Staro 29.08.2015., 06:28   #2311
Karlo666
Karlo666's Avatar
Datum registracije: Oct 2010
Lokacija: Kaštel Lukšić
Postovi: 1,568
Autor Veki-os Pregled postova
Na Win 8.1/10 onaj slider ne gasi UAC kompletno kao na Win 7 nego samo kao makne upozorenja,koja naravno i dalje iskaču.
Guglaj kako potpuno disejblati tu glupost,ima više načina.
Eh da,i kad to potpuno disejblaš metrosexual modern apps više ne rade.
Ovo isto vrijedi za Win 8/8.1 a to što ti iskače je SmartScreen.
UAC kompletno gasiš u Group Policyu.
Isto tako dok se UAC neugasi u Group Policyu programi koji nemaju WHQL ili interni Windows whitelist neće se dizati čak iako si ih ubacio u startup.
Pošten trgovac:
1,2,3,
Staro 29.08.2015., 06:54   #2312
tomek@vz
tomek@vz's Avatar
Lokacija: München/Varaždin
Postovi: 4,752
Windows 10 Child Spying Feature Is Upsetting People
It seems to me that the biggest problem with this feature is that it is turned on by default.
Windows 10 sends a weekly "activity update" on childrens’ internet browsing and computer history to parents, by default and without telling anyone. The feature could be dangerous as well as embarrassing, users have pointed out, allowing parents to watch everything their children do on the computer.
http://www.independent.co.uk/life-st...-10472226.html
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16GB DDR5 / Micron M.2 2242 1TB / nVidia Geforce RTX 4050 / Windows 11 Pro
Lenovo Thinkpad L15 Gen 1 || Intel Core i5 10210U / 16GB DDR4 / WD SN730 256GB / Intel UHD / Fedora Workstation 42
Staro 29.08.2015., 08:54   #2313
Cukipuki1
Datum registracije: Nov 2012
Lokacija: Usa
Postovi: 1
Autor vinja Pregled postova
da, ali npr nama je ultrabitan AutoCAD, a koliko vidim, Autodesk kaže da verzija 2016 (tek izašla) nije kompatibilna s Win10...
kako će tek onda biti kompatibilnost nekih naših opskurnijih programa
AutoCAD 2016 odlično radi na W10.
Cukipuki1 je offline   Reply With Quote
Staro 29.08.2015., 15:18   #2314
vinja
vinja's Avatar
Postovi: 788
Autor Cukipuki1 Pregled postova
to se traži. Post 1, ali vrijedan
dakle iskušao si? Jer Autodesk službeno ne podržava 2016 na W10....
thanx!
vinja je offline   Reply With Quote
Staro 29.08.2015., 21:11   #2315
Ma autokadija nije izbirljiv. Ja vrtim 2004 na Win7 x64 tako da na W10 će raditi vjerojatno sve i jedan nakon 2004
Staro 29.08.2015., 21:23   #2316
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Znam,ja ga isto gasim u GP-u,vidio sam da se može i kroz registry ugasiti ali nisam isprobavao jer sam navikao na ovu metodu.
Ne iskače mi ništa jer mi je i SmartScreen disejblan
Staro 29.08.2015., 22:20   #2317
Karlo666
Karlo666's Avatar
Postovi: 1,568
Kad govorim o UACu o kome pričaš to je onaj virtualni a u GPu se zove "Run all apps in Admin approval mode"
Kad ga staviš na disabled dobiješ svaki put Error pri bootanju za Virtualni UAC.
A nakon nekog vremena pojavi se i onaj problem sa searchom "We are getting search ready" sve dok nevratiš taj virtualni UAC na jedan boot pa nazad na off search neće raditi i tako u krug.
A ako misliš da nisam rebuildao search index varaš se.
Pošten trgovac:
1,2,3,
Staro 29.08.2015., 22:39   #2318
Veki-os
Veki-os's Avatar
Postovi: 3,996
Mislim da se nismo razumjeli,gasim ga tako da disejblam preko GP-a ove dvije stavke,isto je u Win 8.1 i u Win 10,pretpostavljam da i ti tako gasiš?
" User Account Control: Only elevate UIAccess applications that are installed in secure locations.
User Account Control: Run all administrators in Admin Approval Mode."
