Povratak   PC Ekspert Forum > Računala > Mobilno > Tableti
Staro 29.11.2013., 20:52   #2551
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Autor Mar Pregled postova
Što mislite o Prestigio PMP5780D.
Evo ti moj kratki review.
Za custom rom ne znam, iako aktualni bi bio 4.4, tak da čisto sumnjam. Sa Rockchipom je puno teže s romovima, a mislim da je to još uvijek rockchip.
Za 900kn je ok. Za mene to nije bilo.
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
Zadnje izmijenjeno od: estugarda. 29.11.2013. u 21:03.
estugarda je offline   Reply With Quote
Staro 01.12.2013., 11:43   #2552
zokisan
Datum registracije: Jun 2011
Lokacija: Slavonija
Postovi: 46
Vivax TPC-7151
U sebi ima ugrađen wifi, no da li se putem usb sticka može spojiti na edge/3g/4g mrežu?
hvala.
zokisan je offline   Reply With Quote
Staro 05.12.2013., 01:53   #2553
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Samsung Galaxy Note 10.1 2014 edition P600 (wifi only, 16gb) kod nas 4100-4400kn. Puno previše za najslabiji model. Sad mi nije toliko žao što nisam čekao i nedavno uzeo par tjedana star n8010 za ravno duplo manje...Ne vrijedi FullHD toliko...
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 05.12.2013., 07:53   #2554
Postovi: 34,005
Staro 07.12.2013., 09:25   #2555
imaticx
Default
imaticx's Avatar
Lokacija: Požega
Postovi: 1,516
Prodajem iPad 2 posto ga vise ne koristim toliko, a ni nemam vise vremena. Ali ipak bi si uzeo neki tablet do max 500 kn, ako zatreba nekad. Koji je best buy u toj kategoriji? Mislio sam neki 7''. Sad ide Bozic pa ce biti dosta popusta, i sad je najbolja prilika za ugrabiti nesto
Staro 07.12.2013., 12:06   #2556
Postovi: 34,005
Imaš na oglasniku dosta povoljnih, a nekorištenih Vivax TPC-7151. Cijena jest malo veća od tvog limita, ali...
Ako nisi zahtjevan korisnik imaš na t-scum akciji Vivax TPC-7125 3G za 500kn sa Simpa karticom i 2Gb prometa. Ima samo 512Mb i to mu je mana.
Staro 07.12.2013., 14:19   #2557
Mar
Suit up!
Mar's Avatar
Postovi: 5,969
Meni zapeo Dell Venue 8 Pro, ako imate fizički pristup MS Storeu, može se kupiti za 99$.
- Barney Stinson
Mar je online   Reply With Quote
Staro 07.12.2013., 16:19   #2558
antebr
antebr's Avatar
Postovi: 421
Odlicna cijena.
Da imam nekoga u US kupija bi ga odma.
antebr je online   Reply With Quote
Staro 07.12.2013., 21:31   #2559
imaticx
Default
imaticx's Avatar
Lokacija: Požega
Postovi: 1,516
Autor coconut Pregled postova
Za ovaj prvi ne mislim toliko davati, a drugi ako je spor, isto otpada.
A ovaj u Tisku?
Staro 07.12.2013., 22:06   #2560
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,567
Za 500kn nećeš ništa bolje dobit.
Možad ima kakav Prestigio rabljeni, ali isto ništa puno bolje.
Ili povećaj buđet, ili smanji očekivanja
Staro 07.12.2013., 22:22   #2561
fanATIk
NITKOV
fanATIk's Avatar
Lokacija: Zagreb / Maksimir
Postovi: 4,007
Za neke sitne novce mogu nabavit izvana samsung galaxy tab 8.9. Jel valja to čemu pošto nisam baš na ti s tim stvarčicama?
Asrock FM2A78M-DG3+
G.SKILL RipjawsX series 8 GB
Palit GTX 460
Corsair VS550
Thermaltake Core V21
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Canon CanoScan 4400F
Win 10
Unique case by fanATIk
Avatar BIG SIZE
Staro 07.12.2013., 22:25   #2562
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,567
Ovisi za kolko jer je već dvije godine taj model vani.
Al za kućno korištenje, malo gubljenja vremena na njemu će bit dobar.
Staro 08.12.2013., 01:43   #2563
doctorg
Lokacija: KC
Postovi: 50
Ima li ovdje vlasnika galaxy tab 2 10.1, a da su primjetili u mraku screen bleeding čak i na manjem brightnessu? (na maksimumu je još više izraženije).
