Staro 01.08.2015., 13:46   #1531
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,278
Autor Alph4Dawg Pregled postova
Za sve one kojima smeta automatsko apdejtanje drajvera:
Desni klik na My Computer - Properties - Advanced system settings (zadnja lijevo).
U novom prozoru kliknete na tab 'Hardware' i onda ispod na 'Device installation settings'.
U novom prozoru odaberete ispod 'No, let me choose what to do', te ispod oznacite 'Never install driver software from Windows update' i uncheck sa 'Automatically get the device app and info provided by your device manufacturer'.
ovo je super za znat..
dakle može se isključiti "telemetrija" , a evo i automatski update drivera..
još malo pričekati, ali pomalo stvari dolaze na svoje
MojSkuter
Staro 01.08.2015., 14:26   #1532
the.elles.d
Datum registracije: Jul 2010
Postovi: 544
Baš dolaze... To sve ima od XP-a...
the.elles.d je online   Reply With Quote
Staro 01.08.2015., 14:27   #1533
partwish
Creeper
Datum registracije: May 2013
Postovi: 2,211
Autor Romano.Cule Pregled postova
Svasta.Ja isprobao na tri racunala i na sva 3 prikazuje ispravno. 2 imaju vistu i jedno ima windows 7.
Na još jednom računala skripta pokazuje krivi ključ. U pitanju su Win 8.1 Pro.
Staro 01.08.2015., 14:58   #1534
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,054
http://msft.gq/gxn/
Skinite ovo i preko toga updejtate Winse. Gotovo garantirano radi.
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 01.08.2015., 14:59   #1535
Hawker
Datum registracije: Nov 2014
Postovi: 1,972
http://www.rt.com/usa/311304-new-win...rivacy-issues/
‘Incredibly intrusive’: Windows 10 spies on you by default
While the upgrade is currently free of charge to owners of licensed copies of Windows 8 and Windows 7, it does come at a price. Several tech bloggers have warned that the privacy settings in the operating system are invasive by default, and that changing them involves over a dozen different screens and an external website.
According to Zach Epstein of BGR News, all of Windows 10’s features that could be considered invasions of privacy are enabled by default. Signing in with your Microsoft email account means Windows is reading your emails, contacts and calendar data. The new Edge browser serves you personalized ads. Solitaire now comes with ads. Using Cortana – the voice-driven assistant that represents Redmond’s answer to Apple’s Siri – reportedly “plays fast and loose with your data.”
EDIT
Koristan link za slucaj da ekipa odustane od rezervacije
LINK
Hawker je offline   Reply With Quote
Staro 01.08.2015., 15:17   #1536
Thermaltake
1
Thermaltake's Avatar
Postovi: 3,568
Zasad sam instalirao win 10 na jedan laptop i na svoj desktop komp i na oba kad se boota znači kad welcome završi ikonice u taskbaru se ne pojave sve odmah nego prvo su 2 pa onda 4 pa nastavi dalje, imam ih ukupno 10. I poslije njih kad učita učita i tray njih imam 3 to traje možda negdje 3-4 sekunde. Na win 8.1 mi je odmah nakon welcome-a učitao sve i na win 7, ne znam jel to neki bug ili to tako treba bit.
I skužio sam da recimo u program files-u, windows folderu i takvi slični mogu kreirat samo new folder ostalog ničeg nema kao text file ili tako neki.
Staro 01.08.2015., 15:30   #1537
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
To je normalno, i događa se i na prijašnjim windowsima. Zavisi koliko ikonica imaš...
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 01.08.2015., 15:41   #1538
Thermaltake
1
Postovi: 3,568
Autor DraŽ Pregled postova
Uvijek sam imao isto i uvijek su mi isto poredane
Staro 01.08.2015., 17:01   #1539
xGAME
xGAME's Avatar
Lokacija: Chernobyl NPP
Postovi: 4,777
Autor xulos Pregled postova
Taj key jednom kad aktiviras nema prenosenja, pise gore u postovima. Dakle promjenis maticnu gubis licencu.
