#4621 |
Postovi: 14,578
BusMaster nije to za 16 jezgri. Vjerojatno za jednu ili dvije boost Nego ovo je možda natruha od čega će biti jače sljedeće konzole: AMD Unveils its Most Powerful Semi-custom SoC for a Chinese OEM |
#4622 | |
Datum registracije: Apr 2017
Postovi: 343
RE: AMD Ryzen Threadripper 2000 Series Specifications and Prices Revealed
#4623 |
Postovi: 14,578
Ma nije kod ryzena/threadrippera uopće problem hlađenje kod max overclocka, nego silikon tj. node udari u svoj zid i to je to, pa makar imao 20C headrooma 32 core će navodno boostati do 4ghz na svim jezgrama sa stock coolerom, vjerojatno je max OC onda tu negdje još bar 100-200mhz worst case scenario |
#4625 | |
..starija garda
Postovi: 3,278
"The CPU runs at up to 3.00 GHz of clocks, and has 4 MB of L3 cache. The GPU is equally impressive: based on "Vega," it packs 24 NGCUs, translating to 1,536 stream processors, and the latest feature-set, including DirectX 12 and Vulkan. The GPU engine ticks at up to 1.30 GHz. 8 GB of GDDR5 memory across a 256-bit wide interface, is hardwired to the SoC (no memory expansion)." nekako 3,9 svi do sada su mogli pa racunam da bi to cak i mogao
![]() Citiraj:
izgleda skroz odlican --> "The CPU runs at up to 3.00 GHz of clocks, and has 4 MB of L3 cache. The GPU is equally impressive: based on "Vega," it packs 24 NGCUs, translating to 1,536 stream processors, and the latest feature-set, including DirectX 12 and Vulkan. The GPU engine ticks at up to 1.30 GHz. 8 GB of GDDR5 memory across a 256-bit wide interface, is hardwired to the SoC (no memory expansion)."
__________________ MojSkuter ---------------------------------PEACE Zadnje izmijenjeno od: Eladio. 05.08.2018. u 00:11. |
#4626 | |
Postovi: 2,138
Meni je isto na prvu zvucalo too much onda se sjetio da 2700x treba 1165 mV za 4GHz tako da nije nemoguce 32core na 4GHz sa zracnim hladjenjem i da bude s nekom razumnom potrosnjom recimo 350W
![]() Zadnje izmijenjeno od: Gigi1. 05.08.2018. u 01:45. |
#4627 | ||
Postovi: 14,578
Nemojte zaboravit da je 1950x imao 27C offset Stock: Citiraj:
Zadnje izmijenjeno od: Manuel Calavera. 05.08.2018. u 02:05. |
#4628 |
Postovi: 8,096
NDA za Threadripper 2 seriju istječe sutra, bar kad su u pitanju službene specifikacije nadolazećih modela. Mada, po svemu sudeći to je samo potvrda većine informacija koje proteklih mjesec dana kruže Internetima. ![]() |
#4632 |
Postovi: 343
AMD Ryzen Threadripper 2990WX 32 Core CPU Is 53% Faster Than Intel’s Core i9-7980XE 1
https://wccftech.com/amd-ryzen-threa...nch-benchmark/ Hehehe..... ![]() AMD Ryzen Threadripper 2990WX TDP 250W Cinebench R15: 5099.3 Points stock Intel Core i9-7980XE TDP 180W Cinebench R15: 3335.2 Points stock Intel Core i9-7980XE OC 4.9Ghz TDP 900W Cinebench R15: 5049.7 Points max OC with Delid |
#4633 |
Postovi: 343
AMD Ryzen Threadripper 2990WX Now Available For Pre-Order
#4636 |
Postovi: 14,578
Moguće je svaša. Nisam vjerovao da mogu ponuditi više od 8c16t na AM4, no 12 i 16c je izgleda tehnološki moguće (što ne znači da će i ponuditi.). IMO sve iznad 8c16t na AM4 će biti tough sell gamerima, streamerima i sl. Naravno ne koriste svi pc za zajebanciju (znam jednog koji bi jedva dočekao više jezgri), ali većina da |
#4638 |
Postovi: 14,578
Doduše nebi to ni pristupačno bilo. Ako gledamo po ovom novom flagship threadripperu - duplo jezgri na 1950X + 80% cijene, znači tako nešto po sadašnjoj situaciji za 16 core bi bilo 2700X + 80% = skoro nekih 5000kn, nebi to gaymeri kupovali. Do vremena izlaska vjerojatno bi bilo jeftinije |
#4639 |
Da, ali Threadripper 2nd gen nema konkurencije ![]() Ne treba 16c/32t na AM4, ali 8c/16t u jednom CCX-u i iGPU te takt od recimo 4.5-4.6GHz bude prava stvar. Sent from Usreo Mobara |
#4640 |
Postovi: 343
AMD 2nd Generation Ryzen Threadripper Performance Benchmarks Detailed
https://wccftech.com/amd-ryzen-threa...ures-detailed/ Koliko vidim iz ovog članka, uspjeli su smanjiti Die-to-Die latencije u odnosu na R2700X, nije nešto puno ali ok. U Ryzen Master grafu... CPU Power Limit 500W!, strujni limit 430 do 600A? Za ovo treba zvijer od MB-a i cooler od omanjeg kombija... ![]() |
