Staro 13.10.2014., 15:47   #1
lobo64
lobo64's Avatar
Postovi: 1,346
wireless 11 AD kuca na vrata
SAMSUNG objavio zanimljiv tekst:
http://global.samsungtomorrow.com/?p=43234
Staro 14.10.2014., 10:36   #2
D/G
D/G's Avatar
Datum registracije: Feb 2010
Lokacija: Ploče
Postovi: 1,186
..evo pročitah, napreduje tehnologija ..samo neznam koliki će problem biti sa prostiranjem signala jer za razliku od 2,4GHz tih 60GHz neide lako kroz zid
Staro 14.10.2014., 13:28   #3
lobo64
lobo64's Avatar
Postovi: 1,346
kopajući noćas malo dublje po temi, nađoh još sljedeće (google prevod sa njemačkog pa je gramatički i kontekstno samo približan):
"In the company's blog simply states that the use of the corresponding chip is planned in various devices that are to come, among other things from the fields of telecommunications and Smart Home. Contrary to the currently fastest standard 802.11ac, which reaches a maximum of 1,300 Mbits per second in practice, will allow about 6,900 Mbits per second, the successor from a standing start.
This is possible thanks to the operation in the 60 GHz band, but the one huge drawback involves. Because if there are obstacles between the transmitter to receiver, such as walls, the transmission rate drops relatively faster than networks in the 2.4 or 5 GHz range. Similarly, the maximum range is significantly lower with about 10 m. Both problems will be encountered with Beamforming, then the information on the possible range and data rates, but it does not reveal. Under optimal conditions, so Samsung could we but reach net rates of up to 575 MB per second with wireless ad.
As practicable, the new standard will be at the start of the appropriately equipped devices, is still difficult to estimate. For one thing, the binding conditions have not yet been determined, on the other ad-capable routers have not yet been announced."
vjerojatno je zamišljeno da cijela stvar radi preko uređaja sa većim brojem antena (4, 6 pa i više) kao i sa učestalijom upotrebom neke vrste ripitera/ekstendera.
ali, ako se samo približe najavljivanoj propusnosti od 575 MB/s, zbogom žicama u kući, i to ne samo prilikom distribucije pristupa internetu, nego si i vrlo lako mogu zamisliti NAS bežično.
ostaje nam samo čekati u nadi da će se uređaji brzo pojaviti na tržištu te da nećemo morati prodavati organe da bi si ih mogli priuštiti.
Staro 14.10.2014., 14:19   #4
domis
Lokacija: Hrvatistan
Postovi: 4,164
wireless je samo nužno zlo, ništa više
a toliko nakladanja još nisam vidio
575mb/s preko zraka, moš mislit
Staro 14.10.2014., 14:31   #5
lobo64
lobo64's Avatar
Postovi: 1,346
Autor domis Pregled postova
ej "stručnjak", kad već pljuješ, nauči barem razliku između Mb/s i MB/s.
Staro 14.10.2014., 14:39   #6
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,463
Da ti je netko pred 5-10 godina rekao da ces moci imati 10 MB/s, isto su svi govorili zice vise nece trebati Sve ide naprijed, ne samo wifi. Koliko bandwidtha treba vec sada za streamanje 4k materijala?
60 GHz je band dosta ogranicen svime, a za ovaj beam forming cu morat malo vidjeti po internetu kako oni to planiraju. Laicki, prebacili bi se sa omni antena na usmjereni prijenos. Tu se onda povlaci pitanje pracenja objekta, i koliko se zapravo efektivno dobije...
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 14.10.2014., 15:36   #7
lobo64
lobo64's Avatar
Postovi: 1,346
Autor Renesis Pregled postova
beamforming je prisutan već danas (vidi NETGEAR R7500, R8000, ASUS rtac87 itd.). čini se da radi preko algoritama koji mjere pokrivenost i kvalitetu signala te onda upravljaju radom antena. koliko znam, antene su i dalje omnice.
no, moguće je da će biti onako kako Ti kažeš, ta sada se još nezna točno, dostupne informacije su još prilično šture (ili ja neznam do njih doći).
naravno, to za sobom povlači pitanje ukupne propusnosti samih rutera: nekako sumnjam da će današnji gigabitni (SOHO) ruteri biti dovoljno snažni da proguraju silne megabajte bežično.
u svakom slučaju, u susret nam se valja uzbudljivo "bežično" vrijeme.
Staro 14.10.2014., 15:38   #8
domis
Postovi: 4,164
Autor lobo64 Pregled postova
tko pljuje? samo velim da su sve previše napuhali
btw.
