Staro 17.09.2019., 20:56   #3181
Postovi: 8,330
Kaj se tiče AirPods čuda tehnike...
For roughly 18 months, AirPods play music, or podcasts, or make phone calls. Then the lithium-ion batteries will stop holding much of a charge, and the AirPods will slowly become unusable. They can’t be repaired because they're glued together. They can’t be thrown out, or else the lithium-ion battery may start a fire in the garbage compactor. They can’t be easily recycled, because there’s no safe way to separate the lithium-ion battery from the plastic shell. Instead, the AirPods sit in your drawer forever. AirPods are "below-average" in terms of sound quality. AirPods offer a lot of value for the price point despite a rating of "below average" sound quality. In reality, AirPods have pretty poor noise isolation.
According to Apple, AirPods are part of a larger vision for a “wireless future.” The Apple website introduces AirPods by stating, "Wireless headphones. Finally untangled." AirPods were introduced in 2016 alongside the debut of the iPhone 7 and 7 Plus, which eliminated the headphone jack. The earbuds are designed to seamlessly switch from iPhone to MacBook to Apple Watch, depending on which device you’re using. Thus, AirPods strategically glue together an ecosystem of luxury products. They are only so “convenient” because, by eliminating the headphone jack, Apple made the iPhone less user-friendly.
AirPods were destined to become e-waste from the moment they were manufactured. And AirPods become e-waste after just eighteen months, when the irreplaceable lithium ion battery dies.
What makes AirPods perform better with iPhones than other wireless headphones is its W1 wireless chip, which does three things:
  • It helps the earbuds communicate with your phone, computer, and with each other.
  • It enables fast device pairing, without needing to go into iOS system preferences.
  • It makes AirPods compatible with Siri, and able to make phone calls.
But the underlying technology that makes AirPods possible is Bluetooth. AirPods have a regular Bluetooth antenna in the stalk below the earbud area. In and of itself, it’s straightforward wireless technology that’s been around for twenty years.
Staro 17.09.2019., 21:08   #3182
bigAdvance
bigAdvance's Avatar
Postovi: 667
Moji imaju 23 mjeseci, rade uredno kao prvog dana.
Baterija kao sto sam i ranije napisao ne znam kakva je trenutno, ali zasigurno minimalno 3h drze, nikad ne gledam battery status na njima.
bigAdvance je offline   Reply With Quote
Staro 18.09.2019., 16:30   #3183
robee
robee's Avatar
Lokacija: VinkovcI
Postovi: 949
https://www.youtube.com/watch?v=fbxpWqGpHQ0
Covjek je vrlo realno rekao kako stvari stoje.
Meni je stvarno zao sto Apple vise nije kao prije no nadam se da ce se u skorije vrijeme trgnuti
robee je offline   Reply With Quote
Staro 18.09.2019., 17:21   #3184
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,393
netko je pitao za bateriju
ovih 5-6 recenzija što sam pogledao spominje se nekakvih ajmo reć ~3h extra
apple za pro max kaže 5h, za pro 4h, no ko zna kakvi uvjeti, tak da realno oko 3h
''The headline feature of the iPhone 11 Pro is the new camera system, but I’m going to start with battery life because I got so many questions about it. It seems like Apple made an incredibly obvious move this year: it made the phone a little thicker and put a bigger battery inside.''
Staro 18.09.2019., 17:26   #3185
bigAdvance
bigAdvance's Avatar
Postovi: 667
po prvim real world testovima pro max je 12-14 screen on timea (naspram 8-10 xs max), običan pro oko 10-11 (naspram 6-8).
tek ga imaju par dana na raspolaganju pa nije skroz mjerodavno
Staro 18.09.2019., 17:35   #3186
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,393
prvih par dana ajfon extra troši bateriju, znam jer sam dosta puta restorao ajfon as new
tek nakon nekih 4-5 dana se smiri i unormali
Staro 18.09.2019., 17:42   #3187
dadoremix
dadoremix's Avatar
Postovi: 4,717
kernela kompajlera .. set as new
Staro 18.09.2019., 18:06   #3188
Dottore
Dottore's Avatar
Postovi: 7,660
Takve rasprave kreću za vrijeme izlaska novih modela.
Za mene iOS dobar jer lakše snađe u menijama , jednostavni i lakši za korištenje. Tako i smatram sa Pixelom.
Jedini minus je što appovi već lagano prelazu preko 150Mb. ( ima neki preko 200mb)
64Gb je zasada standard ali brzo će polako biti usko. Vrlo moguće od modela osmice
Malo je debilno što početni model bude 64gb i nakon toga velika rupa do sljedećih 256Gb i 512Gb.
