Staro 07.10.2017., 15:19   #1891
tole_
Casual Racist
tole_'s Avatar
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
Pa 8400 ima 6 core boost na 3.8GHz neovisno o ploči, to je defaultno ponašanje procesora. Bitno je samo da ne throttla zbog visoke temprature. Druga je stvar MCE/MCT koji gura sve jezgre na single core turbo takt, ali pitanje je radi li to još na na nonK procesorima i nonZ čipsetima. BCLK na nonK CPU će se vjerojatno moći dizati na pločama poput z370 Taichi koje imaju externi clcok gen., ali s obzirom na cijenu ploče bolje je uzet jači proc i jeftiniju ploču.
Why did the console peasant cross the road?
To render the buildings on the other side!
tole_ je offline   Reply With Quote
Staro 07.10.2017., 16:13   #1892
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
..ja ne vidim nekog smisla imati coffe a ne ici preko 4,5 prema 5 ghz
3,8 svaki ryzen drzi, dobis i SMT, uz manju temp, manju potrosnju, jeftiniju ploču, bez petljanja s hladnjacima, platforma ima jasniju buducnost, manja je cijena..
mislim tko voli neka izvoli, ali nije neki poso
MojSkuter
Staro 07.10.2017., 23:52   #1893
Dottore
Dottore's Avatar
Postovi: 7,709
Autor Eladio Pregled postova
Petljanje sa RAM i niže preformanse, zar ne?
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 08.10.2017., 00:10   #1894
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
Autor Dottore Pregled postova
pa kad govorimo o i5 8400 nisam impresioniran performansama, solidno, pri taktu 3800.. nista znacajno..
ryzen i problem s ramom je davna proslost, radi i bolje nego sto je specificirano.. ja te probleme nisam stigao ni osjetiti, piknuo i radi od prvog dana kako treba . probao više vrsta rama
kao sto rekoh, vidim smisao u ovima koji ganjaju visok takt , u nekim namjenama gejmerske prirode s monitorima 144mhz, tko voli neka izvoli
MojSkuter
Zadnje izmijenjeno od: Eladio. 08.10.2017. u 00:19.
Staro 08.10.2017., 01:12   #1895
Gigi1
Postovi: 2,138
Mislim da je i brko koristio stiltove postavke..
Staro 08.10.2017., 21:38   #1896
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
Staro 09.10.2017., 00:37   #1897
vedranzeman
Lokacija: Kloštar Podravski
Postovi: 1,019
Tko nije skršio Socket A procesor na bilo koji način, neka prvi baci kamen!
vedranzeman je offline   Reply With Quote
Staro 10.10.2017., 11:57   #1898
Gigi1
Postovi: 2,138
za sada na nabavi jedini 8700k...3800 kn
https://www.nabava.net/search.php?q=8700k
Staro 10.10.2017., 16:21   #1899
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,836
https://www.links.hr/hr/maticna-ploc...1151-050300302
Cijena matične ploče je sasvim prihvatljiva, strahovi o nebulozno skupim pločama ovime su raspršeni
Staro 10.10.2017., 18:42   #1900
markecSMB
Lokacija: Cro
Postovi: 1,042
Autor Sinac Pregled postova
S obzirom da je to žnj kategorija ploče bez hlađenja napajanja i nije baš prihvatljiva.
