Staro 10.06.2013., 23:22   #781
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Da se nadovežem na Low power ljetni mod rada
S obzirom na sve te nebrojene opcije po ploči ... bilo bi šteta ne iskoristiti ih.
Popis (nekome se dalo prepisati ih )
Extreme Tweaker menu:
Ai Overclock tuner: Manual
CPU Level up: Disabled (default)
Bclk freq: 100 (default stock speed)
CPU Strap: 100 (default stock speed)
ClockGen full reset: Enabled (default)
Turbo ratio: By all cores
By all cores (can adjust in OS): 44
CPU Clock gen filter: Enabled (default)
Memory freq: DDR3-1600
Extreme tweaking: Enabled (default)
EPU power saving mode: Disabled (default)
Extreme 0V: Disabled (default)
Bclk skew: Auto
CPU Vcore V: Offset mode
Offset mode sign: +
CPU Vcore offset V: 0.005 (minimum)
VTT CPU V: 1.15
2nd VTTCPU V: Auto (1.10387)
CPU VCCSA manual V: 1.15
DRAM V (chA, chB): 1.64
DRAM V (chC, chD): 1.67
CPU PLL V: Auto (1.8)
PCH 1.1v: Auto (1.1)
VTTDR voltage (chA, chB): Auto
VTTDR voltage (chC, chD): Auto
CPU spread spectrum: Auto
PCIe spread sprectrum: Auto
(xxxx Tweaker's paradise settings all default)
DRAM timing control submenu:
"Load tight PSC profile" settings adjusted by UEFI; the second number (in parenthesis) was the value previously set by "auto" when I set the other latencies manually, FYI for comparison:
CAS: 7 (7)
RAS to CAS Delay: 11 (8)
RAS Pre time: 7 (7)
RAS ACT time: 24 (24)
DRAM command mode: 1 (1)
Latency boundry: default NEARER
RAS to RAS delay: 4 (5)
Ref cycle time: 96 (128)
WRITE recovery time: 9 (12)
READ to Pre time: 4 (5)
FOUR ACT WIN time: 24 (24)
WRITE to READ Delay: 4 (6)
Write latency: 8 (8)
tRRDR: 0 (0)
tRRDD: 0 (2)
tWWDR: 0 (3)
tWWDD: 0 (3)
tRWDR: 8 (3)
tRWDD: 3 (3)
tWRDR: 1 (1)
tWRDD: 1 (1)
tRWSR: 8 (3)
tCCD: 0 (0)
The rest were set at "auto" except:
CLK period: 3
Digi+ power control submenu:
CPU load-line calibration: Medium
CPU current capability: 120%
CPU voltage freq: Auto
VRM over temperature protection: Auto
CPU power duty control: T.Probe
Vcore MOS volt. control: 7V
CPU power phase control: Optimized
CPU spread spectrum: Disabled
CPU Vcore boot up Voltage: Auto
VCCSA load-line calibration: Regular
VCCSA current capability: 120%
VCCSA fixed freq: 300 (default)
CPU VCCSA boot up voltage: Auto
CPU VTT switching freq: Auto
CPU VTT over-current protection: Auto
DRAM-AB current capability: 120%
DRAM-AB voltage frequency: Auto
DRAM-AB power phase control: Optimized
DRAM-CD current capability: 120%
DRAM-CD voltage frequency: Auto
DRAM-CD power phase control: Optimized
PCH 1.1V switching freq: Auto
CPU Performance settings submenu:
CPU ratio: Auto
Enhanced Intel Speedstep tech: Enabled
Turbo mode: Enabled
Turbo mode parameters submenu; Power limit control: Auto
Advanced menu.
CPU configuration submenu:
Intel Adaptive thermal monitor: Disabled
Hyper-threading: Disabled
Active processor cores: All
Limit CPUID maximum: Disabled (default)
Execute disable bit: Enabled (default)
Hardware prefetcher: Enabled (default)
Adjacent cache line prefetch: Enabled (default)
Intel Virtualization tech: Enabled (default)
CPU power management submenu:
CPU ratio: Auto
Enhanced Intel Speedstep tech: Enabled (default)
Turbo mode: Enabled
CPU C1E: Enabled
CPU C3 report: Enabled
CPU C6 report: Enabled
CPU C7 report: Enabled
System agent configuration submenu (PCIe config):
All 3 PCIe speeds set set to "GEN3". (default)
PCH configuration submenu:
High precision timer: Enabled (default)
SATA configuration submenu:
SATA mode: AHCI
S.M.A.R.T. status check: Enabled (default)
Hot plugs: All disabled except SATA3G_3 (front panel eSATA)
USB configuration submenu:
Legacy USB support: Enabled (default)
Legacy USB3.0 support: Enabled (default)
ECHI hand-off: disabled (default)
Mass storage devices all "auto."