Za ram nikako ne prigovaram, radi fluidno i presavršeno.
Bio bi presretan da povećaju kapacitet iCloud, nije se mjenjao dugo.
Отправлено через Pixel
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 18.09.2019., 18:15   #3189
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,393
još je debilnije da ''PRO'' model počinje sa 64gb, al dobro, meni netreba pa ajde, al debilno mi je
Staro 18.09.2019., 20:59   #3190
Garro
Postovi: 2,390
Autor robee Pregled postova
Pogledao. Skoro svaku mu potpisujem.
Staro 18.09.2019., 22:20   #3191
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,393
da, pogledo sam to kad su objavili, sve štima
+ ne kužim zaš apple zaobilazi srbiju, bar da im daju kreirat account za app store
Staro 19.09.2019., 00:20   #3192
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,100
Sjeća li se tko Nokie?
Apple radi ono što je Nokia radila tamo cca. 2000. - 2005.
Sve što je kod konkurencije već bio standard, Nokia je trpala u svoje uređaje dosta kasnije, i to tek u najjače (najskuplje) modele.
Nokia serije 8 i 9, ili kasnije E i N, su mi onda bili u istoj kategoriji kao iPhone u ovoj svojoj eri postojanja.
Probao, vidio što može, nije me interesiralo. iPhone ima brutalne business deployment mogućnosti, što ljudi uopće ne znaju.
Integracija i administriranje Apple uređaja u poslovanju je daleko jednostavnije i brže, od bilo koje druge kombinacije.
Koga zanima više, može više saznati ovdje:
https://www.apple.com/business/it/
Ne znam mogu li nabrojati na prste obje ruke, tko od domaćih poslovnih korisnika uopće zna ili koristi te mogućnosti.
Idealni mobilni OS bi bio kombinacija iOS-a i Androida, zatvorenosti i otvorenosti, nešto što je bio Symbian svojevremeno.
Sjećam se problema s faksa gdje se nitko s OSX i iOS nije mogao spojiti na eduroam, jer koristi EAP-TTLS. Svi Androidi su se normalno spajali, jer su mogli primiti vanjske certifikate.
Kasnije je to riješeno, ali tek novom verzijom OS-a koja je stigla nakon skoro godinu dana. Nije Apple savršen, daleko od toga. Što sam stariji, sve su mi privlačniji, jer mi se više ne da čačkati ispod površine OS-a da bih napravio neke stvari i sigurno će doći trenutak kad ću odlučiti da ću platiti nešto više za taj luksuz.
Kao i s Nokijom tad, s Appleom je ista situacija. Dio korisnika će kupiti jer je već postojeći zadovoljni korisnik. Dio jer želi probati nešto novo i drugačije od onog što trenutno koristi. Dio će kupiti jer će se bolje osjećati.
Svatko svoj križ nosi, ne vidim zašto bi se morali sekirati ako vam susjedi i prijatelji istresu 10 000kn za iPhone. Isključivo je njihov problem ako im kvaliteta života zbog tog trpi. Ni prvi ni zadnji.
Jel stojite pred finim restoranima i prigovarate ljudima što jedu steak za 200 kn, kad su mogli otići na grah s kobasom za 25 i imati isti rezultat (pun želudac i pun wc)
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 19.09.2019., 01:25   #3193
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,393
kul je ovo, znači ne pojačava se samo zvuk nego i smanjuje ono što nije u kadru, wat
+ ovaj je dobre fotke okinuo http://austinmann.com/trek/iphone-11-pro-review-china
Zadnje izmijenjeno od: mamutarka. 19.09.2019. u 01:33.
Staro 19.09.2019., 02:40   #3194
Postovi: 33,993
Staro 19.09.2019., 08:52   #3195
Master_Hrc
Master_Hrc's Avatar
Lokacija: Bec
Postovi: 1,194
Iskreno, meni kad netko veli da mu pase AjFon, apsolutno uvazavam kao argument i tu bilo kakva rasprava prestaje. Covjek kupuje ono kaj mu pase i u cemu uziva. Ali, kad cujem prosere tipa da na androidu treba šarafit, treba znati programirati da bi promijenio brightness (karikiram), android se nakon 15 dana uspori (mozda se i uspori neki low budget šaomi za soma kuna ali se onda nemoze uspoređivati sa ajfonom od 10 hiljada kuna), android treba rootat i sličnu mitomaniju i demagogiju odmah mi padne mrak na oči. I u tom slučaju je to čisti fanbojizam. Čak sam i sam razmisljao i pitao na ovoj temu nedavno, da pređem na Ajfon čisto malo promjene radi ali na kraju sam odustao jer IMHO nisam vidio neke prednosti u odnosu na flagship koji sam trenutno imao...
