Staro 14.12.2005., 20:56   #1
Postovi: 7,568
Novi procesori nakon 4. mjeseca '06.
Advanced Micro Devices is reported to unveil its central processing units (CPUs) in the second quarter of the year 2006, after April. The ramp of DDR2-supporting chips will be quick as the chipmaker plans to release DDR2 supporting chips for different market segments, including desktops and laptops at approximately the same timeframe. Socket M2 will be used for AMD Sempron, AMD Athlon 64, AMD Athlon 64 FX and AMD Opteron 100-series processors and will substitute existing Socket 754, Socket 939 and Socket 940 desktop and workstation infrastructure. For AMD Opteron processors for 2P and MP servers AMD reportedly prepares a 1207-pin socket F that will be utilized instead of Socket 940. For mobile computers AMD is expected to offer Socket S1 with 638-pins, which will replace existing Socket 754 for laptops.
Izvor: www.xbitlabs.com
Zadnje izmijenjeno od: McG. 14.12.2005. u 21:08.
Staro 15.12.2005., 20:38   #2
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,352
Novi mainstream socket će se službeno zvati AM2, baza HT/LT-a će biti 333Mhz, a AMD do kraja drugog kvartala 2006. namjerava u opticaj stavit svu silu procesora:
Windsor
AMD Athlon 64 FX-62
AMD Athlon 64 X2 5000+
AMD Athlon 64 X2 4800+
AMD Athlon 64 X2 4600+
AMD Athlon 64 X2 4200+
Orleans
AMD Athlon 64 4000+
AMD Athlon 64 3800+
AMD Athlon 64 3500+
Manilla
Sempr0n 3600+
Sempr0n 3500+
Sempr0n 3400+
Sempr0n 3200+
Sempr0n 3000+
izvor:
http://theinquirer.net/?article=28367
Staro 15.12.2005., 20:50   #3
Postovi: 7,568
Bome zanimljiva bu ta '06.
Staro 15.12.2005., 21:33   #4
Konan
Konan's Avatar
Datum registracije: Jun 2004
Lokacija: Xindi weapon
Postovi: 441
izvor:
Čekaj onda će budući da je bitno da mem radi sinhrono s proc biti potrebno kupiti ddr2 667(666 )
Ne kužim se baš u ddr2...
I ako kupiš ddr 800 mem te neće kočiti do
20+%OC?
Konan je offline   Reply With Quote
Staro 15.12.2005., 21:41   #5
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,352
Pa dobro je to , a mogli bi s vremenom i službeno puknut HT na 400.
Staro 16.12.2005., 10:00   #6
sick_boy
sick_boy's Avatar
Postovi: 680
Nije bitno da memorija radi sinhrono. TO je bilo bitno u vrijeme Athlona XP, kod 64-ki je to apsolutno nebitno (uostalom, u slucaju s939 Athlona64 DDR400 memorija radi asinhrono).
iBase MI980VF-4700EQ Motherboard
Intel Core I7-4700EQ (2.4-3.4Ghz, 4 cores, 8 threads)
16GB DDR3L RAM 1600 MHz
250 GB Samsung 860 Evo mSATA SSD
1TB Seagate Barracuda 7200 2.5" HDD
ATI RX550 4GB
Kolink Satellite mATX Cube Case
Delta Electronics GPS-350EB-200 A ATX 350W PSU
Acer 27" 1440p 75Hz Freesync IPS monitor
Cherry MX Board 1.0 keyboard, brown switches
LOGITECH G305 Lightspeed mouse
Arch Linux/Win 10
Lenovo Idepad 5 pro:
AMD Ryzen 7 6800HS
16GB DDR5 RAM 5600 MHz
1TB Micron nVme HDD
16" 2160x1600 16:10 IPS Display
Windows 11
Fujitsu Esprimo:
Intel(R) Core(TM)2 Duo CPU E7500
4GB DDR2 RAM
WDC WD1600AAJS-0 160GB
Seagate ST4000DM000 4TB
openmediavault 4.1.17
Philips 55PUS7373/12 55" 4K HDR VA Direct LED TV
Toshiba 50" QLED 4K Dolby Vision/Dolby Atmos TV
TCL 40ES560 40" FullHD TV
Pioneer BDP-160 BD player
Maxell SB-3000 soundbar
Onkyo TX-SV444 AV Receiver
Onkyo DX-7333 CD Player
Audio-Technica AT-LP2XGY gramofon
Mirage 290is bookshelf speakers
sick_boy je offline   Reply With Quote
Staro 16.12.2005., 10:27   #7
nicko
Postovi: 4,190
nebitno je kod a64, ali nije istina da memorija ne radi sinhrono na defaultu...radi...
nicko je offline   Reply With Quote
Staro 16.12.2005., 14:36   #8
sick_boy
sick_boy's Avatar
Postovi: 680
Joj da, sorry. S939 procovi rade na 1000, to je izvedeno kao 5x200, jelda?
Mea Culpa. No, i dalje ostaje cinjenica da nema razlike u perfomansama radi li memorija sinhrono ili asinhrono.