Pitanje je također upućeno i vlasnicima svih ostalih tableta što se tiče bleedinga, ili je recimo ista stvar kao i kod monitora, jednostavno bleeding je pristuan od panela do panela i tu nema prevelike pomoći.
uređaj je prilično nov (dobiven na nagradnoj igri, 30.9, ali je tek upaljen prije 2 tjedna), ovl. servis je ni manje ni više nego Agram
prilažem i sliku, nažalost slikano mobom jer nemam drugo sredstvo, pa ne znam koliko bude vjerodostojno.
http://i.imgur.com/7mTKCNe.jpg
hvala,
lp
doctorg je offline   Reply With Quote
Staro 08.12.2013., 11:33   #2564
chief_wolfinjo
bok,
kaj mislite o ovome : https://www.hrvatskitelekom.hr/mobit...rollTo=detalji
to bi danas naručio.
čini mi se odličan deal. ima 3g, gps, wifi. 2 godine garancije
nije baš za ekstremni gaming, ali za večinu toga je dobar
kaj vi velite na to ?
i koji je to točno vivax model ?
Staro 08.12.2013., 11:41   #2565
lowrider
lowrider's Avatar
Lokacija: KR
Postovi: 1,167
Ček to je na bonove cijena, bez pretplate?
Staro 08.12.2013., 11:44   #2566
chief_wolfinjo
da na bonove. sada sam ih pitao.
to je VIVAX TPC-7125 tablet.
Staro 08.12.2013., 12:06   #2567
Zvone2772
interferometar
Zvone2772's Avatar
Postovi: 768
Čisto u redu, kad pogledaš - samo GPS navigaciju bi više platio.
Ne vidim kako se može pogriješiti s tim uz takvu cijenu
Zvone2772 je offline   Reply With Quote
Staro 09.12.2013., 11:35   #2568
fanATIk
NITKOV
fanATIk's Avatar
Postovi: 4,007
Autor Juice Pregled postova
Ma veličina ekrana mi je ok, nit premali, nit prevelik. Dualkorac je, giga rama, nadogradiv na ICS. I klinci će na njemu igrat igrice, ić na fejs i slične pizdarije. Valjda će bit dobar.
Asrock FM2A78M-DG3+
Palit GTX 460
Corsair VS550
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Win 10
Avatar BIG SIZE
Staro 10.12.2013., 21:39   #2569
sodom
sodom's Avatar
Postovi: 593
Autor sodom Pregled postova
Nakon manje od dva mjeseca imam zanimljiv problem sa tabletom. Asus MemoPad FHD10. Pola ekrana je jednostavno prestalo radit, tablet nije padao, nije rootan, sve original i jučer kada sam ga zapalio imam kaj za vidjet.
Evo kako to izgleda: https://lh6.googleusercontent.com/e0...YwS2grkfnYAfA4
Znači slika prikazuje ugašen tablet na punjenju.Probao Factory reset, sve živo ali nema pomoći. Slika se ponekad na sekundu zna pojavit pa nestane, uglavnom je polovica ekrana stalno crna a ponekad iskaču artefakti. Kao da iznutra nešto gubi kontakt.
Nosim na servis danas popodne pa eto samo da vidite čega sve ima
Danas dobio tablet nazad nakon 14 dana, kažu : tablet ispravan.
I stvarno sve radi, barem u zadnja 2 sata otkako ga koristim. Ima li itko ideju što je ovo bilo...bolje pitanje hoće li se ponovit?
Da citiram sam sebe, bit će lakše objasnit situaciju. Dakle tablet je uredno radio nekih 14 dana i onda se problem počeo ponavljat. Snimio sam video o čemu se točno radi:
https://www.youtube.com/watch?v=FtQdfpLLcB0
Jeli problem softverske ili hardverske prirode neznam sa sigurnošću ali izgleda da naginje na ovo drugo. Mislim si eventualno pričekat da Asus izbaci novu verziju firmwarea pa vidjet ima li promjena ...ali zeznuto je to kada želiš koristit uređaj a nejde.
Vjerojatno ću im vratit nazad to na servis sa snimljenim videom (da i sami vide o čemu je riječ jer se navodno to tamo nije događalo) no zanima me bilo kakav prijedlog što mogu sam probat prije toga , ako netko ima kakav savjet bilo bi super....
Zadnje izmijenjeno od: sodom. 10.12.2013. u 21:49.
sodom je offline   Reply With Quote
Staro 10.12.2013., 21:54   #2570
raliSHA
raliSHA's Avatar
Datum registracije: Feb 2010
Postovi: 971
opala, zanimljivo: http://www.androidcentral.com/lg-ann...urce=pulsenews
kraj nexusa 7 i 10 sad imamo i "nexus" 8.3
raliSHA je offline   Reply With Quote
Staro 11.12.2013., 09:31   #2571
Postovi: 34,005
Taj tablet nema veze s Nexusom. To ti je isto kao da kažeš da su S4 GPE i HO GPE Nexusi. Radi se o LG 8.3" tabletu.
Staro 11.12.2013., 15:56   #2572
9800pro
aka Edo, aka Syncros
9800pro's Avatar
Postovi: 1,776
Nemaš tu kaj, očito je nešto hardwerski zmrdano.
Nosi ga u servis sa filmićem...
