#2221 |
Never Forgetti
Lokacija: .
Postovi: 1,640
Triba mi neko ko ima BrokenStones account, neka se javi na PM ![]()
#2222 |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,556
Karagarga na udaru zakona: http://pastebin.com/deHQDjgd |
#2224 |
#2226 |
pa imam ja 6 referala jedan sam mu poslao ![]() to je treci koji sam tu na forumu dao, jedan je banan, a drugi nikad nije ni poceo downloadat. |
#2228 |
tak su i ova prva dvojica rekla ![]() Once Generated, you will only have 24 hours to get your referral account created before the code times out!Invitees should be advised NOT to use hotmail, msn or outlook to signup as they often block our email responder and they may not receive their sign up confirmation email.If your invitee doesn't receive their confirmation email, firstly please advise them to wait at least 15 minutes and also check their junk / spam folder as it commonly arrives there, if it's definitely not received the code can be used again to retry with a different email address within the 24 hour period. |
#2229 |
Postovi: 2,636
Kaj se tolko jezite oko BCG-a? Tamo barem ne treba seedbox, dovoljno je da par dana držiš torrent i dobivaš upload. Već par godina tako funkcionira.
#2230 |
da, ima seeding points system. |
#2231 |
Torrent freek
Postovi: 3,946
Ja sna na BCG dobija -100 GB kazne jer je čovjek kojeg sam pozvao varao, bija je neko sa PCE, ne znan ko više iskreno. Mislim da smo čak kasnije imali raspravu na PM, gdje san ja bio oštar poprilično, a on mi je samo rekao u stilu "šta se ložiš, obični tracker, nije da sam ti nešto napravio" ![]()
#2232 |
a jebiga, to je dio rizika. meni je isto glupo sad nekog prozivat da vara na ilegalnim svarima :P |
#2235 |
Datum registracije: Jan 2010
Lokacija: kragujevac
Postovi: 1
Moj pozdrav, Zaboravili ste rutracker.org Kojim redom bi Vi rangirali ove trackere what.cd waffles rutracker pedro's Sto se tice pedro's da li oni pocetniku daju par gb bez uslovljavanja ,kao sto daju what i waffles. Takodje , uz pametnu strategiju fiovanja zahteva i dosta uploada, jel se moze preziveti tamo bez seedbox. I najvaznija stvar. Kako se na pedro's postaje clan. Jel samo preko pozivnice? I gde da je covek trazi? Moj pozdrav |
#2236 |
TorrentHR, CroBytes od naših. Pretome, Blackcats od stranih. Osobno ih koristim. Invite imam samo od CroBytes. THR ih je ukinuo, za BCG nemam a za Pretome čak možda i imam. Nemam. Ukralo mi. |
#2239 |
Fresh Juice
Postovi: 4,550
Sve imaš na THRu kaj ima tamo. A CB ima i manje sadržaja. |
#2242 | |
DIY DILETANT
Postovi: 3,556
Ako si spreman seedat 336 sati IPT praktički postaje no-ratio. GFT je no-ratio al ti treba pozivnica. Preporučam ti da se potrudiš oko TSH-a. |
#2243 |
Datum registracije: Sep 2013
Postovi: 15
Pitanje jedno, kratko i jasno: Isplati li se jos uvijek varati sa uploudom sa programima tipa RatioMaster i sl.? Imam acc na XtremeZoneu (rumunjski torrent), gdje su fenomenalne brzine i tamo sam prije vec valjda 5 godina namlatio kojih 500gb uplouda na taj nacin i od tada sam vip clan, iako mi ratio konstantno opada jer logicno sa nasim brzinama nemam sta uploudat. Ta stranica lagano propada i krenuli su hardcoreat svoje titlove u puno stvari, pa me zanima cisto unaprijed prije nego popusim ban, jesu li se promijenile stvari od tad? Btw. ako nekom treba inv nek se javi u inbox ![]() |
#2245 |
Postovi: 15
Ma na Xtremeu imam acc u sa 3.5 ratiom jos uvijek nakon 5 godina sto sam se izvarao, to mi ne treba. Pitam za ostale stranice jel' se isto da varat ili da se manim corava posla. XZ em sto sporo dobiva nove naslove, em sto hardcoraju rumunjske titlove na sve. |
#2246 |
Datum registracije: Aug 2008
Lokacija: Vukovar
Postovi: 35
ne isplati se varati, a niti nije pošteno, uhvatit te mogu, jednostavnije bi ti bilo uzeti seedbox slot na mjesec dana i stvoriti neki buffer i kasnije u miru skidati ili idi na neke "no ratio" trackere gdje se ne gleda globalni ratio nego samo torrent moraš držati na seedu određeno vrijeme dok ne zadovoljiš pravila trackera ali ne moraš uploadat već samo seedat. |
#2247 |
Never Forgetti
Lokacija: .
Postovi: 1,640
I dalje trazin alternativu neprezaljenom TvT. I dalje trazin alternativu neprezaljenom TvT.
#2248 |
Never Forgetti
Lokacija: .
Postovi: 1,640
BTN ili BitHDTV. Pice po zelji ![]()
#2250 |
Never Forgetti
Lokacija: .
Postovi: 1,640