Današnji SOHO switchevi ti imaju propusnost po 2gbps (ili 200mbps) po portu
današnji SOHO routeri ti nisu ništa više osim routera na kojeg ti je nakeljen switch
a i kao što rekoh - žica je zakon
Zadnje izmijenjeno od: domis. 14.10.2014. u 15:45.
Staro 14.10.2014., 15:53   #9
Postovi: 23,534
I opet sve miriše na podvalu i interes kompanija a ne malog čoeka
šta će mi "ludilo" brzina koja se može bacit do prve prepreke, logična posljedica dizanja frekvencije,
za primjer, zašto nisu "izmislili" standard u FI bandu koji se sada oslobodio prelaskom na DVB-T, a ne, to su ostavili za xy operatere ...
Staro 14.10.2014., 15:57   #10
lobo64
lobo64's Avatar
Postovi: 1,346
"rvacka" posla po cijelom svijetu, sunce im...
Staro 14.10.2014., 16:00   #11
syss
syss's Avatar
Postovi: 10,805
zato kaj za zaobilažnje te prepreke kupiš još jedan divajs pa onda neće bit prepreke i tako u nedogled
Staro 14.10.2014., 16:39   #12
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,774
Autor syss Pregled postova
I kako ti razmak izmedju divajsova tezi nuli tako dolazis do kabela
Staro 14.10.2014., 16:43   #13
Postovi: 23,534
Šuti tamo, neću politiku u moju butigu
Formula bi bila: cca beskonačno = žica
Staro 14.10.2014., 16:52   #14
lobo64
lobo64's Avatar
Postovi: 1,346
op, žica, žica, drma mi se tamburica...
Staro 14.10.2014., 17:22   #15
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Ako su postigli brzinu od 0.5GB/s bežično, recimo da imaš crno na bijelo prilikom prebacivanja datoteka tu brzinu, kako dosad tehnologija nije toliko napredovala pa da kroz CAT5e kabel guraju gotovo 5 puta manju brzinu od ~120MB/s, a za veće brzine rade SciFi kablove (CAT6,7,8)? Da, da, nije direktno usporedivo znam
Bez ulaženja u dubinu (možemo i to ako se ukaže potreba), moramo uzeti u obzir da, počevši od 11Mbps standarda nadalje, nikad nisi mogao imati maksimalnu propusnost makar bio u laboratorijskim uvjetima. Unutar tih 11Mbps (ili stavi brojku po izboru) se nalaze korisnički podaci koje prebacujemo + ogromna količina redundancije i ECC metoda. Ovaj ne-korisnički dio raste kako raste frekvencija kojom sustav komunicira, ali isto tako raste i s brzinom. Naravno, napredak tih metoda je neminovan, no nitko mi ne može prodati foru da ću prebaciti podatak s pol GB u sekundi kad znam da je i u idealnim uvjetima (laboratorijskim) ta brojka znatno manja, usudio bih se reći ispod 70% nazivne brzine.
Ubacimo u priču realnu situaciju, ne daj bože da dišeš kraj aparata i eto te na 50% brzine. Kamoli kad susjedi počnu kupovat nove ultrabrze routere
Nema kruha od wlana osim kad se mora, pa ne bi velike megalomanske firme vukle CAT5e po novim novcatim zgradama kad imaju 500MB/s wlan i cijena instalacija je 0.
Naravno, sad se dotičemo i onoga što je Renesis rekao, 4K streaming sadržaja. I dalje je najveći problem osigurati vezu do samog korisnika te brzine da bi mogli dalje pričati o LAN distribuciji takvog sadržaja
Bit će zanimljivo vidjeti kako će riješiti problem zidova opcorns:
Spoiler alert!
Staro 14.10.2014., 17:28   #16
syss
syss's Avatar
Postovi: 10,805
Autor rendula Pregled postova
ha čuj sigurno doma imaš više strujnih utičnica u zidu nego što imaš rj45
Staro 14.10.2014., 17:56   #17
domis
Postovi: 4,164
malo štemanja, bušenja, farbanja, 2-3 gigabitna switcha na lako dostupnim mjestima za zamijeniti ako krepaju i dam se kladiti da bi trosak bio i manji nego za...pa onaj linksys od 2 soma kunića
kabel imam, volje za bušenje i štemanje još nemam, al bude jednog dana
Staro 14.10.2014., 21:13   #18
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,463
OK nakon malo edukacije oko postojecih metoda beamforminga. postoje dva kampa:
1. fizicki beamforming kroz usmjerivanje antena
2. DSP beamforming gdje se kroz prilagodbu faze i amplitude signala dolazi do boljeg signala na mjestu receivera.
oba su zanimljiva, ali sa trenutacnim rjesenjima, nisu pretjerano djelotvorna.
