Staro 30.09.2016., 12:58   #3751
T}{OR
DBS
T}{OR's Avatar
Datum registracije: Nov 2010
Postovi: 1,855
Yolo rush sad daje najveću lovu:
http://forum.worldofwarships.eu/inde...3#entry1332163
- meta na čelo, 4xW za full speed, boost on i prema neprijatelju za najviše love
Autor Neo-ST Pregled postova
Izrazite nezadovoljstvo na njihovom forumu, tamo barem čitaju pa možda promijene mehaniku...
Yup. Malo Throl... er citiram samog sebe:
Autor T}{OR Pregled postova
Staro 30.09.2016., 13:11   #3752
BladeRy
BladeRy's Avatar
Datum registracije: Aug 2008
Postovi: 2,000
Bas gledam topic i pitam se zasto nema notifikacije za nove postove.... pa izrazio sam nezadovoljstvo. A da, izbrisali mi post.
Gledam gore sta je jedan lik fino rekao kako los igrac izgubi brod i ne napravi dmg da plati popravke. A sad dobar igrac starta rundu kao da je izgubio brod i placa full popravke. Nema ni toga posta... brise stoka postove ako si imalo agresivan il ako pogodis cinjenicu.
Staro 30.09.2016., 14:04   #3753
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Što si im sve svece skidao tamo pa su ti pobrisali post?
Barem par dobrih vijesti:
http://forum.worldofwarships.eu/inde...4#entry1330084
Q: Are you satisfied with the performance of the Bismarck? Some consider it overpowered, especially its secondaries. Are the developers considering a nerf?
A: We are not considering it now. German BBs, in our opinion, look good. We wanted them to be good brawlers, and they seem to work that way. What's more pleasing, is that players tend to understand that and enjoy them.
Q: How much of the suggestions made by the playing community, be it here on the subreddit or one of the forums, does the development team consider for implementation? I'm not talking about pure game mechanic complaints, such as "OMG fix high tier economy pls"-stuff (but thank you for giving us a new game economy system smiley face), but rather more focused on additions to the game, such as this proposed second IJN carrier line? Would be interested to know whether community contributions in this manner are valued by the development team.
A: They are valued, because the game is obviously being developed for the audience. However, there may be difference between one popular proposal (which appeals to a limited group of players) and one popular trend (which is distinctly seen througout the while community).
And we do try to react as quick as we can - even yesterday, working here in comments, I was able to start three tasks for New Orleans, Tenryu and Mogami improvements - which is great. And today, two bug reports came from this community.
Što se tiče ekonomije, morat će je mijenjati ako ne žele ostat i bez ono malo CV igrača koji ih još igraju. Imam dojam da im je uzroak i pogotoov meta na PTS bilo nedovoljno za pošteni test prije ubacivanja u patch. Pa je zato ovakav model zaživio u live verziji.
Staro 30.09.2016., 19:41   #3754
BladeRy
BladeRy's Avatar
Postovi: 2,000
Thor, ovo je cisti razlog zasto je njihova komunikacija sa ljudima na nuli i PTR sluzi kurcu. I onda se govorilo da je ekonomija losa...otislo u live. Od pocetka se govorilo da ce to bit propast, al njima je draze kad par dupelizaca podrzava ocito losu promjenu nego da misle svojom glavom.
A za izbrisani post...pa i nisam bio toliko ostar, nisam dobio warning il ban, tako da mislim da samo sutke brisu misleci kako ekipa nece primjetit.
Staro 01.10.2016., 01:18   #3755
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Komunikacija im je uvjerljivo najgora na EU serveru. To nije nikakva tajna. Zato i imamo "info sa RU servera" thread na službenom forumu gdje je glavni info što dolazi...
Enivej. Našao ovaj Notserov video sa Des i Propulsion Mod 2 / Steering Gear Mod 3:
Skužio sam da je Des trom. I kad si jednom commited, često je to kraj priče nevezano koliko ih povućeš sa sobom dolje. Zato i većina ekipe ima low survival rate s njim. Tako da ako već tako mora biti, mogu se barem zabaviti sa WASD haxom & Des.
Kapetan je trenutno u postupku retreninga sa Balmera na Des. Još 40k to go...
Staro 01.10.2016., 01:31   #3756
Neo-ST
Neo-ST's Avatar
Postovi: 8,425
Napokon i 15-i bod na kapetanu za Bmarka.
Upgrade za sekundarne: check
Zastavica za sekundarne: check
Manual firing za sekundarne: check
Rezultat:
Najjači brawler trenutno.
Imam osjećaj da ovi sekundarni demoraliziraju neprijatelja, pogotovo DD-ove.
Maloprije mi jedan Farragut išao prići, onako direktno. Pa to je smiješno šta su mu napravili sekundarni.
Staro 01.10.2016., 03:01   #3757
Gigi1
Postovi: 2,138
Rezultat:
happy hunting
Staro 01.10.2016., 07:06   #3758
windfucker
Da li sa sjeća netko za ARP Ashigara i onaj drugi (Hiei, mislim da je taj), do kada je trajala misija? 01.10 ili još traje do 01.11.??
