Staro 01.05.2017., 22:37   #2731
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
AMD Takes Meaningful CPU Market Share From Intel For The First Time In 3 Years
Q2 će biti boom, u Q1 se ryzen prodavao samo zadnji mjesec, samo high end (R7) i to uz nestašicu mbo.
Evo i report iz Južne Afrike http://www.fudzilla.com/news/process...-in-the-dubans
Staro 01.05.2017., 22:56   #2732
Pa da nisu ovi panjevi što štampaju ploče ovako epično zakazali iz samo njima poznatih razloga, rezultati bi bili još i bolji.
Ali nema veze. Ryzen je pun pogodak u kojem god segmentu ga gledamo i iz kojeg kod kuta...osim kroz plave naočale.
Sent from my SM-G930F using Tapatalk
Staro 01.05.2017., 23:16   #2733
Manuel Calavera
Postovi: 14,584
The data is courtesy of PassMark’s quarterly market share report, which is based on the thousands of submissions that go through the database in any given quarter. It’s important to note that because PassMark’s market share data is based on benchmark submissions it counts actual systems in use, rather than systems sold. It also does not include consoles or any computer systems running operating systems other than Windows
Nevertheless, pročitao negdje da navodno večeras imaju službeni financijski izvještaj
EDIT
“We achieved 18 percent year-over-year revenue growth driven by strong demand for our high performance Ryzen CPUs as well as graphics processors,” said Dr. Lisa Su, AMD president and CEO.
Staro 02.05.2017., 03:59   #2734
Emissary
ČLAN FKTa
Emissary's Avatar
Datum registracije: Jul 2004
Postovi: 2,264
Staro 02.05.2017., 04:10   #2735
suedamA obmaR
Game, PC ,motobikes, bike
suedamA obmaR's Avatar
Datum registracije: Jan 2010
Lokacija: Sibenik
Postovi: 777
Autor BladeRy Pregled postova
Ili dual bios, neznam sta stede na tim sitnicama kad ploce same po sebi nisu neki low level entry model. Ipak je to skuplja ploca da stede na jednom bios cipu.
To samo gigabyte imaju patent na dual bios supci, zato nitko drugi nema.
suedamA obmaR je offline   Reply With Quote
Staro 02.05.2017., 08:43   #2736
warlock25
warlock25's Avatar
Postovi: 2,327
Za ryzen je bolje ganjat frekvu umjesto latencija na memoriji zbog fabrica.
Sent from my EVA-L09 using Tapatalk
Staro 02.05.2017., 09:35   #2737
Busola29
Nije baš pun pogodak , ajmo reći iskreno r5 1400 precijenjen , r5 1500 se nalazi nigdje jer malo skuplji r5 1600 ga tuče strašno...
Puni pogoci : r5 1600 i r7 1700 + x verzije ostalo prosjek ... Manja potrošnja i zagrijavanje su veliki plus.
Ps. nego kakva je memorija , postoje programi koji namješaju izgled memorije tj. kako će svjetliti ... Prijatelju ću morati sastavljati komp i prvi put se sa tim čudom susrećem, već vidim priču nakon koje pive ma može se podesiti boja memorije kako bi bila u boji kluba kojeg navijam... :P
Staro 02.05.2017., 09:47   #2738
Mislio sam na Ryzen općenito kao proizvod, a ne seciranje pojedinog procesora. Cijene će se ustabiliti. Pogledaj samo da je Crosshair VI Hero cijena pala za 50 eura u mjesec dana.
Za razliku od Intela koji nije skinuo cijene ni 50 lipa.
Što se sinkronizacije lightninga tiče, osobno, za nebitniju i irelevantniju stvar na systemu odavno nisam čuo. Kad sam slagao build i imao stranicu otvorenu da vidim jel sve radi, skoro sam dobio epileptični napadaj.