Ima i obican koliko vidim, za malo vecu cijenu. Mozda si uzmem pri sljedecoj placi
xGAME je offline   Reply With Quote
Staro 01.08.2015., 17:03   #1540
esc
Lynnfield
Datum registracije: Sep 2012
Postovi: 1,023
Jel mogu kako maknut ovu ikonu GET WINDOWS 10 iz taskbara,iz control panela i od bilo kuda da mi više ne skače odasvud,da to skroz maknem,obrišem,unistall,finito jer ne mislim stavljat win 10 na ovaj jedan komp?
esc je offline   Reply With Quote
Staro 01.08.2015., 18:04   #1541
dashko
Datum registracije: Jul 2009
Postovi: 338
KB3035583 je update koji ga je doveo unutar računala, vjerujem da ako njega ukloniš da ćeš se rješiti svih obavijest, ali nisam 100% siguran. Windows/System32/GWX je lokacija exe file-a koji je dežuran za obavijest u taskbaru (koji se može u centru i isključiti).
Ima o tome previše na googlu btw.
dashko je offline   Reply With Quote
Staro 01.08.2015., 19:25   #1542
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,262
Autor esc Pregled postova
http://www.ghacks.net/2015/04/17/how...ndows-7-and-8/
Slobodno me dodajte na PSN
Staro 01.08.2015., 21:30   #1543
esc
Lynnfield
Postovi: 1,023
Hvala diskač,riješio sam izgleda,više ne dosađuje i nestao je iz taskbara
Staro 01.08.2015., 22:32   #1544
Drift_King
Never Forgetti
Drift_King's Avatar
Lokacija: .
Postovi: 1,640
Da li je moguČe aktivirati licencu bez instalacije na Win7? Konkretno clean instal iz temelja, ali s original Win7 HP licencom?
Drift_King je offline   Reply With Quote
Staro 01.08.2015., 23:54   #1545
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,753
Nasao sam ovo da bi izvukli pravi cd kljuc morate copy paste skriptu koju sam nasao na ovom sajtu.
Ako se nekome ne prepisuje (em ova hrpa VBS-a, em sam kod):
http://dev.banelli.biz/tmp/GetWindowsCDKey.exe [21,1 KB (21.656 bytes)]
Prikaz + kod ce vam automatski biti prebacen u clipboard pa ga mozete veselo kopirati kako vas volja.
Naravno, ovo radi na svim x64 bitnim Windowsima (probao sam na Visti i 7, radit ce i na 8.x a vjerojatno i na x64 WXP te svim serverskim verzijama).
Nema videa (pa necu vam valjda davati svoj key ), ali za paranoicne -> VirusTotal
Programer
Staro 02.08.2015., 00:21   #1546
phantom_fuxor
Datum registracije: Apr 2008
Lokacija: somwhere behind enemy lines
Postovi: 47
kratko pitanje - instalirati kao UEFI GPT ili klasični stari MBR?
može li netko ukratko prednosti/mane navesti? koliko sam vidio UEFI = 2sec boot, MBR 10-20sec (ssd jel), i još neke đigubacije
in advance
phantom_fuxor je offline   Reply With Quote
Staro 02.08.2015., 00:37   #1547
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,753
Autor phantom_fuxor Pregled postova
in advance
MBR nema nikakve prednosti nad GPT-om.
Programer
Staro 02.08.2015., 00:55   #1548
silver_tip
silver_tip's Avatar
Lokacija: doma
Postovi: 2,890
Ja odustajem... ne prepoznaje mi zvucnu od maticne iako sam probao i sa Realtek Audio Driver V6.0.1.7040 for Windows Win8.1 32bit & Win8.1 64bit---(WHQL). sa Asusove stranice, P8Z77-V LE je u pitanju.
Takodjer Creative SB X-Fi Fatality XtremeGamer nula bodova, nakon fijaska sa tonom nisam ni htio stavljati vulgaris Audigy Platinum Ex sto imam za rezervu
Update drivera iz device managera nista ne nadje... zanimljivo da sam imao tona ako ih apgrejdam ali samo na front zvucnicima i samo sa X-Fi Fatality.
