#3303 | |
Prvoklasni Krkan
Postovi: 5,312
Pitanje naravno nije upuceno tebi, nego opcenito, ali ako znas odg. slobodno pucaj |
#3304 | |
Poboljsana verzija
Postovi: 483
Per the data gathered, if you don't have a CPU built on or after the last week of June, good chance you'll have this issue. This isn't a RAM, CPU, MOBO or VOLTAGE issue as the replacement chips work without changing anything. Threadripper chips have UA1727+ Build Dates. Reported Good RMA CPU Build Dates UA1725SUS (mcl00@amdcommunityforums , fujii@amdcommunityforums, sat@amdcommunityforums, supercom32@amdcommunityforus, raydude@amdcommunityforums) UA1730SUS (parttimehorse@reddit) Reported Instance of bad CPU Build Dates UA1706SUT (sat@amdcommunityforums) UA1707SUT (supercom32@amdcommunityforums) UA1707SUT (apache14@amdcommunityforums) UA1707PGT (fujii@amdcommunityforums) UA1707PGT (parttimehorse@reddit) UA1707PGT (markh@amdcommunityforums) UA1707SUS (xtronom@amdcommunityforums) UA1708SUT (kaseki@amdcommunityforums) UA1709PGT (bradc@amdcommunityforums) UA1713PGT (raydude@amdcommunityforums) UA1714SUS (xtronom@amdcommunityforums) UA1714SUS (runningman@amdcommunitforums) UA1714PGT (udamanfunks@amdcommunityforums) UA1716PGT (fujii@amdcommunityforums) UA1717PGS (dbdbdb@amdcommunityforums) UA1717SUT (sat@amdcommunityforums) UA1725SUS (sat@amdcommunityforums) Prve dvije znamenke nakon UA označavaju godinu a druge dvije tjedan proizvodnje. Taj broj se može vidjeti samo na procesoru pa ako se nekome da skidati sve neka gleda ![]() |
#3305 | |
Prvoklasni Krkan
Postovi: 5,312
Fala ![]() |
#3306 |
Datum registracije: Feb 2016
Lokacija: ______
Postovi: 1,455
Hvala obojici na odg ![]() Na ovoj stranici su upute kako reproducirati test. Treba samo dignuti Linux (bilo koja verzija Linuxa?) i pokrenuti taj Ryzen test (ovome sa te stranice greška se pojavila već nakon 88 sekundi, dok nekima trebaju sati testiranja)? Mene samo zanima da li je Windows zahvaćen... |
#3307 | |
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,767
#3308 |
Postovi: 14,584
#3309 |
Link 1: hijaoooo, a kad je Brko rekao da će kad tad Gnjidabajt (tm) BIOS usrat nekako, smijeha je bilo. Vidoviti Milan mi je rekao to i beše u pravu. Link 2: mislim da ovo više govori o tome koliko su ljudi bili siti Intelovog masnog naplaćivanja reciklaža nego o tome koliko je ryzen zapravo dobar i jak (a je, i dobar i jak i dobro pogođen). @mob |
#3310 | ||
Postovi: 14,584
Prodaja na švapskom portalu je logična - ide po isplativosti. Intel jedino drži i7 7700K kao naj gayming cpu, ostalih nema ni blizu vrha prodaje Citiraj:
#3311 | |
Lokacija: ______
Postovi: 1,455
#3312 |
..starija garda
Postovi: 3,280
..čuo si da može biti i da se zna desiti ..ja jedino što znam, je da mi komp radi stutter free 24/7 , iako su win ostali stari od intel mašine a molili su me da stavim friške. ..i jedino "restartam" komp kako mjenjam hardware tj grafičke u zadnje dane. uglavnom se ljudi žale koliko vidim prilikom OCa na rame, ali nitko da mu išta šteka oko aplikacija u win, a već nas se je ohoho skupilo čak i na ovom forumu. ono što želim reći, ok to je prijavljeni problem, i ako te dira dobro je znati, ali treba izbjegavati ovo čuo si da može biti da se zna desiti ![]()
__________________ MojSkuter ---------------------------------PEACE Zadnje izmijenjeno od: Eladio. 02.09.2017. u 23:40. |
#3313 |
