#901 | |
dr. sc. tech. dipl. ing.
Lokacija: Rijeka-Opatija
Postovi: 3,164
Ustvari, nakon što sam isprobao Horneta, postao sam još zadovoljniji sa svojim 315p ![]()
Pouzdan i pošten trgovac! (ima još puno novijih primjera, nisam ni pratio jel me još tko stavljao u temu.. slobodno pretražite novije postove na temi) StarCitizen refferal code: |
#902 |
Postovi: 1,154
Pogledajte ovo: https://www.youtube.com/watch?v=QePaUrVneLM |
#903 |
Vozi Miškoooo!!!
Lokacija: Svuda okolo / EU
Postovi: 1,404
Star Citizen's director of game operations, Jeremy Masker, revealed that Star Citizen's client size will be around 100GB and that patches may weight over 20GB. Looks like I need a bigger SSD drive ![]() As I have already said, I would not count on this. The game compression and asset removal is unlikely to yield such high gains that we will be able to reduce our client size to 30-40gb. The size and number of assets that are left to deliver means that our client size is much more likely to be 100gb. Also, yes we are optimizing game patching for speed and to only deliver diffs, but this is unlikely to reduce actual patch size. Again, each patch has 100s of assets, each of these assets are at times 200mb, this leads to 2-6gb patches, and if we end up doing a file type re-factor and have to re-download 30-40% of the assets on the hard-drive, then the patch will be 14-20gb. ...ono stvarno... al ajd
#904 | |
Postovi: 3,164
![]() Sjeti se kako je bilo davnih dana, dvije igre su stale na hard (od 20MB-40MB, LoL )i onda je bio pun! ![]()
#907 |
Postovi: 1,154
#908 |
Postovi: 2,394
Isprobao Avengera i M50, još mi je ostao Cutlass za isprobati. On another note, kako su postali dostupni svi brodovi skinuo 6 Omnisky VI sa serije 300 i stavio na SH. Sweet baby Jesus, ono što sam mislio da je flajšmašina u dogfightu je upravo postalo wood chipper. Scavengeri padaju poslije dva dobra pogotka. ![]() ![]() |
#909 |
Datum registracije: Jul 2009
Postovi: 338
Nakon dugo vremena sam se odlučio isprobati malo preletati, i jako sam zadovoljan promjenom od prije pola godine. Provozao sam Aurorice i Cutlassa, možda još malo provedem vremena u 300 seriji i Avengeru vidjet ćemo, međutim stvarno je sad smooth, čak i na mojoj mašini radi >30 FPS na low postavkama, ali zato udaraju 100% konstantno. Možda još ima nade da do kraja godine zaigram Sq42 na ovoj konfiguraciji. |
#910 |
Postovi: 1,154
Šta misliš da će se nešto bitno povećati zahtjevi kada se igra počne bližiti kraju? @garro: jučer navečer sam ja isto to napravio i odigrao par squadron borbi, bilo je svega: psovki, ragequitanja... ![]() |
#911 |
Postovi: 3,164
Teško je reći kakvi će bit zahtjevi. Igra će bit puno više optimizirana, ali očekujem i puno više objekata na ekranu, kao i puno više posla za cpu....dakle, nemoguće ni procijeniti koliko će biti zahtjevna...
