Staro 19.06.2013., 21:49   #361
nino
nino's Avatar
Postovi: 12,613
Melbourne F1 2013 speed comparison
Staro 21.06.2013., 14:38   #362
Baja 001
Baja 001's Avatar
Postovi: 7,504
Renault Energy F1, 2014 F1 engine
Renault have revealed the engine which their teams will use during the 2014 F1 season.
The 2014 season will see teams ditch the existing 2.4-litre V8 normally-aspirated engines for new 1.6-litre V6s with sophisticated energy recovery technologies.
President of Renault Sport F1 Jean-Michel Jalinier introduced the new power unit, named Energy F1: “From next year, one of greatest challenges in F1 will be to maximise energy efficiency and fuel economy while maintaining the power output and performance expected of F1 cars.”
“Renault has pioneered this technology in its road car engine range with the Energy series. Naming the power unit Energy F1 creates an unbroken range, from the Clio through to our competition department.”
Renault engines have powered the world championship-winners for the last three seasons. They will continue to supply reigning champions Red Bull next year as well as Toro Rosso.
The complete engine unit for 2014 will be heavier than the current design, as director of programmes and customer support Axel Plasse explained:
“The current V8 is 95kg, 100kg if you add the weight of the MGU. This increases to 120kg when you include the ancillary parts, such as the radiators and other cooling devices. With the 2014 power unit, the V6 turbocharged engine will be a minimum of 145kg, plus 35kg for the battery. At 180kg, this is a 80% increase over the current units, plus a further 20kg for the ancillaries such as the intercooler and other radiators.
In response to speculation over how the new engines will sound, Renault have released an audio clip of theirs being revved. Deputy managing director (technical) said the engine will retain an appealling sound: “The sound of the engine is the sum of three principal components, exhaust, intake and mechanical noise. On fired engines, exhaust noise dominates, but the other two sources are not trivial and would be loud if the exhaust noise was suppressed and contribute to the perceived sound of the engines in the car.
“All three sources are still present on the V6. At the outset, there is more energy in each combustion event but there are fewer cylinders turning at lower speed and both intake and exhaust noise are attenuated by the turbo. Overall, the sound pressure level (so the perceived volume) is lower and the nature of the sound reflects the new architecture.
“The car will still accelerate and decelerate rapidly, with instant gearshifts. The engines remain high revving, ultra high output competition engines. Fundamentally the engine noise will still be loud. It will wake you from sleep, and circuit neighbours will still complain. The engine noise is just a turbocharged noise rather than a normally aspirated noise: you can just hear the turbo when the driver lifts off the throttle and the engine speed drops.
“I am sure some people will be nostalgic for the sound of engines from previous eras, including the preceding V8, but the sound of the new generation Power Units is just different. It’s like asking whether you like Motorhead or AC/DC. Ultimately it is a matter of personal taste. Both in concert are still pretty loud.”
via F1fanatics
Pohrani.com Pohrani.com Pohrani.com Pohrani.com
_____
@Nino
Formula 5 krugova (kratkih), MotoGP 4 kraljica brzine!
Staro 21.06.2013., 22:23   #363
begi
begi's Avatar
Datum registracije: Apr 2011
Lokacija: Usa
Postovi: 628
@ Baja 001
Koliko me sjećanje služi nekad su pravili najače turbo motore. Još akoo Kimi pređe u RB, šta će da rade mali i on.
Mercedes i Pireli samo opomena. Iako su to velike ekipe, drago mi je, radi razvoja F1.
begi je offline   Reply With Quote
Staro 21.06.2013., 22:32   #364
Postovi: 8,216
Samo što to opet neće biti najjači turbo motori, već neka dovoljna/potrebna snaga koja će izdržat xy utrka. Spominje se nekih 600ks+180strujnih. Sve je to malo naspram prije, 900-1k
Ovo za gume i kazne su smješne, no FIA, odnosno sud nisu praktički ništa mogli pošto je pirelli izjavio da ih boli k i da neće platit ništa, a momčadi isto nisu pod nikakvim ugovorom.
