Staro 29.06.2017., 10:40   #1381
Gigi1
Postovi: 2,138
Ocekivano, no zanimljivo kako nijedan pisani/video rivju novih x299 cpuova (koje sam citao/pogledao)se nije dotakao tog problema sa vrm-ovima, svi su uredno potezali cpu na 4.6-4.8 GHz super oc potencijal bla bla bla... i jedina zamjerka im je bila visoka temperatura samog cpu.
Koliko je intel rushao x299 toliko su i rivjueri rushali rezenzije, smijesno
Staro 29.06.2017., 11:01   #1382
sti
Lokacija: Lawl
Postovi: 1,374
Zato je Tweaktown odličan kad su recenzije ploča u pitanju, redovno slikaju i opišu naponsku regulaciju.
http://www.tweaktown.com/reviews/823...ew/index3.html
Staro 29.06.2017., 11:11   #1383
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
I taj overclock je napuhan gro, nije to mnogo bolje od broadwell-e
The results were mixed, my chip only managed a stable 4.6GHz overclock, no matter how much voltage I threw at it I wasn't able to stabilize anything beyond that. The system would boot into Windows but would blue screen within the first few moments of running a stress test. Stability might improve with future BIOS updates, or perhaps I just have a dud. Looking around the Internet it seems others are also stuck at 4.6GHz like me while some folks have managed to stabilize their system at 4.7 or 4.8GHz.
However, the frequency isn't my greatest concern right now. Using just 1.2 volts, which is all I needed for a stable 4.6GHz overclock on all cores, the system consumption went from the 259 watts just seen to an insane 402 watts! That might not even be the worst part, the deal breaker is probably the operating temps. Chilling the 7900X was Corsair's H100i v2 and despite being a premium 240mm AIO liquid cooler, temps skyrocketed as the CPU was place under load, reaching 90 degrees instantly before climbing further towards 100 degrees. Unless you have an amazing cooler, I'm not sure overclocking is going to be worth it.
https://www.techspot.com/review/1433...e-x/page4.html
Overclocking the Core i9-7900X
Though my time with the ASUS X299-Deluxe and the Core i9-7900X was short, I was able to get our sample overclocked to an impressive state. With a core voltage of 1.28v I was able to push all cores to a 4.6 GHz and run the system mostly stable.
However, temperatures at this point would spike to over 100C (!!) and level off in the mid-90C range, which was too hot for me to run for an extended period with a clear conscious, even with a Corsair H100i GTX as the cooler.
https://www.pcper.com/reviews/Proces...-Performance-a
So far, the 7900X is running hot – overclocking got us stuck at around 4.5GHz/1.275V with a 90-95C package temperature when using a Kraken X62, and can increase power draw into a couple hundred watts.
http://www.gamersnexus.net/news-pc/2...hot-xbox-one-x
Znači vrelo na 4.5ghz i 4.6ghz i high end vodenjačama
Zadnje izmijenjeno od: Manuel Calavera. 29.06.2017. u 11:23.
Staro 29.06.2017., 11:33   #1384
Gigi1
Postovi: 2,138
E ali nitko od ovih nije spomenuo ista o vrm koliko sam preko mob preletio tekstom, problem je u tome kaj ce ekipa vidjet 4.5/4.6 mogu oni, mogu onda i ja-samo mi treba vrh hladjenje, postavit ce setup a za par dana ce im prdnut mbo ili jos gore mogucnost zapaljenja
Staro 29.06.2017., 14:38   #1385
Dottore
Dottore's Avatar
Postovi: 7,635
Nisam stigao pročitati, da li su spomenuli temperature okolina ako su testirali cpu i vrm-ove? Kako Manuel opisao vrelo pod vodenjačom i to mene potaknulo znatiželju.
Sent from my HTC U11
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 01.07.2017., 05:44   #1386
Rino
[ZA DOM]Rino
Rino's Avatar
Lokacija: Kutina
Postovi: 762
fan
Lik koristi vodeno bez ikakvih ventilatora da pušu preko VRM
Rino je offline   Reply With Quote
Staro 01.07.2017., 08:29   #1387
nick praskaton
Asshole
nick praskaton's Avatar
Lokacija: RH
Postovi: 2,358
Autor Rino Pregled postova
fan
pa ko od prosjecnih korisnika koristi aktivno hlađenje vrm-ova, poanta je da ploče od 300€ ne mogu ohladit VRM-ove sa ni blago ocanim procom, a hladnjaci na vrm-ovima sluze za ukras
Staro 01.07.2017., 10:16   #1388
Rino
[ZA DOM]Rino
Rino's Avatar
Lokacija: Kutina
Postovi: 762
Autor nick praskaton Pregled postova
Ako imaš hladnjak na procu i ventove za usis/ispuh imaš i aktivno hlađenje. Pretpostavka je da imaš i kvalitetno kučište čim daješ 300€ za ploču.
