Staro 31.05.2013., 18:41   #2911
Dottore
Dottore's Avatar
Postovi: 7,616
Štedim pare za ISU-100 ili ISU-125. Trenutno imam 750.000
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 31.05.2013., 18:54   #2912
JozicA
Vozi Miškoooo!!!
JozicA's Avatar
Lokacija: Svuda okolo / EU
Postovi: 1,404
Upalim KV-1, par partija izgubimo u roku odmah, za nevjerovati, i ova krenila, nasih 8 mrtvo 15 neprijatelja , svi zivi nakon par minuta, na kraju pobjedimo, iako 8 nasih tenkova nikakvu stetu nikome nanjeli nisu, WoT, nekad ga volimo, nekad bas i ne.
LINK
JozicA je offline   Reply With Quote
Staro 31.05.2013., 19:37   #2913
Dottore
Dottore's Avatar
Postovi: 7,616
Opa, 10 kill rijetko vidim Često do 8 killova. Moj prosjek 2-3 killa za T-46. Jedino max Leichttraktor 5 killova.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 01.06.2013., 10:31   #2914
Amdejac
Amdejac's Avatar
Datum registracije: Jun 2003
Lokacija: Kuća
Postovi: 5,398
Pohrani.com
4200 domagea, 7/7, svaki hitac 600 štete.
Asus N750JK (Upgrade)
MBO: Asus N750JK
RAM: 2x8 Gb PC3-12800 DDR3
PSU: Asus Li-ion 69486 mWh
OS: Windows 8.1
Monitor: 17,3 LCD (FHD)
Net: Intel AX210 NGW
Net: TP-Link Archer TX55E
PSU: Xilence, Bronze 550W
Monitor: Samsung
VGA: ATI RX570, 4 Gb
HDD: NVMe 1 Tb, Patriot
PSU: Inter-Tech SP750
Monitor: Samsung
Amdejac je online   Reply With Quote
Staro 01.06.2013., 16:00   #2915
VulcanRaven
VulcanRaven's Avatar
Lokacija: Rijeka-Belveder
Postovi: 741
Slusajte ovo:
Ja i kolega GizCRo iz CTN-a igramo x tier-ove,u protivnickom timu igraju 2 unicuma,ljubicasta igraca,kada smo ih razlupali i kad su ostala samo 2 igraca u tom timu,jedan od prezivjelih unicuma je izveo nesto novo.
Imamo replay i SS nakon borbe: tip je igrao sa T110E5 i imao je 1850hp i kada smo mu ja i Giz prilazili da ga dovrsimo napravio je "SELFDESTRUCT"!!!!!
Znaci tip je sam sebe raznio nekako s nekim hackom,da mu j..... sve. Smrad
VulcanRaven je offline   Reply With Quote
Staro 01.06.2013., 16:09   #2916
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,343
Daj video baci.
žmnpp
Staro 01.06.2013., 16:13   #2917
MeanBoss
|CTS|MeanBoss|
MeanBoss's Avatar
Lokacija: Sinj
Postovi: 1,005
da vas pitam...s kv1...da idem na kv1-s,t-150 ili kv2...nekako bi najradje na kv1s,ali mi ni t150 ne izgleda los?
Staro 01.06.2013., 17:05   #2918
gsxr750k9
Datum registracije: Apr 2011
Lokacija: Agram
Postovi: 603
Autor VulcanRaven Pregled postova
daj replay.
http://forum.worldoftanks.com/index....-wot-mod-site/
haha show
gsxr750k9 je offline   Reply With Quote
Staro 01.06.2013., 17:35   #2919
windfucker
Ma svaki self destruct tipa utapanja, HE u zid do sebe, bacanje sa litice...trebalo bi drakonski kazniti, -100k silvera pa se ti utapaj , frajeru...
Staro 01.06.2013., 17:43   #2920
gsxr750k9
Lokacija: Agram
Postovi: 603
ovo je self destruct MOD!
