#2221 | |
Ovisnik o nikotinu
Datum registracije: Sep 2010
Lokacija: Međimurje<->Švabija
Postovi: 114
![]() Al ak se ne planira OC, onda sam provjeri dal je mema na QVLu. S novijim biosima vidim da su se liste dosta proširile tak da mislim da ne bu problema.
Više lurkam nego pišem... ![]() |
#2223 |
Postovi: 379
Evo mozda nekima koristan info sa OC foruma: For Europe the X370 Prime Pro is a solid choice. https://geizhals.eu/?cat=mbam4&xf=317_X370 Gigabyte Aorus GA-AX370-Gaming K3 ~ € 142 --- overpriced RGB board with a BCLK that is not going to help with a weaker B350 - level VRM MSI X370 SLI Plus ~ € 147 --- supposed to be okay VRM (same as X370 Pro Carbon) but everything else is cut down (audio is ALC892, LAN is Realtek , 2nd M.2 slot gone, etc) ASUS Prime X370-Pro ~ € 159 ASRock X370 Killer SLI ~ € 160 ---- typically weaker VRM than X370 Prime Pro , weaker audio ALC892 , missing USB 3.1 Gen2 on specsheet MSI X370 Krait Gaming ~ € 160 supposed to be okay VRM (same as X370 Pro Carbon) but everything else is cut down (audio is ALC892, LAN is Realtek , 2nd M.2 slot gone, etc) , difference to X370 SLI Plus is mainly better capacitors ASRock Fatal1ty X370 Gaming K4 ~ € 162 ---- typically weaker VRM than X370 Prime Pro , adds post code debug LED Gigabyte Aorus GA-AX370-Gaming K5 ~ € 178 --- it's a very overpriced RGB board with BCLK that is not going to help with a weaker B350 - level VRM , Intel LAN is only major difference to K3 MSI X370 Gaming Pro carbon ~ € 180 --- supposed to be same VRM as X370 SLI Plus Biostar X370GT7 ~ € 184 --- top tier VRM , with Realtek LAN Gigabyte Aorus GA-AX370-Gaming 5 ~ € 208 --- extras that add on to the price (dual LAN/audio , RGB), the VRM is on par with ASUS Prime X370 Pro Gigabyte Aorus GA-AX370-Gaming K7 ~ € 248 --- extras that add on to the price (dual LAN/audio, RGB), the VRM is on par with ASUS Prime X370 Pro , BCLK gen ASRock X370 Taichi ~ € 252 --- top tier VRM , BLCK gen , wifi+BT, overkill memory VRM uses TI NexFET components in 2 phase configuration ASUS ROG Crosshair VI Hero ~ € 258 ---- top tier VRM , BLCK gen ASRock Fatal1ty X370 Professional Gaming € 287 = Taichi + 5GBps LAN + power/reset buttons MSI X370 XPower Gaming titanium € 300 = decent VRM, hilariously bad pricing |
#2224 |
Ovisnik o nikotinu
Postovi: 114
Ak se ne varam, kolega warlock25 ti ima tu memu u svojoj konfi, taman smo u slično vrijeme kupili kolko se sjećam pred 2 mjeseca. Možda njega cimnut na PM, vidim u threadu za vlasnike da mu radi na 3200 MHz. Zaboravil sam napomenuti, taj GVKB je single rank ak ti treba taj info. EDIT: Joj da, zaboravil. Najčešće kod GSkilla: 3200 MHz CL16 - Hynix (zna biti i nešt Samsunga, al ak se ne varam Samsung ima 16-16-16 latencije dok je Hynix isključivo 16-18-18) 3200 MHz CL14 - Samsung b-die Puno.