Staro 19.09.2019., 09:55   #3196
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,393
opet dobar video, + ajfon tematika ga odvela u trending
Staro 19.09.2019., 09:59   #3197
Postovi: 16,888
Glupost.
Moje su preko godinu i nešto stare, 96% battery life, drže 3-4 sata, pune se bar 3-4 puta s jednim punjenjem.
Najbolji Apple proizvod ikad.
Staro 19.09.2019., 13:53   #3198
Postovi: 8,330
Baš i nije glupost, jer baterije u njima općenito gube kapacitet s vremenom, a i Apple uredno između ostalog (za finu cifru) nudi zamjenu/"servis" za korisnike koji imaju problema sa slušalicama koje polako, ali sigurno traju sve kraće i kraće.
Ne bi riječ rekel da na poslu svako malo netko nadobudno ne dolazi s fiks idejama za njihove AirPods slušalice. Lagano dobe odjeb, službeni link i snađi se druže.
Staro 19.09.2019., 14:21   #3199
Postovi: 16,888
A koji uređaj koji ima punjivu bateriju ne gubi kapacitet s vremenom?
Kažem ti, 2 godine su stare, koristim ih redovno, baterija nije kao i prvog dana, no da me biješ, ne vidim očiglednu razliku u trajanju od kada sam ih kupio i danas.
Osobno, čak mi i nije puno za popravak dati 300-tinjak kuna, ako će raditi sljedećih 2 godine ponovo.
Očekivao sam i veću cifru, poznavajući Apple.
Zadnje izmijenjeno od: Mommistake. 19.09.2019. u 14:27.
Staro 19.09.2019., 14:26   #3200
Postovi: 8,330
Tak jasno da svi gube, zato i velim da ipak nije glupost, jer kad polako skroz odu, možeš ih baciti u smeće.
Naravno da svaki korisnik ovisno o korištenju ima drukčija iskustva, pa nekom traju ko prvog dana, dok se drugi šeću po uredima u potrazi za bilo kakvim slušalicama dok im ne stignu zamjenske sa servisa.
Staro 19.09.2019., 14:47   #3201
srale7
srale7's Avatar
Postovi: 5,772
Glupost.
znači cca 14 mjeseci su stare
tu su vec dvije
Ako ih jos jednom spomenes, bit ce 3 godine, znači da tvoj primjerak ipodsa putuje kroz vrijeme
Staro 19.09.2019., 14:53   #3202
Postovi: 16,888
14 mjeseci je godinu i nešto? Po kojem to numeričkom sistemu?
Stare su godinu i 10 mjeseci.
Staro 19.09.2019., 14:59   #3203
srale7
srale7's Avatar
Postovi: 5,772
godina-12 mjeseci
godina i nesto-14-15 mjeseci, uglavnom manje od godinu i pol
godina i pol- 18 mjeseci
skoro 2 godine 18-24 mjeseca
Staro 19.09.2019., 16:53   #3204
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
$49 po slušalici.
Po našim cijenama, to je vjerojatno 49*10HRK*2=980kn.
Staro 19.09.2019., 20:28   #3205
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,104
Evo stigao mi update na iOS, odnosno mogucnost updatea na iOS 13. Velicina 2.03 Gb
Staro 19.09.2019., 20:30   #3206
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,393
Autor pogi Pregled postova
stavljeno u iOS temu već
Staro 19.09.2019., 23:59   #3207
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Gigabajti RAMa, kme, kme. Čemu to? U pravilu je okej lik, tho.
Također, kenja al ga kenja o smartphoneu od 300EUR, a prosječan iPhone kupac/korisnik ni nosom ne mrdne na takve uređaje.
Zadnje izmijenjeno od: IcyTexx. 20.09.2019. u 00:09.
Staro 20.09.2019., 09:34   #3208
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,393
kao pravi fanboy, prije amera
Staro 20.09.2019., 09:37   #3209
RimtuTiTuki
RimtuTiTuki's Avatar
Postovi: 1,649
I jesu ove kamere uživo jednako ružne kao i na slikama?
Staro 20.09.2019., 09:51   #3210
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,393
nemrem ti reć jer meni nisu ružne
mogu samo reć da je ovo staklo iza kul, izgleda ko aluminij,a i pod rukom je matirano
