#1261 |
Ex-Gastarbajter
Lokacija: Zagreb / Rijeka
Postovi: 5,463
bome imas veliki kofer ^^ ja sam gledao onog LG-a 27UK650 /27UK850 i uzivo izgleda jako fino. Doma imam 32UD59 (MVA) i jako se dobro moze kalibrirat ![]() ![]() |
#1262 |
Postovi: 2,937
Da taj kofer sam slučajno našao na tajlandu. U njemu nosio Acer 32" XB321HK (bio kod nas 8k+, naletio na njega u maleziji na 5k). Baš ciljam na taj LG 27UK650 (iako ima i UK600 verzija koja je samo 300$, ali se postolje ne može podići što mi ne paše :/). Druga opcija je LG 32UD99-W, al mislim da mi se ne isplati tolka razlika u cijeni (400 vs 900$). Ustvari, rađe bi 27 (da zamijeni sadašnji 27" lenovo QHD), samo se bojim da mi ne bude sve previše sitno.. pretpotavljam da ću morati scale stavit na 125 ili 150 (ovaj 32" acer mi je na 100 sad, al baš mi treba prostor na tom ekranu). |
#1263 |
Postovi: 14,584
#1265 |
hajde kome se da prouciti i testirati novi feature riva tunera SCANLINE SYNC i pojasniti princip rada ![]() Scanline Sync in the latest Riva Tuner is freaking AMAZING. Note: If you already have a Gsync/Freesync monitor then you don't really need this feature, since it's basically the same effect as Gsync/Freesync only in software instead of hardware in the monitor itself, but if you have monitor that is not Gsync/Freesync compatible, you should really try this IMO! also if your monitor supports strobing (ULMB/Lightboost/Dyac) Scanline Sync works in combination with strobing unlike Gsync/Freesync, then you can have best of both (three?) worlds, no lag - no blur - no tearing!, however it won't work so well if your GPU load is high, keep that in mind ! (Scanline Sync) is a GAME CHANGER for people with regular monitors https://www.reddit.com/r/nvidia/comm...riva_tuner_is/ https://www.reddit.com/r/nvidia/comm...ync_is_a_game/ |
#1266 |
Kostolomac
Postovi: 1,502
Probao se igrati s tim prije nego je Nvidia enableala Freesync. Treba imati ili jaku grafu, ili igrati na slabijim postavkama kako grafa ne bi bila opterećena više od 70%. Fora je da se tearing lokalizira na jednu ili dvije linije, ovisno o modu, i onda se treba poigrati sa offsetiranjem tih linija van ekrana. Na tim linkovima što si stavio je dobro objašnjeno. |
#1267 |
Datum registracije: Nov 2011
Lokacija: Ri,De,Čk,Zg itd
Postovi: 500
https://www.amazon.de/Samsung-C34J79...dp_ob_title_ce ima li smisla uzeti ili če doći još bolji i time jeftiniji za mjesec-dva ?
Brzi Picek |
#1268 | |
Datum registracije: Feb 2016
Lokacija: ______
Postovi: 1,455
Koju cijenu ti gledaš, tu od 767€? Od tih sellera nitko nije amazon.de. Cijena toga se kreće od 666€ na amazonu. https://www.hagglezon.com/de/s/Samsung%20C34J791 |
#1269 |
Datum registracije: Mar 2008
Postovi: 893
u posjedu sam AOC AGON AG322QC4 sada vec oko 2 mjeseca. Kvaliteta izrada je izvanredna, VA panel, slika je super. Zakrivljen ekran sto meni pase. QHD, 144hz Eksterni joystick za upravljanje menijem - super samo su ga mogli malo bolje napraviti u smislu navigacije ali eto...no sam joystick na monitoru je izvanredan takoder. Osvjetljenje je OK, ja ga ionako imam na off. HDR je onako ovisi od igre do igre kuzim ga ali nije sada WOW. jedva 400 peak svjetline. Stalak je vrhunski iako osobno volio bih da se moze jos vise spustiti. Trebate dosta velik stol kako god okrenete. Mana je sto ne radi FS s Nvidia karticom kako treba, vidi se ghosting i titra ekran s ukljucenim FS-om.. meni je to nebitno jer ionako su mi Syncovi na off Odziv ekreana je super, MP naslove igram kao veliki ![]() iako moram priznat da sam presao s Acera Predatora x34a na ovo pa me tesko nesto moze ostaviti u WOW efektu. Koliko sam pratio ima i jeftiniji bez HDR-a 8\10 - preporuka svakako za kupnju. |
#1270 |
Postovi: 16,803
A gledaj, to je monitor od 600EUR, mora biti dobar. ![]() |
#1271 |
Postovi: 1,212
Gledam kupiti 4k 43" Philipsa Stvar je u tom da ću možda dan, 2 moći raditi od doma, a i inače znam nakon posla raditi na službenom laptopu. Kupio bi dock za njega i i svoj 32" AOC te 23" LG u portraitu zamjenio za njega. Koliko sam skužio mogao bi imati svoj desktop i službeni istovremeno na njemu pa podijeliti sliku po pola i onda imati 2 "ultra wide" monitora? Ako se to može, može li se jedna od tih polovica prepoloviti i od nje napraviti dual monitor set-up (2x1080p) tako da mogu imati na službenom kompu otvorena 2 1080p RDP-a u full screenu jedan do drugoga? 80cm sam udaljen od monitora, ali pošto neću gledati cijelu sliku istovremeno mislim da bi trebalo biti ok.