Elmor savjetuje da se i dalje sa tim ne drka jer se mogu ujebat keksi. Ili nek svijetli po defaultu ili nek bude ugašeno (ako već ne treba svijetliti).
Staro 02.05.2017., 10:03   #2739
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,752
Autor suedamA obmaR Pregled postova
Asus je u proslosti ima modele sa 2 biosa AFAIK, Biostar cak i na novijim plocama...
Ali da, Gigabyte izgleda jedini ugradjuje 2 cipa na jeftinije modele i dobro reklamira taj feature...
Staro 02.05.2017., 10:39   #2740
BladeRy
BladeRy's Avatar
Datum registracije: Aug 2008
Postovi: 2,000
Saphire i XFX imaju dual bios na grafama, i switch za biranje koji ces koristit.
Izgleda da su oni nasli nacina za to stavit na svoj hardware.
Dual bios je odlicna ideja, a ako Gbyte to moze stavit na plocu od 600-800kn onda je prokleti asus mogao platit i taj feature nabit na Rog serije od 2500+ kn a ne nasrat ledice da ti ploca svjetli ko betlehem.
Il neka stave 3 bios cipa ako G ima patent na 2, taj usrani cip sigurno ne kosta u nebo.
@snake
Da, biostar ima dual bios.
To use Dual BIOS, select the desired ROM (ROM1/ROM2) via the onboard switch and power on the system.
Izgleda da su uzeli shemu sa manualnim switchem ko na grafama, mozda taj sistem ne podleze patentu od gbytea.
Edit - nasao i MSI ploce sa dual biosom i manuam switchem.
Zadnje izmijenjeno od: BladeRy. 02.05.2017. u 10:44.
Staro 02.05.2017., 10:48   #2741
robimarko-bug
Datum registracije: Jul 2013
Lokacija: Tenja(Osijek)
Postovi: 1,135
Kakav patent?
Pa to su samo dva identična flash čipa i jedan switch kojime biraš koji će biti fizički spojen i s kojega će se BIOS loadati i to je to.
robimarko-bug je online   Reply With Quote
Staro 02.05.2017., 10:53   #2742
BladeRy
BladeRy's Avatar
Postovi: 2,000
Fini patent. Ako su se prvi toga sjetili i zastitili ideju, njihova je, i ako hoces taj sistem koristit plati im. Pa usrani apple je patentirao slovo "i", iShit, iCrapOnCustomers, itd...
Linky
A glede switcha, gbyte ne koristi switch, sve je automatski. Ako faila boot, boota se sa read only cipa, onda flashas onaj R/W cip (il ga on sam kopira sa R-only cipa). Ovi drugi sa dual biosima imaju fizicki switch za biranje. Mozda je to caka za stavit 2 biosa a ne doc u konflikt sa patentom od gbytea.
Interesantno, asus ima svoj dual bios patent, uredno registriran... Linky
Zadnje izmijenjeno od: BladeRy. 02.05.2017. u 11:00.
Staro 02.05.2017., 11:00   #2743
robimarko-bug
Postovi: 1,135
Linky
A glede switcha, gbyte ne koristi switch, sve je automatski. Ako faila boot, boota se sa read only cipa, onda flashas onaj R/W cip. Ovi drugi sa dual biosima imaju fizicki switch za biranje. Mozda je to caka za stavit 2 biosa a ne doc u konflikt sa patentom od gbytea.
Jedino me čudi što Aple nije Cisco tužio jer koristi ime IOS već preko 20 godina,vjerovatno jer bi izgubili.
Nego nazad na citat.
Jedino što mogu patentirati jer automatski failover
Staro 02.05.2017., 11:13   #2744
BladeRy
BladeRy's Avatar
Postovi: 2,000
Slazem se.
Sta opet povlaci pitanje, ako gbyte nema prava totalna na tu tehnologiju, zasto drugi ne stavljaju dual bios? Doduse neki stavljaju a neki nisu.