Staro 21.06.2013., 23:33   #365
listerstorm
listerstorm's Avatar
Postovi: 1,429
Eh, kad se sjetim McLaren MP4/13 dominacije.
Staro 22.06.2013., 09:26   #366
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor Pupo Pregled postova
Da, moglo bi bit nešto manje KS (od današnjih) ako se gleda 1.4 koeficijent (N/A vs forced), ali i dobro je da motore ne minjaju ka gume... Inače bi volio vidit V10 (<3L) s turbom, i slick gume naravno i downforce prije 10 godina
Redikuli, nema više pojma ni FIA šta se smi a šta ne...
Staro 22.06.2013., 09:42   #367
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
Samo što to opet neće biti najjači turbo motori, već neka dovoljna/potrebna snaga koja će izdržat xy utrka. Spominje se nekih 600ks+180strujnih. Sve je to malo naspram prije, 900-1k.
Prije su imali jednu turbinu samo za kvalifikacije gdje su motori razvijali oko 1500 ks. Turbina se poslje kvalija mogla samo bacit u staro željezo.
Turbo rupu su eliminirali na način da već u pola zavoja opizde gas i drže kočnicu kako bi nabili pritisak.
Sick stuff. Nekad je sve bila mehanika i rad nogu i ruku, a sad će uskoro tipkovnicu dobit u ruke i nek voze.
Staro 22.06.2013., 09:47   #368
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor Blue_Fatal1ty Pregled postova
A da izbace i powerassisted kočnice, kacige i sve ostalo šta napredak donosi
I sad nemaju TC/ABS/ESP da im pomaže tako da je ok, samo sad je i grip dosta veći pa nema toliko plesanja i igranja, turbo rupu možeš zaboravit (onu od prije). I da ako je gas ~80% virmena aktivan, znači i turbo je a to je jako jako velik pritisak na turbinu, zato ćemo teško vidit 1000 konja.
Staro 22.06.2013., 11:20   #369
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,463
Da se omoguci vise testiranja itekako bi oni napravili jace/vise/bolje...
sto se tice TC-a, nesto se RedBull spominje :P
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 22.06.2013., 11:29   #370
draksa
Postovi: 333
Malo je glupo da su ukinuli razvoj motora. Recimo sljedece godine Mercedes napravi najbolji motor i sta onda, njihovi bolidi ce pobjedjivati sljedecih 5 godina dok ne uvedu novi motor. Sad su svi motori navodno podjednaki, ali ko zna sta ce bit.
Sve se zeli smanjiti potrosnja timova. Pa ako se nema novaca onda se ne ulazi u F1, ko npr HRT oni su zavrsili nakon 2-3 godine u debelom minusu ,bez boda i 4 sec iza svih u svakim kvalama.
draksa je offline   Reply With Quote
Staro 22.06.2013., 11:44   #371
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor Renesis Pregled postova
A e, navodno da imaju nekakav sustav koji napravi ono šta TC radi, oduzme snagu i sl kad dođe do gubitka gripa... Uglavnom neka kemija ili Mark ima ludu nogu na gasu
Zanimljiva rasprava... http://jalopnik.com/has-red-bull-fig...-con-514107361
Autor draksa Pregled postova
Ma meni je konkretno glupo šta se igraju zelenaša i pizdarija s svim tim ograničenjima, užasno mi je retardirano fixno gorivo, a o jednakosti manje više sada se više odnosi ko će napravit bolje "nelegalno" krilce i skinit pola sekunde...
Staro 22.06.2013., 11:49   #372
Postovi: 8,216
Možda imaju vode u gorivu pa im motor trokira dok starta
Staro 22.06.2013., 11:58   #373
Baja 001
Baja 001's Avatar
Postovi: 7,504
Ili svićice zajebaju, ili ruzina u rezervaru
A možda su i bumpovi, ali dobri su bili pa ljudi imaju uvik neke premisli...