Staro 11.12.2013., 16:00   #2573
sodom
sodom's Avatar
Postovi: 593
Autor 9800pro Pregled postova
Je, već sam ga ostavio jutros. Napravio reset , obrisao sve ikone sa desktopa osim jedne - Gallery na koju kad kliknu počne video sa gornjeg linka.
Ako ga sad vrate i kažu da je ispravan onda stvarno
Staro 11.12.2013., 18:26   #2574
raliSHA
raliSHA's Avatar
Postovi: 971
Primijeti navodnike
a i neka nema, ovako bar ima sd slot
Staro 14.12.2013., 20:15   #2575
fishkal
fishkal's Avatar
Datum registracije: Dec 2009
Postovi: 1,116
Ekipa imam pitanje pa da postavim u ovoj općenitoj temi.
Radi se o tabletu Prestigio quantum multipad 4. Tablet je star mjesec dana, nije nadrobljeno puno aplikacija i jako fino radi, fluidan je otvara brzo aplikacije.
Problem nastaje kad se nešto skida preko wifija i pokuša se još nešto raditi. Naime, stavio sam skidati speedtest aplikaciju, i dok se navedena skida sam pokušao otvoriti neke aplikacije, i tablet se jednostavno usporio, i dok nije skinuo zadano nije mogao otvoriti aplikaciju. Ista je stvar kad se skidaju npr. Torrenti. Ništa drugo nije moguće raditi jer je nevjerojatno spor. Molim za neki savjet.
Gledam, čitam, kad ne znam pitam!
fishkal je offline   Reply With Quote
Staro 15.12.2013., 11:10   #2576
Zvone2772
interferometar
Zvone2772's Avatar
Postovi: 768
Autor fishkal Pregled postova
Opa, rings a bell. Nisam mislio da su svi modeli takvi, no priča ide ovako...
Naime, imam 9.7 Ultra Duo s 16GB memorije i isto tako, kad on nešto radi (najgore je kad zapisuje) multitasking je koma i usporen. Svi su takvi, pa do te razine da je na jednoj stranoj (co.uk) recenziji to bilo napomenuto.
To vole prešutiti, a mislim da je stvar u kontroleru NAND-a, odnosno flash memorije. Ne voli multitasking.
Tako da te moram razočarati, takvi su izgleda svi i mislim da im ne možeš ništa jer je uređaj ispravan. To što oni ugrađuju unutra zadnje smeće od komponenata, to je druga stvar.
Sad mala digresija, oprosti:
Mene više razočaravaju "domaće" stranice koje se bave recenzijama jer su oni ti koji bi to korisnicima trebali napomenuti, ali te recenzije očigledno ostaju beskorisne jer ne napominje ključne nedostatke a ostalim testovima pristupaju krajnje amaterski. Recimo baš taj "quantum" je nedavno recenziran i niti u jednoj domaćoj recenziji nisam našao da su spomenuli taj problem, a nadao sam se da su ga ispravili.
Staro 15.12.2013., 12:03   #2577
fishkal
fishkal's Avatar
Postovi: 1,116
Pa zato sam ga i preporučio šogorici jer je odlično konstruiran, fenomenalan ekran i fluidan u radu. Pročitao par recenzija, svi hvale. Probao ga uživo u emmezeti i činio se ok. I sve stvarno super osim toga kad nešto skida, ona može zaboraviti korištenje za kaj drugo. Kontaktirat ću ja prestigio.
Staro 15.12.2013., 13:55   #2578
9800pro
9800pro's Avatar
Postovi: 1,776
Dečki mala pomoć, danas bi išao uzet Asus Memo Pad HD 7.
Jel ga ima tko, jel dobar. Po recenzijama ispada za tu lovu super (cca 1300 kuna)...
Sada imam Pipo S3 i na prvu je dobar ali ispada da nije. baterija traje 3 sata, puni se 3 sata, svako malo se restarta sam od sebe a dođe 800 kuna (u Chipoteci 700 na akciji).
Rađe dam malo više al da znam da sam miran za ubuduće. Namjena čitanje knjiga, web, XBMC daljinski i možda kakva igrica za WC
Staro 15.12.2013., 16:48   #2579
fishkal
fishkal's Avatar
Postovi: 1,116
Autor Zvone2772 Pregled postova
A kako bi bilo da se stavi da sva skidanja idu na microsd karticu, class 10? Možda bi to riješilo problem. Nemam trenutno takvu karticu, jesi možda ti probao?
Staro 15.12.2013., 17:04   #2580
Zvone2772
interferometar
Zvone2772's Avatar
Postovi: 768
Nisam probao, ali ako će riješiti - riješiti će problem samo kod downloada.
Osobno ne koristim tablet za skidanje ogromnih količina podataka, već samo za čitanje i kao drugi display, pa mi se problem ne manifestira često.
Za sve ostale situacije, npr. ažuriranje aplikacija na Play Storeu ili neki intenzivniji multitasking ne vjerujem da će biti pomaka.