U svakom slucaju, vidi se da ima nacina implementirat to i na druge ploce, a zasto to neki ne rade, to je sad pitanje tvrdoglavosti i/ili ljenosti.
Staro 02.05.2017., 11:15   #2745
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,662
Zato jer Asus zivi na staroj slavi i naplacuju masno svoje ime. Gigabyte dual bios ima na najjadnijim plocama i kod flashanja nema stresa.
Staro 02.05.2017., 12:57   #2746
shar
Overclocker
shar's Avatar
Datum registracije: Nov 2016
Postovi: 523
Na (boljim) asus pločama imaš flashback sa kojim možeš flashat bios u velikoj većini slučajeva, ako nešto nije fizički oštećeno.
shar je offline   Reply With Quote
Staro 02.05.2017., 13:04   #2747
Busola29
Autor Bono Pregled postova
nije to baš tako , oba dvije firme su jako dugo u informatičkom vremenu na sceni i imaju ime. Imaju bugova , ali ipak ploče rade svoj posao. Iza njih idu Asrock i MSI koje ili znaju biti vrlo dobre ili problemne.
Meni je pregledajući net zapela za oko puno manje razvikani Biostar (kojega nema kod nas , jer je gotovo bio jedno vrijeme krahirao...) npr Racing serija
https://www.youtube.com/watch?v=ozfWG_cvBgA
Uz to imaju vrlo dobru podršku za update BIOS-a što govori da je tamo se krenulo ozbiljno raditi, a to je dobro za informatičku scenu.
PS. tko je ljubitelj LED-a oni imaju neku bjesnu seriju sve svjetli u šesnaest kao Las Vegas ili MAcau ...
https://www.youtube.com/watch?v=JVKP6HZv2XI
Staro 02.05.2017., 16:43   #2748
Solo761
Postovi: 62
Nastavljam tu da ne spamam previše temu sa bazom ryzen korisnika , početak je tu
Autor Sn4k3 Pregled postova
Hmm, zajebancija... Uglavnom probaj ovo sto Shar govori, jer default opcija u biosu mozda nije namistena da efikasno koristi sve faze Vrm-a. Treba staviti na extreme (ili kako god to gigabyte naziva) opciju, ne znam tocno sad koju jer sam na poslu ali mogu ti javiti na pm kad dodjem doma. Meni se btw vrm-ovi ne griju nista, iako imam aio ko i ti a nikakav vent ne puse direktno po njima osim onog straznjeg sto vuce zrak vani...
Pogledati ću još kada dođem doma. Ali nisam optimističan, jednostavno je VRM kilav i to je to. Tvoja radi dobro jer je ima jedan od najdebljih VRM-ova .
Probati ću staviti neki vent ispod čisto da vidim kako će ići sa nekom cirkulacijom zraka, ali si sve mislim da ću kupiti drugu, u tom cjenovnom rangu mi Asus Prime X370-Pro izgleda OK. Ova tvoja je malo paprenija .
Autor nino Pregled postova
@Solo761, zas je na vodenjaci vent okrenut krivo?
Misliš na to da su ventovi upuh umjesto ispuh? Imao sam do juče da je ispuh, a Arctic u manualu kaže da je bolje da su ventovi okrenuti da iz vana ubacuju zrak u kućište nego da izvlače iz kućišta van. Pa sam, nakon što sam neuspješno pokušao staviti blok na "plafon", probao ovako okrenuti ventove da vidim kako će se ponašati. Ionako ću ga uskoro opet šarafati.
Solo761 je offline   Reply With Quote
Staro 02.05.2017., 18:26   #2749
Manuel Calavera
Postovi: 14,584
Znači R3 vjerojatno krajem 6 mjeseca ili u 7 mjesecu
Inače sa popustom R5 1400 u uzishopu bi sada bio negdje 1370kn, a R5 1600 1770kn. Sve bolje i bolje. Još kad dođe R3, te intel izbaci ove kvazi entuzijast quadove na s2066 bit će zanimljivo
EDIT
Ryzen 5 1600 vs i5 7600K Showdown - Price to Price Comparison! (2933mhz ram i gtx 1080)
*kod nas je 1600 jeftiniji za jednog LC-CC-120
Zadnje izmijenjeno od: Manuel Calavera. 02.05.2017. u 18:41.