#912 |
Postovi: 3,164
Jel netko planira veceras pokrenut ac?☺
#913 |
Postovi: 3,164
Nitko ne igra otkad je poceo kaos sa verzijom 1.1? ![]()
#914 |
Postovi: 2,394
Odigrao par public rundi sa SH i šest Omniskya, nabio 30k RECova, našao bug sa laser repeaterima i raketama, isprobao par loudouta, isprobao Gladius... Sad gledam Vanguarda, ali kad sam vidio cijenu sam se samo nasmijao i produžio dalje. ![]() |
#915 |
Postovi: 1,154
Cijene su brutalne, ali ekipa masovno kupuje, stalno na chatu kombiniraju. Ja neznam otkud im tolko love. čekam da popeglaju multiplayer pa cu onda pocet. Trenutno nemogu sa full loadoutom izać u borbu sa 325a, jako su zbagana oružja(ne spawnaju se, fali ammo). Jednom, ali JEDNOM sam uspio upast u meč sa 3 sledge guna na sebi. Mrzili su me. ![]() |
#916 | |
Postovi: 3,164
Naletio sam na hrpu bugova na 315p (sa shieldom od Cutlass-a... sletio na platformu i onda nisam mogao ući jer bi stalno ispadao iz 315p kad bih prešao preko pozicije gdje je montiran shield ) i na Cutlassu mi se događalo da iz nekog razloga neka oružja jednostavno ne rade i slično... uglavnom , ni ne stignem baš igrat...samo me zanimalo da vidim kako ekipu ovdje "diše" po pitanju novog AC/SC 1.1 ![]()
#920 |
El Mattador
Lokacija: <->
Postovi: 1,928
Boatanje je kada na stroj za ubijanje (svemirski brod, Mech, tenk, itd.) loadaš jednu vrstu oružja. Kod Mechwarrior Online napr, laser boat je Mech koji je nakrcao u sve hardpointe medium lasere napr. I ako nemas neki penalty na takvu vrstu loadouta obicno ti ne treba puno skilla da bi imao dosta killova (penalty u MWO je bitno povecan heat output prilikom ispaljenja svih lasera odjednom). |
#921 |
Postovi: 2,394
Istina. 6 gimball-ana Omniskya (2xIII, 4xIV) na SH faširaju sve što leti u Arena Commanderu. Mislim, smiješno je kad upadnem u Vanduul Coop sa Avengerom, 325 i Gladiusom, pa na kraju runde imam više bodova nego svi oni zajedno. Uz malo vježbe obično dva Scavengera skinem pri prvom prilazu. I ne, nemam l33t ski11z nego je jednostavno SH u toj kombi, odnosno njegov alpha strike, prejak/premalo crpi energije/premalo daje topline. |
#922 |
Postovi: 3,164
Jel netko testira SC 1.1.1 alpha nakon patchiranih servera? Kakvi su dojmovi? Ja sam jucer odigrao VS co-op, nije crklo prije kraja tj. nije me izbacilo, sto mi se prije redovito dogadjalo, ako bi uopce doslo do spajanja na server. Za vise testiranja nisam imao vremena. Ali sam primjetio da sam dobio (pre)malo RECova, buduci da smo bili samo dvojica i dosli do kraja. U 1.1je to bilo puno vise, cak i kad bi dosli samo do recimo wave 9.
#923 |
Postovi: 1,154
Možda su privremeno nerfali REC jer su pisali da će smanjiti kapacitete servera da bi lakše izvukli što više logova da što prije ispeglaju probleme. Uglavnom, stvari se lagano zahuktavaju: došao je prvi brod (gladiator) koji može preživjeti 4 talon rakete iz mog 325a. I onda nakon toga me raskečit po cijeloj mapi. ![]() |
#924 |
Postovi: 3,164
Jel netko igra SC uopce? Osim AC-a ![]() Serveri vise ne stekaju previse, a free flight multi zna bit jako zabavan (stopirao sam danas Auroru i provozao se lezeci u krevetu , provozao "suvozaca" u Cutlass-u kroz polje asteroida i sl.)
#927 | |
Datum registracije: Aug 2009
Lokacija: Otoče
Postovi: 65
Moj pledge (pun intended ) sa ovom igrom jest da ne instaliram ponovno dok ne čujem da su popeglali klijent odnosno da ne moram skidati 20GB nakon svakog novog patcha.To se možda promijeni ako izbace nešto ekstra što bi opravdalo skidanje te gomile nedovršenog koda. U svakom slučaju pratim novosti i ovdje na forumu pa ako ima nešto značajno - pokličite ! |
#928 |
Postovi: 3,164
Imam 315p i Cutlass-a ... iako su Hull-ovi cool, ne namjeravam igrati tu ulogu u SC niti namjeravam istresti još hrpu love za SC, imam i drugih troškova u životu. Sada mi je trenutno najbolja "fora" REC, pa se uvijek može iznajmiti nešto od opreme/brodova i isprobati. Između ostaloga, u FreeFlight multi-ju uvijek možeš sletiti uz nekog i isprobati tuđi brod (tako sam npr. isprobao Gladiatora )
#929 |
Postovi: 2,394
Gle, sve brodove će se i tako moći kupiti u igri kada napokon izađe. LTI priznajem da je dobra stvar, ali davati skoro 5000 kn (550$+pdv) za recimo Hull E LTI je glupost osim ako ne plivaš u parama. |
#930 |
Lokacija: Chernobyl NPP
Postovi: 4,777
Zato sam i odustao od kupnje ove igre sve dok ne izađe. Fuck that, za cijenu tih brodova (packova) si u rl pošten auto kupim ![]() Tko može nek pledga Drago mi je da će se kasnije free moći kupovat (ingame novcima).Zadnje izmijenjeno od: xGAME. 04.05.2015. u 11:58. |
