Staro 08.09.2018., 12:01   #2401
livada2
livada2's Avatar
Datum registracije: Oct 2017
Lokacija: nigdje
Postovi: 475
Code:
[2018-09-08 10:40:49] GPU0 :    888 H/s [T: 48c, RPM: 0, CC: 1200 MHz, MC: 2150 MHz][BUS:4]
[2018-09-08 10:40:49] GPU1 :    916 H/s [T: 50c, RPM: 1560, CC: 1200 MHz, MC: 2000 MHz][BUS:8]
[2018-09-08 10:40:49] GPU2 :    888 H/s [T: 47c, RPM: 1133, CC: 1200 MHz, MC: 2150 MHz][BUS:6]
[2018-09-08 10:40:49] GPU3 :    834 H/s [T: 47c, RPM: 1550, CC: 1200 MHz, MC: 2200 MHz][BUS:1]
[2018-09-08 10:40:49] GPU4 :    950 H/s [T: 46c, RPM: 1524, CC: 1200 MHz, MC: 2100 MHz][BUS:2]
[2018-09-08 10:40:49] GPU5 :    888 H/s [T: 52c, RPM: 1379, CC: 1200 MHz, MC: 2150 MHz][BUS:5]
[2018-09-08 10:40:49] GPU6 :    966 H/s [T: 48c, RPM: 1160, CC: 1200 MHz, MC: 2000 MHz][BUS:9]
[2018-09-08 10:40:49] Total:    6330 H/s
[2018-09-08 10:40:58] Pool sent a new job (ID: 000000dc19763045)
[2018-09-08 10:41:02] Pool accepted result 0x000004B3
-------------------------STATS-------------------------
Miner version:  1.6.7
Driver version: 23.20.15033.5003
Mining time:    0 days, 0 hours, 56 minutes, 21 seconds
Max allowed pool difficulty: 1700000
Algo: normalv7
Pool: cryptonightv7.eu.nicehash.com:33363 (SSL/TLS)
Connected since: 2018-09-08 09:44:50
Pool Difficulty: 400015
Pool latency: ~88 ms
Last job received: 11 seconds ago
GPU target temperature: 50c
Accepted(Stale)/Total shares: 82(0)/82 (100.0%)
Average time to find share: 41 seconds
1 min. average speed:   6323 H/s
5 min. average speed:   6328 H/s
30 min. average speed:  6330 H/s
Max. speed:             6332 H/s
pokusao sam jos nešto tweakati, ali nema razlike, zato je sad uptime minera 1h .. ali peživio je noč uspješno
E sad, dal je to max što kartice rx580 mogu dat ?
Potrošnja iz zida 750w na 7 gpu i matična
kolko sam upoznat 580 s 8gb prelazi 1000 (al to primi s rezervom jer ipak nemam tu kartic pa su mi t opopratne informacije koje sam procitao i mozda krivo zapamtio)
ktome srbminer je osjetljiv na drivere- i najbolje rezultate s v7algom daje s 1881 driverima a na heavy algo sa 1834 driverima.
za daljnji info oko frekvi i biosa ces morat procitat bitcointalk.org
evo ti jedna info za haven algo
XFX 580-8Gb Samsung memory, flashed with SRBPolaris bios. 1318/1100Mv Core, 2130/950mV Memory, -20% powerlimit
My friend have same cards XFX 580-8 with same BIOS, but he have 1100-1150 h/s! 1318/1150 Core, 2100/950 Mem and 0 powerlimit.
intenzitet na havenu je u biti manji nego sam napisao jucer. ono je za vege a ne za 580 kartice
sa 580 eu:
51 je za haven.- heavy -tube
znaci da je za v7 duplo - 102-110
Zadnje izmijenjeno od: livada2. 08.09.2018. u 12:15.
livada2 je offline   Reply With Quote
Staro 08.09.2018., 13:09   #2402
BBminer
Datum registracije: Dec 2017
Lokacija: Sisačko-moslavačka županija
Postovi: 183
Lijepo sam ti rekao da staviš stak
Dokazano daje više od SRB minera. Istina, srb je lakše postaviti, ali stak daje više hasha sa istim postavkama..