Ipak mi vrag nije dao mira ali Creative ce neke drivere izdat tek u 10-tom mjesecu.
Stvar je spasio Daniel.
http://danielkawakami.blogspot.com/
Za SB X-Fi PCI Fatality XtremeGamer ide Support Pack 3.4 ili 3.3 uz malo "uvjeravanja" tj. rucne instalacije zvuk je proradio iako se nesto prozor bunio oko CMSS-3D jer iako imam 2.0 set zvucnika isti koristim tako da konfiguriram 4.0 zvucnika a kroz CMSS-3D i Stereo Surround dobijem na drugi izlaz, izlaz za slusalice koji radi identicno kao sami Front zvucnici.
Znaci ima malo gnjavaze dok se to sve podesi ali radi ok evo cjelo popodne i vecer...
Sto se tice Audigy Platinum Ex i Audigy 5.1 koje imaju game port windows 10 je prepoznaje od prve i sve ok to me bas zacudilo jer je to sad poprilicno stara serija kartica. Istina nema dodatnih podesavanja osim basa i visokih i nema CMSS-3D no i ovdje je stvar spasio Daniel.
http://danielkawakami.blogspot.com/2...t-pack-53.html
Za razliku od X-Fi nema problema, instalacija prolazi glatko i kartice rade sa svim svojim dodatnim ficurima.
PAX driveri nula bodova, sve 3 kartice se ponasaju kao da sa nakovnja pokusavam cuti nesto...
Za kraj kX Project - Driveri rade !!
http://www.kxproject.com/index.php?language=en
Naravno X-Fi ne jer nema podrsku ali Audigy Platinum Ex i Audigy 5.1 rade identicno kao na w7.
Ispada da starije Creative kartice imaju bolju podrsku nego nesto novije, nemos vjerovat. Zalosno je samo i spomeniti da sam sa driverima za w8.1 uzaludno pokusavao dobiti bilo kakav zvuk na bilo kojoj kartici....
Staro 02.08.2015., 00:57   #1549
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,068
Realtek još uvijek nema drivere za W10.
Zvuk radi, ali mi se kod svakog pokretanja sustava, isti driveri žele ponovo instalirati, pa ne uspiju. Jack sensing ne radi, tj. ne mogu na programirati jackove da rade ono što ja želim da rade.
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 02.08.2015., 01:03   #1550
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,054
Autor 1v@n Pregled postova
Ja ovo radim još od Win8.0:
http://www.reaper-x.com/2012/02/13/h...d-jacks-ports/
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 02.08.2015., 01:49   #1551
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
OK, više manje snalazim se uredno u W10. Par drivera što mi je falilo, našao, sredio...
Tu i tamo mi se nekako smrzne explorer, kao da se uspori na brzinu puža i onda čekam čekam, dok ne pošizim i restartam. To mi se dešava samo ako sam prethodno nešto instaliravao.
Nadalje, ne mogu podesiti u ovom EDGU pokretanje jave, radi internet RBA bankarstva...
Sviđa mi se ovaj EDGE i volio bi ga isprobati max bez da ga zaobiđem...
EDIT:
In Windows 10, the Edge browser does not support plug-ins and therefore will not run Java. Switch to a different browser (Firefox or Internet Explorer 11) to run the Java plug-in. More info
OK, dobio odgovor
MC
Staro 02.08.2015., 02:35   #1552
spaceman
spaceman's Avatar
Datum registracije: Feb 2010
Lokacija: Našice
Postovi: 327
Meni na laptopu ne radi alt+tab,odnosno radi samo tako da aplikaciju otvori u full screen ako je smanjena a obratno nikako.
spaceman je offline   Reply With Quote
Staro 02.08.2015., 02:36   #1553
silver_tip
silver_tip's Avatar
Lokacija: doma
Postovi: 2,890
Mene ubija Font jos od Viste... na w7 se to dalo urediti a od 8.0 nema vise. Nije da mi smetaju deblja slova ali su nekako "masna" a Clear Type samo djelomicno rjesava stvar i ne svagdje, neke stranice kad se citaju po netu sa tim ficurom ukljucenim meni je ogavno.
