Autor 1v@n Pregled postova
Jel može i viber odraditi ili samo whatsapp...tj jesi isprobao viber ?
CPU: Amd Ryzen 5 9600x cooled by Ac Freezer 36 Co
MBO: Gigabyte x870 Gaming X Wifi 7
RAM: 2x16gb ddr5 Kingston Fury Beast Rgb Expo 6000mt
VGA: ASRock Intel Arc B580 Challenger OC 12Gb
HDD: Nvme Kingston KC 3000 1TB+Cruical SSD BX500 1TB+1000Gb WD10EZEX-22MFCA0
PSU: SeaSonic G-Series (Gold) Modular 550 W
Case: Endorfy ARX 700 ARGB
Mause: Logitech G403 Hero
Monitor: Asus Tuf Gaming VG249 24"
OS: Win 10 X64 Pro
Wizzard je offline   Reply With Quote
Staro 16.03.2020., 12:02   #3594
Postovi: 16,881
Ove low light fotke na iPhoneu su valjda najbolji feature koji su uveli u zadnjih par godina.
Nevjerojatno što s fotke napravi.
Staro 16.03.2020., 13:12   #3595
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,100
Autor Wizzard Pregled postova
Nisam isprobao, jer ne koristim Viber, ali kaže da uz Whatsapp, može prebaciti još i LINE/Viber/Kik/Wechat. Ne vidim razlog zašto ne vjerovati.
LCD: BENQ PD3200Q
Staro 17.03.2020., 09:22   #3596
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
Ekipa - koja je caka sa Dark mode i Whatsappom na IOS-u?
Imam IOS 13, updatean WA, i navodno bi se dark mode automatski trebao uključiti u WA kada se uključi u IOS, ali nikako. Na oba telefona imam takav problem (8 i 6s)...
Da li sam nešto propustio? :/
Staro 17.03.2020., 09:25   #3597
Postovi: 16,881
Ja sam jučer primjetio da mi je došao taj Dark Mode u Whatsapp-u.
Nisam ništa dirao, update-ao niti mjenjao.
Tako da mislim da trebaš počekati. Žena na iphone x nema, ja na 11 imam.
Staro 17.03.2020., 09:28   #3598
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,100
Na 7 isto imam.
Vezano je uz Dark mode u samom iOS-u
LCD: BENQ PD3200Q
Staro 17.03.2020., 09:46   #3599
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,391
@sem fišer, pa odi u app store i apdejtaj, zadnja verzija je dark mode, nemože te zaobić ak si apdejto
Staro 17.03.2020., 10:03   #3600
prileee
laser
prileee's Avatar
Postovi: 2,346
Updejtaj app...