BBminer je offline   Reply With Quote
Staro 08.09.2018., 14:51   #2403
livada2
livada2's Avatar
Lokacija: nigdje
Postovi: 475
nikad stack na CN nije davao ni blizu rezultate kao CASt a o srb mineru da ne pricamo (bar je tako s vegama a po bitcointalku je tako i sa ostalim karticama)
Testirao sam par verzija cast staka i srbminera i da su svi na istom devfeeu srb miner uvjek daje vise za isti ulog.
kad jos dadamo da mu je najmanji fee i da daje 3-5% vise od casta nema se tu dalje sta mislit nego prec i poigrat se s srbminerom.
Daleko je srb miner od lakog postelavanja.
Ak ga "lako" postelas onda i imas los HR.
Srb miner trazi jako puno ispipavanja ak oces izvuc maksimum iz kartica.
Moj start je bio s stackom 1850 HR pa cast 1900HR a sad sam na 2000+HR s istim karticama( atrosim manje struje)
To sto pricas na istim postavkama ti ne stoji jer svaki miner trazi svoju postavku. npr s mojim postavkama cast ne radi minut a srbminer radi danima.
ktome srbminer na manjoj frekvi gpu a vecoj mem trosi manje struje a daje veci hr-
i kako to usporedit s stakom kad se odma srusi i radi jedino na manjoj frekvi?
za 580 8gb na haven algu pouzdano znam da daje 1100+HR s asrbminerom
evo probaj stack kolko ima- mozda 950?
ak imas vege tu je razika jos i veca- srbminer-jce miner-cast-stak eto tim redosljedom su poredani po iskoristivosti
ovo je sa BC driverima
RX 470, 480, 570, 580 - 4GB:
-CN7, Stellitev4: 950-1000
-Heavy, Bittubev2: 750-775 (800+ in some cards)
-Fast: 1850-1900
-Litev7: 1900-1950
RX 470, 480, 580 - 8GB:
-CN7, Stellitev4: 1050-1100
-Heavy, Bittubev2: 1050-1100 (1100+ in some cards)
-Fast: 2050-2100
-Litev7: 2100
instalcijom 1.8.34 drivera heavy-haven-tube algo idu cirka 20HR po kartici gore
instalacijom 1.8.61 drivera -V7 -fast-lite idu 20-30HR po kartici gore
jos nisam vidio nijedan rezultat preko1050HR(sa 580 karticom) u heavy-haven algu s stakom ili castom na netu
Zadnje izmijenjeno od: livada2. 10.09.2018. u 09:19.
Staro 08.09.2018., 15:41   #2404
dadoremix
dadoremix's Avatar
Postovi: 4,693
budem se poigrao i sad drugim minerom pa javim
bitno da je sad stabilan .. budemo ga nasli na koliko puca opet
jer sad je stabilan i claymore
voltaza ista .. core sam digao 1150 na 1200 i meme sam smanjio za 50 mhz
a imam kako sam rekao sapphire nitro + .. 4 i 8 gb ..
fora je da elpida daje najviše 950 h/s ... a na eth-u je najslabija
hynix i micron još imam i te se vrte 880 +/-
dadoremix je online   Reply With Quote
Staro 09.09.2018., 23:56   #2405
...Tihomir...
...Tihomir...'s Avatar
Postovi: 341
SRB Miner + watchdog restarter + reset vega + pokretanje OverdriveNtool-a
Livada hvala na postavkama SRB Minera koje si stavio ovdje
Nekoliko dana se igram s postavkama, proučavam, i nije baš da na njemu nema podešavanja, ima kao u priči ako ga želiš namjestiti da radi samostalno (jedna vega 56 sapphire reference mi je malo tvrdoglavija za dobiti dugotrajnu stabilnost)
Cilj proučavanja mi je bio da koristim ugrađeni watchdog restarter + reset vega + ponovno apliciranje OverdriveNtool.bat bez potrebe stavljanja skripte za restart cijelog stroja jer ona po napisanom na stranicama onemogućava watchdog restart minera.