Staro 01.10.2016., 07:52   #3759
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,249
01.10.
Taman nisam stigao napravit 4.-ti dio misije.
Staro 01.10.2016., 08:54   #3760
windfucker
Pa jeboimpasmater onda.
Ja sve napravio i ništa od brodova.
Baš krasno
Izgleda da će i to biti kao sa vašim zastavicama...piši, nateži se.
Zadnje izmijenjeno od: windfucker. 01.10.2016. u 08:59.
Staro 01.10.2016., 09:37   #3761
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,249
Jesi probao promijenit luku? Mislim da treba biti postavljena "yokosuka", ako se dobro sjecam naziva. Ja dobio kapetana, al nisam stigao zavrsit taj zadnji dio tako da nisam dobio brod.
Staro 01.10.2016., 09:59   #3762
extasy
Lokacija: st
Postovi: 371
Autor Cuky Pregled postova
Ovo
istu reakciju sam imao nakon zavrsenih misija
extasy je offline   Reply With Quote
Staro 01.10.2016., 14:29   #3763
Neo-ST
Neo-ST's Avatar
Postovi: 8,425
Moglo je to i bolje, npr. da nisam pri kraju stajao bočno Iowi, ali jbga.
Dosad najbolja partija sa Bmarkom.
Mislim da sam ga shvatio. Preko 12km koristit HE (osim na bočne cruisere), ispod toga AP+sekundarni.
Baš te potiče na brawling i zbližavanje s neprijateljem
Staro 01.10.2016., 16:19   #3764
BladeRy
BladeRy's Avatar
Postovi: 2,000
To ti je tako kad te topovi hoce. Onda redas citadele ko blesav. A nekad je jednostavno tako frustrirajuce da bi razbio monitor.
Staro 01.10.2016., 18:06   #3765
Admiral72
Admiral72's Avatar
Datum registracije: Aug 2016
Lokacija: Koper, Slovenija
Postovi: 42
Decki, ako morate trenirati kapetane, ranked je ta vikend odlicna prilika. Uz zastavice imate i bonus 100%+XP ako ste u prvih 5 (u ranked ste skoro sigurno).
Pobjede mi nose cca 15.000 XP na kapetanu svaku partiju (sa dragon flag, naravno).
Edit : 9 bitaka za 7 preskocenih ranka (startao od pocetka, easy peasy). Farragut OP
Edit2 : Da li je moguce, da su malo nerfali XP u ranked? Recimo dobijena partija, 66k dmg, 3 potopljena broda (od toga jedan DD), oba osvojena capa, samo 1.800 XP. Mogao bi se kladiti, da bi u 3.sezoni za taku partiju dobio min 2.500 XP...
Road to Rank15 je bio nesto brzi od ocekivanog Da li vrijedi gurati do 12, 10? Samo su zastavice u pitanju a ostalo se cini kao neko grindanje..
Zadnje izmijenjeno od: Admiral72. 01.10.2016. u 20:03.
Admiral72 je offline   Reply With Quote
Staro 01.10.2016., 18:22   #3766
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Da, odigrao jednu s Indianom i odmah 10k XP-a, bez Dragon zastavica. Mislim da ću sutra do kraja odraditi re-trening.
Staro 01.10.2016., 20:11   #3767
extasy
Lokacija: st
Postovi: 371
http://prntscr.com/comhh8
vikend i ranked nikako nije dobra kombinacija...
Staro 01.10.2016., 20:14   #3768
Flayer
Why So Serious?
Flayer's Avatar
Datum registracije: May 2005
Postovi: 151
Fuso nije baš najbolji za ranked....odigrao sam samo jednu s njim i prebacio se na Farragut-a do levela kad kreću 8-ce.
If you're in control, you aren't going fast enough.
Flayer je offline   Reply With Quote
Staro 01.10.2016., 20:44   #3769
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Dogurao do R7 prošlu sezonu - počeo odmah u drugoj ligi sa T8. Uletim u prvi game i 4 Bismarcka vs. 4 Bismarcka plus 3 x DDa po strani. Yeah, vrijeme je za Shokakua za farmanje Bismarcka u Ranked.
Sent using Tapatalk.
Zadnje izmijenjeno od: T}{OR. 01.10.2016. u 20:59.
Staro 01.10.2016., 23:28   #3770
extasy
Lokacija: st
Postovi: 371
Danas rank 14 sa 23 uz jako puno bad lucka sa fusom...
Sad benson / atago puno lakse ide! Jedva cekam Flint-a provozat da vidim jel vrijedilo muke
Staro 02.10.2016., 00:59   #3771
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Iskoristio ove bonuse i iztrenirao kapetana u jednom danu natrag na Des (bome je ova Indiana radni konj u mojoj luci, em DD em CA linija). Zadnja partija večeras završim kao bottom tier. I top scorer.
http://wowreplays.com/Replay/18197
USS Indianapolis in BB infested waters ... za 93k fire dmg
Demo Expert FTW!