Onboard devices configuration submenu:
Azalia HD audio: Disabled
Bluetooth controller: Enabled
Intel LAN controller: Enabled (default)
Intel LAN PXE OPROM: Disabled (default)
Asmedia USB3.0 controller: Enabled (default)
Asmedia USB3.0 battery charging support: Disabled (default)
ASM1061 storage controller: Disabled
APM submenu:
Restore AC power loss: Power off (default)
Power on by PS/2 kybd: Disabled (default)
Power on by PS/2 mouse: Disabled (default)
Power on by PCIe: Disabled (default)
Power on by RTC: Disabled (default)
ErP ready: Disabled (default)
Monitor menu:
Fan speed control submenu:
CPU Q-fan control: Enabled (default)
CPU fan speed low limit: 600RPM (default)
CPU fan profile: Manual
CPU upper temperature: 55
CPU fan max. duty cycle(%): 100
CPU lower temperature: 40
CPU fan min. duty cycle(%): 60
Chassis Q-fan control: Enabled (default)
Chassis fan speed low limit: 600RPM (default)
Chassis fan profile: Manual
Chassis upper temperature: 55
Chassis fan max. duty cycle(%): 100
Chassis lower temperature: 40 (non-adjustable)
Chassis fan min. duty cycle(%): 60 (minimum)
PCH fan control: Profile mode
PCH fan profile: Optional
OPT fan 1 control: Disabled (default)
OPT fan 2 control: Disabled (default)
OPT fan 3 control: Disabled (default)
Boot menu:
Bootup numlock state: On (default)
Full screen logo: Enabled (default)
Wait for 'F1' if error: Enabled (default)
Option ROM messages: Force BIOS (default)
Setup mode: Advanced mode
Definitivno polako dolazi vrijeme za snižavanje voltaže, jer odsad pa do zime temperature mogu samo ići gore.
Primjerice evo postavki na kojima radi malac posljednjih mjesec dana (evridej usage, Idle/Prime95 load):
SpeedStep: ON, Offset: -0.05V, Heating: OFF
Po zimi dobro dođe grijanje, ali po ovakvom toplijem vremenu zaista treba obuzdati zagrijavanje prostorije. Kroz duži period klima jednostavno ne dolazi u obzir :/
Potrošnja u loadu je naspram bench postavki pala za više od 50%, što je poprilična količina fata za 24/7 rad.
Zaista je šteta ne iskoristiti sve te tehnologije koje vam matične pružaju. Pogotovo nove ploče, koje imaju i dodatni Adaptive voltage mode (dizanje voltaže samo pri aktivnosti Turbo multija).
The Secret ...
Zadnje izmijenjeno od: dh41400. 10.06.2013. u 23:29.
Staro 11.06.2013., 18:16   #782
drz_nedaj
Axl Rose
drz_nedaj's Avatar
Postovi: 395
http://imageshack.us/photo/my-images...uredadada.jpg/
4.4ghz na -0.20 offsetu, nakon 8 sati prime95 na small FFT.. da idem jos dolje?
ne kuzim samo kaku voltažu mjeri taj core temp? :S
Zadnje izmijenjeno od: drz_nedaj. 11.06.2013. u 18:38.
drz_nedaj je offline   Reply With Quote
Staro 11.06.2013., 21:27   #783
xtreme96
OC addict
xtreme96's Avatar
Datum registracije: Apr 2009
Lokacija: Gothenburg, Sweden
Postovi: 1,001
Ma najbolje gledaj voltazu u CPU-Z programu ili u softveru koji dodje s plocom, nemoj se opterecivati naponom koji CoreTemp prikazuje.