Problem propagacije: 60 GHz nije bezveze "free" band, tu je taman negdje rezonancija molekule O2 (kisik, jel), i prilicno se gusi u atmosferi. U kucnoj upotrebi to nije veliki faktor, ali za wifi linkove na iole nekoj udaljenosti (100+ metera) je veoma velika prepreka.
Istina, i 2.4 GHz je taman rezonancija H2O, al ima daleko manje gusenje u atmosferi.
U kucnoj upotrebi 60 GHz ne penetrira prakticki nikakve prepreke ili to radi sa velikim penalima...
Staro 15.10.2014., 11:13   #19
lobo64
lobo64's Avatar
Postovi: 1,346
upravo si mislim da će tako i biti: već danas ima za kupiti pekove od po 5 komada AP-a za stropno montiranje. znači, jedan divajs po prostoriji, što opet postavlja pitanje same svrhe wless-a po kući pošto moraš vući barem jedan kabel od rutera do ap-a.
gledam malo NETGEAR R8000 koji je doduše "samo" AC standard, kada su mu antene uvučene u kućište, čini mi se da je konstruiran i/ili za stropnu montažu.
šteta da baš nema previše testova pa da se vidi koliko dobro slični uređaji bežično funkcioniraju.
Staro 16.10.2014., 15:04   #20
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Treba definirati što će njima biti djelotvorno. Primjerice, kod izrada baterija one nisu spremne za tržište dok nemaju iskoristivost od 99.999%. Dakle 99.99% iskoristivosti nije dovoljno da se tehnologija počne komercijalno primjenjivati.
Zato je pitanje: što u ovom slučaju djelotvorno znači? Je li to mogućnost primanja podataka na udaljenosti od XY metara uz 70% max BW ili na YZ metara uz 20% BW
H2O molekula u zraku ima znatno manje nego O2. Maseni udio vode u zraku može biti veći, no sam broj molekula ostaje manji. Svaki besplatni ili slobodni pojas je upravo besplatan jer je komercijalna primjena ograničena.
Fun fact: Intelov WiDi radi u 2.4GHz ili 5GHz pojasu, 1080p slika i 5.1 zvuk.
Čini mi se da će se za postizanje dovoljnog bandwitha za 4K ipak morati odvojeni standard koristiti u kojem se može lijepo definirati vrsta sadržaja, a ne općeniti wifi pa da kroz njega proturimo i 4K stream
Spoiler alert!
Staro 16.10.2014., 15:06   #21
lobo64
lobo64's Avatar
Postovi: 1,346
malo OT: koliki je bandwith uopće potreban za strimanje 4k videa?
Staro 16.10.2014., 22:28   #22
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Ovisi koje je kodiranje, kakav je chroma subsampling, a to sve ovisi zapravo o kojem se codecu radi, ali ajmo općenito:
4K TV standard je draftan ovako:
rezolucije 3840x2160 [X*Y]
broj bita po uzorku signala: 10bit [N]
max frequency 60Hz [f]
Eh sad, ne znam primjenjuje li se još uvijek ITU-R preporuka BT.601, ali recimo da vrijedi (može biti samo još zahtjevnije).
Signal se ne prebacuje u RGB obliku već se koristi luminantna (E’Y = 0,30⋅E’R + 0,59⋅E’G + 0,11⋅E’B) i dvije krominante komponente koje su razlika R i B signala respektivno i luminantne komponente.
To je tako jer se time ostvaruje najveći raspon signala tj. manja je šansa pogreške prilikom određivanja razine signala koji uvjetuje krajnji prikaz boja.
Najčešće strukture uzorkovanja su 4:4:4, 4:2:2 te 4:1:1.
Rezolucija pojedinog krominantnog signala u relativnom odnosu s rezolucijom luminantnog signala je ovakva[%]:
Horizontalna[pX*100]/Vertikalna[pY*100]
4:4:4 100/100
4:2:2 50/100
4:2:0 50/50
4:1:1 25/100
Sličice će pomoći razumjeti:
Uz to sve postoji još nešto što se zove vertikalni potisni interval koji su zapravo nevidljive linije u slici i služe sinkronizaciji slike prilikom refresha, ali to ćemo sad zanemariti, ionako postoji dovoljno pixela u slici da dobijemo impozantnu brojku bandwitha.
Kalkulacija ide kako slijedi, R je bandwith:
R=X*Y*f*N+X*pX*Y*pY*f*n *2
Drugim riječima, za gore navedenu rezoluciju bez VPI, uz 4:2:0 ili 4:1:1 i ajmo pretpostaviti "i" standard (interlacing, duplo manje sličica u sekundi, naizmjence se prikazuju parni i neparni dijelovi jedne slike) dobije se 444.95MB/s.