Instalirao sam 18.3.4 drivere (zbog povremenog BitTube) i SRB Miner 1.6.7.
Nova verzija minera ima foldere npr. Config gdje su konfiguracije za sve valute.
Isto se može izraditi za poolove npr Pools i sve ih strpaš tamo.
U folder minera treba staviti OverdriveNTool, njegov .ini i .bat za pokretanje s vašim postavkama.
Treba paziti da je omogućeno pokretanje minera uz administratorske ovlasti. Ako ovo nije odrađeno Vege neće biti restartirane iako će nam miner radosno zelenim slovima napisati da su resetirane - laž.
Tek kada miner ima ovlasti, vidjeti ćemo čekanje 5 sec na reset, ponovno pokretanje, sve napisano u mineru...
dodati u start.bat:
SRBMiner-CN.exe --gpureorder --resetvega --startupscript Run_OverdriveNTool.bat --config Config\config-normalv7.txt --pools Pools\pools.txt --logfile %LOGTIME%
Za sada mi se na ovaj način se miner nije smrznuo, pa se nadam da će raditi ovako uz restart vega + ponovno apliciranje OverdriveNTool postavki...
...Tihomir... je offline   Reply With Quote
Staro 10.09.2018., 02:11   #2406
livada2
livada2's Avatar
Lokacija: nigdje
Postovi: 475
meni 1834 ne traze disable enable kartica da bi proradila hbc memorija.
ak rudarim v7 ili fast i prealazim na heavy onda mora disable enable kartica.
a koristim reset s ovim
reset-minera.bat pozivam umjesto "reboot-windows.bat", koji je po defaultu
mada razlika izmedju reseta kartica i reboota stroja je par sekundi posto kad se reboota stroj ne treba disable-enable kartica
reset-minera.bat :
@echo off
SET "version=01"
SET "title=%~nx0 - version %version%"
TITLE %title%
cd %~dp0
timeout /t 5
echo.
SET device1="Radeon RX Vega"
echo.
echo Uredjaj: %device1%
timeout 10
DevManView.exe /disable %device1%
echo Uredjaj: %device1% disablan
timeout 5
DevManView.exe /enable %device1%
echo Uredjaj: %device1% enablan
timeout 7
echo Palim Overdrive!!!
OverdriveNTool.exe -r1 -r2 -r3 -r4 -r5 -r6 -p1tube1+ -p2tube2+ -p3tube3+ -p4tube4+ -p5tube5+ -p6tube6+
echo UPALJEN OverdriveNTool.exe -r1 -r2 -r3 -r4 -r5 -r6 -p1tube1+ -p2tube2+ -p3tube3+ -p4tube4+ -p5tube5+ -p6tube6+
echo.
cd %~dp0
timeout /t 3
echo palim tube.bat - TUBE algo heavy
timeout 7
cd\
cd SRBMiner
start "RESET TUBE scripta" "C:\SRBMiner\tube.bat"
echo.
echo Kraj!!!
timeout 5
disable-enable kartica devconom umjesto devmanviewom :
cd %~dp0
timeout /t 10
devcon.exe disable "PCI\VEN_1002&DEV_687F"
timeout /t 10
devcon.exe enable "PCI\VEN_1002&DEV_687F"
timeout /t 10
OverdriveNTool.exe -r1 -r2 -r3 -r4 -r5 -r6 -p1radni1 -p2radni2 -p3radni3 -p4radni4 -p5radni5 -p6radni6
timeout /t 10
ostalo prepisat iz gornje scripte
v7 algo : "intensity" : 120, "worksize" : 16, vega 56 - "intensity" : 120, "worksize" : 8, vega 64
FAST algo "intensity" : 112, "worksize" : 16,vega 56 - "intensity" : 120, "worksize" : 8, vega 64
Heavy-Haven-BitTube algo : "intensity" : 56, "worksize" : 8,vega 56 - "intensity" : 60, "worksize" : 8, vega64
Zadnje izmijenjeno od: livada2. 10.09.2018. u 02:35.
