Staro 11.09.2013., 23:43   #1
(riješeno) Problem: Mreža zeza sve u 16 - WinSock problem
Daklem, prvo mi se izbacio "WSAStartup() failed, or you have the incorrect version of winsock installed."
Nakon toga, kad sam htio pokrenuti Firefox izbacio je ovo: "WSAStartup() error"
Nije bilo konekcije sa interenetom.
Nakon toga, napravio sam ručno čišćenje tog sranja ovako:
  1. 1
    Go to Start>Run, type in: netsh int ip reset c:\resetlog.txt
  2. 2
    Restart your computer and you're done.
  3. 3
    Follow the steps below if you have XP SP2 (this only works on windows XP SP2 and later).
  4. 4
    Go to regedit.
  5. 5
    Go to HKEY_LOCAL_MACHINE/System/CurrentControlSet/Services
  6. 6
    Click on Winsock and Delete.
  7. 7
    Click on Winsock2 and Delete.
  8. 8
    Close registry.
  9. 9
  10. 10
    Go to properties of Local Area Connection
  11. 11
    Click on the Install button in the Properties window
  12. 12
    Choose PROTOCOL, then click on ADD button.
  13. 13
    Click on HAVE DISK button...
  14. 14
    Type in C:\windows\inf\nettcpip.inf in the dialog box and click OK.
  15. 15
    Choose from the list INTERNET PROTOCOL TCP/IP in the list, and click OK.
  16. 16
    Click CLOSE.
  17. 17
    Reboot your computer.(At this point the Winsock is complete however to not only prevent this problem from happening in the future but also to make the process a lot easier you should update Windows.)
Nakon toga, Internet je proradio, ali Torrenti ne rade nikako, samo piše hostname not found (ne može se nakačiti na tracker), ne mogu pingati tracker, a ne radi ni Windows update.
Zna li netko od vas mrežnih stručnjaka šta o ovome? Mreže su mi najtanje područje.
Staro 12.09.2013., 00:21   #2
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,800
Nadji negdje odgovarajucu (ispravnu, prije svega) Ws2_32.dll knjiznicu pa ju prekopiraj u system32 folder. Koliko sam shvatio, imas WXP, pa pokusaj s ovom verzijom iz privitka.
ws2_32.zip
To bas nije lijepi error koji ti baca, nesto gadno ne valja s tom masinom i ne vjerujem samo da je stalo na WinSocku... :\
Programer
Staro 12.09.2013., 00:22   #3
Win7 x64 je u pitanju.
Staro 12.09.2013., 08:23   #4
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
ako me pamćenje dobro služi, baš sam na jednoj win7 x64 takav slučaj riješio s nekakvim MS winsock fix tool ili tako nešto.
Zadnje izmijenjeno od: tor. 12.09.2013. u 08:29.
Staro 12.09.2013., 08:44   #5
Autor tor Pregled postova
ajd molim te sjeti se koji je to tool neda mi se reinstaliravati mašinu, imam pametnijeg posla nego izgubiti popodne na reinstall i vraćanje starih postavki
Staro 12.09.2013., 09:09   #6
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
si lud, pa nemam ja više 18
Mislim da je bilo ovo ali nekako mi smrdi da tebe *ebe nešto drugo sad. Ili si nešto pobrao ili je mašina u gadnom neredu Zguglaj malo ovaj problem s torrentima, u dosta slučajeva je neka napast. Jesi izvrtio kakav AV alat ili malwarebyts i slično?
Staro 12.09.2013., 09:14   #7
Ma kaka napast. Imam legalni BitDefender total internet security 2014 tako da ne vjerujem da je nekaj pobro... Nisu detektirali ništa, ni BitDefender ni Malwarebytes.
Staro 12.09.2013., 11:15   #8
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,800
Nadji onaj DLL za W7 pa ga presnimi u isti folder.
Kao sto sam rekao, mislim da je tu nesto vise od virusnog pitanja - jesi provrtio malo Memtestove, nesto za precekirati disk i slicna zezanja? Osim hardverske greske ili nekog ruznog virusa, ovakve stvari ti se ne smiju dogoditi, jer jednostavno znace da je taj DLL koruptiran, za sto nema nekog pametnog razloga...
Programer
Staro 12.09.2013., 11:22   #9
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
korupt winsocka na 7-ci i nije tako rijedak problem kako misliš...Ne sam od sebe naravno, no ima dosta stvari koje ga mogu zeznuti, mislim da je bila i nekakav virusčina s tom namjenom baš.
Staro 12.09.2013., 11:26   #10
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,800
OK, to ne sumnjam, ali jedini nacin da ga "pokvaris" je da nesto zamijenis/promijenis/sjebes s konkretnim DLL-om.
Sad, jesu li veseljaci virusopisci odlucili iz nekog razloga gaziti po tim fajlekima, ne znam, ali covjek kaze da virusa nema - onda je to vec ozbiljniji problem.