Staro 02.10.2016., 02:56   #3772
Flayer
Why So Serious?
Flayer's Avatar
Postovi: 151
Autor extasy Pregled postova
Koju si još sezonu Ranked-a dogurao do 1og mjesta?
Sent from my LG-H815 using Tapatalk
Staro 02.10.2016., 07:50   #3773
extasy
Lokacija: st
Postovi: 371
Autor Flayer Pregled postova
2. i 3.
4. sezonu nisam ni igrao zbog posla...
Staro 02.10.2016., 09:46   #3774
BladeRy
BladeRy's Avatar
Postovi: 2,000
Jucer je bio ok dan.
Gneisenau kad topovi ne trolaju.. 165k dmga
http://wowreplays.com/Replay/18223
Bismarck kraken u kratkom roku. Neo kukavicki stoji iza...
http://wowreplays.com/Replay/18224
Highlight dana, idemo Neo i ja u Bmarcima, naletimo na shima wall of skill (tm), ja se provucem na nos, Neo se dere, vidim rupu, vidim rupu, 10 sec poslije je pobrao 3 torpeda
Staro 02.10.2016., 11:30   #3775
Neo-ST
Neo-ST's Avatar
Postovi: 8,425
Nije majke mi, dobro sam naciljao rupu, torpeda su garant navođeća
Staro 02.10.2016., 11:51   #3776
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Autor BladeRy Pregled postova
Odličan video gdje iChase objašnjava zašto se događa overpen na manjim udaljenostima, koji put je bolje metu gađat pod kutem:
Staro 02.10.2016., 12:41   #3777
BladeRy
BladeRy's Avatar
Postovi: 2,000
iChasea uopce vise ne dozivljavam kao nekoga tko zna sta govori. Sad ce pravdat overpen mehaniku sta je smece nakon onog patcha a ne da BB skine nekoga u broadside i napravis 1k dmga... sve drugo overpen.
Sjetim se spotting videa i njegovih lazi kako brani WG, a poslije WG prizna sranje i popravi ono sta, po njemu, nikad nije ni bio problem. Lik je seronja, radi videa radi broja pregleda a koja usrana mehanika u RNG igri ima smisla. Jednom opalis miss, drugi put overpen, treci citadela, cetvrti detonacija...u istim uvjetima.
Staro 02.10.2016., 12:46   #3778
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Odigrao jednu partiju s Des jutros. Još je to sve subjektivno ali Propulsion Modification 2 i Steering Gears Modification 3 u zamjenu za uobičajeni rudder shift & max concealment je vrijedilo. Welcome back Des Moines.
Nakon 30 partija s Fletcherom vidim da je odličan, ali nismo si kliknuli baš. Dok danas nisam zamijenio Torpedo Tubes Modification 3 sa Main Battery Modification 3:
- naravno da sam mulac zaboravio staviti zastavicu za +300% FreeXP na prvu pobjedu dana...
Gun reload je sad 2,6 sekundi. Što ti daje šansu protiv Gearinga u duelu. Potjerao jednoga iz capa - ravno na torpeda koja sam ranije lansirao.
Sa TAE skillom torpeda se reloadaju za 95 sekundi, što je 5 sekundi dulje od Fubukija bez TAE skilla. Taman jer ima partija gdje torpeda uopće ne koristiš - a Main Battery Modification 3 je ono što ti daje prednost nad Bensonima koji imaju iste (i broj) topove i reload. Jedna sekunda više za rotaciju (5s vs 6s) je smiješno zanemariva. Ovo je D modul za uzeti na američkim DD-ima T9 i T10.
Pogledaj video. Lik je stavio matematiku i primjere - ovo je "ispravljen video" nakon što mu je ekipa rekla da je pogriješio. Info od nekog lika s NA foruma tako da nije njegovo uobičajeno baljezganje.
Zadnje izmijenjeno od: T}{OR. 02.10.2016. u 12:52.
Staro 02.10.2016., 13:05   #3779
Flayer
Why So Serious?
Flayer's Avatar
Postovi: 151
2. i 3.
Oooo super
Staro 02.10.2016., 13:09   #3780
Lun
Lun's Avatar
Datum registracije: Jan 2010
Postovi: 414
Gotovo sam uvjeren da tip od WG-a dobiva lovu za nekakvu promociju. Nekidan gledam iChaseov stream gdje je hvalio Leningrada na sva usta. No prava istina je da Leningrad treba posebnog kapetana sa EM i LS skillovima da bi bio dobar, kao i Anshan. A druga stvar: je u tom tieru su Blyska i Mahan, oba broda imaju jednak concealment i manji concealment firing penalty od Lenina. Uz Blysku uz shopu, Lenin nema šta tražit.
Da ne spominjemo njegova videa u kojima ljubi WGov nježnik sa stavom tipa "sve znam", pa ga netko "ispravi" u komentarima ili forumima pa ide video gdje se izvlači itd.
Uglavnom ako netkome trebaju detaljne informacije o mehanikama igre, na EU i US forumima ima more dobrih threadova.
Lun je offline   Reply With Quote