Staro 10.09.2018., 07:23   #2407
...Tihomir...
Postovi: 341
Meni isto 18.3.4 ne traži disable, enable kartica, osim kada se jedna kartica zblesa pa moram jer ce mi inace raditi samo ona sporije.
Zato radim uvijek, probam ovo tvoje cini mi se jos bolje.
Htio bih pokusati referentnim 56 karticama sa samsung mem promjeniti softpower play table jer su od prvog dana izbirljive i traze nesto jaci napon cca 930 jezgre i 910 mem. Npr softpower play sa mining guide mi ne radi. Koristim safe file softpowerplay od hulale koji je krenuo s onim 1100 spp table.
Koji tocno power play koristis za ref vege 56 samsung mem sa 64 biosom da probam?
Txs
Autor livada2 Pregled postova
reset-minera.bat :
@echo off
SET "version=01"
TITLE %title%
cd %~dp0
timeout /t 5
echo.
echo.
timeout 10
timeout 5
timeout 7
echo.
cd %~dp0
timeout /t 3
timeout 7
cd\
cd SRBMiner
echo.
echo Kraj!!!
timeout 5
cd %~dp0
timeout /t 10
timeout /t 10
timeout /t 10
timeout /t 10
Poslano sa mog SM-T585 koristeći Tapatalk
Staro 10.09.2018., 08:46   #2408
livada2
livada2's Avatar
Lokacija: nigdje
Postovi: 475
Autor ...Tihomir... Pregled postova
Koju god softtablu sma stavio radilo je. sad imam jednu koju sam sam editiro tak da bude ista onom sto dizem i spustam sa ovedriverom.
to sam radio s nekim excel editorom prvo a poslje s obicnim notepadom.
Napravim export PP_PhmSoft linije iz regedita i promjenim sto treba.
evo ovo je moja soft tabla za referentnu powercolor vegu 56 s samsung memorijom sa 64 biosom. GPU je namjesten na 1442 900mv i mem na 1995 900mv.
sve kartice su mi na 900 ili 905mv GPU i mem
"PP_PhmSoftPowerPlayTable"=hex:b6,02,08,01,00,5c,00,e1,06,00,00,ee,2b,00,00,1b,\
00,48,00,00,00,80,a9,03,00,f0,49,02,00,8e,00,08,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00,02,01,5c,00,4f,02,46,02,94,00,9e,01,be,00,28,01,7a,00,8c,00,\
bc,01,00,00,00,00,72,02,00,00,90,00,a8,02,6d,01,43,01,97,01,f0,49,02,00,71,\
02,02,02,00,00,00,00,00,00,08,00,00,00,00,00,00,00,05,00,07,00,03,00,05,00,\
00,00,00,00,00,00,01,08,84,03,84,03,84,03,84,03,84,03,84,03,89,03,89,03,01,\
01,84,03,01,01,84,03,00,08,60,ea,00,00,00,40,19,01,00,01,80,38,01,00,02,dc,\
4a,01,00,03,90,5f,01,00,04,00,77,01,00,05,90,91,01,00,06,6c,b0,01,00,07,01,\
08,d0,4c,01,00,00,00,80,00,00,00,00,00,00,1c,83,01,00,01,00,00,00,00,00,00,\
00,00,70,a7,01,00,02,00,00,00,00,00,00,00,00,88,bc,01,00,03,00,00,00,00,00,\
00,00,00,38,c1,01,00,04,00,00,00,00,00,00,00,00,88,d5,01,00,05,00,00,00,00,\
01,00,00,00,70,d9,01,00,06,00,00,00,00,01,00,00,00,48,33,02,00,07,00,00,00,\
