Staro 21.02.2015., 13:30   #1
Red Worm
Plasticni kirurg
Red Worm's Avatar
Postovi: 1,205
WD Caviar Blue 1 TB 7200 rpm HDD - Current Pending Sector
Imam Western Digital HDD, 1TB, 7200rpm, Caviar Blue,
HD Tune pokazuje žuto: (C5) Current Pending Sector 200 200 0 20 warning
Našao sam 4 kvadratića bad sektora (zeleno-žuta polja mi misu poznata). Disk mi je pun podataka. Garancija koliko vidim traje 24 mjeseca. Da ne povjeruješ istekla prije dva mjeseca (što čovjek može zaključit iz ovoga, ode garancija ode i hard u pm).
Što mi je činiti, jel se dadne kako popraviti HDD?
Može li mi tko dati dijagnozu prema analizi sa slika?
Hvala
Zadnje izmijenjeno od: igorba. 21.02.2015. u 19:39.
Red Worm je offline   Reply With Quote
Staro 21.02.2015., 17:07   #2
Red Worm
Plasticni kirurg
Red Worm's Avatar
Postovi: 1,205
Molim, ako netko može dati kakav odgovor...
Staro 21.02.2015., 17:56   #3
nino
nino's Avatar
Postovi: 12,602
Smanji gornju sliku. Toliki staz na forumu a ne cekiras disk sa WD alatom.
Data Lifeguard Diagnostic for Windows
Instructions
Download the Windows Data Lifeguard Diagnostics, WinDlg_v1_28.zip
Extract and run the program, WinDlg.exe. If running Windows Vista (or later), you will need to Right-Click on the WinDlg.exe file and choose to Run As Administrator.
Read and accept the license agreement to continue.
On the main program screen, there are two windows. In the top window, you will see the drives in your system that are available for testing. The model number, serial number, capacity, and SMART status of each drive will be displayed. In the bottom window, the partition information for the selected drive will be displayed.
Highlight the drive and select the icon on the top row to test or run SMART status.
When you select the run tests icon, the "DLGDIAG - Select an Option" window appears.
You will see the following options:
QUICK TEST - performs SMART drive quick self-test to gather and verify the Data Lifeguard information contained on the drive.
EXTENDED TEST - performs a Full Media Scan to detect bad sectors. Test may take several hours to complete depending on the size of the drive.
WRITE ZEROS - writes zeros to the drive with options of Full Erase and Quick Erase. File system and data will be lost.
VIEW TEST RESULT - displays the latest test results.
Select the test you wish to perform and click the Start button.
When the test completes, you will be notified with a pass/fail message. Click the Close button.
Staro 21.02.2015., 19:42   #4
igorba
igorba's Avatar
Datum registracije: Jul 2004
Lokacija: Đakovo
Postovi: 1,817
Nino sve rekao. Smanjio sam ti sliku. Ako imaš bitnih podataka na disku, prvo napravi backup (ako ga već nemaš), a zatim napravi test s WD DLG, bilo windows verzija, ili verzija na bootabilnom sticku/CD-u (npr. skineš Hiren's Boot CD, na njemu ima).
KANTA: Fractal Design Core 3000 - AMD Ryzen 7 5800X (w. Dark Rock 4) - Asus TUF Gaming B550 Plus - Sapphire RX570 ITX 4GB - 2×16GB Corsair Vengeance LPX DDR4@3600 CL16 - Corsair TX550M - Samsung 980 Pro M2 1 TB - Samsung 970 EVO Plus M2 2 TB - 2*WD Red Plus 4TB (WD40EFZX) - Monitor Dell S2721DGFA - Logitech G602 miš + Logitech Media 600 tipkovnica - Altec Lansing 221 zvučnici
igorba je offline   Reply With Quote
Staro 21.02.2015., 19:43   #5
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Sačuvaj važne podatke i odvrti HDDRegenerator (bude trajao jedno 2,3 dana ) ali možda izolira/popravi.
Staro 22.02.2015., 11:07   #6
Red Worm
Plasticni kirurg
Red Worm's Avatar
Postovi: 1,205
Ok, hvala za upute i sliku. Naime, imam takav ekran pa ne vidim da je rašireno. Nisam znao ovo za taj wd alat. Hvala.
Staro 22.02.2015., 12:37   #7
smirnoff
smirnoff's Avatar
Datum registracije: Dec 2009
Lokacija: nisam u ZG!!!!!!!!
Postovi: 1,191
evo može i sa WD toolem upisat sve "nule"...meni je tako pomglo sa 10tak BSa. sad je HDD bez njih.
za 1,5 TB upisivanje nula je trajalo cca 5,5 sati.
Staro 22.02.2015., 14:17   #8
Red Worm
Plasticni kirurg
Red Worm's Avatar
Postovi: 1,205
Da li postoji neki program s kojim bih otkrio koji su podaci u bad sektoru?
Hvala
Staro 22.02.2015., 16:01   #9
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
ne...a zašto bi to otkrivao?
i ovako i onako ako ideš popravljati disk, moraš sve sačuvati jer se cijeli disk briše...
Staro 22.02.2015., 18:53   #10
Red Worm
Plasticni kirurg
Red Worm's Avatar
Postovi: 1,205
Autor FRipper Pregled postova
Analizirao sa WD alatom, i javi da samo briše sve što je na bad sektorima.
Imam nekoliko starih ATA hardova, i svaki radi bez problema. A ove današnje tako ih prave da traju kratko tako da kupiš druge, nove. Govna
Zadnje izmijenjeno od: Red Worm. 22.02.2015. u 19:05.
Staro 22.02.2015., 21:24   #11
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,750
Autor Red Worm Pregled postova
Da, i ne samo to, nego mi se cini da tebe osobno mrze.
Programer
Staro 22.02.2015., 21:44   #12
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,208
Ne znam koliko bi vjerovao ovom wd alatu. Po njegovom scanu od prije nekoliko tjedana mi je prikazao da je sve ok sa diskovima, dok je recimo hd tune uredno prikazao smart errore te bad sectore. Diskovi su naravno bili neispravni
Spasavaj podatke dok mozes
Staro 23.02.2015., 11:36   #13
microsoft66
microsoft66's Avatar
Datum registracije: Apr 2008
Lokacija: VK
Postovi: 1,255
da se nisi stiso za 100 kn više bi još imao dvije godine garancije da si crnca uzo i mir
sad sve prebacuj i kad dobiješ CRC error negdje znat ćeš koji su podaci ležali na miniranom
