Staro 26.09.2018., 00:45   #2281
shar
Overclocker
shar's Avatar
Datum registracije: Nov 2016
Postovi: 523
Vidjeli da stvar prolazi sa "nestašicom" rama pa eto da i oni malo probaju sa "nestašicom" proceva. Jel se kome dogodilo da je u zadnjih godinu dana ušetao u bilo koju IT trgovinu i da nije vidio paletu rama u ponudi?
shar je offline   Reply With Quote
Staro 27.09.2018., 20:50   #2282
Postovi: 8,336
Tight supply of Intel processors unlikely to ease until 2H19
The ongoing tight supply of Intel's processors is unlikely to ease until the second half of 2019 and will undermine worldwide notebook shipments during the upcoming peak season, according to Martin Wong, president and CEO of Compal Electronics. Wong noted that so far Intel has not yet given its downstream partners a clear schedule on when the shortages can be resolved. In response to the CPU shortages, Intel noted that it has been cooperating closely with its partners to manage their extra orders and its supply priority will be given to Xeon and Core series processors including the latest eighth-generation U and Y series. Acer recently noted that the shortages are not only affecting certain individual brands, but the notebook market as a whole. Wistron originally expected its notebook shipments to grow 5-10% sequentially in the third quarter, but has already cut the forecast to 5% or less. Inventec expects its third-quarter shipments to rise by a single-digit percentage sequentially and stay at the same level in the fourth quarter, while Quanta also expects a single-digit percentage sequential growth for the third quarter shipments, but was unable to give an estimate on its fourth-quarter performance. However, some market watchers are still optimistic about the situation and expect the problem to improve in the first quarter of 2019.
Izvor: DigiTimes
Staro 29.09.2018., 20:07   #2283
the_ghost
lar~
the_ghost's Avatar
Postovi: 1,557
Da, cijene gore i market share dole:
https://imgur.com/a/YMIHjSk
Staro 30.09.2018., 01:16   #2284
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Staro 01.10.2018., 08:27   #2285
Postovi: 8,336
Intel HEDT Platform to be Forked into Z399 and X599
Intel could very soon fork its high-end desktop platform into two, with the introduction of the new Z399 socket LGA2066 chipset later this quarter; and the fabled X599 chipset powering LGA3647 processors. The move is probably triggered by AMD's introduction of new 24-core and 32-core Ryzen Threadripper processors that wipe out competitiveness of its existing "Basin Falls" X299 platform. The X599 could essentially be a C629 with the addition of some client-segment features (and the subtraction of some enterprise-segment ones), whereas the Z399 is a whole different beast.
With the introduction X599 and LGA3647, Intel could restore competitiveness at the >$1,500 market segment with new 24-core, 26-core, and 28-core "Skylake-X" XCC (extended/extreme core count) processors; whereas the introduction of Z399 could be necessitated with a that of a new 22-core chip for the LGA2066 socket, from which Intel can carve out new 20-core and 22-core SKUs. Existing Skylake-X LCC and HCC chips could be forwards-compatible with Z399, and X299 motherboards could still be eligible for supporting new 20-core and 22-core processors via BIOS updates. The Z399 could introduce a handful of new client-segment features Intel is introducing with the Z390.
Since the LGA2066 platform won't be "extreme" anymore as that distinction gets reserved for LGA3647, the "X" in the chipset name gets replaced by "Z." This could also help consumers tell Intel's platform apart from AMD X399, which powers two generations of Ryzen Threadripper processors. Intel could hence use Z399 and the new 22-core die to compete with 2nd generation Threadripper X-series processors, while the X599 and 28-core processor could deal with Threadripper WX-series.
Izvor: TechPowerUp
Staro 01.10.2018., 11:48   #2286
sakomako
Datum registracije: May 2013
Lokacija: nigdje
Postovi: 599
Jedno pitanje?
U PC imam 4 HD i 2 SDD.
Recimo diskovi 1 do 6!
Kopiranjem sa diska 1 na 2 brzina je maksimalno moguća i ovisi o brzini sporijeg uređaja.
No ako istovremeno počnem kopirati sa diska 3 na disk 4, brzine se spuste na pola ili niže.