Probavaj sve manji i manji offset dok ne dodjes do rusenja, a onda vrati stepenicu gore i vozi misko
Neki bi rekli da mora proci xyz sati torture, ja nebi.....ako je prosao 8h prime-a onda sada odigraj najzahtjevniju igricu koju igras (npr. BF3 dosta gazi proc) nekoliko sati i ako se ne srusi onda je stabilan
Ja bi ti preporucio da ga ostavis sada na 4.4ghz i 1.27v (ako se slucajno srusi povecaj na 1.28v i mora raditi)....preporucam da ostavis na 4.4ghz zato sto su ti sada temperature malo ispod 70c, a dolazi ljeto i vrucine i temperature ce ti narasti...i mislim da kad bi ga ostavio na 4.4ghz kako je sada, na ljeto bi imao temp ispod 80c i na to pazi...80c je gornja granica
imas jos malo prostora za OC sto se tice temperature ali bi ga ja ostavio ovako zato sto ce biti uskoro vrucine....a isao bi na 4.5-4.6ghz ako ne trazi puno vise napona
Pošten trgovac: 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15...
- prije mi je bio nick "xTreme Gamer" (profil je isti ali sam promjenio nick)
Zadnje izmijenjeno od: xtreme96. 11.06.2013. u 21:39.
xtreme96 je offline   Reply With Quote
Staro 11.06.2013., 22:44   #784
drz_nedaj
Axl Rose
drz_nedaj's Avatar
Postovi: 395
ma ne opterecujem se, koristim jos CPU-Z, HW monitor, aidu itd.. na svim njima je ista voltaza.. jel mi mos objasnit nesto samo, recimo sad mi je voltaza 1.3 ja mislim sa offsetom -0.10, kak ja mogu znat za koliko ce mi taj offset spustit voltazu? naprimjer ako ga spustim na -0.20, za koliko ce on spustit voltazu? za 0.02 ili? znaci na -0.20 ce mi voltaza bit 1.28? ili to ima neka drugacija racunica.. vratit cu ja njega na stock sam kad se malo naucim OC-at.. i jel postoji neki program s kojim mogu preko windowsa mjenjat recimo one OC profile sto mogu napravit u Biosu? recimo, sad igram neku zahtjevnu igru i ocu ga stavit na 4.4, uđem sammo u taj program i prebacim ili kada samo surfam, skidam torrente, da mi vrati na stock?
Zadnje izmijenjeno od: drz_nedaj. 12.06.2013. u 02:04.
Staro 11.06.2013., 23:17   #785
xtreme96
OC addict
xtreme96's Avatar
Postovi: 1,001
Nema potrebe za vracanjem na stock dok surfas i slicno. Postoji Speedstep tehnologija koja sama mjenja clock ovisno o opterecenju. Prema tome, dok ti surfas on ce sam spustiti clock na npr. 1.6ghz, a kad pokrenes nesto zahtjevno dignut ce ga na 4.4 ili na koliko vec ga podesis. Dakle, nemoj iskljuciti one power saving opcije,EIST, C1E, Speedstep i kako se vec zovu te pizdarije sto smanjuju clock
Offset ti i u idle-u i u load-u poveca napon procesora za onoliko koliko podesis.
isprobaj sam offset pa ces skuzit...povecaj za jednu stepenicu ili smanji, pogledaj cpu-z pa ce ti biti jasno
Staro 11.06.2013., 23:25   #786
drz_nedaj
Axl Rose
drz_nedaj's Avatar
Postovi: 395
a ne znam kake su posljedice za proc OC-anje, kazu da mu skracuje vijek trajanja, ne znam koliko je to konkretno pa zato mozda ili ne? xD
stavio sam offset na -0.50 i nije booto, digo na -45.0, digo windows i nakon par minuda pljas, sad mi na -0.40 radi vec jendo 20 minuta prime, temp max 66-67, 1.25 V, pa cmeo vidit dokle ce xD
idem ja poslikat bios pa stavit tu u post pa pogledaj jel to sve valja.. fala jos jednom na odgovorima
EDIT: Slike BIOS-a:
Jel valja??