#4641 |
Postovi: 2,138
da na zen 2 ponude msrp 12core 450usd i 16core za 550usd, sa boljim ipc i nesto visim taktom prodavalo bi se to dosta dobro vani, makar 16core mi je skakljiv jer direktno ide u teritorij TR2 pa mislim da su manje sanse za to. ovo sa gpu isto moguce, onda ce ti cpu-i imati manje cacha zbog jednog ccx-a @bus master, ipak je to proc sa 32jezgre, hedt ionako nikad nije bio da se spara na hladnjacima, jos kod ovoga zracni hladnjak velicine noctue d15 ga drzi na 4GHz sto je odlicno
![]() Zadnje izmijenjeno od: Gigi1. 07.08.2018. u 14:38. |
#4642 | |
Postovi: 14,578
Čuj mogli su i više tražiti za njega (32c64t). 200$ je jeftiniji od intelovog 18 corea, o lejnsima da ne pričam. Tako da i je jeftino pored intela. Vidjet ćemo 8c16t + što jača gpu sa hbm u drugoj polovici bi bio IMO najjači proizvod u novijoj povijesti (za običnog čovjeka). Die je oko 200mm2, treba vidjeti koliko se gpu može utrpati u polovici od 100mm2 na 7nm. Zen 2 bi vjerojatno došao do 3 mjeseca, zen 2 APU vjerojatno kasnije, no nije poznato dali bi do takvog APU-a bio gotov Navi ili bi išla vega. AKo bi bilo barem 2-3 puta jače od moje gpu razmislio bih o tome, umjesto da kupujem gpu Vega64 je 486mm2, 7nm ima negdje 50% bolju gustoću, 24CU bi se uguralo da ga jebeš, a navi arhitektura možda još bude jača gledano prostor/performanse. AL to bi dosta trebalo trošiti New AMD Console Tech Offers Ryzen CPU + Vega Graphics - Full Spec Analysis! Zadnje izmijenjeno od: Manuel Calavera. 07.08.2018. u 15:06. |
#4643 | |
Postovi: 343
Ispravak: AMD 2nd Generation Ryzen Threadripper Performance Benchmarks Detailed
Ispravak na prethodni post, u Gaming modu TR radi samo sa 1 DIE-om, sorry, pročitao u brzini ![]() Another thing worth noting is that in game mode, Ryzen Threadripper processors will optimize to run with 8 cores, 16 threads. That means only 2 CCX or 1 die would be enabled, reducing latency. This would allow the Ryzen Threadripper 2950X to operate at speeds of 4.4 GHz with Precision Boost 2.0, achieving the maximum 8 core default frequency on any Ryzen processor released to date. |
#4644 | |
..starija garda
Postovi: 3,278
#4645 |
Osobno bi bio jako zadovoljan sa R5 3600 6c/12t 1 CCX + iGPU @ 4.7GHz za 1500 kn ![]() Opet, s druge strane, kakav god da bude, jasno je da ga uzimam ![]() Sent from Usreo Mobara Zadnje izmijenjeno od: Brko. 07.08.2018. u 17:18. |
#4646 | |
..starija garda
Postovi: 3,278
Vrijedi napomenuti da se spekulura da ce biti i 10%+ bolji ipc
__________________ MojSkuter ---------------------------------PEACE Zadnje izmijenjeno od: Eladio. 07.08.2018. u 17:46. |
#4647 |
Ne spominje se zato jer još nitko ne zna ništa. WCCF obično nagađa i u tome imaju 50% uspješnosti što je nikakav score. Dok ja ne nagađam nego pišem svoje želje koje mogu i ne moraju biti uslišene ![]() ![]() Sent from Usreo Mobara |
#4648 |
..starija garda
Postovi: 3,278
Imas izjave mislim amdovih ljudi koji spominju da 7nm proces vec po njihovom valjda beta testiranju ili informacijama koje imaju iz tvornice da je 5ghz sasvim moguće Bilo je i drugih slicnih izvora Ako naletim na nesto opet pustim tu link ![]()
#4649 |
"Isti" ti AMDovi ljudi su pričali da su na testirsnjima postizali 4.4GHz sa malim naponima na Zen+ Ryzenima, pa eto, 4.2GHz sa ispod 1.4V je izuzetno postignuće na kraju ![]() Pusti priče Snježana. Prije prvih leakova i benčeva ništa ne vjerujem. Pogotovo ne ovom Mujtabi sa WCCFa. Sent from Usreo Mobara |
#4650 |
Postovi: 14,578
Brko to je već APU, a oni ne izlaze istovremeno kao i cpu (to ti možda bude najranije do ljeta, a da će ccx biti više od 4 jezgre na AM4 je još u nepotvrđenoj, ali vjerojatnoj fazi). @Eladio To je onaj direktor GloFo tvrdio da bi moglo do 5ghz, što ne znači da hoće, ako to kaže onda sigurno neće 5ghz (pogotovo ako je neko random nagađanje ili best case scenario). Ionako će ryzene (ili većinu njih) praviti TSMC. IMO bitno je samo da clock ne nazaduje na 7nm, osobno ne očekujem preko 4.5ghz, a možda ni to. |