Ovo govori da propusnost chipseta ima problema, jer kopiranje sa diska 1 na 2 i sa diska 3 na 4 nije međusobno povezano osim preko chipseta, odnosno kontrolera na njemu. Sistem se vrti na recimo disku 5. Dakle kopiranje među diskovima bi trebalo raditi u pozadini, no ta operacija ima utjecaja na brzine kopiranja ako je istovremeno aktivno više od 2 HDD ili SD neovisno o uređaju, ali ako se vrše istovremeno 2 kopiranja brzine padaju, a diskovi se međusobno ne križaju, pa da ide s 1 na 2 uređaja i obratno, već se radi o potpuno dva odvojena para uređaja što se tiče kopiranja.
Dali su nešto tako popravili u ovim novim koje najavljuju ili je sve po starom?
Meni je dosta glupo da se zbog operacije kopiranja sa diska na disk zaguši chipset, ako se kopiranje vrši istivremeno na 4 uređaja koji se nigdje međusobno ne križaju.
I kako tako nešto radi na AMD, jer sa njima nemam iskustva, ali Intel definitvno sa time ima problema i stvar je ista na starim i najnovijim pločama.
sakomako je offline   Reply With Quote
Staro 01.10.2018., 12:46   #2287
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,760
Autor sakomako Pregled postova
Ako ti je to "glupo", kupi posteni kontroler i nemas brige.
Programer
Staro 01.10.2018., 13:01   #2288
sakomako
Lokacija: nigdje
Postovi: 599
Autor Bubba Pregled postova
To sam imao nekada davno sa SCSI diskovima. No kako tehnologija napreduje čovjek očekuje da su se kontroleri u Intelovim chipsetima popravili, ali očito nisu. Za AMD neznam kako rade, no nekako mi se čini da bi trebalo ipak nešto bolje nego kod Intela?
Staro 01.10.2018., 14:00   #2289
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,760
Uopce ne vidim sto je sporno. Oprema koju ti kupujes ionako nije namijenjena za takvo sto. Tko normalan doma ima 6 diskova, od kojih su dva SSD a 4 HDD? I jos kopira simultano s jednog na drugi.
Ako imas takve potrebe, kupis takav hardver koji to moze odraditi bez problema. A posto takve potrebe nitko "za po doma" nema, moras ici na ozbiljniju opremu. Nema to veze ni s Intelom, AMD-om ili necim trecim.
Ti kupi pa nam javi.
Programer
Staro 01.10.2018., 20:54   #2290
Postovi: 8,336
Koju ploču imaš, tj. koju Intel platformu uopće koristiš? Također, nisu svi SATA konektori spojeni na isti kontroler, pa ploča koristi ASMedia SATA kontroler za određene (najčešće dva) SATA konektore. Isto tak, ovisi o ploči i proizvođaču.
Staro 01.10.2018., 23:24   #2291
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,829
Bubba, sakomako, The Exiled, OVO JE THREAD O INTEL PROCESORIMA i totalno ste off topic.
Sinac je online   Reply With Quote
Staro 02.10.2018., 01:08   #2292
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,403
to je to, kupujem
Staro 02.10.2018., 07:07   #2293
sakomako
Lokacija: nigdje
Postovi: 599
Autor Sinac Pregled postova
Nisi u pravu. Ovo je tred o CPU i chipsetima, a dio chipseta su i kontroleri, koji nisu baš nešto kada ih malo jače opteretiš.
Poseban kontroler za HDD i SD za takvu upotrebu košta često puta više od top CPU.
Kada reklamiraju chipsete onda se hvale sa brzinama koje su u praksi očaj.
Evo jesam li malo pojasnio da ovo spada u ovu temu.
Staro 02.10.2018., 08:52   #2294
Sinac
Sinac's Avatar
Postovi: 2,829
VIDI GORE:
Vijesti i novosti o Intel procesorima i čipsetima
Što točno od tvojih postova spada u vijesti i novosti o čipsetima? Ne smatraš li da to spada u hardverske ili softverske probleme?
Staro 02.10.2018., 09:42   #2295
U pravu je. Ovo je thread za vijesti i novosti, a ne za želje i pozdrave
Daj se molim te malo konsolidiraj.
Otvori thread Intel ICHxx problematika ili tako nešto i brate piši koliko hoćeš. Ovo nije tema za to.
