Staro 10.08.2017., 23:26   #511
alen_os
Postovi: 26
Autor buljo Pregled postova
Kak može 1060 sa 50% power limita trošit 90W?
Kartica ima 8pin napajanje
http://imgur.com/a/0N8Sh
alen_os je offline   Reply With Quote
Staro 10.08.2017., 23:59   #512
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,344
Ma pusti te price o potrosnji, izmjeri iz zida.
žmnpp
Staro 14.08.2017., 18:14   #513
Ante697
Datum registracije: Mar 2008
Postovi: 31
MSI RX580 Gaming X 8gb (Hynix)
Claymore 9.8
Crimson 17.2.2 driver
Stock: 21.5 MH/s ETH
S ovim BIOS-om : 29.4 MH/s
Memojrija je već s BIOS-om na 2150 MHz I to radi stabilno
Gigabyte RX470 4gb (Samsung)
Stock: 21.5 MH/s
BIOS: strapovi sa 1500 na više 24.5 MH/s
Memorija: 1900 MHz daje 26.8 MH/s
Iako je Samsungova memorija neda mi više od ovoga makar mi je i na 1900 znao uletit Incorrect share.
Uz to hashrate zna zatrzat do 24.2-25.3
Koliko vama vrte rx470 sad? Ako netko ima bolji setup volio bi da ga podjeli
Ante697 je offline   Reply With Quote
Staro 14.08.2017., 19:08   #514
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
What about cryptocurrency mining?
Given the shortages on AMD's RX 570/580 cards, which are typically selling at prices 50 percent or more above the MSRP, many have feared—and miners have hoped—that the RX Vega would be another excellent mining option. I poked around a bit to see what sort of performance the Vega 56/64 delivered in Ethereum mining, and so far it's been pretty lackluster, considering the price and power use. The Vega 56 manages around 31MH/s for Ethereum, and the Vega 64 does 33MH/s. Overclocking the VRAM helps boost both cards closer to 40MH/s right now. So at launch, that's not super promising.
The problem is that most of the mining software has been finely tuned to run on AMD's Polaris architecture. Given time, we could see substantially higher hashrates out of Vega, and there are rumors that the right combination of VBIOS, drivers, and mining software can hit mining speeds more than double what I measured. Perhaps AMD is intentionally holding back drivers or other tweaks that would boost mining performance, and long-term AMD remains committed to gaming. All we can do is hold our breath and hope that mining doesn't drive prices of Vega into the stratosphere in the future.
izvor:
http://www.pcgamer.com/the-amd-radeo...ega-64-review/
Staro 14.08.2017., 19:46   #515
BlackDwarf
BIND SOFT d.o.o.
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,415
A pricalo se da Vega ide 70-100MH/s
https://youtu.be/LLyEknCynpY?t=941
Staro 14.08.2017., 20:05   #516
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
Evo jedna radosna vijest.
Novi nvidia driveri dižu nešto sitno mhs.
https://www.reddit.com/r/EtherMining...bump_in_mhsec/
Isprobam pa javim.
EDIT: na 1060tkama 0% napretka...
Zadnje izmijenjeno od: Blue_Fatal1ty. 14.08.2017. u 20:36.
Staro 14.08.2017., 20:57   #517
lit
Lokacija: hr
Postovi: 976
Trebam pomoć za overclockat gtx 1070 windforce 8GB sa micron memorijom.
Trenutno mi je ovaj setup:
i postižm s time 18.65 MH/s na signatum coinu.
Ali trebalo bi ići barem 26 ako ne i 30 MH s tom grafičkom.