Pisao sam ono na brzaka pa nisam baš skroz objasnio.
Nemam nikakvi error i search radi normalno.
Staro 30.08.2015., 07:54   #2319
tomek@vz
tomek@vz's Avatar
Postovi: 4,752
Windows 10 Business Users May Get Patch Notes
I don’t know about you, but I am starting to get tired of hearing about the fallacies of Microsoft’s update policies and what may or may not improve. They should just make updates optional and add patch notes for everyone so we can move on to whatever Windows 10 annoys us with next.
Windows SuperSite's Rod Trent, who was attending the press briefing, tweeted "Change lists for Windows 10 updates are coming for businesses." And Ars Technica's Peter Bright tweeted from the event that "Microsoft is considering some kind of change lists for Enterprise users, but still not a hard commitment to provide proper patch notes."
http://www.zdnet.com/article/microso...ils-after-all/
Staro 30.08.2015., 07:57   #2320
lit
Lokacija: hr
Postovi: 976
Jel netko primjetio da kada pališ/gasiš komp nadogradnja raznih fixeva ne pali, već moraš kliknuti na onaj pop-up koji hoće Schedulati restart.
Zašto ne prihvati svaki slijedeći restarat, nego baš mora biti "njegov"? jel ima rješenje tomu?
lit je offline   Reply With Quote
Staro 30.08.2015., 16:21   #2321
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,270
Staro 30.08.2015., 17:15   #2322
FitzTN
FitzTN's Avatar
Lokacija: Samobor, HR
Postovi: 1,614
Autor lit Pregled postova
Kako ne prihvati restart? Meni prihvati svaki put. Restart da, ali shutdown ne. To je valjda jer je MS prije izazvao gnjev kod korisnika kad bi htio isključit npr. laptop, a on još 5 min instalira updateove.
Staro 30.08.2015., 17:20   #2323
lit
Lokacija: hr
Postovi: 976
Autor FitzTN Pregled postova
Ne znam jesmo se razumjeli, meni već 2-3 dana stoji poruka dolje da treba napraviti schedule za restart kako bi upgradeove neke fixeve.
U ta 2-3 dana palio sam komp najmanje 6 puta, zašto to već nije napravio kužiš?
Prije je to automatski napravio kad si restartao komp. A sad moraš "scheduleati" da bi on prihvatio upgrade fix i tek će onda nadograditi.
ako ima workaround za ovo da bude normalno kao i prije neka mi javi
Staro 30.08.2015., 18:26   #2324
FitzTN
FitzTN's Avatar
Postovi: 1,614
Čekaj, si radio restart ili shutdown?
Staro 31.08.2015., 02:38   #2325
Sanogo
Sanogo's Avatar
Datum registracije: Dec 2011
Postovi: 188
Eto, tko nije htio na 10-ku zbog privatnosti, najgora novost sa desetke stiže na 7 i 8.
http://www.forbes.com/sites/gordonke...rtner=yahootix
Sanogo je offline   Reply With Quote
Staro 31.08.2015., 06:09   #2326
tomek@vz
tomek@vz's Avatar
Postovi: 4,752
Autor Sanogo Pregled postova
Čak i ako disejblaš Win update servise?
Zadnje izmijenjeno od: tomek@vz. 31.08.2015. u 06:19.
Staro 31.08.2015., 09:16   #2327
lit
Lokacija: hr
Postovi: 976
Oboje, ni jedno nije upalilo, dok nisam odabrao Schedule...
Staro 31.08.2015., 09:21   #2328
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,546
Zasto gasis kompletan UAC u GP? Mislim koji ti program ne radi ako samo spustis slider ?
Staro 31.08.2015., 09:23   #2329
alengrosevic
alengrosevic's Avatar
Postovi: 3,775
Pa kad vidim kako su opisali tu "nadogradnju", sve mi je jasno...
"This service provides benefits from the latest version of Windows to systems that have not yet upgraded."
Staro 31.08.2015., 10:26   #2330
Sanogo
Sanogo's Avatar
Postovi: 188
Da, tako piše, da to fino u pozadini fantomski instalira bez obzira na ugašene servise. Treba netko potvrdit iz prve ruke da li je istina, meni su upaljeni update-ovi pa ne znam.