Staro 01.06.2013., 18:52   #2921
m4dm4n
Does youer dewg byte?
m4dm4n's Avatar
Postovi: 1,936
Na KV2 jedino ak misliš derpat, ili ići na S-51 arty. Nakon T150 dolaze spori i dobro oklopljeni tenkovi. KV1S je uvod u heavy medium tank liniju. Osobno sam odabrao ovo zadnje, makar me sad i T150 grebe.
Staro 01.06.2013., 19:11   #2922
migmo
trainspotter
migmo's Avatar
Datum registracije: Apr 2009
Postovi: 58
KV1S je opasan tenk kada ima sve module sa 122mm topom i 100% posadom. Taj tenk dere sve živo. Nije bezveze jedan od najpopularnijih tenkova u igri. KV2 je blesavo zabavan kada ima 152mm haubicu sa HE granatama i 100% posadom. Spor jeste, ali tier osmice, devetke pa i desetke dobivaju po glavi od tog topa. Tier sedam i svi tierovi ispod bivaju desetkovani kada budu pogođeni. Oba tenka zabavna. T-150 je dobro oklopljen ali nema baš pre impresivan top (107mm) i vrlo je spor, Ukratko nije niti blizu po zabavi kao što su KV2 i KV1S.
migmo je offline   Reply With Quote
Staro 01.06.2013., 19:46   #2923
VulcanRaven
Postovi: 741
evo replay cu sada postati:
dajte mi par minuta da ga nadem:
http://speedy.sh/djMe4/20130531-0912...ille.wotreplay
Code:
http://speedy.sh/djMe4/20130531-0912-usa-T110E4-07-lakeville.wotreplay
Ne mogu ucitati wotreplay pa evo ovako,pa recite sto mislite
ako se pitate zasto pred kraj nisam odmah krenuo na njega,kolega me zamolio na ts-u da pricekam da napuni da krenemo skupa
ocekujem komentare na E5:::: ahahah
Zadnje izmijenjeno od: VulcanRaven. 01.06.2013. u 20:04.
Staro 01.06.2013., 19:47   #2924
MeanBoss
|CTS|MeanBoss|
MeanBoss's Avatar
Lokacija: Sinj
Postovi: 1,005
nista...udaram na kv1s! nekako imam vec osjecaj da ce mi odgovarat..malo je i brzi od kv1 ako se ne varam! a za derpanje,tu idem sa Su100 daje do ISU-a..tako da ipak bude malo raznoliko!
Staro 01.06.2013., 20:10   #2925
Dottore
Dottore's Avatar
Postovi: 7,616
@Vulcan
Ima i takvih koju brzo odustaju.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 01.06.2013., 20:16   #2926
tpm4
tpm4's Avatar
Postovi: 326
Slusajte ovo:
ESC i izades u garazu.
Tako sam ja prije par dana izasa zbog cw-a, i pisalo mi je da sam ja unistio tenk.
Mislim da bi moglo bit to, provjeri
tpm4 je offline   Reply With Quote
Staro 01.06.2013., 20:59   #2927
VulcanRaven
Postovi: 741
Pa jeb. im pas m.... , prije ti je tenk ostao tamo i izrokaju te ko majmuna i to je to, ovo je cisti debilizam,kukavicluk i idiotarija a majmune u wg-u bi trebalo napucat u zubalo...
pa gdje je tu logika jbt da tako nesto sloze i dozvole?
Staro 01.06.2013., 21:40   #2928
JozicA
Vozi Miškoooo!!!
JozicA's Avatar
Postovi: 1,404
Code:
pa kako je uspio 85% dmg da se ubije ? ja jesam jednom s arty kad sam zaglavio nizbrdo, pa sam opalio i ubio se, ali ovo jos nisam vidio, a sto se tice tvoje igre s Tier X tenkom, ajd kad ja odigram s tier 5 tenkom njubasto, ali ti s tier X tako
i sam evo odigrao 2 partije veceras za x2, dosta za danas, jednu s kv-1 a jedna s su-85, konto sam da smo izgubili, svi na jednu stranu, ali cudan razvoj dogadjaja bio, zali boze gold municije i kredita, ali pomaze, ponekad , bitna je pobjeda, a opet pola tima nikog nepogodi u obje, ali win je win
Staro 01.06.2013., 21:51   #2929
VulcanRaven
Postovi: 741
hahaha,zelis me poduciti malo? daj koji savjet,mislim ono kad vec uzimas drugi acc radi eff,daj konkretne savjete u danoj situaciji.