Staro 11.06.2013., 23:49   #787
xtreme96
OC addict
xtreme96's Avatar
Postovi: 1,001
Nece ti se degradirati proc od takvog overclocka poput tvog nemas brige
to se moze dogoditi u ekstremnim slucajevima gdje se proc drzi na max stabilnom clocku 24/7 i sa visokim naponom, mozda cak ni tada.....znam tipa koji 2500k vozi vec godinu dvije na 4.8 sa skoro 1.4v i nista mu nije bilo
EDIT:
Valja
Kazem ti, stavi ga na 4.4Ghz, nadji najmanji offset s kojim radi, kazes da sada radi sa 1.25v naponom...testiraj sad s tim naponom....idi odigrat (u komadu) par sati neke zahtjevne igre koja cucla puno proc i ako se ne srusi onda eto cisto radi sigurnosti odvrti prime ili (meni jos draze) occt....
p.s. dobronamjeran savjet: nemoj quote-ati post koji je odmah iznad, preglednije ce biti
Zadnje izmijenjeno od: xtreme96. 12.06.2013. u 06:32.
Staro 12.06.2013., 02:08   #788
drz_nedaj
Axl Rose
drz_nedaj's Avatar
Postovi: 395
eo i to rijeseno (quotanje).. ipak nista od -0.40, izdrzalo 20 minuta primea, al nakon pol sata LoL-a mi zastekalo sve, nije blue screen neg mi jednostavno stalo sve xD ne kuzim kako
sad je na -0.35, koliko dugo vrtis occt?
Staro 12.06.2013., 06:30   #789
xtreme96
OC addict
xtreme96's Avatar
Postovi: 1,001
Ja kad clockam pustim OCCT da odradi jedno 6h i jos odigram par sati neke zahtjevne igrice.
Ne testiram vise jer mi ne treba vise....ne renderiram pa da mi treba "rock solid stable"...
Daj mi reci kolika ti je sobna temperatura dok to testiras? da vidim koliko je efikasan taj 612S
Staro 12.06.2013., 09:15   #790
Autor xtreme96 Pregled postova
Meni su igre benčmark. Ako ga ne sruše Metro i Stalker igre, za mene je stabilan
Staro 12.06.2013., 11:53   #791
drz_nedaj
Axl Rose
drz_nedaj's Avatar
Postovi: 395
od tih porgrama za testiranje stabilnosti imam intel burn test, occt, prime 95.. sada sam recimo stavio IBT na maximum i upalio ga i izbaico mi je gresku nakon 10 minuta, to znaci da nije prosao, tj. da nije stabilan? nije bilo nikakog blue screena il tak nesto nego mi nije proso test..
a iskreno ne znam kolka je tem u sobi, morat cu i to jednom provjerit..
Staro 12.06.2013., 13:30   #792
xtreme96
OC addict
xtreme96's Avatar
Postovi: 1,001
@ Drug Brko
Same here!
rijetko kada testiram sa nekim programom....bitno mi je da se ne rusi u igrama....ali ako clockam neku konfu koja mora radit 100% stabilno onda pustim dugo occt ili ibt i jos malo igrica
@drz nedaj
Ma daj jednostavno se nemoj patit....sa 1.26v ti je radio na 4.4ghz, sa 1.25 se srusio....stavi offset tako da bude 1.27v u loadu i nece se rusit i mirna Bosna
Temperature su ti ok, ispod 70c...odlicno...preko ljeta ako ostavis iste postavke biti ce ispod 80c i to je sve sto te zanima
Staro 12.06.2013., 13:38   #793
syss
syss's Avatar
Postovi: 10,805
evo umene statusa... fino je to sve skupa sjelo.
Staro 12.06.2013., 13:42   #794
Postovi: 8,215
Jel ti ovo krivo pokazuje il stvarno imaš vent na 4.4K
Staro 12.06.2013., 13:43   #795
syss
syss's Avatar
Postovi: 10,805
dobro pokazuje... to je h60 pumpa na nereguliranom izlazu iliti na stalnih 12v.
Staro 12.06.2013., 14:00   #796
Postovi: 8,215
Aha, potpuno sam zaboravio na te poluproizvode
Staro 12.06.2013., 14:02   #797
syss
syss's Avatar
Postovi: 10,805
pusti, vidi malog kako hladi, a vent mu se nije ni raspuhao
ti si u tome koliko znam... jel zamjenom stock cors 120mm venta se može dobiti nekaj revolucionarno?
mislim testirao sam ovaj vent na 1000 i 2000rpm i ono razlike u temp na cpu su presmiješno male, tipa 3c ili tako nešto, buka je naravno neopisiva.