Ne bi nikad rekao da problema nema. Vjerujem da ima. No stvarno, ali stvarno sam više puta upregnuo R5 1600 na 3.93GHz i ama baš ništa se nije negativno dogodilo. Možda i ploče imaju određenih problema i dalje koji nisu skroz riješeni, stvarno nemam pojima. Al da treba brusiti još tu platformu, treba. @mob |
#3314 |
Datum registracije: Aug 2013
Postovi: 268
Pitanje za vidovitog Milana, ali koliki se price drop Ryzena/DDR4/MBO moze ocekivati do Bozica? Dolar bi isto mogao otici gore. Planiram upgrade, a realno mi nije neka hica, mogu se strpit jos koji mjesec da ustedim nesto i da se eventualno ispeglaju neke sitnice na platformi. Jos mislim da mi je najbolja opcija loviti Black Friday/Cyber Monday, uzimam hardver u USA. |
#3316 |
..starija garda
Postovi: 3,280
Nemas sta cekat, sve je izaslo sto je trebalo izać. Možda intel coffe lake malo poremeti cijene još eventualno, ali poznavajući intel on će biti skuplji i amd će možda samo malo podesiti price/performance line up po tome. Ipak generalno ove godine to je to, sitne oscilacije su više vezane za dolar Ps ddr4 ram ti ide gore, bar je takva najava, tako da tu može biti stvar još i gora nego sad ![]()
#3317 |
Dolar i Euro su pali dok je turistička sezona. Za RAM je najbolje kupiti ga danas jer on malo po malo i dalje raste. Ryzen i ploče neće drastično pasti. A za Božić je ionako sve skuplje ![]() @mob |
#3318 |
Lokacija: Zagreb, Dubrava
Postovi: 502
Danas se malo poigro sam overeclockom ryzena 1600x. U 10 min postavio ga na 4.0 GHz na 1,35 i za sada stabilno sa svim stress testovima. Temperatura max je 63 c što je zadovoljavajuće. Vjerovatno ću se još poigrat s voltažom jer bi je htio maksimalno spustit, ali to je izazov za drugi dan. Usput jedan dobar video za vlasnike asus c6h po kojem sam radio. https://www.youtube.com/watch?v=pBmVf0S4UDs |
#3319 | |
E Pluribus UNIX
Lokacija: M82
Postovi: 6,767
Slicno ti je i ovdje. Srusi se svaki 1.000 aparat u nekoj opskurnoj situaciji. Bude bilo popeglano u novijim verzijama a ako ce bas netko jako jesti govna, dobit ce novi CPU i bok-cao-papa. Koliko to dugorocno pomaze AMD-u u plasmanu na trzista koja donose hrpu para? Nemam pojma. Calculated risk. Steta, jer procesor ipak u nekom price/performance odnosu za boraniju predstavlja fantasticnu pricu. Isprobao sam ga za Pix4D (dosta opskuran ali vrlo mocan softvercic za 3D mapiranje i slicna zazanja) i rezultati su, obzirom na ulozeni novac, fantasticni. Zelim li se kockati s time hoce li mi 10 dana vrcenja tog softvera puknuti nekada? E, i ne bas. Jer cu isplatiti 40% skuplji stroj za 30 dana. Po meni je tu AMD napravio pacersku gresku, kao i obicno. Bezrazlozno.
#3320 |
MadModerator
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Ako sam dobro skuzio, taj problem je rijesen u novijim verzijama Ryzena. Ako netko ima problema s tim, moze poslati CPU nazad AMD-u i dobit ce novi.
#3323 |
Postovi: 8,357
Uključiš Windows Subsystem for Linux (WSL) i pokreneš prethodno spomenutu ./kill-ryzen.sh skriptu s Phoronixa. |
#3325 | |
Zanimljiv mi je taj zapad (Njemačka u ovom slučaju...). Njihovi grafovi i analize su mnogo puta vrlo nepregledni , nedostatak informatičara i ljudi koji imaju smisao za dizajn. Koda je Njemcima sve kvalitetno ošlo u autoindustriju i strojarstvo... |
#3326 |
Prvoklasni Krkan
Postovi: 5,312
#3328 |
Prvoklasni Krkan
Postovi: 5,312
#3329 | ||
Nisam doma još par dana pa to neću moći provjeriti. Vjerojatno je affected. Uzeo sam R5 1600 5 dana nakon launcha. Ali ga ne mislim vraćati AMDu ne još... možda kad dođe Pinnacle Ridge ![]() Citiraj:
![]() @mob |