Da li imate kakav savjet kako postići više od tih 18MH?
lit je offline   Reply With Quote
Staro 14.08.2017., 20:59   #518
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,598
Ocito nemas onaj "poboljsani" miner
Digni core clock za +150 i imat ces oko 20 MH/s, za sve ostalo vise ti treba drugi miner
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 14.08.2017., 21:03   #519
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Jesi probao s drugim majnerom?
https://mega.nz/#!QkFBRboJ!nO2bxvPsX...CDOj4wd0C8eHGA
Power limit stavi na 70%-75%
Staro 14.08.2017., 22:38   #520
lit
Lokacija: hr
Postovi: 976
Super hvala dečki, skočilo je sada na 30.25+ MH/s , very cool
samo da pitam što je skunk block?
Staro 15.08.2017., 09:33   #521
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,585
Autor Blue_Fatal1ty Pregled postova
Isprobam pa javim.
Ja još uvijek na 378 driverima, jel da instaliram te najnovije, pitam se.
Glede skunka, tpruvot je izdao 2.2 verziju ccminera neki dan i totalno rasturio sp-ovu verziju skunk minera.
spmod5 228mh
cc 2.2 244mh
https://bitcointalk.org/index.php?to...68#msg20854368
Staro 15.08.2017., 15:38   #522
Ante697
Postovi: 31
Sa DAG fixom za radeon dobio skoro 2 MH/s na rx icama
580 sad radi 31.3 MH/s a 470 je radila 29.3 i nakon restarta kompa davao incorrect share pa ga morao spustit na 27.8 MH/s
Staro 15.08.2017., 20:51   #523
Uzi84
Datum registracije: Jul 2017
Lokacija: Vinkovci
Postovi: 170
Jel izasao fix na sluzbenim driverima il su to jos uvjek ovi "divlji".
Uzi84 je offline   Reply With Quote
Staro 15.08.2017., 21:05   #524
Ante697
Postovi: 31
Autor Uzi84 Pregled postova
Ja sam instalirao ove "divlje" i zasad se isplati
Staro 15.08.2017., 22:29   #525
goran047
goran047's Avatar
Datum registracije: Nov 2016
Postovi: 142
zasto meni ne zeli te drivere uopce instalirat, imam 3 asus rx 570 expedition i 2 asus rx 570 strix i jedino sljakaju oni prvi modani driveri sve ostalo nema sanse da instaliram
goran047 je offline   Reply With Quote
Staro 16.08.2017., 11:06   #526
Nikol@Grozni
Nikol@Grozni's Avatar
Postovi: 320
Ga 970a-ds3p, athlon 240, 4Gb rama, 3x RX470 4Gb,Fsp Raider 750W
Rx 470
xfx 4 Gb Hynix
Stock: 21.5 , Bios mod 25.4 , mem oc na 1900Mhz 26.5 Mhz
Msi 4gb armor, Samsung
Stock: 22 , Bios mod 25.2 , mem oc na 1900Mhz 27.5 Mhz
Asus strix 4Gb, elpida
Stock: 20.3 , Bios mod + mem oc na 1850Mhz 24.9 Mhz
Sve stock cijeli rig 64Mh/s, s bios mod + oc na 1850, Pw -5% ( 80W prikazuje gpuz ), daje 75,8 Mh/s.
Sve na 16.11.4 beta driverima, imam problema s oc( afterburner stavlja sve taktove na 300Mhz.. ) na novim s dag fixom i 17.7.2..
Projekti:
No_name
No_name II
Mini
OC
Nikol@Grozni je offline   Reply With Quote
Staro 16.08.2017., 13:26   #527
SarKast
Bartonize Your Mind!
SarKast's Avatar
Lokacija: Syewerozapad
Postovi: 351
a eto, nešto se pojavilo - sad treba vidjeti je li to to!
https://support.amd.com/en-us/kb-art...ase-Notes.aspx
ako je netko već testirao, neka se ne libi podijeliti iskustva!!!
W!
edit: Pixel Clock Patcher je i dalje potreban...