Barem meni
Staro 10.10.2017., 19:02   #1901
Gigi1
Postovi: 2,138
vrm na toj tuf z370 ploci ne izgleda bas tako tuf, naginje ka low endu
inace z370 gaming7 od gbyte je cca 450 skuplja od x370 pandana
Staro 10.10.2017., 19:20   #1902
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
Dobro je da uopće ima ploča , al to ima veze i s potraznjom
MojSkuter
Staro 10.10.2017., 21:58   #1903
Sinac
Sinac's Avatar
Postovi: 2,836
Stavio sam onu TUF ploču isključivo radi cijene, evo vam i skupljih pa se divite:
https://www.links.hr/hr/search?q=z370&orderby=11
Staro 11.10.2017., 18:42   #1904
ShebY
ShebY's Avatar
Lokacija: Velika / Osijek
Postovi: 1,442
Škot:
Staro 11.10.2017., 19:54   #1905
Gigi1
Postovi: 2,138
Sad ce opet bit da skot baljazga bedastoce jer je zavirio u osinjak
Ono sto isto treba napomenuti da je najlakse bacit kost ovima jubituberima zbog loseg predznanja, tako da nije tu samo intela za 'kriviti'
Nazalost i pce je nasjeo, ali mislim da je to zbog nedostatka vremena i zurenja, a ne zbog nedostatka znanja jer su oni prije od vecine izbacili rivju, svejedno sa upitnom tocnoscu rezultata. Vidi se da je rezultat u cinebench grafovima indentican na "stock" i na oc od 4.7GHz.
edit: napisano je u clanku da je koristen Core Enhancement
Zadnje izmijenjeno od: Gigi1. 11.10.2017. u 20:28.
Staro 11.10.2017., 20:39   #1906
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Možda nije tolika drama, ali recimo hw canucs su ispali najveći šupci. Vrtili na 4.7ghz (znači skoro max OC) i u tekstu rekli da se vrtio 4.1ghz all core. Ove recenzije recenzija su mensečini postale jednako potrebne kao same recenzije. Ostali sa jednako visokim rezultatima barem nisu rekli ništa, a gamersnexus barem naknadno priznao da se vrtio na 4.7ghz
Intelu svaka čast što se toga tiče. Oni su svoje rekli o boostevima i time se ogradili (nemoš reć da lažu i muljaju) i isporučili naj ploče
Zadnje izmijenjeno od: Manuel Calavera. 11.10.2017. u 20:44.
Staro 11.10.2017., 20:52   #1907
Gigi1
Postovi: 2,138
Ma naravno da su potrebni, skot je korektor kao nekad goran juric na liberu
Kod hw c je intel poradio na ipcu hehehe
Nije to sad neka drama samo upitno bi li zracni hladnjak uspio drzati 8700k sa core enhancmentom + deklarirani tdp pada u vodu
Staro 11.10.2017., 21:01   #1908
Manuel Calavera
Postovi: 14,589
Treba vidjeti i dali će budžet ploče (B360) držati 3.8ghz all core na i5 8400, mislim da bi mogle, nisam pesimističan glede toga kao škot, samo naravno to nije tad 65w tdp cpu. Naravno sada ih se može testirati samo na Z370, a te recenzije će vječno ostati na netu... Što se tiče tdp i amd i nvidia muljaju glede toga, to je zona marketinga pa nebih previše obraćao pažnju na to. Ti natpisi su za noobove.
S druge strane recenzenti ispali neprofesionalni - i ovi što lažu, kao i ovi što prešućuju takve info
Staro 11.10.2017., 21:10   #1909
Gigi1
Postovi: 2,138
Zona marketinga apsolutno, no iz consumer gledanja ostaje da se svi ryzeni mogu voziti sa ocom na zraku kod intela ne mogu.
Isto tako se onda u testovima moze za razliku u cijeni(zrak/aio)uzeti b die sa stiltovim settingsima pa to staviti u rezultate...poanta je da ako nastimas jednom(intelu aio zbog zagrijavanja) nastimaj i drugom(ryzenu b die zbog inf.fabrica)
Staro 11.10.2017., 21:18   #1910
Manuel Calavera
Postovi: 14,589
Usporedbe bi tu poštenije bile na max OC svi i kom opanci a kom obojci. Ovako ovaj furi na 4.7ghz, kažu da je stock (a do max OC imaš još recimo 200mhz) i onda ispadne recimo brži od 1700 i 1700X u mnogim multi benčevima. Naravno 1ghz veći clock i nešto bolji IPC tu dosta odradi i stvarno im je tu negdje, da nebi ispalo da osporavam snagu cpu-a, pričamo o standardu recenziranja.
