#1531 | |
..starija garda
Postovi: 3,280
ovo je super za znat.. dakle može se isključiti "telemetrija" , a evo i automatski update drivera.. još malo pričekati, ali pomalo stvari dolaze na svoje ![]()
#1532 |
Datum registracije: Jul 2010
Postovi: 552
Baš dolaze... To sve ima od XP-a... |
#1533 |
Creeper
Datum registracije: May 2013
Postovi: 2,215
#1534 |
Omicron Alpha resident
Lokacija: Bistra
Postovi: 5,082
#1535 |
Datum registracije: Nov 2014
Postovi: 1,972
http://www.rt.com/usa/311304-new-win...rivacy-issues/ ‘Incredibly intrusive’: Windows 10 spies on you by default While the upgrade is currently free of charge to owners of licensed copies of Windows 8 and Windows 7, it does come at a price. Several tech bloggers have warned that the privacy settings in the operating system are invasive by default, and that changing them involves over a dozen different screens and an external website. According to Zach Epstein of BGR News, all of Windows 10’s features that could be considered invasions of privacy are enabled by default. Signing in with your Microsoft email account means Windows is reading your emails, contacts and calendar data. The new Edge browser serves you personalized ads. Solitaire now comes with ads. Using Cortana – the voice-driven assistant that represents Redmond’s answer to Apple’s Siri – reportedly “plays fast and loose with your data.” EDIT Koristan link za slucaj da ekipa odustane od rezervacije LINK |
#1536 |
1
Postovi: 3,593
Zasad sam instalirao win 10 na jedan laptop i na svoj desktop komp i na oba kad se boota znači kad welcome završi ikonice u taskbaru se ne pojave sve odmah nego prvo su 2 pa onda 4 pa nastavi dalje, imam ih ukupno 10. I poslije njih kad učita učita i tray njih imam 3 to traje možda negdje 3-4 sekunde. Na win 8.1 mi je odmah nakon welcome-a učitao sve i na win 7, ne znam jel to neki bug ili to tako treba bit. I skužio sam da recimo u program files-u, windows folderu i takvi slični mogu kreirat samo new folder ostalog ničeg nema kao text file ili tako neki. |
#1537 | |
Lokacija: Petrinja
Postovi: 904
#1538 |
1
Postovi: 3,593
#1539 | |
Lokacija: Chernobyl NPP
Postovi: 4,777
#1540 |
Lynnfield
Datum registracije: Sep 2012
Postovi: 1,023
Jel mogu kako maknut ovu ikonu GET WINDOWS 10 iz taskbara,iz control panela i od bilo kuda da mi više ne skače odasvud,da to skroz maknem,obrišem,unistall,finito jer ne mislim stavljat win 10 na ovaj jedan komp? |
#1541 |
Datum registracije: Jul 2009
Postovi: 338
KB3035583 je update koji ga je doveo unutar računala, vjerujem da ako njega ukloniš da ćeš se rješiti svih obavijest, ali nisam 100% siguran. Windows/System32/GWX je lokacija exe file-a koji je dežuran za obavijest u taskbaru (koji se može u centru i isključiti). Ima o tome previše na googlu btw. |
#1542 | |
Prvoklasni Krkan
Postovi: 5,332
#1543 | |
Lynnfield
Postovi: 1,023
#1544 |
Never Forgetti
Lokacija: .
Postovi: 1,640
Da li je moguČe aktivirati licencu bez instalacije na Win7? Konkretno clean instal iz temelja, ali s original Win7 HP licencom? Da li je moguČe aktivirati licencu bez instalacije na Win7? Konkretno clean instal iz temelja, ali s original Win7 HP licencom?
#1545 | |
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,780
http://dev.banelli.biz/tmp/GetWindowsCDKey.exe [21,1 KB (21.656 bytes)] Prikaz + kod ce vam automatski biti prebacen u clipboard pa ga mozete veselo kopirati kako vas volja. Naravno, ovo radi na svim x64 bitnim Windowsima (probao sam na Visti i 7, radit ce i na 8.x a vjerojatno i na x64 WXP te svim serverskim verzijama). Nema videa (pa necu vam valjda davati svoj key ), ali za paranoicne -> VirusTotal![]()
#1546 |
Datum registracije: Apr 2008
Lokacija: somwhere behind enemy lines
Postovi: 47
kratko pitanje - instalirati kao UEFI GPT ili klasični stari MBR? može li netko ukratko prednosti/mane navesti? koliko sam vidio UEFI = 2sec boot, MBR 10-20sec (ssd jel), i još neke đigubacije in advance |
#1547 |
E Pluribus UNIX
Lokacija: M82
Postovi: 6,780
#1548 | |
Lokacija: doma
Postovi: 2,899
ce neke drivere izdat tek u 10-tom mjesecu.Stvar je spasio Daniel. http://danielkawakami.blogspot.com/ Za SB X-Fi PCI Fatality XtremeGamer ide Support Pack 3.4 ili 3.3 uz malo "uvjeravanja" tj. rucne instalacije zvuk je proradio iako se nesto prozor bunio oko CMSS-3D jer iako imam 2.0 set zvucnika isti koristim tako da konfiguriram 4.0 zvucnika a kroz CMSS-3D i Stereo Surround dobijem na drugi izlaz, izlaz za slusalice koji radi identicno kao sami Front zvucnici. Znaci ima malo gnjavaze dok se to sve podesi ali radi ok evo cjelo popodne i vecer... Sto se tice Audigy Platinum Ex i Audigy 5.1 koje imaju game port windows 10 je prepoznaje od prve i sve ok to me bas zacudilo jer je to sad poprilicno stara serija kartica. Istina nema dodatnih podesavanja osim basa i visokih i nema CMSS-3D no i ovdje je stvar spasio Daniel.http://danielkawakami.blogspot.com/2...t-pack-53.html Za razliku od X-Fi nema problema, instalacija prolazi glatko i kartice rade sa svim svojim dodatnim ficurima. PAX driveri nula bodova, sve 3 kartice se ponasaju kao da sa nakovnja pokusavam cuti nesto... Za kraj kX Project - Driveri rade !! http://www.kxproject.com/index.php?language=en Naravno X-Fi ne jer nema podrsku ali Audigy Platinum Ex i Audigy 5.1 rade identicno kao na w7. Ispada da starije Creative kartice imaju bolju podrsku nego nesto novije, nemos vjerovat. Zalosno je samo i spomeniti da sam sa driverima za w8.1 uzaludno pokusavao dobiti bilo kakav zvuk na bilo kojoj kartici.... |
#1549 |
The mighty pirate
Lokacija: London
Postovi: 9,122
Realtek još uvijek nema drivere za W10. Zvuk radi, ali mi se kod svakog pokretanja sustava, isti driveri žele ponovo instalirati, pa ne uspiju. Jack sensing ne radi, tj. ne mogu na programirati jackove da rade ono što ja želim da rade.