Staro 01.07.2017., 10:51   #1389
nick praskaton
Asshole
Lokacija: RH
Postovi: 2,358
naravno, ali to ne znaci da ću trpit buku i 6 ventova u kucistu na 1700 rpm samo da bi mogli ohladit jadne VRM-ove
Staro 01.07.2017., 10:53   #1390
NoneSoVile
samo warmetal
NoneSoVile's Avatar
Datum registracije: Jun 2017
Postovi: 192
Nisu vrmovi jadni nego heatsinkovi i thermal pads
NoneSoVile je offline   Reply With Quote
Staro 01.07.2017., 11:09   #1391
nick praskaton
Asshole
Lokacija: RH
Postovi: 2,358
Autor NoneSoVile Pregled postova
ma na to sam i mislio...
Staro 01.07.2017., 11:15   #1392
Gigi1
Postovi: 2,138
Bit ce zanimljivo vidjeti kako ce ove ploce koje imaju problem sa 10jezgri drzati 14+ jezgrene i9
Staro 06.07.2017., 02:15   #1393
Gigi1
Postovi: 2,138
Suska se da ce biti rev.2 x299 ploca za hcc i9 procove, sto bi potencijalno znacilo da sadasnje x299 ploce nece raditi sa 12+ core i9 cpuovima
Inace 10 jezgreni moze i do 350-400W povuc
Staro 06.07.2017., 07:29   #1394
Amd_Shill
Datum registracije: Dec 2016
Lokacija: Sat
Postovi: 1,119
Jasno da će bit nova verzija ploče jer VRM na ovima ne mogu držati ove abominacije od proceva koje su izbacili,tj napumpali server parts na 4+ghz i nabili potrošnju da postide 9590
Sve je to zbrzano radi Threadrippera.
Amd_Shill je offline   Reply With Quote
Staro 06.07.2017., 08:48   #1395
Gigi1
Postovi: 2,138
Naponska regulacija za do 10jezgri nije losa koliko je lose hladjenje i ona kauguma na njima. Lik je u prvom videu maknuo cijeli coooler i samo stavio vent da puse, kaze sasvim dovoljno.
Za veci br.jezgri vjerojatno ni nap.reg nije dovoljna i da stave bolje hladjenje.
Staro 06.07.2017., 12:46   #1396
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,822
Izgleda da je Intel sam sebi zabio nož u leđa s ostankom na 14 nm tehnologiji, mislim da bi daleko bolje prošli da su prešli na 10 nm, i zbog performansi i zbog potrošnje.
Staro 06.07.2017., 13:29   #1397
NoneSoVile
samo warmetal
NoneSoVile's Avatar
Postovi: 192
Ti onda očito neshvaćaš kako funkcionira intelova HEDT serija
Staro 06.07.2017., 14:08   #1398
Sinac
Sinac's Avatar
Postovi: 2,822
Daj me prosvijetli, zapisano je u kamenu da mora biti onako kako si ti zamislio, radi se o High End DESKOPU, ne o serveru da bih si ja kao korisnik mogao dozvoliti veliku buku, kemijanje s hlađenjem itd.
Ista je stvar bila kad se prva generacija P4 procesora pojavila, grijanje, loše performanse a onda su promijenili socket.
Staro 06.07.2017., 16:51   #1399
NoneSoVile
samo warmetal
NoneSoVile's Avatar
Postovi: 192
Pa ti neshvaćaš da Intelov HEDT procesori su oduvijek bili bazirani na jednoj generaciji prije sadašnje. Znači Kaby-lake=skylake-x, skylake=broadwell-e (haswell na 14nm) itd. Broadwell je mogao ić na 14nm umjesto 22nm jer se već skylake proizvodio na 14nm ali da bi skylake-x bio na 10nm onda bi značilo da će i coffe-lake biti na 10nm što očito neće nego će bit ponovni refresh skylakea/kaby-lakea.