Jbga ako se ide na foru tj. fičure nekih, recimo zašto ne kod amd-a otključanost - R7 1700, napravi konzervativan OC od recimo 3.9ghz, isti cooler za sve CPU-e, zbrojit sve i oduzet. A oni senzacionalistički pumpaju sa "faster than 1800X" od milijun maraka kojeg nitko upućen ne gleda
Staro 12.10.2017., 10:08   #1911
sakomako
Datum registracije: May 2013
Lokacija: nigdje
Postovi: 599
Naravno, tko ima i tko misli da mu se isplati nek plati. Kao što reče jedan od qotanih zaključaka:
Na kraju krajeva prodajni rezultati X299 će reći svoje. Zasada su poražavajući.
Sadašnja situacija bi se mogla opisati ovako:
Intel nudi više nego prije (jezgri i threadova), jer mora zbog konkurencije koju prije nije imao u većini segmenata. I to treba pozdraviti jer postoji veći izbor.
S druge strane je evidentno da je intel u potpunosti tehnološki stao. Prvi put u povijesti ima i treću generaciju za redom sa istim IPC, također i po prvi puta 4 generacije na istom proizvodnom procesu, znači nakon tick-tock odmah je u vodu pala i "proces-arhitektura-optimizacija" šema. Trenutno iskorištavaju ovo malo IPC vodstva što im je ostalo + bruteforcaju clock (tj. iskorištavaju bolji proizvidni proces do maximuma) kako bi što više dobili na performansama i max uštedjeli na jezgrama gdje mogu tj. gdje im taj IPC i clock daje leap. To im je sva taktika, od novog uarch nemaju apsolutno ništa trenutno tj. već neko vrijeme.
Prilog onome što sam rekao da je trenutno najveći napredak na polju procesora za mobilne telefone i da ta ekipa polako skuplja znanja i razvija nove procese i tehnologije koji jednog dana ako se odluče prošitriti i na tržište PC moglo bi imati povoljne rezultate za nas kao krajnje korisnike a poražavajuće za Intel, odnosno moglo bi ih to koštati gubitka znatnog udjela na tržištu prvo mobilnih a onda i stolnih računala. A da će spavati, kao zadnjih par godina mogu zaboraviti i sami određivati po kojoj će cijeni prodavati svoje procesore i time sebi osigurati extra profite biti će davno svršeno vrijeme, što znači da će cijena procesora postati puno realnija, osim ako se ne upuste u međukartelske dogovore oko držanja cijena.
Također treba poželjeti da AMD također krene naprijed još bržim koracima.
Realno gledano zadnjih par godina ništa značajno se nije niti dogodilo sve su to jako mali koraci u napretku. Od obećavanja komunikacije s računalom na druge načine a ne samo mišem i tipkovnicom za sada realno gledano malo se toga ostvarilo. Prepoznavanje govora nije praktično puno napredovalo već 2 desetljeća. Sve to pokazuje zastoj u razvoju kako hardwera tako i softwera.
Na polju skladištenja podataka također je nastao zastoj, kapaciteti diskova se nisu puno promijenili u zadnjih par godina, dok je to prije išlo skokovito u zadnjih par godina nema znatnijeg napretka na tom polju iako su već davno obećavali cca 60 TB za obične mase. 2TB je danas postalo kao nekada disketa od 720 kb. Da ne pričamo o najavama većih brzina zapisivanja podataka, a na ovim današnjim diskovima brzina zapisivanja podataka u realnim procesima zna ponekad pasti ovisno o strukturi podataka koji se zapisuju na bolno sporih 1 MB/s pa i manje. Ubacite u PC 4 ili 6 diskova i probajte u isto vrijeme kopirati sa diska 1 na disk 2 i sa diska 3 na disk 4 pa ćete vidjeti svu slabost čipseta na pločama jer propusnost je problem i uz to ako nešto skidate sa mreže i istovremeno strimate u svojoj lokalnoj mreži film na tv imate veliki problem zagušenja. A pričamo o multitasking stolnim računalima, koja se vrlo lako zaguše. Također koji je risponse na disku sa kojeg trenutno nešto kopirate na drugi, ako želite istovremeno pristup do nekog podatka na njemu koji vam treba u nekoj drugoj aplikaciji. Pravog multitaskinga nema jer je ograničen brzinom komunikacije sa perifernim uređajima i propusnošću magistrale preko koje se odvija sva komunikacija, sami CPU tu više uopće nisu kritični.