Programer
Staro 12.09.2013., 11:43   #11
OK, di da nađem taj DLL, tj. koji je naziv tog DLL-a? Ako to ne pomogne, reinstall mi ne gine danas popodne.
BTW; nije ardverska greška. Sve je tip top...
Zadnje izmijenjeno od: Brko. 12.09.2013. u 11:51.
Staro 12.09.2013., 11:58   #12
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
To stoji...iako ja i dalje sumnjam na zarazu
Staro 12.09.2013., 12:17   #13
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,800
http://forum.pcekspert.com/showpost....83&postcount=2
Programer
Staro 12.09.2013., 12:48   #14
Aaaaaa... ja mislio... aaaaaa mislih da je to samo za XP. Budem probo popodne da se javim.
Ako imaš još koji predlog ili se sjetiš nećeg, nemoj se sramiti reći.
Staro 12.09.2013., 15:33   #15
Postovi: 23,623
Opće poznato da gomila smeća / nametnika prčka po winsock - u, bilo po fajlovima ili registriju.
Odradi ovu proceduru na dnu stranice > http://answers.microsoft.com/en-us/w...e-a8487391b151
U vezi wsock32.dll fajla, pod uvjetom da reinstall tcp/ip protokola ne odradi šta treba predlažem:
- nađi na drugom kompu / lapu, vidi da je ista verzija
- da te os ne bi za * * * o digni neki Win ili Linux Live i kopiraj file
- osim standardne lokacije u Windows\System32 kod x64 verzije trebao bi postojati Windows\SysWOW64 pa file i tu kopiraj
evo zgodnog tumačenja gdje šta ide ovisno o x32 ili x64 verzija > http://www.samlogic.net/articles/32-...6-syswow64.htm
Staro 12.09.2013., 15:46   #16
Donju proceduru sam odradio. I dalje isto.
Budem ovo probao, ako ovo ne uspije, ide reinstall majke mu ga spalim... kako mi se to nedaaaaa
Staro 12.09.2013., 17:35   #17
Hvala svima na pomoći no radim reinstall mašine tako da niš o istraživanja
Staro 12.09.2013., 19:46   #18
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
buuuu, amateru prokleti
Staro 12.09.2013., 19:52   #19
syss
syss's Avatar
Postovi: 10,805
pkk
Staro 12.09.2013., 22:57   #20
Haha, da se nebi patio. Imam SSD i USB Butabilni. Instalacija je gore za 5 minuta
Staro 13.09.2013., 00:22   #21
Forace
Lokacija: Petrinja
Postovi: 1,604
Sad je za 5 minuta par postova prije je bio gubitak cijelog popodneva ... koji upgrade. Koliko vidim win 7 je pa probaj onaj njegov wizard za prijenos postavki i datoteka, koristio sam to jednom i ugodno me iznenadio.
Forace je offline   Reply With Quote
Staro 13.09.2013., 07:26   #22
Autor Forace Pregled postova
Mah, kad si len onda ti je i 5 minuta celo popodne nažalost nisam se sreo sa tim alatom. Ručno sam vratio postavke nekih programa i igara u app data i to je to.
Staro 14.09.2013., 13:15   #23
Postovi: 23,623
I sad kad sve složiš i podesiš napravi backup system particije nekamo, npr. zadnja data particija.
Kada opet skršiš winse onda se za x min vratiš u operativno stanje a ne da ko njub radiš reinstal.
Staro 14.09.2013., 13:17   #24
Autor Nikky Pregled postova
Neda mi se. ovako svaki puta si dam zanimaciju da vidim kaj instaliravam gore i kaj me od zadnji put je treba. Jednom godišnje je to zdravo
Ali čiste winse i drivere imam image backup
Staro 14.09.2013., 15:25   #25
Postovi: 23,623
Pa eto, imaš barem start, iza toga "peglaj" dodatne programe.
Staro 16.09.2013., 12:25   #26
Eto, čisto za info. Saznao sam što se dogodilo. Wondershare MobileGo for Android je zasro motku. Njegov WShelper.exe je poseksao winsockove i ostalo je povijest.
A zdrkalo se tako jer sam išao gaziti prastaru verziju tog programa sa najnovijom. Pa su se našla 2 ta helpera.exe koji su to zdrkali.
Probao sam opet bezveze na testnom kompu na čistoj sedmici i dogodilo se isto. Nakon repaira radi net ali ne torrenti.
Tako da se zna...
Staro 16.09.2013., 12:38   #27
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
ajd super, dobro da si skužio
Staro 16.09.2013., 12:48   #28
U par navrata na gugletu sam vidio da wondershare aplikacije znaju zdrkat to jer koriste te sockse za nešto (neću o tome jer se ne kužim). A ja sam imao njihovu aplikaciju pa reko da probam isto. I voila - ode sve u ku..c