00,01,00,00,00,00,05,60,ea,00,00,00,40,19,01,00,00,80,38,01,00,00,dc,4a,01,\
00,00,90,5f,01,00,00,00,08,28,6e,00,00,00,2c,c9,00,00,01,f8,0b,01,00,02,80,\
38,01,00,03,90,5f,01,00,04,f4,91,01,00,05,d0,b0,01,00,06,c0,d4,01,00,07,00,\
08,6c,39,00,00,00,24,5e,00,00,01,fc,85,00,00,02,ac,bc,00,00,03,34,d0,00,00,\
04,68,6e,01,00,05,08,97,01,00,06,ec,a3,01,00,07,00,01,68,3c,01,00,00,01,04,\
3c,41,00,00,00,00,00,50,c3,00,00,00,00,00,80,38,01,00,02,00,00,bc,ab,01,00,\
04,00,00,01,08,00,98,85,00,00,40,b5,00,00,60,ea,00,00,50,c3,00,00,01,80,bb,\
00,00,60,ea,00,00,94,0b,01,00,50,c3,00,00,02,00,e1,00,00,94,0b,01,00,40,19,\
01,00,50,c3,00,00,03,78,ff,00,00,40,19,01,00,88,26,01,00,50,c3,00,00,04,40,\
19,01,00,80,38,01,00,80,38,01,00,50,c3,00,00,05,80,38,01,00,dc,4a,01,00,dc,\
4a,01,00,50,c3,00,00,06,00,77,01,00,00,77,01,00,90,5f,01,00,50,c3,00,00,07,\
90,91,01,00,90,91,01,00,00,77,01,00,50,c3,00,00,01,18,00,00,00,00,00,00,00,\
0b,e4,12,60,09,60,09,4b,00,0a,00,54,03,90,01,90,01,90,01,90,01,90,01,90,01,\
90,01,00,00,00,00,00,02,04,31,07,dc,00,dc,00,dc,00,90,01,00,00,59,00,69,00,\
4a,00,4a,00,5f,00,73,00,73,00,64,00,40,00,90,92,97,60,96,00,90,55,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,02,02,d4,30,00,00,02,10,60,ea,00,\
00,02,10
onaj podebljan 48,33 ti je frekvencija gpu P7(1442mhz)- ako oces gpu na 1427mhz stavis broj 6c,2d odnosno 00,26 za 1408mhz
memorija P3 je ono crveno podebljano bc,ab i to je 1095mhz - ak stavis c8,a9 imas 1090mhz na memoriji odnosno b0,ad je 1100mhz
u soft tabli je bolje imat nesto nizi broj jer kad se zblesa kartica i ode stroj sam u restart ocitace tu vrijednost i ako ti overdrive ima iste vrijednosti nezna mzasto vege onda ko da nisu ni ocitale overdrive i trose vise struje iz zida. pogotovo je to naglaseno na naponima. zato drzim tablu na 900mv a ovedrive npr 901 ili obrnuto.
razlika je oko 50w iz zida mjereno. zasto je to tako neznam i desava se samo ak se neka kartica ublesira sama i napravi reset stroja a overdrive ima identicne postavke kao softabla na naponima
Zadnje izmijenjeno od: livada2. 10.09.2018. u 09:32.
Staro 10.09.2018., 11:41   #2409
Alister
Alister's Avatar
Datum registracije: Aug 2009
Postovi: 1,490
Jel ima tko kakvih iskustava s likom AjgorMan na face-u koji nudi jako veliku zaradu ukoliko se uloži kod njega, čak i zaradu od 250% za 2 mjeseca?
Staro 10.09.2018., 11:54   #2410
dada-as
Bot Maker
dada-as's Avatar
Postovi: 2,741
Neznam kakve veze to ima s bilo kojim djelom ovog foruma. Ja znam masu likova na facebooku koji prodaju maglu pa ne dolazim u mining forum pitat jel ih tko pozna.