Staro 02.05.2017., 18:45   #2750
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Na koliko novca procjenjuješ R3 kad dođe u nas?
Dobra preporuka
Pomelo mi sig -.-
Staro 02.05.2017., 18:47   #2751
Manuel Calavera
Postovi: 14,584
i3 7100 cijene +/-
Jer je svaki ryzen "priljepak" na neki intelov, što se vidi i po imenima. R5 1600 je zapravo konkurent i6 7600 (non K)
Staro 02.05.2017., 18:49   #2752
Drvoje
Drvoje's Avatar
Postovi: 4,037
Držim te za riječ, "varane"
Pomelo mi sig -.-
Staro 02.05.2017., 18:52   #2753
EDIT
Odlično...pače, genijalno. Ako imamo dual kurca sa HaTe-om za soma i pol u 2017. (slovima: dveiljade i jebenosedamnejstoj ), možemo imat i kvada sa HaTe-om za 4+ soma.
Staro 02.05.2017., 19:10   #2754
Manuel Calavera
Postovi: 14,584
Kad intel izbaci s2066 AMD će vjerojatno barem malo pojeftiniti ryzene R7
Koju stotinu kn. Intel vjerojatno neće mnogo spustiti broadwell-e cijene, a kad ovi još izbace x399 (mnogo pci-e lanes i quad channel procesore) bit će show.
Staro 02.05.2017., 19:26   #2755
Postovi: 8,222
Uspio je Ryzen uzet dio kolača, al moram priznat da nisam mislio da je baš tako loša situacija.
Da li priprema što amd po pitanju mobilnih cpu-a? Moram priznat da se nesjećam kad sam zadnji put vidio notebook pogonjen amd procesorom.
Staro 02.05.2017., 19:30   #2756
Manuel Calavera
Postovi: 14,584
Prema onom linku od Emissary krajem godine tek mobilni
U serverima je još gore, intel ima 99%, tu ako, odnosno KAD maznu 10-20% bit će ogromna lova za firmu veličine AMD-a
Tih 18-20% na desktopu je IMO bilo poprilično dobro budući da nisu imali high end, a u mainstreamu cpu i arhitektura po nekoliko godina stari tj. moglo je biti i puno gore
Zadnje izmijenjeno od: Manuel Calavera. 02.05.2017. u 19:36.
Staro 02.05.2017., 20:31   #2757
Busola29
Moje osobno mišljenje je da r5 1400 mora još ići dolje jer se neće prodavati , e sada ako su u AMD toliko blesavi neka guraju cijenu od 170$ volja im...
R5 1500 bi se trebao pozicionirati cijenom gdje je sada r5 1400 i onda bi se nekako ta dva procesora isplatila kupiti.
Čekam tih 1200,00 kn za r5 1400 to mi je neki limit , a stvarno ne igram previše pa mi ne treba r5 1600 koji smo svi ustvrdili da je daleko najbolji danas procesor za novac.
R3 procesori će koštati od 600-1000 kn nikako ne više , jer bi veća cijena donijela promašaj.
Staro 02.05.2017., 21:27   #2758
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
R5 1400 za 1200 je super ..pa to je maltene i7
Nego ako je i3 ispod 900kn , pa onda ce i r3 ispod 900 valjda
MojSkuter
Staro 03.05.2017., 12:43   #2759
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,333
Slobodno me dodajte na PSN
Staro 03.05.2017., 15:48   #2760
warlock25
warlock25's Avatar
Postovi: 2,327
kad je may update tocno?