Jel' ima šta ženskih starih
što vole strance da nas vozaju u autu i kupuju skupe lance |
#1272 |
Postovi: 500
Upravo i sam gledam taj monitor, ali nemoguće je da je po toj cijeni da je monitor osim ako nije kakav vračen https://www.amazon.de/s?k=Philips+BD...ref=nb_sb_noss Ali ja ču uzeti ovaj skuplji Philips 436 M6VBPAB/00 dođe za par dana, a jamstvo u €U, pa na kraju ispada da je svejedno di kupio Ako ne grešim
Brzi Picek |
#1274 |
Postovi: 16,803
Samsung C34F791WQ Bio je ispod 6000kn. Ako je za gaming, stisnuo bi još zube, dodao 500kn i uzeo Alienware AW3418DW. |
#1276 |
Postovi: 380
#1277 |
Postovi: 16,803
#1278 |
Postovi: 1,358
https://www.youtube.com/watch?v=-xDNVl3LlVs Monitorac za prave muškarce i one koji bi takvim željeli biti! Molim curice da ne otvaraju poveznicu!
AMD Ryzen 5900X; Gigabyte Aorus X570 Elite; Corsair Vengeance RGB Pro SL DDR4 2X16 Gb 3600 Mhz; AMD Radeon Gigabyte 7900 XTX; SSD Patriot Viper VP4300 PCIe m.2 GEN4 2 Tb;Lian Li 011 Dynamic EVO; LG C2 |
#1279 |
Lokacija: Solin.
Postovi: 262
Tribala bi mi preporuka za monitor,G sync kompatibilan.Koristicu ga za igranje igara i gledanje videa na you tube.Graficka kartica na koju cu spajat monitor je Nvidia RTX 2080 Ti.Triba mi ultra hd rezolucija,dijagonala ne manja od 30 inch,ravni ekran,format ekrana moze bit bilo koji.Mogu platit najvise 12000 kn.Kupujen monitor za najvise nekoliko dana. |
#1280 |
ODUZIMAM VAM RIJEČ
Postovi: 13,356
#1281 | |
Lokacija: Solin.
Postovi: 262
#1283 |
Pijem samo KAJ
Lokacija: Vž
Postovi: 2,688
Jel valja ovo? https://www.futura-it.hr/samsung-mon...m_medium=click Namjena je ured, nikakvo igranje. Hvala |
#1284 |
Postovi: 10,074
Dosta je sirok za VA matricu, provjeri koliko se "degradira" prikaz prema kutevima ovisno o udaljenosti s koje ga mislis gledati. VA ima uzak sweetspot nakon cega boje i crna pocnu blijediti ako ti je to bitno
#1286 |
Postovi: 16,803
Misliš gejmati na tom monitoru s tom 1060? |
#1288 | |
ODUZIMAM VAM RIJEČ
Postovi: 13,356
#1289 |
Postovi: 10,074
Ako znas koga s VA telkom moglo bi pomoci da steknes dojam kako se matrica ponasa pod kutem. Ili proguglaj usporedbe s IPS-om. Imam VA tv i meni osobno ne smeta, bitno da se boje ne mijenjaju, a to sto svjetlina skoci mi je podnosljivo. U radu bi mi vjerojatno smetalo, nisam probao. Ovisi koliko daleko sjedis (kut pod kojim gledas krajeve je uvijek manji i nepovoljniji) i sto radis (u exelicama neces primjetiti nista heh).
#1290 |
Pijem samo KAJ
Lokacija: Vž
Postovi: 2,688
Moje razmisljanje: VA ima dosta bolji kut gledanja od TN-a. Ova 2 samsunga kaj sad imam su sira s okvirima od jednog 34" 21:9. Dakle, ovo mora biti bolje kako god okrenes ![]() Al probat cu bas naci nekog kaj ima VA da vidim uzivo. Bavim se obradom prostornih podataka (3d lasersko skeniranje, fotogrametrija) i arhitekturom tak da mi nije od zivotne vaznosti da u svakom kutu imam 100% jednake boje (iz tocke gledista) ![]() |