s obzirom da sam slusao naredbe kolege preko ts-a jer je takav dogovor,sto ne vidis,nemas mi sto reci
bez ljutnje
Zadnje izmijenjeno od: VulcanRaven. 01.06.2013. u 22:01.
Staro 01.06.2013., 22:30   #2930
Amdejac
Amdejac's Avatar
Lokacija: Kuća
Postovi: 5,398
Meni ide pa stane, ali sve u svemu OK je.
http://www.wotlabs.net/eu/player/amdejac
MBO: Asus N750JK
OS: Windows 8.1
Monitor: Samsung
Monitor: Samsung
Staro 01.06.2013., 22:41   #2931
gsxr750k9
Lokacija: Agram
Postovi: 603
Staro 01.06.2013., 22:51   #2932
Amdejac
Amdejac's Avatar
Lokacija: Kuća
Postovi: 5,398
Ovo me previše ne zamara jer u zadnje vrijeme igram samo sa Ferdom i ISU-152 i skupljam za jači TD, a tko mi dođe na nišan naj.strada.
MBO: Asus N750JK
OS: Windows 8.1
Monitor: Samsung
Monitor: Samsung
Staro 02.06.2013., 00:07   #2933
VulcanRaven
Postovi: 741
Stari,ne znam kakav tip igre volis,ali ako volis mobilnost ispred "tvrdoce" ona si definitivno trebao izabrati jagpanthera2,jer je najopakiji td tier 8 s kojim sam igrao. Inace,imao sam isu-a i t28 prot-a a sa ferdijem sam igrao na frendovom ac.
Danas kada 80% ljudi puca gold,ferdijevih 200 armora ti ne zanci nista,barem sam se ja tako ravnao,a sa njegovim bratom mozes letiti po mapi kao manijak raditi sto te volja a imas isti top kao ferdi(128mm).
Btw posada mi je sa jagtigra 8.8 i dosta je dobra ali ipak nemjerljiv mi je sa ostalima,idem kao med panther2 uzbrdo ( nisam siguran za njegovu posadu kakva je)
@ gsxr - super p je smijesno slozen tenk,katastrofalan za probiti a tier 8 med,moras imat jako dobar gun da ga sjebes ili biti jako blizu... treba mu srezat te kutove iako mislim da ni to nece biti od neke koristi da ga se probije...
Staro 02.06.2013., 02:02   #2934
windfucker
Autor gsxr750k9 Pregled postova
Vidim, i nije upitno jel mod ili neki treći q, poanta je da to treba oštro sankcionirati... iako od toga nema kruha, ja takve uredno prijavim pod unfair play.
Klasa igrača uz bok čiterima, ja ne vidim razliku, sve isti smrad.
Staro 02.06.2013., 02:14   #2935
VulcanRaven
Postovi: 741
I dobio sam takav odgovor,kao postuju to sto smo prijavili ali ima ingame solucija za takve prijave, unfair play, pa sam im uzvratio porukom da ne znam niti jednog igraca koji je bio baniran sa razlogom unfair play,samo vrijedanja i slicne stvari prolaze sa chat banom....
to samounistenje me toliko nanerviralo tako da samo jos vise zelim mlatit ljubicaste igrace
Staro 02.06.2013., 05:05   #2936
Amdejac
Amdejac's Avatar
Lokacija: Kuća
Postovi: 5,398
Bez brige, imat ću i Jagpanthera2 u garaži
MBO: Asus N750JK
OS: Windows 8.1
Monitor: Samsung
Monitor: Samsung
Staro 02.06.2013., 05:40   #2937
VulcanRaven
Postovi: 741
kolega,bez zajebancije,to je nazabavniji td s kojim sam igrao,a cak nisam ima ni bia na njemu,strasan tenk,nerijetko sam s njim bio na vrhu exp-a i dmg-a na devetkama. ludilo
ferdi je smijesan prema njemu,doletis nekome iza ugla okrenes se za 30 stupnjeva u sekundi kao amx f155 opalis i pobjegnes...
mana mu je spor reverse,ide 11km/h cca ovisno o terenu i nagibu
pa otkud ti tako rano?