Evo tko zeli imat Fontove jos od XP-a koji su meni i dan danas dobri i nezamenjivi.
https://www.dropbox.com/s/l967p2snn63c2ti/Font.rar?dl=0
Imate i beckup nazad na originalne od w10. Nije sve 100% obuhvaceno ali ono bitno je... Restartati poslje merganja.
Staro 02.08.2015., 06:39   #1554
Karlo666
Karlo666's Avatar
Datum registracije: Oct 2010
Lokacija: Kaštel Lukšić
Postovi: 1,569
Autor Bubba Pregled postova
Ajd da pogađam key ti je:
TY4CG JDJH7 VJ2WF DY4X9 HCFC6
I kod aktivacije i instalacije ga odbija.
Pošten trgovac:
1,2,3,
Staro 02.08.2015., 08:13   #1555
Ico2005
Ico2005's Avatar
Lokacija: Slavonija ravna
Postovi: 464
Pitanje... Kako funkcionira opcija Change windows key? Konkretno, rađen update sa w7 kiselo vrhnje na w10 pro. Da li se sada može na tom mjestu unijeti originalan ključ i od kojih win, ovih koji su bili ili može i od w8.1? Ili se baš mora radit nova instalacija w8.1, pa upgrade pa aktivacija?
Naletio sam na ovo http://winaero.com/blog/generic-key-to-install-windows/ pa me zanima da li je netko naknadno aktivirao win10 na takav način
Ico2005 je offline   Reply With Quote
Staro 02.08.2015., 08:56   #1556
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,262
in advance
Ja sam napravio clean install samo zbog GPT-a, nisam znao za to kada sam instalirao w8.
Sada se puno brze dizu win.
Staro 02.08.2015., 09:54   #1557
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,553
Meni Ultimate PID checker baca YTMG3-N6DKC-DKB77-7M9GH-8HVX7, to je key koji je embedded u instalacijski medij.
Ali ova VBS skripta i Bubbina alatka mi bacaju drugačiji key od ovog gore, no kad sam probao aktivirati desetku s tim ključem bacio mi je error.
Kad checkiram taj key u PID checkeru kaže mi da je "invalid", dok za ovaj generički microsoftov kaže da je valid retail.
Nije mi jasno zašto Bubbino čedo i PID checker bacaju različite rezultate. Možda Bubbina bebica očitava key od prijašnje instalacije?
Anyway, se su to akademska pitanja, bitno je da vam za clean instalaciju desetke netreba nikakav key.
Zadnje izmijenjeno od: kopija. 02.08.2015. u 10:36.
Staro 02.08.2015., 11:13   #1558
imart
Datum registracije: Feb 2013
Postovi: 1,167
ne kužim zakaj mi neće auto updejtat..
gore su 8.1 x64 aktivirani windowsi MAK ključem preko telefona..
imart je offline   Reply With Quote
Staro 02.08.2015., 11:53   #1559
spaceman
spaceman's Avatar
Lokacija: Našice
Postovi: 327
Probaj s onime što je predložio kolega forumaš Mario92 (post 1534), meni je tako prošao upgrade na laptopu.
Staro 02.08.2015., 11:56   #1560
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
Jedno kratko pitanje, imam na msdnaa dostupne ove verzije:
Windows 10 EDU
Windows 10 (Multiple Editions)
Windows 10 EDU N
Windows 10 N (Multiple Editions)
Windows 10 (Multiple Editions) Debug/Checked
Windows 10 Features on Demand
Paaa, sto preuzeti? Mislim da cu moci samo jednu veriju skinuti i pokupiti kljuc. Dal i ove licence vrijede 2 godine kao win 7/8 ili je neka druga prica?
Campeonato je offline   Reply With Quote
