#1023 | |
Postovi: 1,554
Uzmi isti ssd/flash storage disk od istog proizvodjaca. Jedan 128gb, drugi 512gb. 512 ce biti brzi. Zasto? Googlaj malo.
"There he goes.One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die" |
#1024 |
ja bi uvijek uzeo mob koji je brzi u aplikacijama, a ne na sintetickom benchmarku. isto vrijedi i za grafe ![]() Sent from my MI MAX using Tapatalk |
#1025 |
ODUZIMAM VAM RIJEČ
Postovi: 13,391
ma to su gluposti, sve sam to pregledao i prostudirao, ne vrijedi mi 1000kn više GSM Arena http://www.gsmarena.com/apple_iphone...iew-1506p5.php ''In practice it would be really hard to spot the difference in performance between the three models in real life. They are equally fast and there is no lag whatsoever.'' http://appadvice.com/post/a-new-test...-speeds/723786 ''So while the benchmarks may be different, I don’t suspect you’ll truly notice any difference in real-world use.'' ne osporavam benchmarke, naravno, i logično je da je veći storage brži, ali real life performance mi je ajmo reć bitan.
#1026 |
jebate kaj nisi reko sad maloprije da ti je baterija najbitnija? ![]() Sent from my MI MAX using Tapatalk |
#1028 |
Postovi: 1,554
Plus verzije iPhonea su cudo po pitanju baterije. Koristio sam 'tacnu' (nazvala ga tako ekipa na poslu) iP6+ cca tjedan dana. Baterija bez vecih problema puna dva dana koristenja, i to heavy usagea. Dakle mjuza/audiobooks u autu kroz bluetooth, surfanje, messangeri, mail, jubito i ponesto gejmanja. I bez ikakvih problema 48h izdrzi i jos ostane 15-20 %. Samo sto je mobitel jebena tava pa mi ta baterija nista ne znaci ![]()
#1032 | |
Postovi: 667
https://support.apple.com/en-us/HT202909 Dakle jedino Model A1660 je truly worldwide compatible mobitel, sa 2g/3g/4g supportom worldwide U Europi se ne prodaje taj model. Iako, europski model ce raditi bez problema u Kini na 2g i 4g, ali 3g nece funkcionirat |
#1033 |
ODUZIMAM VAM RIJEČ
Postovi: 13,391
n00b question već dugo koristim Outlook app za mail, kad stigne mail odmah na ekranu dobijem notification sad bi dao priliku default aplikaciji Mail, al nikak ju namjestit da odmah dobijem notifikaciju drko sam po push i fetch al bezuspješno, kak to treba poštelat?
#1034 |
Datum registracije: Dec 2009
Postovi: 385
Da notifikacije rade za default mail app ne bih ni koristio Gmail (ili bilo koju drugu app te vrste). |
#1036 | |
![]() nego upravo sam updateao iphone 5s na 10 i puno se zagrijao. jel to normalno? Sent from my MI MAX using Tapatalk |
#1038 | |
ODUZIMAM VAM RIJEČ
Postovi: 13,391
Outlook mi je ionako najbolja al reko da dam priliku defaultnoj
#1041 | |
Postovi: 667
Ne znam, meni je sve radilo out of the box cim sam namjestio mail konfiguraciju.. |
#1045 |
Datum registracije: Jul 2010
Lokacija: Pakrac
Postovi: 352
Pa meni ne dode odmah. Evo sad sam recimo usao u app i refreshao i zakljucao mob. Sa koleginog moba sam si poslao mail i dosao je nakon 6min. Sad kako to radi ne znam. Sent from my iPhone using Tapatalk |
#1049 |
Postovi: 1,554
Appleov mail ima push. Kod mene uredno isti funkcionira.