I što se danas događa, ono što je od SD diskova (512 GB) za široke mase na to stane praktično 5 do 6 filmova 4K HDR rezolucije. Ako slušate glazbu koja je visoke kvalitete što se tiče samog signala i zapisa (ne mp3) vidjet ćete da vam na obični 2TB disk ne stane baš puno toga.
Od puno lipih stvari koje se najavljuju sada već skoro 10 godina, ništa od toga nije došlo na tržište. Kod klasičnih diskova smo zaglavili na 8 TB odnosno 16 TB ako se u HD ubaci neki drugi plin a ne zrak. Kod SD diskova se došlo do 60 TB samo cijena je danas nebuloza i za one koji mogu tako nešto nabaviti. Puno je tu najvljivano novih tehnologija koje postoje već cijelo desetljeće ali nikako da dođu u masovnu primjenu.
Na polju PC monitora također nema nekog napretka i poboljšanja. Prešlo se na LCD monitore, da bi sada govorili o zamoru očiju i štetnosti plaviog svjetla u monitorima.
Istina je da se stalno napreduje, ali malo malo zaglavimo na istim stvarima kao i prije 20 ili 30 godina, kapicitet i brzina uređaja na kojime spremamo naše podatke, kvaliteta slike, brzina propusnosti čipseta na pločama, brzina i sposbnost procesora. Način na koji komuniciramo sa desktop računalom. OS nisu postali ništa kvalitetniji samo ušminkaniji a time realno i sporiji, a ne brži kao što se stalno naglašava. U njima samo raste gomila mrtvog koda.
I ono što je najžalosnije isti trend se danas polako počinje ponavljati i na području aplikacija za mobilne uređaje.
Nismo se daleko maknuli od pojave prvih PC uređaja.
sakomako je offline   Reply With Quote
Staro 12.10.2017., 10:28   #1912
Majko isusova... TL;DR
@mob
Staro 12.10.2017., 10:51   #1913
Sinac
Sinac's Avatar
Postovi: 2,836
@mob
Kaj ti se palac zapalio na mobitelu od tolikog skrolanja?
U suštini je kolega u pravu, brzina se rješava samo na nekim mjestima u velikim koracima, drugdje je nekako neproporcionalno ubrzanje.
Ali da se vratimo na temu, Intel je imao u planu nove procesore, nije to izletjelo nekome iz guze zbog Ryzena, koliko je sada ova 8x00 serija ubrzana s izlaskom to je pitanje ali još prije gotovo dvije godine spominjao se kraj 2017./početak 2018.
A da bi mogli u Intelu promijeniti pastu, to je neosporno. Mislim, koliko ih košta ta kauguma? Gledam ovakve clipove i pitam se ne radi li to Intel namjerno da korisnici ne bi prelazili 5 GHz sa svojim procesorima jer mi nekako izgleda da je 5 GHz rezervirano za iduću generaciju procesora:
https://www.youtube.com/watch?v=OKhfZd5HDkY
Staro 13.10.2017., 18:02   #1914
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,884
http://www.guru3d.com/articles-pages...-review,1.html
što sam najbitnije zapamtio da ne ide preko 60 stupnjeva na 5 ghz,zašto se i7 8700k tolko više grije??sumljam da je kod 8600k pasta bolja,hipertreading upaljen kod i7 8700k?