Staro 12.06.2013., 14:31   #798
MAGARAC
MAGARAC's Avatar
Postovi: 5,989
http://www.pohrani.com/?2U/oI/UEGo0u...picture027.jpg
Prevelka mi je to razlika, bez obzira na memoriju, isto dela na 4.7. Zvrti to jos koji put..
MAGARAC je online   Reply With Quote
Staro 12.06.2013., 14:31   #799
Postovi: 8,215
Ok su temperature, odnosno napon je mali pa nije problem. Ja svom 2500K moram krkanski stavit napona za taj takt.
Za vent, pa nebudeš dobio ništa specijalno. Jer jednostavno nema tog venta koji će gurat veliku količinu zraka kroz saće a da se malo vrti i/ili da bude tih. Probavao sam i push/pull i na kraju ostavio jer sam uspio da s dva venta na manje okretaja imam temperature kao s jedim na više. S tim da je ovo manje tipa 2x850 umjesto jednog na 1400.
Najviše sam dobio kad sam okrenuo vent i stavio da mi vuče svježi zrak izvana u kućište, s tim da i to treba uzet s rezervom jer se radilo o A05N koje nije baš provjetreno i sam zrak unutar kućišta je bio povišene temperature uvijek i to nebi imalo izražaja toliko u nekom provjetrenijem i većem kućištu.
Iako, nije to dugo trajalo kod mene jer me pumpa ubijala(bar na mome H50), nisam ja navikao na to.
Staro 12.06.2013., 14:36   #800
syss
syss's Avatar
Postovi: 10,805
hebiga eto tako ivy hendla prime... nemam tu šta ja sada fantazirati.
edit: onda smo i to riješili
meni je od prvog dana podešeno da vent iz vana puše u kejs, isto kao front 200mm, a top 200mm baca sve to skupa gore i to se jebeno osjeti kada se komp ugrije + keeps dust off.
Staro 12.06.2013., 14:37   #801
MAGARAC
MAGARAC's Avatar
Postovi: 5,989
Ne znam bum probal kasnije sa 1600. Je za ocekivat da bu brzi ali ne bas tolko.
Staro 12.06.2013., 14:41   #802
syss
syss's Avatar
Postovi: 10,805
daj okači ivy na ovom testu - kljik
to ti je cpu queen aida64, zanemari zaokruženo.
Staro 12.06.2013., 14:52   #803
MAGARAC
MAGARAC's Avatar
Postovi: 5,989
Svakak on meni to vrti, jednom 12x sekundi, drigi put 14x sekundi. Tak da to nije mjerodavno.
Staro 12.06.2013., 14:53   #804
syss
syss's Avatar
Postovi: 10,805
pa dobro imaš aidu, ne? daj baš da vidim kolike su razlike u nekim sintetskim benčevima...
Staro 12.06.2013., 14:56   #805
MAGARAC
MAGARAC's Avatar
Postovi: 5,989
Ma govorim za wprime.
Nema razlike u tome.
Zadnje izmijenjeno od: MAGARAC. 12.06.2013. u 15:06.
Staro 12.06.2013., 15:01   #806
syss
syss's Avatar
Postovi: 10,805
velim ti u aidi64 prvi cpu test... cpu queen.
Staro 12.06.2013., 15:13   #807
MAGARAC
MAGARAC's Avatar
Postovi: 5,989
Kaj jos oces?
Staro 12.06.2013., 15:15   #808
syss
syss's Avatar
Postovi: 10,805
ma to je to... oke ovo nije sada neki referentni test, ali oke je za vidjeti okvirno performanse vs. temp na istom taktu.
Staro 12.06.2013., 19:53   #809
E-mil
Oppa Gangbang Style
E-mil's Avatar
Postovi: 1,763
evo ti syssATI moderatoru za usporedbu
E-mil je offline   Reply With Quote
Staro 13.06.2013., 00:14   #810
drz_nedaj
Axl Rose
drz_nedaj's Avatar
Postovi: 395
hahah legendarno.. odvrti mi proc 13 i po sati prajma i onda nakon toga pokrenem hebeni Lol i pojavi mi se blue screen.. -.-
