Staro 04.04.2017., 00:05   #1861
Full Throttle
Full Throttle's Avatar
Datum registracije: Dec 2009
Lokacija: Zagorje
Postovi: 872
da. evo u idleu 40 stupnjeva na 3.7ghz, a kuler ne mlačan nego hladan
Full Throttle je offline   Reply With Quote
Staro 04.04.2017., 00:09   #1862
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
http://wccftech.com/amd-ryzen-5-1400...nchmarks-leak/
Navodno ne ide preko 3.8ghz, što mi je malo čudno
Staro 04.04.2017., 00:11   #1863
Gigi1
Postovi: 2,138
mislim da se previse brinete ako vam pod loadom temperature ne idu u neke ludosti.
masu senzora je stavljeno u zen i nije ni cudno da razliciti programi imaju razlicito ocitavanje...
a ovo dali je 35 ili 45 je fakat nebitno, i vjerojatno ovisi o trenutnom workloadu određenog djela proca
Scattered across each CCX are a whole bunch of sensors; 20 thermal diodes, 48 power supply monitors, nine voltage droop detectors, and more than 1,300 critical path monitors. These sensors are all connected to an Infinity Fabric control plane, feeding their data into a power management unit.They report their readings 1,000 times a second, and are accurate to 1mA, 1mV, 1mW, and 1°C.
On the one hand, this system allows Zen to cut back its voltages to the bare minimum needed to operate correctly. Each core has its own voltage regulator, and they'll be set as low as possible to maintain clock speeds. Not all cores are created equal; some are naturally faster than others. Those faster cores are given slightly less power, creating the thermal headroom to boost the power given to other, weaker cores. A fast core can use as much as five percent less power than a slow one at the same speed.
This per-core adjustment is in contrast to AMD's previous Adaptive Voltage and Frequency Scaling (AVFS) implementations, where the voltage was set chip-wide. In the past, the voltage had to be high enough to support all the cores. Likewise, Intel's cores all share a power plane and operate at the same voltage. Setting it on a core-by-core basis saves power.
potpuno nova arhitektura, treba to sve pohvatat, proc ce jos vremena dok se neke stvari ne standardiziraju u monitoring softverima
Staro 04.04.2017., 00:15   #1864
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,253
Autor Busola29 Pregled postova
Ne karinđaju ih , nego su to dvije sestrinske tvrtke... (čak i u slično vrijeme nastale...) Već sam odavno pisao da nikome u SAD-a nije u interesu da AMD padne ni samom Intelu , jer bez konkurencije inženjeri puno slabije rade.
Ps. izbrisao politiku...
Znam kako je amd nastao
Normalno da im nije u interesu da propadne, al im je u interesu da bude oslabljen kao u ovoj eri s bulldozerom.
Staro 04.04.2017., 00:15   #1865
Manuel Calavera
Postovi: 14,584
Staro 04.04.2017., 00:32   #1866
ZOKSY
ZOKSY's Avatar
Postovi: 278
Moze mala pomoc
Latencije u biosu podesene na deklarirane vrijednosti,a cpuz,hwmonitor prikazuju sasma druge a vjerujem i stvarne.tipa u biosu stavim 15-17-17-30 za 3000mhz i nece postavit te latencije nego 16-20-20-40......
Bios 1002 je u pitanju na ch6 ploci.
I da moj nejde vise od 3925 mhz na bilo kojem naponu.prolazi sve testove s 1.417v u ibt.te temperstura u ryzenmasteru ne prelazi 75c
GPU/CPU Freak
Zadnje izmijenjeno od: ZOKSY. 04.04.2017. u 00:34. Razlog: Krivo napisano
ZOKSY je offline   Reply With Quote
Staro 04.04.2017., 00:52   #1867
messiah
aka Mithrandir
messiah's Avatar
Postovi: 449
Kolko se ja sjećam kad se manualno OC-a idle temp. budu "visoke". To je spomenio tech showdown, ali i bitwit u onom wraith spire videu. Treba se namjestiti p-states tko može.
https://hardforum.com/threads/ryzen-...lator.1928648/
https://forum.level1techs.com/t/help...es-info/114283
Da li to znači da ako se ne koristi P-state OC da procesor drži sve jezgre na konstantnom taktu definiranom u BIOS-u?
Bio sam pitao slično pitanje ranije, ali nitko nije trznuo. Ovo mi se čini kao jedini ispravan način za OC jer se komp manje zagrijava i tiši je u idleu/manjim opterećenjima.
messiah je offline   Reply With Quote
Staro 04.04.2017., 01:41   #1868
Manuel Calavera
Postovi: 14,584
Iskreno nemam pojma. Nisam toliko proučavao. Samo sam primjetio da mnogi kažu da zbog toga ima povišene idle temperature
Staro 04.04.2017., 01:57   #1869
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,493
suma sumarum
The Windows update didn't help. Neither did the EFI update (before OC). It appears that most of the change comes from the two game updates and from, as expected, the memory OC.
https://www.youtube.com/watch?v=8cHJ7FDZKg8
Staro 04.04.2017., 01:59   #1870
Overclock_freak
Datum registracije: Dec 2012
Lokacija: Rijeka-Zagreb
Postovi: 1,207
Evo dečkići koji su na PM molili.. stigla je.. i par slika od unboxinga.. sutra gledamo kakva je clockerica i stabilnost.. u najgorem slučaju preksutra
Staro 04.04.2017., 08:13   #1871
Amd_Shill
Datum registracije: Dec 2016
Lokacija: Sat
Postovi: 1,119
Autor BsClocked Pregled postova
EFI updates didnt help??