#1550 | |
Lokacija: Bistra
Postovi: 5,082
http://www.reaper-x.com/2012/02/13/h...d-jacks-ports/
#1551 |
Postovi: 2,717
OK, više manje snalazim se uredno u W10. Par drivera što mi je falilo, našao, sredio... Tu i tamo mi se nekako smrzne explorer, kao da se uspori na brzinu puža i onda čekam čekam, dok ne pošizim i restartam. To mi se dešava samo ako sam prethodno nešto instaliravao. Nadalje, ne mogu podesiti u ovom EDGU pokretanje jave, radi internet RBA bankarstva... Sviđa mi se ovaj EDGE i volio bi ga isprobati max bez da ga zaobiđem... EDIT: In Windows 10, the Edge browser does not support plug-ins and therefore will not run Java. Switch to a different browser (Firefox or Internet Explorer 11) to run the Java plug-in. More info OK, dobio odgovor ![]()
MC |
#1553 |
Lokacija: doma
Postovi: 2,899
Mene ubija Font jos od Viste... na w7 se to dalo urediti a od 8.0 nema vise. Nije da mi smetaju deblja slova ali su nekako "masna" a Clear Type samo djelomicno rjesava stvar i ne svagdje, neke stranice kad se citaju po netu sa tim ficurom ukljucenim meni je ogavno. Evo tko zeli imat Fontove jos od XP-a koji su meni i dan danas dobri i nezamenjivi. https://www.dropbox.com/s/l967p2snn63c2ti/Font.rar?dl=0 Imate i beckup nazad na originalne od w10. Nije sve 100% obuhvaceno ali ono bitno je... Restartati poslje merganja. |
#1554 | |
Datum registracije: Oct 2010
Lokacija: Kaštel Lukšić
Postovi: 1,573
TY4CG JDJH7 VJ2WF DY4X9 HCFC6 I kod aktivacije i instalacije ga odbija. |
#1555 |
Lokacija: Slavonija ravna
Postovi: 465
Pitanje... Kako funkcionira opcija Change windows key? Konkretno, rađen update sa w7 kiselo vrhnje na w10 pro. Da li se sada može na tom mjestu unijeti originalan ključ i od kojih win, ovih koji su bili ili može i od w8.1? Ili se baš mora radit nova instalacija w8.1, pa upgrade pa aktivacija? Naletio sam na ovo http://winaero.com/blog/generic-key-to-install-windows/ pa me zanima da li je netko naknadno aktivirao win10 na takav način |
#1556 | |
Prvoklasni Krkan
Postovi: 5,332
Sada se puno brze dizu win. |
#1557 |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,675
Meni Ultimate PID checker baca YTMG3-N6DKC-DKB77-7M9GH-8HVX7, to je key koji je embedded u instalacijski medij. Ali ova VBS skripta i Bubbina alatka mi bacaju drugačiji key od ovog gore, no kad sam probao aktivirati desetku s tim ključem bacio mi je error. Kad checkiram taj key u PID checkeru kaže mi da je "invalid", dok za ovaj generički microsoftov kaže da je valid retail. Nije mi jasno zašto Bubbino čedo i PID checker bacaju različite rezultate. Možda Bubbina bebica očitava key od prijašnje instalacije? Anyway, se su to akademska pitanja, bitno je da vam za clean instalaciju desetke netreba nikakav key. Zadnje izmijenjeno od: kopija. 02.08.2015. u 11:36. |
#1560 |
Premuim
Postovi: 1,748
Jedno kratko pitanje, imam na msdnaa dostupne ove verzije: Windows 10 EDU Windows 10 (Multiple Editions) Windows 10 EDU N Windows 10 N (Multiple Editions) Windows 10 (Multiple Editions) Debug/Checked Windows 10 Features on Demand Paaa, sto preuzeti? Mislim da cu moci samo jednu veriju skinuti i pokupiti kljuc. Dal i ove licence vrijede 2 godine kao win 7/8 ili je neka druga prica? |