Sent from Usreo Mobara
Staro 02.10.2018., 09:57   #2296
sakomako
Lokacija: nigdje
Postovi: 599
VIDI GORE:
Pitanje za neki link:
"propusnost chipseta ima problema"
A sa prethodne dvije rečenice u onoj poruci sam objasnio osnovne stvari koje se događaju i gdje je problem.
Dakle pitam imali vijesti o tome dali su popravili išta od toga u novim najavljivanim chipsetima?
Najlakše je Intelu nacrtati blok shemu chipseta i tamo napisati 6 ili više SATA konektora koji idu preko intrenog kontrolera, napisati super brzine, ali kada to pokreneš u praksi jad i bijeda.
Zadnje izmijenjeno od: sakomako. 02.10.2018. u 10:04.
Staro 02.10.2018., 10:01   #2297
Ono što je Bubba rekao, koga zanima propusnost i ostale stvari oko kontrolera, ne kupuju ploče od 2000 kn sa RGBT osvjetljenjem nego malo ozbiljnije stvari.
Koliko ja znam, lntel piči skoro isti kontroler godinama i sigurno je da neće se pretrgati da ga unaprijede u ovom consumer segmentu.
Tako da je ovo tema previđena više kao orjentir na same procesore i čipset podršku za consumere sa težištem na gamingu, dok se sa propusnosti nitko previše zamara
Staro 08.10.2018., 17:12   #2298
Postovi: 8,336
Intel Announces Xeon W-3175X: 28-Core Processor for Extreme Workstations
Intel officially introduced its 28-core processor for extreme workstations that it teased first back in June. The new chip comes with unlocked multiplier and can run at up to 4.3 GHz in burst mode. The Intel Xeon W-3175X CPU is based on the Skylake/Cascade Lake microarchitecture and is compatible with motherboards featuring Intel’s LGA-3647 server-based socket. The CPUs runs at 3.1 GHz stock, but can increase its frequency to 4.3 GHz, it features a six-channel DDR4 memory controller that supports up to 512 GB and a massive 38.5 MB cache. Since the chip uses a new socket, it is naturally not compatible with any motherboards available on the market. Meanwhile, to date, only ASUS and GIGABYTE have confirmed plans to offer mainboards for Intel’s Xeon W-3175X. The new 28-core processor has a massive TDP of 265 W and considering the fact that it comes with an unlocked multiplier and can be overclocked, that power draw may get even higher. The ASUS ROG Dominus Extreme is one of the first motherboards specifically designed for the Xeon W-3175X processor. The platform features not one, but two 24-pin power connectors to ensure that the processor and other components have enough juice.
Izvor: AnandTech
Staro 09.10.2018., 12:59   #2299
Wozniak jR.
humanware
Wozniak jR.'s Avatar
Datum registracije: Mar 2009
Lokacija: zGb
Postovi: 456
Wozniak jR. je offline   Reply With Quote
Staro 09.10.2018., 13:39   #2300
Gigi1
Postovi: 2,138
Nista neocekivano od takve kompanije, smecari bili-smecari ostali
Staro 09.10.2018., 18:31   #2301
Postovi: 8,336
Usporedbe su im na mjestu: Core i9-9980XE vs. Threadripper 2990WX, jer eto - koštaju isto (~2.000$).
I naravno naglasak na eSports - pogotovo za HEDT platformu.
  • More cores doesn't always equal more performance
  • Performance is more than just a simple Cinebench number
Nevoljko (o)stavljam ovaj link, ali kanadska dvorska luda je već prije mjesec i pol dala naslutiti kakav bi mogel biti rasplet situacije.
Staro 09.10.2018., 21:20   #2302
DuHc
DuHc's Avatar
Lokacija: Dubrovnik
Postovi: 204
Nadovezano na Hardware Unboxed video: Intelova dosljednost i neovisno third-party testiranje.
Gamers Nexus: Intel's Gross Incompetence & Principled Technologies
DuHc je offline   Reply With Quote
Staro 09.10.2018., 21:21   #2303
Gigi1
Postovi: 2,138
Intel je stvarno spao na niske grane kad stavlja svoj potpis na ovakvu tragikomediju od benchanja i onda jos to koristi u sluzbenoj prezentaciji
https://youtu.be/D1mJMI_uaa8
Staro 09.10.2018., 21:36   #2304
Postovi: 8,336
Kog vraga im je to trebalo. Mada izgleda kao logičan nastavak na prijašnje (1 - 2) pizdarije. U međuvremenu, (pre-order) Core i9-9900K ni više ni manje, nego duplo skuplji (1 - 2) od Ryzen 7 2700X modela.