Znao sam da su ovi iz Gamer Nexusa totalni tulipani,ali gornja izjava je....
Amd_Shill je offline   Reply With Quote
Staro 04.04.2017., 08:34   #1872
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Na 3.8 , r5 1400 usporediv je za i7 4770k..
(Novo, a jeftinije od rabljenog navedenog intela, bit ce frke u procjenama uskoro )
MojSkuter
Zadnje izmijenjeno od: Eladio. 04.04.2017. u 08:46.
Staro 04.04.2017., 08:50   #1873
Amd_Shill
Lokacija: Sat
Postovi: 1,119
Vise niko ne spominje ultimativni benchmark zvan Cinebench.
Staro 04.04.2017., 09:15   #1874
warlock25
warlock25's Avatar
Postovi: 2,327
Autor messiah Pregled postova
tako je.cim se digne takt za neku vrijednost iznad stocka brzina bude konstantna.
Sent from my EVA-L09 using Tapatalk
Staro 04.04.2017., 09:30   #1875
Ima li tko ASRock X370 Fatal1ty Gaming K4 ploču? Piše da je izašao BIOS v2.00 sa updated Agesa kodovima.
I općenito, jel to dobra ploča? Vidim da je zeru skuplja od Asusove Prime X370 Pro?
Sent from my SM-G930F using Tapatalk
Staro 04.04.2017., 10:06   #1876
Full Throttle
Lokacija: Zagorje
Postovi: 872
Probal sam 2.00, najbolje performanse su mi s 1.64 za sad.
Rami (single rank) su radili out of the box sa loadanim xmp profilom.
Malo su bili čudni ventovi, dok nisam pokrenul Fan Tuning.
Temperature su normalne. Softver javlja 30-32 stupnja i pod opterećenjem proca.
Nisam gledal dal ima mogućnost za ove PStateove.
Odlična zvučna. Sve u svemu skroz zadovoljan.
Sad teram 3.7 na 1.2v. Probal budem max OC kad mi ventovi stignu.
Jedini minusi koje bi navel je da mu za razliku od prijašnjih sistema treba malo duže vrijeme da dođe od paljenja do boot skrina. Neznam dal je to do svih am4 sistema ili samo na ovoj ploči. Al nakon boot skrina odma je winsima, naravno sa ssd-om
I nema channel retasking za audio kanale. Neznam jel to do hardvera ili softvera.
EDIT: ima u UEFIju opcija za fast boot. al onda nemožeš ući u uefi normalnim putem nego samo restartati iz windowsa.
Zadnje izmijenjeno od: Full Throttle. 04.04.2017. u 10:47.
Staro 04.04.2017., 10:13   #1877
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,253
Autor Overclock_freak Pregled postova
Evo dečkići koji su na PM molili.. stigla je.. i par slika od unboxinga.. sutra gledamo kakva je clockerica i stabilnost.. u najgorem slučaju....
To care. Cekamo rezultate.
Staro 04.04.2017., 10:39   #1878
jed2i
jed2i's Avatar
Datum registracije: Jul 2004
Postovi: 1,771
Imam ju ja.
Ne koristim 2.0 bios, koristim 1.94A - beta bios
Kaj se same ploče tiče- nemam zamjerke
Sve fino radi, hladno, vrmovi se ne griju (cpu je na 1.2V)
RAM mi uredno radi na 2933mhz kak su i rekli da će raditi....
Plus je svakakvo zvuk, ak imaš bolje sluške ili zvučnike odmah ćeš čuti razliku.
Da nastavim s bracketima.
12 dana nakon otvorenog ticketa za bracket odgovara NZXT
kažu da će u roku od 8 dana poslati bracket za am4
preimenovat ću ih u Speedy Gonzales
Corsair i TT još uvijek nemaju bracket na zalihi.
Zadnje izmijenjeno od: jed2i. 04.04.2017. u 10:48.
Staro 04.04.2017., 13:20   #1879
Manuel Calavera
Postovi: 14,584
Još benčeva r5 1400
https://youtu.be/0psggdh1gm0
Staro 04.04.2017., 13:31   #1880
Dottore
Dottore's Avatar
Postovi: 7,668
@Overclock_freak
Toplo pozdravljam na tu ploču.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 04.04.2017., 15:15   #1881
Manuel Calavera
Postovi: 14,584
Staro 04.04.2017., 15:27   #1882
To kao da neki idioti rade. Čemu usporedba sa 1700X? Valjda bi trebala biti usporedba sa 1700, prvo na stocku a kasnije na OC.