Staro 13.10.2017., 19:58   #1915
Manuel Calavera
Postovi: 14,589
Stječe se dojam da je 5ghz postić kao iz pichke, maltene zagarantirano na svakom, ako ne i više. A hlađenje kao da nije upitno
Guru3d:
Your reachable target for Coffee Lake is 5 GHz and 5.2 perhaps even 5.3 GHz with a really good processor.
TPU recenzija:
It seems that our Core i5-8600K is not one of the lucky ones. Reaching 5 GHz is out of the question, not even with watercooling, no matter the voltage. 4.9 GHz is doable on decent watercooling, but it took a lot of extra voltage to fully stabilize every single application. 4.8 GHz, on the other hand, was relatively easy and achieved at a voltage level air cooling can deal with (to keep load temperatures below the thermal throttle point).
Staro 13.10.2017., 20:09   #1916
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
Mani, cuo si sta skot kaze.. njemu je sumnjivo i onih 2,8 na 8400
MojSkuter
Staro 13.10.2017., 20:24   #1917
Manuel Calavera
Postovi: 14,589
Škot je napravio dobru recenziju recenzija i skužio odstupanja od cca 20-25% u istom benču u različitim recenzijama, ali je malo previše pesimističan (kao i za vegu). Mislim da ni većini B360 neće biti problem držati 3.8ghz na svih 6c, pa nije to 4.8ghz. A i da ne mogu držati svejedno mislim da će biti iznad 3ghz tj. dosta više od base clocka, a sam intel se fino ogradio i to je to.
Kažem, samo mi je malo glupo ovo "5ghz kao dobar dan" i "možda može i više", kad je full stabilno za većinu cpu-a 4.8ghz (što je isto rekao anandtech kad su krenule 5ghz priče za i7 7700K, a većina delidala). Naravno uz niže kriterije stressanja (za gaming recimo) i sigurno uz delid je i 5ghz vjerojatno norma
Zadnje izmijenjeno od: Manuel Calavera. 13.10.2017. u 20:31.
Staro 13.10.2017., 22:08   #1918
Postovi: 8,568
Remember the days of easily achieving 5GHz when overclocking on air? Neither do we, really, but that magical number is within the remit of the sample Core i7-8700K. Recipe: hit an all-core 5GHz in the BIOS, increase voltage from stock to 1.275V, and away you go. The all-core temperature averaged 76°C under sustained load. However, we have since spoken to a number of UK-based system integrators and learned that the engineering-sample chips provided by Intel overclock to 5GHz far more easily than retail models, to the extent that an extra 0.1V is needed to ensure stability, raising heat and calling a guaranteed all-core 5GHz overclock into serious question. We'll undoubtedly learn more as systems come into the lab, but don't be surprised to see PCs arrive at speeds that don't rival what we show.
Izvor: HEXUS.net
Staro 13.10.2017., 22:17   #1919
Manuel Calavera
Postovi: 14,589
Možda su dobili cherry pickane primjerke. Nije lako nasvirat na 5ghz retail verziji (ne kažem da nije teoretski moguće, treba dobar primjerak + burtalan cooler ili labavije stressanje), ali je teško.
Nego:
Staro 13.10.2017., 22:53   #1920
Lungz
Registrirani Korisnik
Lungz's Avatar
Lokacija: Županja
Postovi: 400
Autor demetrius Pregled postova
Po ovome za gaming na 1440p + 1080 i7-8700k ima iste performanse kao i5-8600k i u odnosu na i5-6600 (ovdje je K proc, ali on je zanemarivo brži od non-K) radi se o 5-6 FPS povećanju performansi u većini igara? Drugim riječima, i dalje se ne može napraviti neki smisleni upgrade procesora...
Lungz je offline   Reply With Quote