Gigabyte GA-Z170N-Gaming 5 (rev. 1.1), Intel Sunrise Point Z170, Intel Skylake-S, Socket 1151
Intel Core i3-6300T [ES] @ 3.3GHz (4MB, Skylake-S, S0)
Noctua NH-U9B SE2, ~1900RPM, 35-45°C
2x16GB DDR4-2133 Kingston HyperX Fury HX421C14FB/16, 14-14-14-35, CL2
OnChip Intel HD Graphics 530, 1GB Shared DDR4 (350-900MHz)
Samsung SSD 850 EVO 2,5", 250GB, SATAIII
XFX Core Edition P1-450S-X2B9, 450W, ATX, 120mm, PFC
Fractal Design Define Nano S
Samsung SyncMaster T220, 22" Wide LCD, 2ms, 20.000:1 Dynamic Contrast
Cambridge SoundWorks DeskTop Theater 5.1 DTT2200
Panasonic TX-P42S30E, 42" [107cm] Plasma TV, 1920x1080 Full-HD, NeoPDP
Asus Maximus IV GENE-Z, Intel Cougar Point Z68, Intel Sandy Bridge, Socket 1155
Intel Core i5 2500K, 3.3GHz, 6MB, 95W, LGA 1155 @ ~4.5GHz
Noctua NH-U9B SE2, ~1900RPM, 45-55°C
4x8GB Patriot G2 Series DDR3-1600MHz, 9-9-9-24
OnChip Intel HD Graphics 3000 @ 850 MHz, 2GB shared DDR3
WD Caviar Green WD20EARS, 2TB, 32MB, 5900RPM, SATAII
Sony NEC Optiarc DVD-RW, AD-7170S
Corsair CX 430 v2
Fractal Design Define R3 Black Pearl
Asus GL552VW, Intel Sunrise Point HM170, Intel Skylake-H, Socket 1440
Mobile Intel QuadCore i7 6700HQ @ 2.6/3.5GHz, 4 Cores/8 Tasks (6MB L3 Cache, Skylake-H, R0)
2*16GB DDR4-2133 SO-DIMM (15-15-15-36, CR2)
500GB Crucial MX200 M.2 Type 2280 Single Sided SSD, R/W:555/500
500GB Samsung EVO 850, 2,5" SATAIII SSD, R/W:550/520
2D Graphics: OnChip Intel HD Graphics 530, 1GB Shared (350/1050 MHz)
3D Graphics: nVidia GeForce GTX 960M (GM107), 4GB GDDR (128bit//2505/2200MHz)
LG Philips LP156WF6-SPB5, 15.6" FullHD IPS LCD, 1920*1080
LG HL-DT-ST DVD-RW DL
Intel Dual Band 8260 WiFi 802.11
Realtek RTL8168/8111 PCI-E Gigabit LAN
Cam & Bluetooth & CardReader On-Board
ACER Aspire AS5738ZG-432G25MN , Intel Cantiga GM45, Socket 479
Mobile Dual Core Intel Pentium T4300 @ 2100 MHz (1MB L2, Penryn-1M, R0)
2*2GB Kingston PC2-6400 SODIMM, KVR800D2S5/2G, DDR2-800 (5-5-5-18 CR2)
Seagate Momentus, 250GB, 5.400RPM, SATAII
ATi Mobility Radeon HD 4570, 512MB GDDR3, (64Bit//680/500x2MHz)
15,6" LG Philips LP156WH1-TLA3, HD Acer CineChrystal LCD WXGA, 1366*768, 32bit @ 60Hz
Sony Nec Optiarc AD-7580S DVD-RW, SATA
Atheros AR5009 802.11a/g/n WiFi
Broadcom NetLink BCM5784 PCI-E Gigabit Ethernet
Broadcom 2046 Bluetooth 2.1
ACER Crystal Eye 0.3Mpx WebCam
Ni}{ilLi$t se jednog jutra probudio transformiran u LG 47LW5500
i od tada jednostavno više nije što je nekad bio, već Smart TV 47"
ASUS Transformer Pad [TF701T]
NVIDIA Tegra 4 1.9GHz Quad-core ARM Coretex-A15 CPU,
2GB Memory, 32GB Internal Storage, 72 Core GeForce GPU,
10.1" LED Backlight IPS Panel WQXGA Display @ 2560x1600,
Wi-Fi, Bluetooth v3.0, 1.2MP [720p] & 5MP [1080p] Camera,
Micro HDMI, MicroSD, OS Android v4.3, Mobile Dock with:
Keyboard, Touchpad, USB3, SD Card Reader & add. Battery.