Ali OK, OC potencijal je isti, uz logično manje zagrijavanje/potrošnju zbog 2 jezgre manje.
Staro 04.04.2017., 15:34   #1883
Manuel Calavera
Postovi: 14,584
Valjda nemaju sav hardver. Od ryzena 1700X, a gpu samo gtx 1070. Uglavnom u skladu sa očekivanjima. Vjerojatno će max overclock biti identičan kao za R7.
Staro 04.04.2017., 15:35   #1884
Je, to stoji. Definitivno uzimam R5 1600. Razliku do 1700 ušparam za neš drugo.
Staro 04.04.2017., 15:37   #1885
Manuel Calavera
Postovi: 14,584
Meni je u toj čitavoj priči od launcha R7 do isčekivanja R5 najvažniji ovaj video gdje različite konfiguracije ccx nemaju utjecaja na real world performanse, te one igre koje su dobile specijalizirani ryzen patch gdje se pokazalo da se mogu dobiti primjetne performanse tj. da optimizacija ima utjecaj. To je ono što je bitno, da arhitektura nema neku bitnu limitaciju
Dakle to je to.
Staro 04.04.2017., 15:56   #1886
Busola29
Po meni r5 1400 je odličan izbor samo kada vidim da takt puno odlučuje , a ne može iznad 3,8 Ghz krivo mi... (iako ja neću nabrijavati ga ako uzmem...)
Usporedba i5 7400 , Ryzen r5 1400, g4560
Cijena će po meni ići dolje jer moram priznati g4560 se jako lijepo nosi sa ovim procesorima sa obzirom na svoju cijenu - cca 450 kuna.
https://videocardz.com/67773/amd-ryz...ormance-leaked
Obratite pozornost na iskoristivost procesora , koja se u Intela u mnogim igrama penje na 99% dok kod AMD-a je na prosjeku 80% znači ima lufta dosta za bolje uslijed bolje podrške, drivera na pločama i podrške u Windows 10-tke... Tu očekujem ubrzo dobitak kada se isprave ove buhice , zato ljudi tko nema baš love samo neka se malo strpi dok sve ne dođe na svoje mjesto.
i5 7400 košta cca 1500 kuna mislim da ryzen r5 1400 će koštati nakon mjesec dva 1000-1100 kuna... (startno 1200-1400...)
PS. ne znam da li je bio video pošto sam radio , a nisam sve stigao studiozno pregledati , pa isprika ako ga ponavljam. Overclock svaka čast, test što prije da to je ploča koja je meni cijenom prihvatljiva cca 800 kuna
Zadnje izmijenjeno od: Busola29. 04.04.2017. u 16:04.
Staro 04.04.2017., 16:04   #1887
Manuel Calavera
Postovi: 14,584
Ma mislim da je to da je 3.8ghz maximum nešto krivo shvaćeno/preneseno. Možda je to maximum sa wraith stealth coolerom, vidiš da ti dečki iz južne amerike nisu imali novaca za bržu memu od 2400mhz, onda nisu ni za AM4 cooler (koji su uglavnom skupe nocutue da imaju out of the box am4 bracket). Čak i ovaj R5 1600 review vrti na 2400mhz
Što se tiče iskorištenosti - to i je deal. Headroom, luft. Recimo imaju isti/sličan clock out of the box (i5 7400 boosta na sve 4 jezgre do 3.2ghz ili 3.1), kaby ima malo bolji ipc, ali ovaj je s druge strane otključan... Intelu hyperthreading skoro duplo podigne cijenu na quadu (najjeftiniji i5 oko 1400kn, a najjeftiniji i7 oko 2500kn), a još je SMT bolji od HT-a, no to se nebi vidjelo baš u gamingu, no u productivity i mt benchmarcima bi.
Inače cijene su ti već poznate neko vrijeme, prema alzi R5 1400 je nekih 1475kn sa hr porezom, a kod nas u ekupi 1549kn. Neće to pasti na 1000-1100kn, preoptimistično, možda 100kn u relativno bliskom vremenu
Staro 04.04.2017., 18:08   #1888
PAŽNJA PAŽNJA:
Molim da se SVI korisnici Ryzen procesora jave u OVU temu, pročitaju prvi post te daju svoj doprinos
Da ne gnjojimo ovdje "koji ram imaš, kak ti dela...".
Ova tema da ostane za najave, recenzije, unboxinge, predviđanja, mišljenja, a druga tema da bude isključivo za User experience te Q&A, da se lakše snađemo.
Hvala.
Staro 04.04.2017., 18:12   #1889
Manuel Calavera
Postovi: 14,584
Gotovo je, brko prelomio
Nego možda se malo preslično zovu teme, možda da nema info u oba naziva, jedan je znači kao general topic, a drugi owners club/database
Staro 04.04.2017., 18:21   #1890
More ovako?
AMD "Ryzen" PCE Owners Club Database
Slobodno može par prijedloga