Staro 02.06.2013., 09:37   #2938
JozicA
Vozi Miškoooo!!!
JozicA's Avatar
Postovi: 1,404
bez ljutnje
ma neljutim se ja natebe nimalo, nego takav nacin igre mi je jako poznat, u svakoj partiji imam najmanje 5-6 koji tako igraju a nekad i desetak, ti si makar neku stetu nanio, vecina takvom igrom ceka pa onda hrabro krece u napad kad vidi da vode 10:0, u toj partiji ste imali vise srece nego pameti, kao prvo, raspolozenu arty, neprijateljska ni za k nije bila, dobru koordinaciju napada tj. vasi u gradu koji su probijali su napravili 95% posla, da ste se kojim slucajem vas dvojica u protivnickom timu nasla, poraz vam nebi ginio, bez obzira na tier X tenkove i stil igre
jednostavno previse ljudi/igraca neigra igru, nego ceka/kampa, stanu negdje, pa ako pogode nekog, super, ako ne, nema veze, ima iduca partija ce biti bolja, bolji zaklon pa ce netko i da naleti ispred topa
edit: evo jedna od maloprije, nas trojica na kraju na hetzera ostali, moja greska (ipak sam njub) prerano sam krenio, a sto reci za KV-1, ceka covjek, nepada mu na pamet napasti, onda kada je krenio dobio metak
To je vikend, od jucer 80% partija zavrsi porazom, a rekao sam vikende preskakat, nevrijedi , a evo i s IS-4 jedna za x2 odigrana, prva danas, dosta, necemo vise
Zadnje izmijenjeno od: JozicA. 02.06.2013. u 10:32.
Staro 02.06.2013., 10:31   #2939
windfucker
I dobio sam takav odgovor,kao postuju to sto smo prijavili ali ima ingame solucija, ja ja za takve prijave, unfair play, pa sam im uzvratio porukom da ne znam niti jednog igraca koji je bio baniran sa razlogom unfair play,samo vrijedanja i slicne stvari prolaze sa chat banom....
To je poluautomatizirano sr@nje od odgovora, ja sam poslao replay lika koji se u parkirao iza mene u gradu, prvi sam zauzeo poziciju za peek-a-boo, ja Lowe on T34, blokirao me, a kada je vidio da ne trzam, sprašio mi par komada u leđa... Namjerno nisam vratio, izgubili smo 14:15 da stvar bude bolja, lik me još vrijeđao... ma, milina.
Sendam replay u ticket-u i dobijem ovaj tvoj odgovor...
Imam osjećaj da je premium tu presudio. Plati i radi šta te volja.
Staro 02.06.2013., 12:43   #2940
ti.le
[CTN]Mr.Ti
ti.le's Avatar
Lokacija: Zg, Novi Zg
Postovi: 563
BTW, evo i replay od one moje runde s leopardom, poprilicno dobra random teamplay
http://wotreplays.com/site/214111#self
CPU: Ryzen 7 5700G / Noctua D15S; MBO: MSI B550 Tomahawk; RAM:Corsair Vengeance 2x16 3200MHz; GPU: XFX Merc 319 RX 6900 XT; HDD: 1. Samsung 970EVO 256 GB; 2. Crucial P2 500GB; PSU: EVGA Supernova G2 750; CASE: NZXT H440 White; MONITOR: Asus MG279Q; KEYBOARD: Roccat Vulcan 100; MOUSE: Razer ViperMini @ SteelSeries QCK mass; HEADPHONES: Kingston HyperX Cloud (I) - Superlux HD-681 EVO
ti.le je offline   Reply With Quote