Ontopic:
Evo konacno je pao difficulty, ali mislim da to male ribe pšolako gase i prodaju rigove, jos uvijek se ceka da neki ogromni factory iz kine ili islanda ugasi pogon pa da vidimo za koliko ce onda pasti difficulty Ethereuma. Znam sad ce neki skociti tko jos kopa ETH...
A si ga kopaju, sa 570, 470 i 1060 je trenutno najvise ETH in. A bojim se da bi takac scenarij mogao biti i nakon sto smanje reward sa 3 na 2 ETH, a to bi onda znacilo da cemo kopat u debelom minusu, jednostavno koliko god da ETH padne drugi coinovi ostaju i dalje ispod za kopanje, nije mi jasno...
Staro 10.09.2018., 12:00   #2411
Alister
Alister's Avatar
Postovi: 1,490
Oprostite na krivom podforumu ili forumu, i još ukoliko se netko uvrijedio. Puno bolje je baljezgati gluposti kakve se tu pišu.
P.S.
Može mod obrisati ono pitanje.
Staro 10.09.2018., 13:08   #2412
livada2
livada2's Avatar
Lokacija: nigdje
Postovi: 475
Autor dada-as Pregled postova
Ontopic:
pa ocito ostali padaju kao i eth ili i vise.
Vidim da kakve god vijesti (dobre ili lose) bile oko btc-a nemaju nikakvog utjecaja na cijenu btc-a- on dere po nekoj svojoj shemi koja nema veze s nicim.
I onda kad na to dodamo da kad god btc raste altovi stagniraju ili malo padaju , a kad btc pada altovi padaju jos brze dodjemo do zakljucka da smo u banani
jedino altovi rastu kad btc miruje i to minimum tjedan dan pa na vise. tek tada altovi daju znakove zivota i oporavka.
sve u svemu nije dobro.
Staro 10.09.2018., 17:09   #2413
...Tihomir...
Postovi: 341
00,02,10
Hvala, poigram se malo. Ja sam mislio da je razlika u ovim donjim statovima koje ovrdrive ne može mijenjati
Staro 24.09.2018., 10:27   #2414
skrgahr
Postovi: 88
pozdrav,
sta se rudari ovih dana? Imam 6x RX570, pola godine sam bio na lyra2z i tdxmineru, ali naravno, prosli dobri dani. razmisljam da se mozda vratim na ETH.
skrgahr je offline   Reply With Quote
Staro 24.09.2018., 21:11   #2415
...Tihomir...
Postovi: 341
Evo malo novog mining hardware-a za one uporne koji bi još kupovali nove kartice ;-).
Ono što je zanimljivo je review jednog korisnika na newegg-u koji tvrdi da ova Vega 56 Nano majna V7 pri 2050 H/s i ima samsung HBM2 memoriju!
Meni je to impresivno za nano verziju...
https://www.newegg.com/global/uk/Pro...-741-_-Product
Staro 26.09.2018., 12:17   #2416
dada-as
Bot Maker
dada-as's Avatar
Postovi: 2,741
meni je impresivna cijena. Ako vega vrijedi 3000 kuna, pa koliko onda vrijedi rx 570? (nista?), LOL
Staro 26.09.2018., 12:18   #2417
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,595
Realno
Nova maksimalno 1500kn, polovna ispod 1000kn
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 26.09.2018., 12:32   #2418
dada-as
Bot Maker
dada-as's Avatar
Postovi: 2,741
Strasno nesto, i te kartice su bile buble, isle i po reko 3000, a sad ne vrijedi ni 1000. Da sam gamer bez graficke ovo je doba. Kupis Vegu za 3000kn, OMG. A sibali su je po preko 5000.