![]() Ak ti se da čitati: Ak se ne varam, kolega warlock25 ti ima tu memu u svojoj konfi, taman smo u slično vrijeme kupili kolko se sjećam pred 2 mjeseca. Možda njega cimnut na PM, vidim u threadu za vlasnike da mu radi na 3200 MHz. Zaboravil sam napomenuti, taj GVKB je single rank ak ti treba taj info. EDIT: Joj da, zaboravil. Najčešće kod GSkilla: 3200 MHz CL16 - Hynix (zna biti i nešt Samsunga, al ak se ne varam Samsung ima 16-16-16 latencije dok je Hynix isključivo 16-18-18) 3200 MHz CL14 - Samsung b-die
Više lurkam nego pišem... ![]() Zadnje izmijenjeno od: Nidjo89. 13.04.2017. u 19:33. Razlog: nadopuna |
#2225 | |
Postovi: 14,584
Također od ovih što sam ja pogledao su svi osim jokera istaknuli da 1600X dolazi bez coolera, jedino joker to nije shvatio |
#2226 |
Overclocker
Datum registracije: Nov 2016
Postovi: 523
Čak i ako se dogodi da dobiješ samsung čip na 3200c16 kitu, puno veća je vjerovatnost da je korišten E-die nego B-die. E die je sličan hynixu uz nešto bolje skaliranje sa naponom. Long story short: ako vam se ne nateže sa memorijom, platiš b die i miran si jer znaš da će radit, možeš klokat a ne moraš. Doduše to vrijedi do izdavanja updatea od strane AMDa, nakon toga ćemo morat vidjeti kako se situacija razvila. |
#2228 | |
Postovi: 379
Kod nas ako ćeš kupovati 1600x onda moraš jos uzeti neki cooler solidan što je onda na kraju dosta skuplja računica ako se gleda svaka kuna, nego da se odmah kupi 1600, pa čak i da mu se poslje doda non stock cooler. |
#2230 |
Postovi: 14,584
Od 14 do 30 min https://www.youtube.com/watch?v=OE7swnns50o Podcast o "prekrasnim" iskustvima sa msi pločama navedenog dvojca, o ryzenu 5 itd. Par kul rečenica https://youtu.be/eH6R-QdRFOI?t=17m20s Zadnje izmijenjeno od: Manuel Calavera. 13.04.2017. u 23:16. |
#2231 |
Datum registracije: Jul 2004
Postovi: 1,771
Evo za sve koji imaju Thermaltake coolere, napisao sam kilometarski mail u kojem ih tražim objašnjenje zašto bi ja kao kupac nastavio koristit njihove proizvode s obzirom da mi Corsair i Nzxt nude besplatnu dostavu am4 bracketa ako imam njihove coolere, skrenuo im pažnju na apsolutno suludu cijenu dostave i ponudili su se da mi besplatno pošalju AM4 bracket. Dakle ako nekome treba bracket za am4 i ima Thermaltake Cooler, samo oštro na njih i poslat će vam bracket ![]() |
#2232 | |
Postovi: 110
#2236 | |
Sent from my SM-G930F using Tapatalk |
#2239 |
Postovi: 14,584
![]() Nego kako taj čudni čiko to sve lijepo i jasno objasni. Evo još i iz onog prvog linka ukratko osvrt u odnosu na i5 https://youtu.be/OE7swnns50o?t=28m11s Slažem se i sa onim da se ne isplati previše ulagati oko overclockiranja istih (high end mbo, bruatalan cooler) jer nema pretjerane koristi. Kaže da je najisplativije stavit 3.7ghz + ostavit wraith spire + auto napon i prst u uho. Mada s druge strane kupovinu aftermarket coolera ne smatram troškom platforme, isplati se jer može ostati godinama. Inače gledao sam cijeli ovaj podcast sa njim i wendelom. Predobra emisija, prejaki su. Zadnje izmijenjeno od: Manuel Calavera. 14.04.2017. u 11:36. |
#2240 |
Datum registracije: Aug 2008
Postovi: 2,000
Slazem se sa ulaganjem u ok cooler, kupio sam prije 7-8 godina Zalmana 9500, taj nema sta nije ohladio. Evo i sad radi na 900rpma preko potenciometra i xeon je na 30c. Full load 50-55c usred ljeta. Tako da posten cooler, vise tisine i bolji temp i znas da ce trajat 5+ godina. I jel tko primjetio problem sa 350 chipsetom, kao VRMovi se griju ohoho. Uz clock do 3.8 oni odu na 85-90c+. A temp ce jos ic gore kako dolazi ljeto. |