Ovakvo kodiranje se koristi kod h.264/AVC codeca.
Naravno, pošto su dosta škrti s informacijama online oko novog ultraHDTV standarda, ne mogu biti siguran da je to ta brojka. Moguća je blaga korekcija ovisno o promjeni tipa kodiranja, ali sam siguran da ispod 300MB/s neće ići, običan 720p s 8bit po uzorku traži preko 20MB/s.
E a sad dolazi ono glavno, a to je što nama prodaju pod HD i 4K sadržaje koje možemo streamati sa youtubea ili netflixa: dobivamo okljaštrene verzije izvornog h.264 kodiranja.
Ono što se događa je da se svaka slika još dodatno komprimira na temelju detekcije redundancije i ponavljanja sadržaja i bla bla bla, mogo bih doktorat na pola napisati.
TL;DR: evo kalkulatora sadržaja za do HD rezolucije, nemojte zaboraviti h.264 odabrati, znatno manje bandwitha cucla
http://www.stardot.com/bandwidth-and-storage-calculator
Spoiler: jako dosadan tekst.
4:4:4 100/100
4:2:2 50/100
4:2:0 50/50
4:1:1 25/100
Spoiler alert!
Staro 16.10.2014., 22:57   #23
lobo64
lobo64's Avatar
Postovi: 1,346
hvala De5tr0yer.
Staro 17.10.2014., 00:32   #24
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,759
Pa obzirom da vec sada LTE ide do vrlo pristojne brzine od parsto megabita (s nekakvom nadogradnjom i do GBps downstream), ne bi me cudilo i da ovakvo nesto realiziraju kroz koju godinu...
Programer
Staro 17.10.2014., 01:06   #25
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Autor Bubba Pregled postova
Te se tehnologije LTE-a isto ostvaruju pomocu beam forminga i/ili upotrebom velikog broja mikroćelija te dinamičnom raspodjelom kanala među korisnicima što može rezultirati prilično visokim brzinama uz obveznu statičnost receivera. Načelno, razlika je "samo" u frekvencijskom pojasu rada.
Spoiler alert!
Staro 18.10.2014., 02:06   #26
Old friend
Postovi: 432
Može zrak (LTE) samo zavisi kako je netko pokriven.
Paralelno moraju i dalje raditi na pokrivenosti, kapacitetima a ne samo brzinama.
Old friend je offline   Reply With Quote
Staro 18.10.2014., 11:49   #27
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Problem pokrivenosti/kapaciteta neminovno povlači broj repetitora/baznih stanica, povećanje broja ćelija i smanjenje opsega ćelija. To košta u infrastrukturi ali se trebaju paziti i zakonske granice zračenja koje su prilično niske s obzirom na nizak rizik ovog oblika zračenja (sunčevo zračenje je štetnije).
Pošto se povećanjem frekvencije penetracija signala u materijal smanjuje, da bi zadržali istu razinu signala morali bi povećati snagu zračenja. To je vrlo nepraktično za korištenje u kućnim okolinama jer bi trošili previše energije za pokretanje takvih uređaja. Iz istog razloga je upstream link kod svih oblika komunikacije (xDSL, optika, kabel) na nižoj frekvenciji nego što je to downstream od operatera (centrale).
Spoiler alert!
Zadnje izmijenjeno od: De5tr0yer. 18.10.2014. u 21:36.
Staro 18.10.2014., 18:38   #28
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 5,826
Po meni oni napreduju u malo krivom smjeru, ako mene pitas radije 200m s preprekama na 50Mb nego 20m sa 500Mb, jbt u kuci iman tri repeatera za wlan...
OuttaControl je online   Reply With Quote
Staro 18.10.2014., 19:33   #29
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,463
veci bandwidth prometa zahtjeva veci frekvencijski raspon po kanalu. 100 MHz od 2,4 Ghz ili 100 MHz od 60 GHz i nije isto
Staro 18.10.2014., 19:51   #30
D/G
D/G's Avatar
Lokacija: Ploče
Postovi: 1,186
...pa normalno za očekivati ako ostave modulaciju kao kod 2,4 i 5 GHz da neće kanal biti 20MHz ( n-mod 40MHz) već će to biti za veliku brzinu prijenosa podataka po kanalu oko 500 MHz i više
....i zaboravite koaksijalne kablove do antena...ni valovod neće na tim frekvencijama biti primjenjiv za privatne kupce , a to znači da će uređaj morati imati antene unutrašnje.
Zadnje izmijenjeno od: D/G. 18.10.2014. u 20:00.