... it is not a tablet - it's a PeeLooL !!!
ASUS A7N8X-E Deluxe, nForce2 Ultra 400 + MCP-T, Socket A, Enhanced Uber BIOS 1013
Mobile AMD Athlon XP-M 2500+ @ 2200MHz [200*11], (Barton, 512KB)
Thermaltake Sonic Tower | passive @ ~45°C, max. 60°C
3*1GB Super Talent D32PB1GJ CL3 PC3200, DDR-400 (3-3-3-8 CR1)
MSI GeForce NX7600GT-TD256Z, Silent, 256MB DDR2, AGP 8X (128Bit//560/400x2MHz)
Western Digital Caviar WD600BB, 60GB, 2MB, 7200RPM, ATA
NEC DVD-RW
Chieftec GPS-400AA-101 A, 400W, 12cm
Shenzhen MMUI Co. VIA VT6421A 3-Port SATA/eSATA & IDE Controller Card, PCI
Gigabyte Triton GZ-XX1CA-SNB, Black
oc:
ASUS A7N8X-Deluxe Rev:2.0, Nvidia nForce2 Ultra 400 + MCP-T, Socket A
AMD Athlon XP 3000+ @ 2167MHz (Barton, 512KB)
Coolermaster Alps HHC-L61 Silent Heat Pipe
3*1GB Super Talent D32PB1GJ CL3 PC3200, DDR-400 (2.5-3-3-7 CR1)
Gigabyte 7600GS, GV-N76G256D-RH, 256MB DDR2, AGP 8X (128Bit//400/400x2MHz)
Western Digital Caviar WD400JB, 40GB, 8MB, 7200RPM, ATA
2*Western Digital Caviar WD1200JB, 120GB, 8MB, 7200RPM, ATA
Plextor DVD-RW PX-740A | Plextor CD-RW PX-W4824A
250MB iOmega ZiP Drive | 5,25" Floppy | 3,5" Floppy
Canyon CN-WF511, 802.11g Wireless Network Adapter, PCI
Micronet SP2612R 10/100/1000 Mbps Gigabit Ethernet Adapter, PCI
Asonic RAID PATA Controller A-6421, 1-ch + SATA + eSATA, PCI
Fortron ATX400W-PNF, 12cm
Codegen Briza 6097
BaSiŁ nema periferije - polished, boxed & archived!
Muzejski primjerak -> da se unuci imaju čemu čuditi
|still active|
Zadnje izmijenjeno od: SarKast. 16.08.2017. u 13:46.
SarKast je offline   Reply With Quote
Staro 16.08.2017., 13:48   #528
Shamanix
Shamanix's Avatar
Postovi: 870
To su cini se isti driveri koji kruze tu forumom vec.. imam ih ja instalirane, samo sto je kod mene u verziji 1 na kraju a na ovim "sluzbenima" je 0 haha
Shamanix je offline   Reply With Quote
Staro 16.08.2017., 22:34   #529
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Gigabyte RX 560, poigrao se još malo sa strapovima:
Šteta što nemam neku 580 sa malo jačom memorijom, trebalo bi to na 33-34
bez problema
Staro 18.08.2017., 12:50   #530
aiku
Datum registracije: Mar 2017
Lokacija: Gradiška
Postovi: 17
Autor SarKast Pregled postova
W!