Staro 27.09.2018., 03:51   #2419
baTman
Lokacija: asfsafsa
Postovi: 327
Što se najviše isplati majnati sa rx 570 karticama?
baTman je offline   Reply With Quote
Staro 27.09.2018., 04:14   #2420
dakky
Uptime freak
dakky's Avatar
Lokacija: Ri, Cro
Postovi: 2,942
Autor baTman Pregled postova
pa imas whattomine i slicne stranice koje racunaju sta se isplati... po meni se trenutno ne isplati mrcvariti karticu za dolar dnevno... (a puno sam i rekao)
Staro 27.09.2018., 04:46   #2421
baTman
Lokacija: asfsafsa
Postovi: 327
Autor dakky Pregled postova
Shvacam o cemu govoris, ali ja vise ciljam, sada je jako tesko to reci, ali neke novije coine koji imaju amo reci dobru podlogu za biti dobar coin jer jako velik mi je problem procjeniti jer se skoro svaki reklamira kao privacy coin, pomislis ovaj X coin je dobar i onda on zakaze, a neki totalno glupo coin koji nema veze s vezom ima dobru cijenu. Sada jeli to do neke vrste promocije coina ili to rade pump&dump grupe neznam, ali iz mjeseca u mjesec je jako tesko naci neki coin koji ima dobru ekipu i ideju kako ce na kraju sve izgledati.
Staro 01.10.2018., 15:46   #2422
dadoremix
dadoremix's Avatar
Postovi: 4,693
eto i taj dan je došao .. ugasio ja svoj rig 7x rx580
malo da hep se zabrine i padne njemu zarada
Staro 01.10.2018., 16:00   #2423
Malatesta
Malatesta's Avatar
Datum registracije: Jun 2017
Lokacija: VŽ
Postovi: 35
bogami i moj je ugašen ima već 2 tjedna...
ostali?
Malatesta je offline   Reply With Quote
Staro 01.10.2018., 16:23   #2424
Facelessone
Facelessone's Avatar
Postovi: 4,203
Rade i dalje, ne isplačujem ništa i čekam da cijena dođe na željenu da prodam. Struja iz džepa, jebiga...
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 01.10.2018., 20:53   #2425
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,545
Pa kojeg smisla ima "ugasiti rig"?
Ili ga prodaš il majnaš i holdaš.
Moguće je BESPLATNO produžiti W10 sigurnosne nadogradnje do 2028!
Staro 01.10.2018., 20:56   #2426
dadoremix
dadoremix's Avatar
Postovi: 4,693
rađe ugasim..
neka stoji .. od stajanja se ništa nebude pokvarilo .. a ovo kupim za isto lovu..
osim ako bas sad kad sam ja ugasio .. ode sve to the MOON
Staro 01.10.2018., 21:05   #2427
...Tihomir...
Postovi: 341
HODL and MINE & MINE and HODL ;-)
Staro 03.10.2018., 09:42   #2428
aerial
Postovi: 163
rađe ugasim..
gasenje jedino ima smisla ako baš nemaš love sa strane za plaćanje struje. S time da kao prvu mjeru bi gasio kad je dnevna skuplja tarifa.
S druge strane ide zima pa nije ta struja ni bačena uz malo domišljatosti.
A istu ili manju količinu coina ćeš iskopati kada krenu cijene gore. Pametni ljdi kopaju stalno a prodaju kad su cijene gore. Ako ikad odu gore, dodao bih
aerial je offline   Reply With Quote
Staro 03.10.2018., 11:12   #2429
Neo-ST
Neo-ST's Avatar
Postovi: 8,322
Sorry na upadanju ali ako netko ima molex kabel sa Corsair napajanja, ovako izgleda:
ili SATA kabel, isto izgleda... Na njima treba pisati "Type4"...bio bih vrlo zahvalan i platit ću.
Staro 04.10.2018., 14:51   #2430
Euhenio
Datum registracije: Mar 2018
Lokacija: Crikvenica
Postovi: 47
Talking
Autor aerial Pregled postova
Slazem se. Po zimi se grijem na graficke a buduci da mi je grijanje ionako na struju da crypto propadne sam na 0 sa potrosnjom struje a ako ikad naraste sam u +
Euhenio je offline   Reply With Quote