Staro 31.08.2015., 11:10   #2331
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,547
Lijepo od njih sad su maknuli izgovor windows 7 i 8 me ne spijuniraju. Ko zna ce disablati ko ne morat ce se pomiriti s novim stanjem ili potraziti alternativu.
Staro 31.08.2015., 11:18   #2332
tomek@vz
tomek@vz's Avatar
Postovi: 4,752
Autor Bono Pregled postova
Problem je da prava alternativa ne postoji. Da - ja koristim Linux kao primarni OS. Ali na njemu 90% igara ne radi. Onaj kome treba AutoCad, Adobe paket ili nešto slično (profi naravno ne za jožeka doma da drkicu baca na te alate) ista stvar - alternativa ne postoji. MS ima debeli monopol na tržištu desktop računala ako želiš računalo za nešto pametnije i bitnije koristiti. Ima alternativa ali - ko da ih nema
Staro 31.08.2015., 11:26   #2333
alengrosevic
Postovi: 3,775
OS X?
Staro 31.08.2015., 11:42   #2334
Hawker
Datum registracije: Nov 2014
Postovi: 1,972
Izgleda da je MSu bas jako stalo do data mininga.
Srecom,sve se to moze eliminirat.
Hawker je offline   Reply With Quote
Staro 31.08.2015., 13:52   #2335
Wizzard
Wizzard's Avatar
Postovi: 493
Koliko pratim ms-ovci nece davati detalje oko nadogradnji tj updejtova..ccc Razlog je vrlo jednostavan: ms će objavljivati detalje samo o velikim nadogradnjama, pa kumulativne nadogradnje i male ispravke neće dolaziti sa listama promjena.. Samo prateći sve ovo čini mi se da će se ovo odnositi samo na klasične korisnike,dok će firme dobijati liste updejtova i promjena koje donose nadogradnje...Što bi se reklo skraćeno lista ispravaka dolazi korisnicima Windows 10 Enterprise.. nas male ko j... hm sad bi na kraju trebao instalirati enterprise da vidim što ide pod ispravke..tj apdejtove..
CPU: Amd Ryzen 5 5600 cooled by BE QUIET Pure Rock 3
MBO: Gigabyte Aorus B550 Elite V2
RAM: 2x16gb ddr4 G Skill F4-3200C16-16GVK
VGA: ASRock Intel Arc B580 Challenger OC 12Gb
HDD: Nvme Kingston KC 3000 1TB+Cruical SSD BX500 1TB+1000Gb WD10EZEX-22MFCA0
PSU: SeaSonic G-Series (Gold) Modular 550 W
Case: Endorfy ARX 700 ARGB
Mause: Logitech G403 Hero
Monitor: Asus Tuf Gaming VG249 24"
OS: Win 10 X64 Pro
Sound: SB X-FI Xtreme Audio
Wizzard je offline   Reply With Quote
Staro 31.08.2015., 15:03   #2336
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,270
http://www.softpedia.com/blog/micros...s-490321.shtml
znači mogu uzet home verziju?
to je ejdini razlog za pro, ali 1000kn više je puno rpeviše..al ak ovo vriejdi onda super
edit: ovo je samo za store, ne OS updates..jbt
Zadnje izmijenjeno od: mamutarka. 31.08.2015. u 16:02.
Staro 31.08.2015., 18:11   #2337
BoobZ
BoobZ's Avatar
Datum registracije: Feb 2012
Lokacija: Usa
Postovi: 161
pa ako imaš legale windowse sada napravi upgrade, zašto žuriš s kupovinom a već su dali besplatan upgrade?
BoobZ je offline   Reply With Quote
Staro 31.08.2015., 19:47   #2338
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Prestize me kolega...
Staro 31.08.2015., 20:38   #2339
Hawker
Postovi: 1,972
mod: 100x smo ponovili da nema spominjanja nelegalnog sadržaja...
Zadnje izmijenjeno od: Brko. 31.08.2015. u 21:24. Razlog: crack
Staro 31.08.2015., 22:02   #2340
Molimo da se prestane pričati o ilegalnom aktiviranju prethodne verzije windowsa. Takve odgovore tražite po netu, a ne pišite o tome ovdje. Neki su dobili opomene, neki GO, stoga lijepo molimo da se nastavi sa diskusijom u normalnom i legalnom tonu.