#2241 | |
Postovi: 379
https://youtu.be/RNu-QiVr95M?t=251 ![]() I/ili uz ovo ghetto hlađenje uzet neki Top down vent tipa Raijintek Palas--be quiet! Shadow Rock LP pa nek pirka na VRM drito, ne vjerujem da će se zapalit na ljeto ryzen ploče dilje planete, da je problem već bi bilo masovnih prijava, barem tako logika nalaže. A mozda onima što nemaju klime u sobama, i dobra prozračna kućišta bude potrebno dati jedan complementary Pastor aparatić sa mount bracketom za kućište sa strane ![]() |
#2243 | |
Postovi: 14,584
Šema je što bolje B350 i entry X370 imaju isti ili sličan VRM, pa sumnjam u veliku razliku. Recimo onu x370 as rockicu je onaj tech city testirao u australiji, a tamo je bilo ljeto, te često kaže u videima da mu je ambijentalna temperatura 28C. Mislim vidiš i po njemu jer je sav crven i u potkošulji ![]() Inače i da dolaze do 85-90C (al kažem, volio bi prvo vidjeti gdje i koje mbo) to nije ohoho za vrm tj. "unutra je" Lc-cc-120 je vjerojatno i dalje best buy bez konkurencije, dok ovi 212 evo i sl. nisu neki value već neko vrijeme. Em koštaju skoro 300kn, te tipa 80% više od sličnog lc-cc-120, za jako slične novce idu bolji cooleri tipa ninja 4 (često bude oko 300kn), također i THERMALRIGHT Macho Direct, pa i onaj Fortis 3 HE1425. Dakle oko 300-njak kn max je što se IMO isplati dati za cooler, jer su slični odnosno identični po performansama starom NH-D14, a on je ionako sličan/preblizu 240mm vodenim... Zadnje izmijenjeno od: Manuel Calavera. 14.04.2017. u 12:26. |
#2244 |
Postovi: 1,771
#2245 |
Postovi: 379
Evo ja sam čitao malo ovdje o toj temi : http://www.overclock.net/t/1626601/p...m-temperatures I neki tamo lumen je stavio ovaj link lista VRM po pločama, na švabski. https://www.hardwareluxx.de/communit...e-1155146.html Pa je dole hans obrazložio na njemačkom, skuzi se poanta neka ako se prevede sa google translate. https://www.hardwareluxx.de/communit...e-1158162.html lol Zadnje izmijenjeno od: Colossus. 14.04.2017. u 12:26. |
#2246 |
Postovi: 2,000
Da, bas na to sam i ja naletio. Racunam ako je sve ok u danima kad mi je 15-20 u sobi, kako ce bit na 35c+ i gaming. Neki kazu da je to do aftermarket hladjenja, tj da spire nekako zrak nabije i po VRmu, a noctue, cryrigi, itd i vodena ne rade nikakvo strujanje zraka preko VRMa. Sad se oceka OC_Freaka da kaze kako je njemu na AB350 koja je clockana. |
#2247 |
Datum registracije: Apr 2011
Lokacija: Velika Gorica
Postovi: 181
Može pomoć oko odabira rama, planiram uzeti r5 1600 i b350 gaming 3 ploču, ali ne znam koji ram. Vidim da se spominje od g.skilla ripjaws v kao dobar ali nigjde nisam našao kod nas 8gb(2x4gb) na 3200mhz, ali sam našao od 3000mhz. Hoće li biti velike razlike između ta dva? Da li mi je bolje uzeti corsair vengence lpx ili neki drugi? |
#2248 |
Postovi: 14,584
Prema listama izgleda da je glede VRM-a još najkupovina asus x370 prime pro za oko 1300kn (adm i uzishop), te asus B350 prime plus (ispod 800kn u uzishopu s popustom). Matoje Što se tiče samog rama vjerujem da se svaki može dići minimum za jednu razinu gore. Pitanje je samo dali može zbog biosa u ovome trenutku |
#2249 |
Lokacija: OS
Postovi: 216
mali update.. znaci 1600x sto je oglasavan kao box u linku ne dolazi sa cooler, to su trebali iznati i ne oglasavati tako, ali kao ispriku dobit cu cooler uz proc sto je posteno, na kraju se isplatilo ![]() Zadnje izmijenjeno od: bloodlike. 14.04.2017. u 14:53. |