Staro 25.06.2013., 10:24   #374
Postovi: 8,216
Zanimljiva usporedba
Staro 25.06.2013., 10:49   #375
Toorop
Mother Russia
Toorop's Avatar
Datum registracije: Mar 2013
Postovi: 326
Kako predobro!
Toorop je offline   Reply With Quote
Staro 26.06.2013., 17:15   #376
Boky Bestbuy
Boky Bestbuy's Avatar
Datum registracije: Jul 2010
Postovi: 36
Nemaju powerassisted kocnice, niti su ikad imali ... na kocenju, pedalu kocnice pritiscu tezinom vecom od 150 kg
Boky Bestbuy je offline   Reply With Quote
Staro 26.06.2013., 20:44   #377
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor Boky Bestbuy Pregled postova
Zanimljivo uvik san mislio da imaju. fala na infu
Lewis Hamilton has all this talent but it's been squandered and lost, says Damon Hill
Staro 27.06.2013., 11:22   #378
Speedbreaker
Postovi: 545
Webber najavio odlazak iz F1
Sad će se opet tjednima nagađat ko će u Red Bull...
Speedbreaker je offline   Reply With Quote
Staro 27.06.2013., 11:49   #379
Nacki
Faktor nesreće
Nacki's Avatar
Datum registracije: Nov 2011
Lokacija: Sesvete, Zagreb
Postovi: 219
Autor Speedbreaker Pregled postova
podrzavam Webbera - ne da mu se vise trpit sranja u RB-u
najvjerojatnije Kimi ako ne bu trazil previse $$, sumnjam da ce uzet nekog od zutokljunaca iz Toro Rossa
Proc: AMD Trinity Athlon 750K + Scythe Katana 3
Ploca: Asrock FM2A85X Extreme 4
RAM: 2*2gb DDR3 1333 Kingston
Grafa: Sapphire Radeon HD6850
Hard: 2*Hitachi 500gb (raid 0), 2*Hitachi 500gb (raid 1), WD blue 640gb
Optika: TSST DVD-RW
Napajanje: Seasonic ssr-650rm
Kućiste: Fractal Design Define R3
Monitor: 2*Samsung Sync Master 923NW
OS: Windows 7 Enterprise x64
Proc: Intel Pentium dual core e5800 + AC Freezer 7 pro rev. 2
Ploca: Asrock G31M-S
RAM: 2*2gb DDR2 Elpida
Grafa: Asus Radeon X1600pro
Hard: Hitachi 500gb
Optika: Benq DVD-RW
Napajanje: Fortron 400-60THN-P
Kućište: HP
Monitor: LG L1919S
Proc:Intel Pentium dual core e5800 + Scythe Shuriken
Grafa: Sapphire radeon HD4850 + Accelero S1 + Xilence 120mm
Hard: Hitachi 500gb
Optika: NEC DVD-RW + LG DVD-ROM
Napajanje: Fortron 350PNF
Kućište: Fujitsu siemens
Monitor: Samsung SyncMaster 740N
Proc: Intel Pentium 4 640 + Zerotherm
Ploca: Epox 5EGMI
RAM: 2*1gb DDR Kingmax
Grafa: Club 3D Radeon X550
Hard: Maxtor 160gb, Maxtor 80gb
Optika: LG DVD-RW
Napajanje: Seasonic ss-250sfd
Monitor: HP 1740
OS: Windows XP pro, SP3
Toshiba Satellite L300-21W
Proc: Intel Pentium dual core T3400
RAM: 2*2gb DDR2 Samsung
Grafa: Integrated Intel GMA4500M
Hard: WD blue 320gb
Optika: TSST DVD-RW
Ekran: 15.4''
Toshiba Satellice U840-10Q
Proc: Intel Core i5 3317U
RAM: 2*2gb DDR3 Samsung
Grafa: Intel HD4000
Grafa: AMD Radeon HD7550M
Hard: Hitachi 500gb
SSD: San disk 32gb
Ekran: 14''
Nacki je offline   Reply With Quote
Staro 27.06.2013., 11:57   #380
Postovi: 8,216
Zašto ne, pa to im i paše. A vidjelo se već u par slučajeva da i prosječan vozač s boljim bolidom od ostalih može biti u vrhu, odnosno osigurat konstruktorski naslov uz jednog top vozača.