Instalirao po ovoj proceduri http://1stminingrig.com/ethereum-dag...s-are-now-out/
i nakon pokretanja Claymores 9.8 miner samo se zatvori prozor. Windows 7 64bit i RX570/4GB modane. Treba li Win 10 za ovu kombinaciju ili je nešto drugo u pitanju?
aiku je offline   Reply With Quote
Staro 18.08.2017., 12:58   #531
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
Da ti nije antivirus pojeo .exe iz majning foldera ili nešto slično?
Staro 18.08.2017., 13:26   #532
Silthrax
Silthrax's Avatar
Lokacija: Gračac
Postovi: 477
bez problema
Pa to je super za RX 560 ne znam zasto vise ljudi ne majna s njima?
Silthrax je offline   Reply With Quote
Staro 18.08.2017., 13:38   #533
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Autor Silthrax Pregled postova
Vjerojatno zato što treba više matičnih i risera ako ideš na puno kartica...doduše malo troše pa je jedan fortron od 700W dovoljan za čitav rig i još mu ostane snage
Mana je i što toliko daju one sa micron memorijom, hynix je lošiji, barem na gigabajticama...da se barem ljudi oće
potrude i poslikaju mi hynix chipove na drugim karticama pa da eventualnu nađemo nekog proizvođača koji
nije cheater kao Gigabyte
Staro 18.08.2017., 14:00   #534
aiku
Lokacija: Gradiška
Postovi: 17
Nije, pošto sam vratio na zvaničnu verziju drajvera i sve radi.
Staro 19.08.2017., 11:57   #535
lit
Lokacija: hr
Postovi: 976
Evo ga Radeon RX Vega 64 ide samo 32-33 MH/s na ETH:
https://youtu.be/CcK0lLz_6m8?t=428
https://youtu.be/y62vFHE-E9g?t=15
$700 dolara, 32-33 MH/s, 300 W potrošnja
riješili smo i tu misteriju
Staro 19.08.2017., 12:18   #536
dada-as
Bot Maker
dada-as's Avatar
Postovi: 2,741
Sto skoro 5000 kuna za 33 MHS, pa bolje je onda kupiti 1060 za 2k koja daje 20 MHS.
No dobra je stvar sto ce konacno gameri moci kupiti karticu i igrati se s njome.
Staro 19.08.2017., 12:35   #537
lit
Lokacija: hr
Postovi: 976
Kod nas će biti sigurno viša cijena od američke. Ja na 1070 dobivam do 32 MH/s ali mi nije baš stabilan hashrate prema grafikonu na poolu:
https://s29.postimg.org/6eq2lfi0n/Snap6.png
jel to mora tako biti?
https://s29.postimg.org/j7e6lctmf/Snap2.png -32 MH/s
Staro 19.08.2017., 13:31   #538
Zeko.mudri
Datum registracije: Aug 2017
Postovi: 133
Autor lit Pregled postova
Slabo, $600-700, 2xGTX 1060 31-32 MH/s neclockana, 34-40 MH/s clockana, 160 W potrošnje
Zeko.mudri je offline   Reply With Quote
Staro 19.08.2017., 19:14   #539
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
Autor Zeko.mudri Pregled postova
600$ 2x1060 190W 50 mhs je kod mene situacija.
Staro 19.08.2017., 20:21   #540
TheVeka
Datum registracije: Aug 2012
Postovi: 34
Koje su to kartice ako može odgovor pliz. Ja bi uzeo dvije GTX 1060 ali ne želim ubost Hynix memoriju
THNX
Autor Colop Pregled postova
Samo da pohvalim INNO 3DGTX 1060 3 GB kartice.
Samsung memorija, već danima mi rig sa 5 x kartica 114 MHS.
pozz!
gdje si uzeo te inno kartice?
ja bi pokušao isto uzet al bojim se da ne ubodem hynix verziju
Zadnje izmijenjeno od: FRipper. 19.08.2017. u 22:23.
TheVeka je offline   Reply With Quote