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 20.12.2005., 11:51   #9
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,531
Ima ako memorija radi sinkrono na visem taktu
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 20.12.2005., 14:05   #10
sick_boy
sick_boy's Avatar
Postovi: 680
Sta se sad razmeces?
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 20.12.2005., 14:09   #11
Mailman
Mailman's Avatar
Postovi: 1,606
o tome bi se dalo raspravljati....
Mailman je offline   Reply With Quote
Staro 20.12.2005., 17:38   #12
bude
Warcraft III TFT
bude's Avatar
Postovi: 862
A što to? Pa naravno da ces imati manje preformanse s manjim taktom memorije nego s vecim. Samo sto u slucaju 939ke ne dolazi do dodatnog pada preformansi, kako kod npr. nforce2 chipseta, ako memorija radi asinhrono..
A64 Venice
Epox 9npa+ Ultra
Super Talent 2x512 MB
Saphire x700 pro
2x80 GB @ RAID0
Staro 20.12.2005., 18:00   #13
Mailman
Mailman's Avatar
Postovi: 1,606
Originally posted by bude
A što to?
da pročitaš još jednom ono što sam kvotao dobio bi odgovor....
dakle, nisam se slagao da je ČINJENICA da nema razlike u performansama držao ti memoriju sinkrono ili asinkrono...
stvarno ne znam u čemu je problem...
Staro 20.12.2005., 18:01   #14
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,750
Ne nuzno, i ne uvijek...
Programer
Staro 20.12.2005., 18:13   #15
sick_boy
sick_boy's Avatar
Postovi: 680
AFAIK na A64 procesorima nema razlike. Meaning, nema utjecaja radi li memorija sinhrono ili asinhrono, vec je bitan takt, latencije ... (ustvari, najbitniji je takt).
Na Athlon XP-ima je djaba bilo povecavati takt memorije, ako ce raditi asinhrono s procesorom, jer je dolazilo do degradacija perfomansi (odnosno, morao bi "potegnut" poprilicno veci takt da kompenziras gubitak perfomansi zbog asinhronog rada).
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Zadnje izmijenjeno od: sick_boy. 20.12.2005. u 18:29.
Staro 20.12.2005., 20:33   #16
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,531
Ne kontam?! :confused:
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 21.12.2005., 14:32   #17
sick_boy
sick_boy's Avatar
Postovi: 680
Pa, razmeces se sa vecim HTT-om i memorijom koja podnosi da ne mora biti raditi asinhrono. Ne?
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 21.12.2005., 19:12   #18
Vedran
Vedran's Avatar
Lokacija: Kutina
Postovi: 1,208
na K8 ne postoji 'sinkroni' način rada. mem kontroler je u procu, to valjda svi znaju. iz toga proizlazi da je memorija uvijek na dijeljitelju zato što je brzina memorije derivat brzine procesora a ne sistemske sabirnice kao na drugim arhitekturama.
cijela ova sinkrono-asinkrono priča je besmislena jer implicira razliku u načinu rada između ta dva režima rada a toga tu jednostavno nema. kada bi ljudi napokon o A64 počeli razmišljati na takav, ispravan način, vrlo brzo bi samostalno došli do zaključka da je dobitak od veće frekvencije memorije zanemariv. tu naravno govorim o realnim performansama a ne o 'softveru' tipa sandra, everest, superpi...
postoji i zgodan članak na tu temu:
wvw.madshrimps.be/?action=getarticle&articID=325
Vedran je offline   Reply With Quote
Staro 21.12.2005., 21:19   #19
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,531
NE!
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 22.12.2005., 14:20   #20
killah_tm
killah_tm's Avatar
Postovi: 900
Vedran say: kada bi ljudi napokon o A64 počeli razmišljati na takav, ispravan način, vrlo brzo bi samostalno došli do zaključka da je dobitak od veće frekvencije memorije zanemariv. tu naravno govorim o realnim performansama a ne o 'softveru' tipa sandra, everest, superpi...
znači ti tvrdiš da na a64 je isto ako drziš memu na ddr400 i na npr. ddr500? što me vodi do pitanja da je onda samo važno dići frekvu od cpu a memorija neka bude po defaultu - to je bolje riješenje?
sorry ako sam krivo skonto...
killah_tm je offline   Reply With Quote
Staro 22.12.2005., 14:20   #21
killah_tm
killah_tm's Avatar
Postovi: 900
Vedran P say: kada bi ljudi napokon o A64 počeli razmišljati na takav, ispravan način, vrlo brzo bi samostalno došli do zaključka da je dobitak od veće frekvencije memorije zanemariv. tu naravno govorim o realnim performansama a ne o 'softveru' tipa sandra, everest, superpi...
Staro 22.12.2005., 14:33   #22
Vedran
Vedran's Avatar
Lokacija: Kutina
Postovi: 1,208
točno tako.
bolje rješenje? ne bih rekao bolje već racionalnije. ne gubiš performanse (tj. gubiš par postotaka), ali gubiš podosta $$$ za skuplju memu.
pa jesam vam dao link na članak na tu temu u prošlom postu:
http://madshrimps.be/?action=getarticle&articID=325
Staro 22.12.2005., 14:38   #23
killah_tm
killah_tm's Avatar
Postovi: 900
evo sad ga baš čitam...