Staro 06.07.2017., 17:03   #1400
Bariarnil
Aiden Fierce
Bariarnil's Avatar
Datum registracije: Jan 2016
Postovi: 1,171
Zae*o si se ako misliš na to kaj piše.
Kaj je onda KabyLake X
the Bariarnil
Bariarnil je offline   Reply With Quote
Staro 06.07.2017., 17:08   #1401
shar
Overclocker
shar's Avatar
Datum registracije: Nov 2016
Postovi: 523
Autor Bariarnil Pregled postova
Promašaj.
shar je offline   Reply With Quote
Staro 06.07.2017., 17:21   #1402
Gigi1
Postovi: 2,138
Negdje sam cuo/procitao da je kablake-x doslovno prikeljen s1151 kaby na s2066, znaci pomogucno ima dva pcba
Staro 06.07.2017., 17:31   #1403
Bariarnil
Aiden Fierce
Bariarnil's Avatar
Postovi: 1,171
Good one @shar
Kolega je vjerojatno se pobunio na naming scheme. Broadwell E je ista arhitektura i isti IPC kao Broadwell. A ovi novo pečeni SkyX su ista arhitektura(osim redizajniran keš, isti IPC ) kao Skylake na desktopu.
the Bariarnil
Staro 06.07.2017., 20:24   #1404
NoneSoVile
samo warmetal
NoneSoVile's Avatar
Postovi: 192
Ništa ja nisam pobunio. Broadwell je haswell na 14nm. Skylake-x je skylake logicno samo sto je izašao za vrijeme kaby-lakea, a za kaby-lake x intel može govorit šta god hoće al to nije ni blizu HEDT procesora.
Staro 07.07.2017., 09:32   #1405
Bariarnil
Aiden Fierce
Bariarnil's Avatar
Postovi: 1,171
Broadwell je Broadwell. Krešo je odradio test i7 5775C i 6950X-a pa nije nigdje rekao da je identična arhitektura Hasswellu(jer nije).
Da je Broadwell Hasswell na 14nm, ne bi bili razliciti procesori(ovi desktopi na 1150 čak imaju L4 keš). Primjer: 6900K vs 5960X
Do KabyLakea Intel je išao tick-tock i na serveru i na desktopu. Jasno ti je da intel ranije izbaci desktop pa malo kasnije HEDT i server, jer uistinu je jednostavnije manje jezgara na novijem procesu i arhitektueri.
the Bariarnil
Staro 07.07.2017., 10:46   #1406
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Autor shar Pregled postova
Promašaj.
Intel Krappy Lake X
Staro 07.07.2017., 15:09   #1407
NoneSoVile
samo warmetal
NoneSoVile's Avatar
Postovi: 192
Sandy(Bridge)32nm=Ivy(Bridge)22nm
Has(well)22nm=Broad(well)14nm
Sky(lake)14nm=Cannon(lake)10nm
Sve su to die shrinkovi, sa minijaturnim 2-3% ipc poboljšanjima.
Staro 08.07.2017., 03:49   #1408
Sinac
Sinac's Avatar
Postovi: 2,822
Smatraš da si Intel može dozvoliti starije tehnologije i politiku objave "novih" procesora kod HEDT-a sad kad AMD ima dobre postojeće desktop procesore i nove još bolje u najavi? Intel gubi tržišni udio jer AMD nudi više ili isto za nižu cijenu. Ne vidim logiku u objavi novih procesora koji su preskupi za ono što nude, kako po performansama tako i po cijeni ukupne konfiguracije jer će i matične ploče biti precijenjene.
Staro 08.07.2017., 08:22   #1409
Manuel Calavera
Postovi: 14,584
Mislim da će oni još barem jednu generaciju HEDT-a ostati na 14nm
Staro 08.07.2017., 09:57   #1410
NoneSoVile
samo warmetal
NoneSoVile's Avatar
Postovi: 192
Intel može radit šta hoće, oni mainstream 6-core coffee-lake će im se prodavat ko lud, a za hedt neznam. "Threadripper v2" će sigurno imat 24 jezgre jer nevidim razloga zašto ne, a intel onda nema šanse da ide u core war sa amdom tako da šta bude biće.