Pogotovo jer će kimija morat dobrano podmazat da pristane na sve restrikcije koje nameće red bull za svoje vozače.
Staro 27.06.2013., 11:59   #381
draksa
Postovi: 333
Kimi ne voli marketing, novinare i ta sranja
Red Bullu je to glavno, da se promovira
Staro 27.06.2013., 12:21   #382
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,101
Sumnjam da je Kimi toliko glup da pristane biti 2. vozač u Red Bullu. Vidio je i sam što su radili Webberu...
Bottas bi bio idealan za to
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 27.06.2013., 12:31   #383
Momir
Momir's Avatar
Postovi: 1,011
Kimija u meklaren, gumbica u mirovinu
Momir je offline   Reply With Quote
Staro 27.06.2013., 13:06   #384
Toorop
Mother Russia
Toorop's Avatar
Postovi: 326
Nemoj kimija u meklaren, kad se sjetim njega prije jadnog u meklarenu, kad mu je pred ciljem stao auto kimi samo može nazad u ferari :3 sa alonsom
Staro 28.06.2013., 19:15   #385
kian
kian's Avatar
Datum registracije: Oct 2001
Lokacija: Velika Gorica
Postovi: 600
Staro 29.06.2013., 12:55   #386
dean225
DD9512
dean225's Avatar
Postovi: 1,869
Gdje se može pogledati Q danas na netu?
dean225 je offline   Reply With Quote
Staro 29.06.2013., 13:08   #387
draksa
Postovi: 333
Evo linkovi za stream
SKY , BBC
Na BBC u je tenis trenutno, al mislim da bi trebalo promjenit kad pocne
Na skyu ima emisija prije kvala
Staro 29.06.2013., 14:24   #388
poweeer
poweeer's Avatar
Lokacija: Otok
Postovi: 182
Ja gledam na 405 preko maxtva, nekako mi je zvuk neispravan, pretiho je.
poweeer je offline   Reply With Quote
Staro 29.06.2013., 14:46   #389
Toorop
Mother Russia
Toorop's Avatar
Postovi: 326
Ja gledam na 12 (SPTV), da, nekako je čudno, slika je isto sjebana.. Ali kako napet Q2, srce me skoro strefilo kad je raikonen završio na 10. mjestu
Staro 29.06.2013., 19:00   #390
begi
begi's Avatar
Lokacija: Usa
Postovi: 628
Evo neka moja razmišljanja nakon današnjih kvalifikacija. Prije 3-4 utrke kad su Fetel i Alonso bili blizu u bodovima, na f1 forumu hr bila anketa da li će Alonso prestići malog (Fetl), u narednoj utrci sa bodovima. 70% se izjasnilo da hoće. Zaključio sam da ljudi ili ne poznaju f1, ili ne vole Fetla, i bio sam u pravu. Sad je situacija takva da Ferari trenutno ne može pratiti 2-3 ekipe. Ako uzmemo da je naredna utrka odmah za 7 dana, razmak prvo i drgo plasiranog bi se mogao povećati, ako se ne dogodi neka drastična promjena-događaj. Znači Fetel bi do kraja mogao voziti kao da ima na utrci 20s prednosti pred drgoplasiranim, a ostalo je 5 krugova do kraja utrke. Alonso počeo plakati (ovaj pojam uveo forumaš Brko), kriv Ferari (loš razvoj bolida) i Pireli (radi gume za RB i Merc.). Šta mislite, jesam li u pravu?
