Postovi: 7,568
Novi procesori nakon 4. mjeseca '06.
Advanced Micro Devices is reported to unveil its central processing units (CPUs) in the second quarter of the year 2006, after April. The ramp of DDR2-supporting chips will be quick as the chipmaker plans to release DDR2 supporting chips for different market segments, including desktops and laptops at approximately the same timeframe. Socket M2 will be used for AMD Sempron, AMD Athlon 64, AMD Athlon 64 FX and AMD Opteron 100-series processors and will substitute existing Socket 754, Socket 939 and Socket 940 desktop and workstation infrastructure. For AMD Opteron processors for 2P and MP servers AMD reportedly prepares a 1207-pin socket F that will be utilized instead of Socket 940. For mobile computers AMD is expected to offer Socket S1 with 638-pins, which will replace existing Socket 754 for laptops. Izvor: www.xbitlabs.com Zadnje izmijenjeno od: McG. 14.12.2005. u 22:08. |
Lokacija: Zabok
Postovi: 3,419
Novi mainstream socket će se službeno zvati AM2, baza HT/LT-a će biti 333Mhz, a AMD do kraja drugog kvartala 2006. namjerava u opticaj stavit svu silu procesora: Windsor AMD Athlon 64 FX-62 AMD Athlon 64 X2 5000+ AMD Athlon 64 X2 4800+ AMD Athlon 64 X2 4600+ AMD Athlon 64 X2 4200+ Orleans AMD Athlon 64 4000+ AMD Athlon 64 3800+ AMD Athlon 64 3500+ Manilla Sempr0n 3600+ Sempr0n 3500+ Sempr0n 3400+ Sempr0n 3200+ Sempr0n 3000+ izvor: http://theinquirer.net/?article=28367 |
Postovi: 7,568
Bome zanimljiva bu ta '06. |
#4 | |
Datum registracije: Jun 2004
Lokacija: Xindi weapon
Postovi: 441
) Ne kužim se baš u ddr2... I ako kupiš ddr 800 mem te neće kočiti do 20+%OC? |
#7 | |
Postovi: 4,190
Postovi: 680
Joj da, sorry. S939 procovi rade na 1000, to je izvedeno kao 5x200, jelda? Mea Culpa. No, i dalje ostaje cinjenica da nema razlike u perfomansama radi li memorija sinhrono ili asinhrono.
#9 | |
Pink Floyd fan
Lokacija: Santa Clara, CA
Postovi: 5,545
Postovi: 680
Sta se sad razmeces?
#11 | |
Postovi: 1,606
#12 | |
Warcraft III TFT
Postovi: 862
#13 | |
Postovi: 1,606
dakle, nisam se slagao da je ČINJENICA da nema razlike u performansama držao ti memoriju sinkrono ili asinkrono... stvarno ne znam u čemu je problem... |
#14 | |
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,795
#15 | |
Postovi: 680
Na Athlon XP-ima je djaba bilo povecavati takt memorije, ako ce raditi asinhrono s procesorom, jer je dolazilo do degradacija perfomansi (odnosno, morao bi "potegnut" poprilicno veci takt da kompenziras gubitak perfomansi zbog asinhronog rada).
Zadnje izmijenjeno od: sick_boy. 20.12.2005. u 19:29. |
#18 |
Lokacija: Kutina
Postovi: 1,208
na K8 ne postoji 'sinkroni' način rada. mem kontroler je u procu, to valjda svi znaju. iz toga proizlazi da je memorija uvijek na dijeljitelju zato što je brzina memorije derivat brzine procesora a ne sistemske sabirnice kao na drugim arhitekturama. cijela ova sinkrono-asinkrono priča je besmislena jer implicira razliku u načinu rada između ta dva režima rada a toga tu jednostavno nema. kada bi ljudi napokon o A64 počeli razmišljati na takav, ispravan način, vrlo brzo bi samostalno došli do zaključka da je dobitak od veće frekvencije memorije zanemariv. tu naravno govorim o realnim performansama a ne o 'softveru' tipa sandra, everest, superpi... postoji i zgodan članak na tu temu: wvw.madshrimps.be/?action=getarticle&articID=325 |
#20 |
Postovi: 900
Vedran say: kada bi ljudi napokon o A64 počeli razmišljati na takav, ispravan način, vrlo brzo bi samostalno došli do zaključka da je dobitak od veće frekvencije memorije zanemariv. tu naravno govorim o realnim performansama a ne o 'softveru' tipa sandra, everest, superpi... znači ti tvrdiš da na a64 je isto ako drziš memu na ddr400 i na npr. ddr500? što me vodi do pitanja da je onda samo važno dići frekvu od cpu a memorija neka bude po defaultu - to je bolje riješenje? sorry ako sam krivo skonto... |
#21 |
Postovi: 900
Vedran P say: kada bi ljudi napokon o A64 počeli razmišljati na takav, ispravan način, vrlo brzo bi samostalno došli do zaključka da je dobitak od veće frekvencije memorije zanemariv. tu naravno govorim o realnim performansama a ne o 'softveru' tipa sandra, everest, superpi... znači ti tvrdiš da na a64 je isto ako drziš memu na ddr400 i na npr. ddr500? što me vodi do pitanja da je onda samo važno dići frekvu od cpu a memorija neka bude po defaultu - to je bolje riješenje? sorry ako sam krivo skonto... |
#22 |
Lokacija: Kutina
Postovi: 1,208
točno tako. bolje rješenje? ne bih rekao bolje već racionalnije. ne gubiš performanse (tj. gubiš par postotaka), ali gubiš podosta $$$ za skuplju memu. ![]() pa jesam vam dao link na članak na tu temu u prošlom postu: http://madshrimps.be/?action=getarticle&articID=325 |
#23 |
Postovi: 900
evo sad ga baš čitam... ![]() |