Staro 09.10.2018., 21:55   #2305
Manuel Calavera
Postovi: 14,584
Koliko sam shvatio pokušavaju odigrat "nvidia rtx" šemu, recenzije ne smiju vani još 10 dana, a cpu pušeni na preorderanje
Pa da ne kupuju baš ful na slijepo kao rtx izbacili koju plaćenu recenziju da pripomognu...
Staro 09.10.2018., 22:14   #2306
Gigi1
Postovi: 2,138
Kolko oni placaju svoju PR ekipu, ili imaju neki broken AI da odgovara...
We are deeply appreciative of the work of the reviewer community and expect that over the coming weeks additional testing will continue to show that the 9th Gen Intel Core i9-9900K is the world’s best gaming processor. Principled Technologies conducted this initial testing using systems running in spec, configured to show CPU performance and has published the configurations used. The data is consistent with what we have seen in our labs, and we look forward to seeing the results from additional third party testing in the coming weeks.
Staro 09.10.2018., 22:55   #2307
Max Rockatansky
Lokacija: Zg/Zd
Postovi: 718
Naravno da ide preorder, treba se pripremiti za navalu na 20$ jeftiniji 7980XE .
Staro 09.10.2018., 22:59   #2308
Postovi: 8,336
Najgore od svega je to da se i dalje ponašaju ko da je upravo lansiran Conroe ili Sandy Bridge, dok svijet stoji na mjestu.
Razlike u cijeni su skoro, pa nepostojeće, dok je 14nm++ proces jedina "novost" u osvježenoj Skylake-X seriji.
The benchmarks carried out by Principled Technologies are even more bogus than we first thought. A few viewers pointed out that the Ryzen 7 2700X was listed as tested in the “Game Mode” within the Ryzen Master software and I foolishly thought they might have just made a simple copy and paste error in their document as they would have used this mode for the 2950X. This does explain why the Threadripper CPUs were faster than the 2700X in every test. What this means is a CCX module in the 2700X was completely disabled, essentially turning it into a quad-core. I’ve gone ahead and re-run the XMP 2933 test with Game Mode enabled and now I’m getting results that are within the margin of error to those published by Principled Technologies. This is unbelievable, I don’t know if they are being extremely malicious or it’s just incompetence of the highest order. How do you take note of every last setting to be documented but not realize just 4-core/8-threads are active on an 8-core/16-thread processor?
Izvor: Hardware Unboxed
Zadnje izmijenjeno od: The Exiled. 09.10.2018. u 23:27.
Staro 09.10.2018., 23:28   #2309
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
..nakon toliko godina ponašanja po istom obrascu, sad se svi odjednom kao nešto čude
..kako bi rekao hebrang, nije "lagao"
..kalkulirana patka koja će im sigurno donijeti više nego što mislimo, generalno par nas koji te stvari pratimo njih ne dira, iako se pomalo stvara neka masa koja je počela malo to balasirati više nego prije.. ali još uvjek smo nebitni.
https://www.youtube.com/watch?v=D1mJMI_uaa8
PS
..muce vas predizborna obecanja? sjetite se toga kad cujete rezultate poslije bilo kojih izbora
..u prijevodu, dok ima ovaca biti će i vune
MojSkuter
Zadnje izmijenjeno od: Eladio. 09.10.2018. u 23:36.
Staro 09.10.2018., 23:52   #2310
Postovi: 8,336
Ovo je lagano nadišlo i Intel i AMD i marketing nadmudrivanja. Ovo je fini materijal za kakvu Jo Nesbo i Jussi Adler-Olsen knjigu.
Samo kaj u ovom slučaju, Harry Hole i Carl Morck + sektor Q ganjaju recenzente po Internetima.
Ili to ili kak i priliči, pa u maniri (meksičke) sapunice, glavni glumac (Intel) u posljednoj epizodi sazna da je sam sebi brat.
